[SOLVED] [W7SP1 x64] CheckSur.log 0x80070002 - Major WU update issue after system restore.
I'll need a fresh copy of your hive.
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload toa file sharing service and just provide the link here.
Please do the following:
Export SideBySide
  5. Change the Save as type: to Registry Hive Files (*.*)
  6. Name this file SxS (with no file extension) and save it to your Desktop.
Please upload the file somewhere and provide me with a link.
Step#1 - FRST Fix
Make sure to report any errors that may come up.
The same error.
Two optional updates has popped-up, I did not upate them, I updated only major KB.:huh:
Fixlog.txt
Rezultat naprawy Farbar Recovery Scan Tool (x64) Wersja: 27-11-2017
Uruchomiony przez slawo (28-11-2017 07:23:06) Run:17
Uruchomiony z C:\Users\slawo\Desktop
Załadowane profile: slawo (Dostępne profile: slawo)
Tryb startu: Normal
fixlist - zawartość:
cmd: wmic qfe list brief /format:texttablewsys
powershell: get-hotfix
========= wmic qfe list brief /format:texttablewsys =========
Description      FixComments  HotFixID   InstallDate  InstalledBy             InstalledOn  Name  ServicePackInEffect  Status
Update                        KB2849697               taras\slawo             4/5/2017
Update                        KB2849696               taras\slawo             4/5/2017
Update                        KB2841134               taras\slawo             4/5/2017
Update                        KB2670838               taras\slawo             10/31/2015
Update                        KB2830477               taras\slawo             9/29/2017
Update                        KB2592687               taras\slawo             9/29/2017
Update                        KB971033                taras\slawo             9/29/2017
Security Update               KB2479943               taras\slawo             10/31/2017
Security Update               KB2491683               taras\slawo             9/29/2017
Update                        KB2506014               taras\slawo             9/29/2017
Security Update               KB2506212               taras\slawo             9/29/2017
Update                        KB2506928               taras\slawo             9/29/2017
Security Update               KB2509553               taras\slawo             9/29/2017
Security Update               KB2532531               taras\slawo             10/31/2017
Update                        KB2533552               ZARZÄ„DZANIE NT\SYSTEM  9/29/2017
Update                        KB2533623               taras\slawo             4/1/2017
Hotfix                        KB2534111                                       10/27/2015
Update                        KB2545698               taras\slawo             9/29/2017
Update                        KB2547666               taras\slawo             10/31/2017
Update                        KB2552343               taras\slawo             9/29/2017
Security Update               KB2560656               taras\slawo             10/31/2017
Update                        KB2563227               taras\slawo             10/31/2017
Security Update               KB2564958               taras\slawo             9/29/2017
Update                        KB2574819               taras\slawo             9/29/2017
Security Update               KB2579686               taras\slawo             9/29/2017
Security Update               KB2585542               taras\slawo             9/29/2017
Update                        KB2603229               taras\slawo             9/29/2017
Security Update               KB2604115               taras\slawo             9/29/2017
Security Update               KB2620704               taras\slawo             10/31/2017
Security Update               KB2621440               taras\slawo             9/29/2017
Security Update               KB2631813               taras\slawo             10/31/2017
Hotfix                        KB2639308               taras\slawo             4/1/2017
Update                        KB2640148               taras\slawo             10/31/2017
Security Update               KB2653956               taras\slawo             9/29/2017
Security Update               KB2654428               taras\slawo             9/29/2017
Update                        KB2660075               taras\slawo             9/29/2017
Security Update               KB2667402               taras\slawo             11/17/2017
Update                        KB2685811               taras\slawo             9/29/2017
Update                        KB2685813               taras\slawo             9/29/2017
Security Update               KB2685939               taras\slawo             9/29/2017
Security Update               KB2690533               taras\slawo             9/29/2017
Security Update               KB2698365               taras\slawo             9/29/2017
Security Update               KB2705219               taras\slawo             9/29/2017
Security Update               KB2719033               taras\slawo             9/29/2017
Update                        KB2719857               taras\slawo             9/29/2017
Update                        KB2726535               taras\slawo             9/29/2017
Security Update               KB2727528               taras\slawo
Update                        KB2729094               taras\slawo             4/1/2017
Security Update               KB2729452               taras\slawo             9/29/2017
Update                        KB2731771               taras\slawo             4/1/2017
Update                        KB2732059               taras\slawo             9/29/2017
Update                        KB2732487               taras\slawo             10/31/2017
Security Update               KB2736422               taras\slawo             9/29/2017
Security Update               KB2742599               taras\slawo             9/29/2017
Update                        KB2750841               taras\slawo             9/29/2017
Security Update               KB2758857               taras\slawo             9/29/2017
Update                        KB2761217               taras\slawo             9/29/2017
Update                        KB2763523               taras\slawo             10/31/2017
Security Update               KB2770660               taras\slawo             9/29/2017
Update                        KB2773072               taras\slawo             9/29/2017
Update                        KB2786081               taras\slawo             4/1/2017
Update                        KB2791765               taras\slawo             9/29/2017
Update                        KB2799926               taras\slawo             9/29/2017
Update                        KB2800095               taras\slawo             9/29/2017
Security Update               KB2807986               taras\slawo             9/29/2017
Update                        KB2808679               taras\slawo             9/29/2017
Security Update               KB2813347               taras\slawo             10/31/2017
Security Update               KB2813430               taras\slawo             10/31/2017
Update                        KB2834140               taras\slawo             4/1/2017
Update                        KB2835174               taras\slawo             9/29/2017
Update                        KB2836942               taras\slawo             9/29/2017
Update                        KB2836943               taras\slawo             9/29/2017
Security Update               KB2840631               taras\slawo             10/31/2017
Update                        KB2843630               taras\slawo             9/29/2017
Security Update               KB2847927               taras\slawo             9/29/2017
Update                        KB2852386               taras\slawo             11/18/2017
Update                        KB2853952               taras\slawo             9/29/2017
Update                        KB2857650               taras\slawo             9/29/2017
Security Update               KB2861698               taras\slawo             9/29/2017
Security Update               KB2862152               taras\slawo             9/29/2017
Security Update               KB2862330               taras\slawo             9/29/2017
Security Update               KB2862335               taras\slawo             9/29/2017
Security Update               KB2864202               taras\slawo             9/29/2017
Security Update               KB2868038               taras\slawo             9/29/2017
Security Update               KB2871997               taras\slawo             9/29/2017
Update                        KB2882822               taras\slawo             4/1/2017
Security Update               KB2884256               taras\slawo             9/29/2017
Update                        KB2888049               taras\slawo             4/1/2017
Update                        KB2891804               taras\slawo             9/29/2017
Security Update               KB2892074               taras\slawo             9/29/2017
Security Update               KB2893294               taras\slawo             9/29/2017
Update                        KB2893519               taras\slawo             9/29/2017
Security Update               KB2894844               taras\slawo             10/31/2017
Security Update               KB2900986               taras\slawo             9/28/2017
Update                        KB2908783               taras\slawo
Security Update               KB2911501               taras\slawo             9/29/2017
Security Update               KB2912390               taras\slawo             9/29/2017
Update                        KB2918077               taras\slawo             10/31/2017
Update                        KB2919469               taras\slawo             9/29/2017
Update                        KB2923545               taras\slawo             10/31/2017
Security Update               KB2931356               taras\slawo             9/29/2017
Security Update               KB2937610               taras\slawo             9/29/2017
Security Update               KB2943357               taras\slawo             9/29/2017
Update                        KB2952664               taras\slawo             11/17/2017
Update                        KB2966583               taras\slawo             9/29/2017
Security Update               KB2968294               taras\slawo             10/31/2017
Update                        KB2970228               taras\slawo             10/31/2017
Security Update               KB2972100               taras\slawo             9/29/2017
Security Update               KB2972211               taras\slawo             9/29/2017
Security Update               KB2973112               taras\slawo             9/29/2017
Security Update               KB2973201               taras\slawo             9/29/2017
Security Update               KB2973351               taras\slawo             9/29/2017
Security Update               KB2977292               taras\slawo             9/29/2017
Security Update               KB2978120               taras\slawo             9/29/2017
Security Update               KB2978742               taras\slawo             10/31/2017
Security Update               KB2984972               taras\slawo             9/29/2017
Security Update               KB2984976               taras\slawo             10/31/2017
Update                        KB2985461               taras\slawo             9/29/2017
Security Update               KB2991963               taras\slawo             9/29/2017
Security Update               KB2992611               taras\slawo             9/29/2017
Security Update               KB3003743               taras\slawo             9/29/2017
Security Update               KB3004361               taras\slawo             9/29/2017
Security Update               KB3004375               taras\slawo             9/29/2017
Update                        KB3006121               taras\slawo             9/29/2017
Hotfix                        KB3006137               taras\slawo             10/31/2017
Security Update               KB3010788               taras\slawo             9/29/2017
Security Update               KB3011780               taras\slawo             9/29/2017
Update                        KB3013531               taras\slawo             9/29/2017
Update                        KB3020369               taras\slawo             9/24/2017
Update                        KB3020370               taras\slawo             9/29/2017
Security Update               KB3020388               taras\slawo             10/31/2017
Security Update               KB3021674               taras\slawo             9/29/2017
Update                        KB3021917               taras\slawo             9/29/2017
Security Update               KB3022777               taras\slawo             9/29/2017
Security Update               KB3023215               taras\slawo             9/29/2017
Security Update               KB3030377               taras\slawo             9/29/2017
Security Update               KB3035126               taras\slawo             9/29/2017
Security Update               KB3035132               taras\slawo             9/29/2017
Security Update               KB3037574               taras\slawo             9/29/2017
Security Update               KB3045685               taras\slawo             9/29/2017
Security Update               KB3046017               taras\slawo             9/29/2017
Security Update               KB3046269               taras\slawo             9/29/2017
Update                        KB3054476               taras\slawo             9/29/2017
Security Update               KB3055642               taras\slawo             10/31/2017
Security Update               KB3059317               taras\slawo             9/29/2017
Security Update               KB3060716               taras\slawo             9/29/2017
Security Update               KB3067903               taras\slawo             10/31/2017
Update                        KB3068708               taras\slawo             11/17/2017
Security Update               KB3071756               taras\slawo             11/17/2017
Security Update               KB3072305               taras\slawo             10/31/2017
Security Update               KB3074543               taras\slawo             9/29/2017
Security Update               KB3075226               taras\slawo             10/31/2017
Security Update               KB3076895               taras\slawo             9/29/2017
Security Update               KB3078601               taras\slawo             9/29/2017
Update                        KB3078667               taras\slawo             10/31/2017
Update                        KB3080079               taras\slawo             11/17/2017
Update                        KB3080149               taras\slawo             9/29/2017
Security Update               KB3084135               taras\slawo             9/29/2017
Security Update               KB3086255               taras\slawo             10/31/2017
Security Update               KB3092601               taras\slawo             9/29/2017
Update                        KB3092627               taras\slawo             9/29/2017
Security Update               KB3093513               taras\slawo             10/31/2017
Security Update               KB3097989               taras\slawo             9/29/2017
Security Update               KB3101722               taras\slawo             9/29/2017
Update                        KB3102429               taras\slawo             9/29/2017
Update                        KB3107998               taras\slawo             9/29/2017
Security Update               KB3108371               taras\slawo             9/29/2017
Security Update               KB3108381               taras\slawo             9/29/2017
Security Update               KB3108664               taras\slawo             10/31/2017
Security Update               KB3109103               taras\slawo             9/29/2017
Security Update               KB3109560               taras\slawo             9/29/2017
Security Update               KB3110329               taras\slawo             9/29/2017
Security Update               KB3115858               taras\slawo             9/29/2017
Security Update               KB3122648               taras\slawo             9/29/2017
Security Update               KB3126587               taras\slawo             11/17/2017
Security Update               KB3127220               taras\slawo             10/31/2017
Update                        KB3133977               taras\slawo             9/29/2017
Update                        KB3137061               taras\slawo             9/29/2017
Update                        KB3138378               taras\slawo             9/29/2017
Update                        KB3138612               taras\slawo             9/29/2017
Security Update               KB3138910               taras\slawo             9/29/2017
Security Update               KB3139398               taras\slawo             9/29/2017
Security Update               KB3139914               taras\slawo             9/29/2017
Update                        KB3140245               taras\slawo             9/29/2017
Update                        KB3147071               taras\slawo             10/31/2017
Security Update               KB3150220               taras\slawo             9/29/2017
Update                        KB3150513               taras\slawo             10/31/2017
Security Update               KB3155178               taras\slawo             9/29/2017
Security Update               KB3156016               taras\slawo             9/29/2017
Security Update               KB3156019               taras\slawo             9/29/2017
Security Update               KB3159398               taras\slawo             9/29/2017
Update                        KB3161102               taras\slawo             9/29/2017
Security Update               KB3161949               taras\slawo             9/29/2017
Security Update               KB3161958               taras\slawo             9/29/2017
Update                        KB3170735               taras\slawo             9/29/2017
Update                        KB3172605               taras\slawo             9/29/2017
Update                        KB3177467               taras\slawo             9/29/2017
Update                        KB3179573               taras\slawo             9/29/2017
Update                        KB3181988               taras\slawo             9/29/2017
Update                        KB3184143               taras\slawo             9/29/2017
Update                        KB4019990               taras\slawo             9/29/2017
Update                        KB4040980               taras\slawo             9/29/2017
Update                        KB958488                taras\slawo             10/27/2015
Update                        KB976902                taras\Administrator     11/21/2010
Update                        KB982018                taras\slawo             10/31/2017
Security Update               KB4038777               taras\slawo             9/29/2017
========= Koniec  CMD: =========
========= get-hotfix =========
Source        Description      HotFixID      InstalledBy          InstalledOn
TARAS         Update           KB2849697     taras\slawo          2017-04-05...
TARAS         Update           KB2849696     taras\slawo          2017-04-05...
TARAS         Update           KB2841134     taras\slawo          2017-04-05...
TARAS         Update           KB2670838     taras\slawo          2015-10-31...
TARAS         Update           KB2830477     taras\slawo          2017-09-29...
TARAS         Update           KB2592687     taras\slawo          2017-09-29...
TARAS         Update           KB971033      taras\slawo          2017-09-29...
TARAS         Security Update  KB2479943     taras\slawo          2017-10-31...
TARAS         Security Update  KB2491683     taras\slawo          2017-09-29...
TARAS         Update           KB2506014     taras\slawo          2017-09-29...
TARAS         Security Update  KB2506212     taras\slawo          2017-09-29...
TARAS         Update           KB2506928     taras\slawo          2017-09-29...
TARAS         Security Update  KB2509553     taras\slawo          2017-09-29...
TARAS         Security Update  KB2532531     taras\slawo          2017-10-31...
TARAS         Update           KB2533552     ZARZÄ„DZANIE NT\SY... 2017-09-29...
TARAS         Update           KB2533623     taras\slawo          2017-04-01...
TARAS         Hotfix           KB2534111                          2015-10-27...
TARAS         Update           KB2545698     taras\slawo          2017-09-29...
TARAS         Update           KB2547666     taras\slawo          2017-10-31...
TARAS         Update           KB2552343     taras\slawo          2017-09-29...
TARAS         Security Update  KB2560656     taras\slawo          2017-10-31...
TARAS         Update           KB2563227     taras\slawo          2017-10-31...
TARAS         Security Update  KB2564958     taras\slawo          2017-09-29...
TARAS         Update           KB2574819     taras\slawo          2017-09-29...
TARAS         Security Update  KB2579686     taras\slawo          2017-09-29...
TARAS         Security Update  KB2585542     taras\slawo          2017-09-29...
TARAS         Update           KB2603229     taras\slawo          2017-09-29...
TARAS         Security Update  KB2604115     taras\slawo          2017-09-29...
TARAS         Security Update  KB2620704     taras\slawo          2017-10-31...
TARAS         Security Update  KB2621440     taras\slawo          2017-09-29...
TARAS         Security Update  KB2631813     taras\slawo          2017-10-31...
TARAS         Hotfix           KB2639308     taras\slawo          2017-04-01...
TARAS         Update           KB2640148     taras\slawo          2017-10-31...
TARAS         Security Update  KB2653956     taras\slawo          2017-09-29...
TARAS         Security Update  KB2654428     taras\slawo          2017-09-29...
TARAS         Update           KB2660075     taras\slawo          2017-09-29...
TARAS         Security Update  KB2667402     taras\slawo          2017-11-17...
TARAS         Update           KB2685811     taras\slawo          2017-09-29...
TARAS         Update           KB2685813     taras\slawo          2017-09-29...
TARAS         Security Update  KB2685939     taras\slawo          2017-09-29...
TARAS         Security Update  KB2690533     taras\slawo          2017-09-29...
TARAS         Security Update  KB2698365     taras\slawo          2017-09-29...
TARAS         Security Update  KB2705219     taras\slawo          2017-09-29...
TARAS         Security Update  KB2719033     taras\slawo          2017-09-29...
TARAS         Update           KB2719857     taras\slawo          2017-09-29...
TARAS         Update           KB2726535     taras\slawo          2017-09-29...
TARAS         Security Update  KB2727528     taras\slawo
TARAS         Update           KB2729094     taras\slawo          2017-04-01...
TARAS         Security Update  KB2729452     taras\slawo          2017-09-29...
TARAS         Update           KB2731771     taras\slawo          2017-04-01...
TARAS         Update           KB2732059     taras\slawo          2017-09-29...
TARAS         Update           KB2732487     taras\slawo          2017-10-31...
TARAS         Security Update  KB2736422     taras\slawo          2017-09-29...
TARAS         Security Update  KB2742599     taras\slawo          2017-09-29...
TARAS         Update           KB2750841     taras\slawo          2017-09-29...
TARAS         Security Update  KB2758857     taras\slawo          2017-09-29...
TARAS         Update           KB2761217     taras\slawo          2017-09-29...
TARAS         Update           KB2763523     taras\slawo          2017-10-31...
TARAS         Security Update  KB2770660     taras\slawo          2017-09-29...
TARAS         Update           KB2773072     taras\slawo          2017-09-29...
TARAS         Update           KB2786081     taras\slawo          2017-04-01...
TARAS         Update           KB2791765     taras\slawo          2017-09-29...
TARAS         Update           KB2799926     taras\slawo          2017-09-29...
TARAS         Update           KB2800095     taras\slawo          2017-09-29...
TARAS         Security Update  KB2807986     taras\slawo          2017-09-29...
TARAS         Update           KB2808679     taras\slawo          2017-09-29...
TARAS         Security Update  KB2813347     taras\slawo          2017-10-31...
TARAS         Security Update  KB2813430     taras\slawo          2017-10-31...
TARAS         Update           KB2834140     taras\slawo          2017-04-01...
TARAS         Update           KB2835174     taras\slawo          2017-09-29...
TARAS         Update           KB2836942     taras\slawo          2017-09-29...
TARAS         Update           KB2836943     taras\slawo          2017-09-29...
TARAS         Security Update  KB2840631     taras\slawo          2017-10-31...
TARAS         Update           KB2843630     taras\slawo          2017-09-29...
TARAS         Security Update  KB2847927     taras\slawo          2017-09-29...
TARAS         Update           KB2852386     taras\slawo          2017-11-18...
TARAS         Update           KB2853952     taras\slawo          2017-09-29...
TARAS         Update           KB2857650     taras\slawo          2017-09-29...
TARAS         Security Update  KB2861698     taras\slawo          2017-09-29...
TARAS         Security Update  KB2862152     taras\slawo          2017-09-29...
TARAS         Security Update  KB2862330     taras\slawo          2017-09-29...
TARAS         Security Update  KB2862335     taras\slawo          2017-09-29...
TARAS         Security Update  KB2864202     taras\slawo          2017-09-29...
TARAS         Security Update  KB2868038     taras\slawo          2017-09-29...
TARAS         Security Update  KB2871997     taras\slawo          2017-09-29...
TARAS         Update           KB2882822     taras\slawo          2017-04-01...
TARAS         Security Update  KB2884256     taras\slawo          2017-09-29...
TARAS         Update           KB2888049     taras\slawo          2017-04-01...
TARAS         Update           KB2891804     taras\slawo          2017-09-29...
TARAS         Security Update  KB2892074     taras\slawo          2017-09-29...
TARAS         Security Update  KB2893294     taras\slawo          2017-09-29...
TARAS         Update           KB2893519     taras\slawo          2017-09-29...
TARAS         Security Update  KB2894844     taras\slawo          2017-10-31...
TARAS         Security Update  KB2900986     taras\slawo          2017-09-28...
TARAS         Update           KB2908783     taras\slawo
TARAS         Security Update  KB2911501     taras\slawo          2017-09-29...
TARAS         Security Update  KB2912390     taras\slawo          2017-09-29...
TARAS         Update           KB2918077     taras\slawo          2017-10-31...
TARAS         Update           KB2919469     taras\slawo          2017-09-29...
TARAS         Update           KB2923545     taras\slawo          2017-10-31...
TARAS         Security Update  KB2931356     taras\slawo          2017-09-29...
TARAS         Security Update  KB2937610     taras\slawo          2017-09-29...
TARAS         Security Update  KB2943357     taras\slawo          2017-09-29...
TARAS         Update           KB2952664     taras\slawo          2017-11-17...
TARAS         Update           KB2966583     taras\slawo          2017-09-29...
TARAS         Security Update  KB2968294     taras\slawo          2017-10-31...
TARAS         Update           KB2970228     taras\slawo          2017-10-31...
TARAS         Security Update  KB2972100     taras\slawo          2017-09-29...
TARAS         Security Update  KB2972211     taras\slawo          2017-09-29...
TARAS         Security Update  KB2973112     taras\slawo          2017-09-29...
TARAS         Security Update  KB2973201     taras\slawo          2017-09-29...
TARAS         Security Update  KB2973351     taras\slawo          2017-09-29...
TARAS         Security Update  KB2977292     taras\slawo          2017-09-29...
TARAS         Security Update  KB2978120     taras\slawo          2017-09-29...
TARAS         Security Update  KB2978742     taras\slawo          2017-10-31...
TARAS         Security Update  KB2984972     taras\slawo          2017-09-29...
TARAS         Security Update  KB2984976     taras\slawo          2017-10-31...
TARAS         Update           KB2985461     taras\slawo          2017-09-29...
TARAS         Security Update  KB2991963     taras\slawo          2017-09-29...
TARAS         Security Update  KB2992611     taras\slawo          2017-09-29...
TARAS         Security Update  KB3003743     taras\slawo          2017-09-29...
TARAS         Security Update  KB3004361     taras\slawo          2017-09-29...
TARAS         Security Update  KB3004375     taras\slawo          2017-09-29...
TARAS         Update           KB3006121     taras\slawo          2017-09-29...
TARAS         Hotfix           KB3006137     taras\slawo          2017-10-31...
TARAS         Security Update  KB3010788     taras\slawo          2017-09-29...
TARAS         Security Update  KB3011780     taras\slawo          2017-09-29...
TARAS         Update           KB3013531     taras\slawo          2017-09-29...
TARAS         Update           KB3020369     taras\slawo          2017-09-24...
TARAS         Update           KB3020370     taras\slawo          2017-09-29...
TARAS         Security Update  KB3020388     taras\slawo          2017-10-31...
TARAS         Security Update  KB3021674     taras\slawo          2017-09-29...
TARAS         Update           KB3021917     taras\slawo          2017-09-29...
TARAS         Security Update  KB3022777     taras\slawo          2017-09-29...
TARAS         Security Update  KB3023215     taras\slawo          2017-09-29...
TARAS         Security Update  KB3030377     taras\slawo          2017-09-29...
TARAS         Security Update  KB3035126     taras\slawo          2017-09-29...
TARAS         Security Update  KB3035132     taras\slawo          2017-09-29...
TARAS         Security Update  KB3037574     taras\slawo          2017-09-29...
TARAS         Security Update  KB3045685     taras\slawo          2017-09-29...
TARAS         Security Update  KB3046017     taras\slawo          2017-09-29...
TARAS         Security Update  KB3046269     taras\slawo          2017-09-29...
TARAS         Update           KB3054476     taras\slawo          2017-09-29...
TARAS         Security Update  KB3055642     taras\slawo          2017-10-31...
TARAS         Security Update  KB3059317     taras\slawo          2017-09-29...
TARAS         Security Update  KB3060716     taras\slawo          2017-09-29...
TARAS         Security Update  KB3067903     taras\slawo          2017-10-31...
TARAS         Update           KB3068708     taras\slawo          2017-11-17...
TARAS         Security Update  KB3071756     taras\slawo          2017-11-17...
TARAS         Security Update  KB3072305     taras\slawo          2017-10-31...
TARAS         Security Update  KB3074543     taras\slawo          2017-09-29...
TARAS         Security Update  KB3075226     taras\slawo          2017-10-31...
TARAS         Security Update  KB3076895     taras\slawo          2017-09-29...
TARAS         Security Update  KB3078601     taras\slawo          2017-09-29...
TARAS         Update           KB3078667     taras\slawo          2017-10-31...
TARAS         Update           KB3080079     taras\slawo          2017-11-17...
TARAS         Update           KB3080149     taras\slawo          2017-09-29...
TARAS         Security Update  KB3084135     taras\slawo          2017-09-29...
TARAS         Security Update  KB3086255     taras\slawo          2017-10-31...
TARAS         Security Update  KB3092601     taras\slawo          2017-09-29...
TARAS         Update           KB3092627     taras\slawo          2017-09-29...
TARAS         Security Update  KB3093513     taras\slawo          2017-10-31...
TARAS         Security Update  KB3097989     taras\slawo          2017-09-29...
TARAS         Security Update  KB3101722     taras\slawo          2017-09-29...
TARAS         Update           KB3102429     taras\slawo          2017-09-29...
TARAS         Update           KB3107998     taras\slawo          2017-09-29...
TARAS         Security Update  KB3108371     taras\slawo          2017-09-29...
TARAS         Security Update  KB3108381     taras\slawo          2017-09-29...
TARAS         Security Update  KB3108664     taras\slawo          2017-10-31...
TARAS         Security Update  KB3109103     taras\slawo          2017-09-29...
TARAS         Security Update  KB3109560     taras\slawo          2017-09-29...
TARAS         Security Update  KB3110329     taras\slawo          2017-09-29...
TARAS         Security Update  KB3115858     taras\slawo          2017-09-29...
TARAS         Security Update  KB3122648     taras\slawo          2017-09-29...
TARAS         Security Update  KB3126587     taras\slawo          2017-11-17...
TARAS         Security Update  KB3127220     taras\slawo          2017-10-31...
TARAS         Update           KB3133977     taras\slawo          2017-09-29...
TARAS         Update           KB3137061     taras\slawo          2017-09-29...
TARAS         Update           KB3138378     taras\slawo          2017-09-29...
TARAS         Update           KB3138612     taras\slawo          2017-09-29...
TARAS         Security Update  KB3138910     taras\slawo          2017-09-29...
TARAS         Security Update  KB3139398     taras\slawo          2017-09-29...
TARAS         Security Update  KB3139914     taras\slawo          2017-09-29...
TARAS         Update           KB3140245     taras\slawo          2017-09-29...
TARAS         Update           KB3147071     taras\slawo          2017-10-31...
TARAS         Security Update  KB3150220     taras\slawo          2017-09-29...
TARAS         Update           KB3150513     taras\slawo          2017-10-31...
TARAS         Security Update  KB3155178     taras\slawo          2017-09-29...
TARAS         Security Update  KB3156016     taras\slawo          2017-09-29...
TARAS         Security Update  KB3156019     taras\slawo          2017-09-29...
TARAS         Security Update  KB3159398     taras\slawo          2017-09-29...
TARAS         Update           KB3161102     taras\slawo          2017-09-29...
TARAS         Security Update  KB3161949     taras\slawo          2017-09-29...
TARAS         Security Update  KB3161958     taras\slawo          2017-09-29...
TARAS         Update           KB3170735     taras\slawo          2017-09-29...
TARAS         Update           KB3172605     taras\slawo          2017-09-29...
TARAS         Update           KB3177467     taras\slawo          2017-09-29...
TARAS         Update           KB3179573     taras\slawo          2017-09-29...
TARAS         Update           KB3181988     taras\slawo          2017-09-29...
TARAS         Update           KB3184143     taras\slawo          2017-09-29...
TARAS         Update           KB4019990     taras\slawo          2017-09-29...
TARAS         Update           KB4040980     taras\slawo          2017-09-29...
TARAS         Update           KB958488      taras\slawo          2015-10-27...
TARAS         Update           KB976902      taras\Administrator  2010-11-21...
TARAS         Update           KB982018      taras\slawo          2017-10-31...
TARAS         Security Update  KB4038777     taras\slawo          2017-09-29...
========= Koniec  Powershell: =========
==== Koniec  Fixlog 07:23:31 ====
CBS.log
View attachment CBS.zip
SFCFix.txt
Start time: 2017-11-29 07:24:39.134
Using .txt script file at C:\Users\slawo\Desktop\SFCFixScript.txt [0]
FileScan::
[0: 1] C:\Windows\winsxs\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.17857_none_4adb14fa07af1699\msado60.tlb
 Expected: ntXqeXuAXvM1G5bJCPxXNTMUR9pDfu6vJhhnTDvv9co=
 Expected: 6.1.7601.17857
Successfully traced component amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.17857_none_4adb14fa07af1699.
Package_8_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.2698365-63_neutral_LDR3
[1: 1] C:\Windows\winsxs\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.22012_none_4b8ac82520b0fb2e\msado60.tlb
 Expected: gFWX/WsS/mYO2C22Z/OvFqKtXOSaHoa8VMz2uqX3W70=
 Expected: 6.1.7601.22012
Successfully traced component amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.22012_none_4b8ac82520b0fb2e.
[2: 1] C:\Windows\winsxs\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7600.21227_none_499e9ca5238e29e6\msado60.tlb
 Expected: GyVujZIMxt+NcwEHAHtsp8khsJkYpbCbeVQienMvHRs=
 Expected: 6.1.7600.21227
Successfully traced component amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7600.21227_none_499e9ca5238e29e6.
Package_19_for_KB2698365~31bf3856ad364e35~amd64~~6.1.1.2.2698365-140_neutral_LDR3
[3: 1] C:\Windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.17857_none_eebc79764f51a563\msado60.tlb
 Expected: jkb/Y1P0wv8pGu8Z8I9VZdyexuUV+VwzFq6OruceTBI=
Successfully traced component x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.17857_none_eebc79764f51a563.
[4: 1] C:\Windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.22012_none_ef6c2ca1685389f8\msado60.tlb
 Expected: Qwd4L5H3YWMwihJXjYx01pBlchIIsLdDM7X7Igjferc=
Successfully traced component x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.22012_none_ef6c2ca1685389f8.
[5: 1] C:\Windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7600.21227_none_ed8001216b30b8b0\msado60.tlb
 Expected: tyMfOY3bCfo0njRYv/vwxHi3FmolcUP/NW/5ws8xOis=
Successfully traced component x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7600.21227_none_ed8001216b30b8b0.
[6: 2] C:\Windows\winsxs\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.23789_none_ef2775b5688604a2\msado60.tlb
 Expected: IWvCD08dmfvROQsnoG2qh7uKSmzwgT2azNKLvCFUjR8=
 Expected: 6.1.7601.23789
Failed to trace component x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.23789_none_ef2775b5688604a2 with return code 1 and conditional return code ERROR_FILE_NOT_FOUND.
 [C:\Program Files (x86)\Common Files\System\ado\msado60.tlb]
[7: 2] C:\Windows\winsxs\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.23789_none_4b46113920e375d8\msado60.tlb
 Expected: 2I1coeXwBczgkrmWyj1D0hk1XPapfCWbvZbcVqRnC4Y=
Failed to trace component amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_6.1.7601.23789_none_4b46113920e375d8 with return code 1 and conditional return code ERROR_FILE_NOT_FOUND.
 [C:\Program Files\Common Files\System\ado\msado60.tlb]
Currently storing 75 datablocks.
Finish time: 2017-11-29 07:24:45.322
Script hash: DEGGrLRuaH408jrTiFgYVq+4bCOnK0yNGJJ2+aTDXLE=
Is it related to work with FRST here, that only CybeReason Ransomfree shows and try to delete random folders with the same contents?
Besides it is not detected by Malwarebytes Anti-Malware nor Microsoft Security Essentials.
Maybe I could transfer the OS to another hard disk to train more agrressive solutions - in this thread - but I am able to transfer to old laptop drive.
You do a great job, but it is impossble that something is blocking the WU in the end.
Sure!
It is hard to say, I tried Eset Online Scanner and there was lag (problems with mouse moving) and it had caused.... BSOD TARGET_MDL_TOO_SMALL 0x00000040 I got back using Restore Point.
Can I try to run Eset Online Scanner one more time from Safe Mode to be sure that its because of it?
No idea if it could have caused system data errors.
Is it possible that malware etc. is causing some driver bugs and crashes?
Besides one guy will check malware issue with FRST, from #130 post.
Sorry to bother you, because you are engaged with WU issue solving
Oh, what a mess :eek:
Please do not try it again until after we're done as it can cause issues. After we have completed Windows Update fixing, then you're free to go into our Security Arena to get your Computer fixed, but please consult with me before doing such things because it can be counter productive.
Thank you.
Then do the following:
SFC Scan
SFCfix.txt
Start time: 2017-11-30 08:38:19.976
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\f256!msado60.tlb.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\ComponentFamilies\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96\f256!msado60.tlb.
WARNING: Failed to create backup for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\f256!msado60.tlb.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\f256!msado60.tlb.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96\6.1.
Successfully imported registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\ComponentFamilies\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96\f256!msado60.tlb.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\ComponentFamilies\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\ComponentFamilies.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\VersionedIndex\6.1.7601.23505 (win7sp1_ldr.160722-0600)\ComponentFamilies\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\f256!msado60.tlb.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\amd64_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_19b2b48942aa2f96.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60\6.1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\SideBySide\Winners\x86_microsoft-windows-m..do-backcompat-tlb60_31bf3856ad364e35_none_bd9419058a4cbe60.
Currently storing 85 datablocks.
Finish time: 2017-11-30 08:38:20.789
Script hash: xmUXu3dceF7YfaoUcgnjyZsFb+8OEXio3jObd5OPzAI=
cbs.txt
2017-11-30 08:38:52, Info                  CBS    Starting TrustedInstaller initialization.
2017-11-30 08:38:52, Info                  CBS    Loaded Servicing Stack v6.1.7601.23505 with Core: C:\Windows\winsxs\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\cbscore.dll
2017-11-30 08:38:52, Info                  CSI    00000001@2017/11/30:07:38:52.772 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee860eb5d @0x7fee8ef9b6d @0x7fee8ec358f @0xff94e97c @0xff94d799 @0xff94db2f)
2017-11-30 08:38:52, Info                  CSI    00000002@2017/11/30:07:38:52.788 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee860eb5d @0x7fee8f46ade @0x7fee8f12984 @0x7fee8ec3665 @0xff94e97c @0xff94d799)
2017-11-30 08:38:52, Info                  CSI    00000003@2017/11/30:07:38:52.788 WcpInitialize (wcp.dll version 0.0.0.6) called (stack @0x7fee860eb5d @0x7feedcc8728 @0x7feedcc8856 @0xff94e474 @0xff94d7de @0xff94db2f)
2017-11-30 08:38:52, Info                  CBS    Ending TrustedInstaller initialization.
2017-11-30 08:38:52, Info                  CBS    Starting the TrustedInstaller main loop.
2017-11-30 08:38:52, Info                  CBS    TrustedInstaller service starts successfully.
2017-11-30 08:38:52, Info                  CBS    SQM: Initializing online with Windows opt-in: False
2017-11-30 08:38:52, Info                  CBS    SQM: Cleaning up report files older than 10 days.
2017-11-30 08:38:52, Info                  CBS    SQM: Requesting upload of all unsent reports.
2017-11-30 08:38:52, Info                  CBS    SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2017-11-30 08:38:52, Info                  CBS    SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2017-11-30 08:38:52, Info                  CBS    SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2017-11-30 08:38:52, Info                  CBS    SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2017-11-30 08:38:52, Info                  CBS    No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2017-11-30 08:38:52, Info                  CBS    NonStart: Checking to ensure startup processing was not required.
2017-11-30 08:38:52, Info                  CSI    00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0xd4fbd0
2017-11-30 08:38:52, Info                  CSI    00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2017-11-30 08:38:52, Info                  CSI    00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x1f0
2017-11-30 08:38:52, Info                  CSI    00000007@2017/11/30:07:38:52.866 CSI perf trace:
CSIPERF:TXCOMMIT;1288
2017-11-30 08:38:52, Info                  CBS    NonStart: Success, startup processing not required as expected.
2017-11-30 08:38:52, Info                  CBS    Startup processing thread terminated normally
2017-11-30 08:38:52, Info                  CSI    00000008 CSI Store 2232736 (0x00000000002211a0) initialized
2017-11-30 08:38:55, Info                  CSI    00000009 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:55, Info                  CSI    0000000a [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:55, Info                  CSI    0000000b Repair results created:
POQ 0 starts:
POQ 0 ends.
2017-11-30 08:38:55, Info                  CSI    0000000c [SR] Verify complete
2017-11-30 08:38:55, Info                  CSI    0000000d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:55, Info                  CSI    0000000e [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:55, Info                  CSI    0000000f Repair results created:
POQ 1 starts:
POQ 1 ends.
2017-11-30 08:38:55, Info                  CSI    00000010 [SR] Verify complete
2017-11-30 08:38:56, Info                  CSI    00000011 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:56, Info                  CSI    00000012 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:56, Info                  CSI    00000013 Repair results created:
POQ 2 starts:
POQ 2 ends.
2017-11-30 08:38:56, Info                  CSI    00000014 [SR] Verify complete
2017-11-30 08:38:56, Info                  CSI    00000015 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:56, Info                  CSI    00000016 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:56, Info                  CSI    00000017 Repair results created:
POQ 3 starts:
POQ 3 ends.
2017-11-30 08:38:56, Info                  CSI    00000018 [SR] Verify complete
2017-11-30 08:38:56, Info                  CSI    00000019 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:56, Info                  CSI    0000001a [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:56, Info                  CSI    0000001b Repair results created:
POQ 4 starts:
POQ 4 ends.
2017-11-30 08:38:56, Info                  CSI    0000001c [SR] Verify complete
2017-11-30 08:38:57, Info                  CSI    0000001d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:57, Info                  CSI    0000001e [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:57, Info                  CSI    0000001f Repair results created:
POQ 5 starts:
POQ 5 ends.
2017-11-30 08:38:57, Info                  CSI    00000020 [SR] Verify complete
2017-11-30 08:38:57, Info                  CSI    00000021 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:57, Info                  CSI    00000022 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:57, Info                  CSI    00000023 Repair results created:
POQ 6 starts:
POQ 6 ends.
2017-11-30 08:38:57, Info                  CSI    00000024 [SR] Verify complete
2017-11-30 08:38:57, Info                  CSI    00000025 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:57, Info                  CSI    00000026 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:57, Info                  CSI    00000027 Repair results created:
POQ 7 starts:
POQ 7 ends.
2017-11-30 08:38:57, Info                  CSI    00000028 [SR] Verify complete
2017-11-30 08:38:58, Info                  CSI    00000029 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:58, Info                  CSI    0000002a [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:58, Info                  CSI    0000002b Repair results created:
POQ 8 starts:
POQ 8 ends.
2017-11-30 08:38:58, Info                  CSI    0000002c [SR] Verify complete
2017-11-30 08:38:58, Info                  CSI    0000002d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:58, Info                  CSI    0000002e [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:58, Info                  CSI    0000002f Repair results created:
POQ 9 starts:
POQ 9 ends.
2017-11-30 08:38:58, Info                  CSI    00000030 [SR] Verify complete
2017-11-30 08:38:58, Info                  CSI    00000031 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:58, Info                  CSI    00000032 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:59, Info                  CSI    00000033 Repair results created:
POQ 10 starts:
POQ 10 ends.
2017-11-30 08:38:59, Info                  CSI    00000034 [SR] Verify complete
2017-11-30 08:38:59, Info                  CSI    00000035 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:38:59, Info                  CSI    00000036 [SR] Beginning Verify and Repair transaction
2017-11-30 08:38:59, Info                  CSI    00000037 Repair results created:
POQ 11 starts:
POQ 11 ends.
2017-11-30 08:38:59, Info                  CSI    00000038 [SR] Verify complete
2017-11-30 08:39:00, Info                  CSI    00000039 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:00, Info                  CSI    0000003a [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:00, Info                  CSI    0000003b Repair results created:
POQ 12 starts:
POQ 12 ends.
2017-11-30 08:39:00, Info                  CSI    0000003c [SR] Verify complete
2017-11-30 08:39:00, Info                  CSI    0000003d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:00, Info                  CSI    0000003e [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:00, Info                  CSI    0000003f Repair results created:
POQ 13 starts:
POQ 13 ends.
2017-11-30 08:39:00, Info                  CSI    00000040 [SR] Verify complete
2017-11-30 08:39:00, Info                  CSI    00000041 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:00, Info                  CSI    00000042 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:01, Info                  CSI    00000043 Repair results created:
POQ 14 starts:
POQ 14 ends.
2017-11-30 08:39:01, Info                  CSI    00000044 [SR] Verify complete
2017-11-30 08:39:01, Info                  CSI    00000045 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:01, Info                  CSI    00000046 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:01, Info                  CSI    00000047 Repair results created:
POQ 15 starts:
POQ 15 ends.
2017-11-30 08:39:01, Info                  CSI    00000048 [SR] Verify complete
2017-11-30 08:39:01, Info                  CSI    00000049 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:01, Info                  CSI    0000004a [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:02, Info                  CSI    0000004b Repair results created:
POQ 16 starts:
POQ 16 ends.
2017-11-30 08:39:02, Info                  CSI    0000004c [SR] Verify complete
2017-11-30 08:39:02, Info                  CSI    0000004d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:02, Info                  CSI    0000004e [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:02, Info                  CSI    0000004f Repair results created:
POQ 17 starts:
POQ 17 ends.
2017-11-30 08:39:02, Info                  CSI    00000050 [SR] Verify complete
2017-11-30 08:39:03, Info                  CSI    00000051 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:03, Info                  CSI    00000052 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:03, Info                  CSI    00000053 Repair results created:
POQ 18 starts:
POQ 18 ends.
2017-11-30 08:39:03, Info                  CSI    00000054 [SR] Verify complete
2017-11-30 08:39:03, Info                  CSI    00000055 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:03, Info                  CSI    00000056 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:04, Info                  CSI    00000057 Repair results created:
POQ 19 starts:
POQ 19 ends.
2017-11-30 08:39:04, Info                  CSI    00000058 [SR] Verify complete
2017-11-30 08:39:04, Info                  CSI    00000059 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:04, Info                  CSI    0000005a [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:05, Info                  CSI    0000005b Repair results created:
POQ 20 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1f74504cae69d301360800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1f74504cae69d301370800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\87fd594cae69d301380800007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\e15f5c4cae69d301390800007c017813.$$_system32_manifeststore_7d35b12f9be4c20e.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_manifeststore_7d35b12f9be4c20e.cdf-ms"
    4: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\a34b684cae69d3013a0800007c017813.$$_system32_compattel_387f970722416aa9.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_compattel_387f970722416aa9.cdf-ms"
    5: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\fdad6a4cae69d3013b0800007c017813.$$_apppatch_1143992cbbbebcab.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_1143992cbbbebcab.cdf-ms"
    6: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\fdad6a4cae69d3013c0800007c017813.$$_apppatch_apppatch64_e39bab3b20714e20.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_apppatch64_e39bab3b20714e20.cdf-ms"
POQ 20 ends.
2017-11-30 08:39:05, Info                  CSI    0000005c [SR] Verify complete
2017-11-30 08:39:05, Info                  CSI    0000005d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:05, Info                  CSI    0000005e [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:06, Info                  CSI    0000005f Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\SchCache" in component Microsoft-Windows-Active-Directory-Services-Interface-LDAP-Provider, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:07, Info                  CSI    00000060 Ignoring duplicate ownership for directory [l:92{46}]"\??\C:\ProgramData\Microsoft\Diagnosis\ETLLogs" in component Microsoft-Windows-Application-Experience-Inventory, Version = 6.1.7601.23933, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:07, Info                  CSI    00000061 Repair results created:
POQ 21 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\7154544dae69d301a10800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\7154544dae69d301a20800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\7154544dae69d301a30800007c017813.$$_schcache_f995a5d4decb8cc0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_schcache_f995a5d4decb8cc0.cdf-ms"
    3: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\2519594dae69d301a40800007c017813.$$_appcompat_programs_99c7f419bd54f4ca.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_appcompat_programs_99c7f419bd54f4ca.cdf-ms"
    4: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\e704654dae69d301a50800007c017813.$$_diagnostics_system_audio_9d2751b7c84ca0f1.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_audio_9d2751b7c84ca0f1.cdf-ms"
    5: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\e704654dae69d301a60800007c017813.$$_diagnostics_system_audio_pl-pl_b4996f7340fbd3e8.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_audio_pl-pl_b4996f7340fbd3e8.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\e704654dae69d301a70800007c017813.$$_diagnostics_system_aero_8b2c42561936b3f0.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_aero_8b2c42561936b3f0.cdf-ms"
    7: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\4167674dae69d301a80800007c017813.$$_diagnostics_system_aero_pl-pl_1a6686ef20af45b1.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_aero_pl
2017-11-30 08:39:07, Info                  CSI    -pl_1a6686ef20af45b1.cdf-ms"
    8: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9f0704dae69d301a90800007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    9: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9f0704dae69d301aa0800007c017813.$$_system32_logfiles_ait_5b4995189d2e6c55.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_system32_logfiles_ait_5b4995189d2e6c55.cdf-ms"
    10: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9f0704dae69d301ab0800007c017813.programdata_microsoft_windows_ait_140a03828e6ffe97.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_ait_140a03828e6ffe97.cdf-ms"
    11: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\117a7a4dae69d301ac0800007c017813.$$_help_windows_pl-pl_ca7ba93a540bfa39.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_help_windows_pl-pl_ca7ba93a540bfa39.cdf-ms"
    12: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\117a7a4dae69d301ad0800007c017813.$$_help_help_pl-pl_905a7d9d9e17e123.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_help_help_pl-pl_905a7d9d9e17e123.cdf-ms"
    13: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\d365864dae69d301ae0800007c017813.$$_resources_fbee56ab048ab239.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_resources_fbee56ab048ab239.cdf-ms"
    14: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\2dc8884dae69d301af0800007c017813.$$_resources_themes_4d0d4910e83c2273.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_4d0d4910e83c2273.cdf-ms"
    15: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\2dc8884dae69d301b00800007c017813.$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms", Destination = [l:152{76}]"\System
2017-11-30 08:39:07, Info                  CSI    Root\WinSxS\FileMaps\$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms"
    16: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\2dc8884dae69d301b10800007c017813.$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms"
    17: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\2dc8884dae69d301b20800007c017813.$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms"
    18: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\efb3944dae69d301b30800007c017813.$$_help_windows_en-us_b594929e73669c5e.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_help_windows_en-us_b594929e73669c5e.cdf-ms"
    19: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\efb3944dae69d301b40800007c017813.$$_help_help_en-us_91e6e7979a9bf9c6.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_help_help_en-us_91e6e7979a9bf9c6.cdf-ms"
    20: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\2750b14dae69d301b50800007c017813.$$_system32_appraiser_59bebec9f06db09b.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_appraiser_59bebec9f06db09b.cdf-ms"
    21: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\2750b14dae69d301b60800007c017813.$$_appcompat_appraiser_telemetry_94274e99519f58a9.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_appcompat_appraiser_telemetry_94274e99519f58a9.cdf-ms"
    22: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\2750b14dae69d301b70800007c017813.programdata_microsoft_diagnosis_af2ddc54e6a8e491.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_af2ddc54e6a8e491.cdf-ms"
    23: Move File: Source = [l:270{135}
2017-11-30 08:39:07, Info                  CSI    ]"\SystemRoot\WinSxS\Temp\PendingRenames\2750b14dae69d301b80800007c017813.programdata_microsoft_diagnosis_etllogs_ffc0f561f3797ceb.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_etllogs_ffc0f561f3797ceb.cdf-ms"
POQ 21 ends.
2017-11-30 08:39:07, Info                  CSI    00000062 [SR] Verify complete
2017-11-30 08:39:07, Info                  CSI    00000063 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:07, Info                  CSI    00000064 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:08, Info                  CSI    00000065 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Branding\Basebrd" in component Microsoft-Windows-Branding-Base-Professional, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:08, Info                  CSI    00000066 Ignoring duplicate ownership for directory [l:74{37}]"\??\C:\Windows\Branding\Basebrd\pl-PL" in component Microsoft-Windows-Branding-Base-Professional.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:08, Info                  CSI    00000067 Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\Branding\Shellbrd" in component Microsoft-Windows-Branding-Shell-Professional, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:09, Info                  CSI    00000068 Repair results created:
POQ 22 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\5533774eae69d3011d0900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5533774eae69d3011e0900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\5533774eae69d3011f0900007c017813.$$_diagnostics_system_audio_9d2751b7c84ca0f1.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_audio_9d2751b7c84ca0f1.cdf-ms"
    3: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\171f834eae69d301200900007c017813.$$_branding_1728f5d8b15e5263.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_branding_1728f5d8b15e5263.cdf-ms"
    4: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\171f834eae69d301210900007c017813.$$_branding_basebrd_9ee9a176c9fadab4.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_branding_basebrd_9ee9a176c9fadab4.cdf-ms"
    5: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\f5589d4eae69d301220900007c017813.$$_branding_basebrd_pl-pl_66a779b923ed512b.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_branding_basebrd_pl-pl_66a779b923ed512b.cdf-ms"
    6: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\d392b74eae69d301230900007c017813.$$_branding_shellbrd_be1f632087fb0947.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_branding_shellbrd_be1f632087fb0947.cdf-ms"
    7: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\81dfe44eae69d301240900007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    8: Move File: Source = [l:224{112}]"\Sys
2017-11-30 08:39:09, Info                  CSI    temRoot\WinSxS\Temp\PendingRenames\81dfe44eae69d301250900007c017813.$$_system32_boot_06654401df2fc50e.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_boot_06654401df2fc50e.cdf-ms"
POQ 22 ends.
2017-11-30 08:39:09, Info                  CSI    00000069 [SR] Verify complete
2017-11-30 08:39:09, Info                  CSI    0000006a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:09, Info                  CSI    0000006b [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:10, Info                  CSI    0000006c Ignoring duplicate ownership for directory [ml:14{7},l:12{6}]"\??\C:" in component Microsoft-Windows-Client-Features-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:10, Info                  CSI    0000006d Repair results created:
POQ 23 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\c9d9604fae69d3018a0900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\c9d9604fae69d3018b0900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\c9d9604fae69d3018c0900007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    3: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\e5276f4fae69d3018d0900007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    4: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\3f8a714fae69d3018e0900007c017813.$$_inf_msdtc_0ef70686e1d9b30c.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_0ef70686e1d9b30c.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3f8a714fae69d3018f0900007c017813.$$_inf_msdtc_0415_5b1b8b3b4f36b9ce.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_0415_5b1b8b3b4f36b9ce.cdf-ms"
    6: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\77268e4fae69d301900900007c017813.$$_inf_bits_0ef6f148bde367d9.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0ef6f148bde367d9.cdf-ms"
    7: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\77268e4fae69d301910900007c017813.$$_inf_bits_0415_a03dbeef63e834fd.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0415_a03dbeef63e834fd.cdf-ms"
    8: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\39129a4fae69d301920900007c017813.$$_inf_bits_00
2017-11-30 08:39:10, Info                  CSI    00_a03dbf7d63e833bd.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0000_a03dbf7d63e833bd.cdf-ms"
    9: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\39129a4fae69d301930900007c017813.$$_branding_1728f5d8b15e5263.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_branding_1728f5d8b15e5263.cdf-ms"
    10: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\39129a4fae69d301940900007c017813.$$_branding_shellbrd_be1f632087fb0947.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_branding_shellbrd_be1f632087fb0947.cdf-ms"
POQ 23 ends.
2017-11-30 08:39:10, Info                  CSI    0000006e [SR] Verify complete
2017-11-30 08:39:10, Info                  CSI    0000006f [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:10, Info                  CSI    00000070 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:11, Info                  CSI    00000071 Repair results created:
POQ 24 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\810c1650ae69d301f90900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\db6e1850ae69d301fa0900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\db6e1850ae69d301fb0900007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\db6e1850ae69d301fc0900007c017813.$$_inf_msdtc_0ef70686e1d9b30c.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_0ef70686e1d9b30c.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\db6e1850ae69d301fd0900007c017813.$$_inf_msdtc_0000_5b1b81b54f36c82e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_0000_5b1b81b54f36c82e.cdf-ms"
    5: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\97e24c50ae69d301fe0900007c017813.$$_tracing_bca9e27848ac4cc0.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_tracing_bca9e27848ac4cc0.cdf-ms"
    6: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\59ce5850ae69d301ff0900007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    7: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3305b50ae69d301000a00007c017813.$$_system32_wdi_perftrack_e5904ddd3f58b556.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wdi_perftrack_e5904ddd3f58b556.cdf-ms"
    8: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3305b50ae69d301010a00007c017
2017-11-30 08:39:11, Info                  CSI    813.$$_system32_wdi_perftrack_traces_0af2b48360b94cec.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wdi_perftrack_traces_0af2b48360b94cec.cdf-ms"
    9: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d935d50ae69d301020a00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    10: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d935d50ae69d301030a00007c017813.program_files_dvd_maker_405775de8763ce75.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_405775de8763ce75.cdf-ms"
    11: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d935d50ae69d301040a00007c017813.program_files_dvd_maker_pl-pl_7148e68acc44ae3c.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_pl-pl_7148e68acc44ae3c.cdf-ms"
POQ 24 ends.
2017-11-30 08:39:11, Info                  CSI    00000072 [SR] Verify complete
2017-11-30 08:39:11, Info                  CSI    00000073 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:11, Info                  CSI    00000074 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:13, Info                  CSI    00000075 Repair results created:
POQ 25 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d29f650ae69d301690a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d29f650ae69d3016a0a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\9b50fd50ae69d3016b0a00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\e1132151ae69d3016c0a00007c017813.$$_resources_fbee56ab048ab239.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_resources_fbee56ab048ab239.cdf-ms"
    4: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b762351ae69d3016d0a00007c017813.$$_resources_ease_of_access_themes_e29108c7f81ea04c.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_resources_ease_of_access_themes_e29108c7f81ea04c.cdf-ms"
    5: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\65eb3851ae69d3016e0a00007c017813.$$_system32_codeintegrity_e9af9308cfc26dc2.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_codeintegrity_e9af9308cfc26dc2.cdf-ms"
    6: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4d3b51ae69d3016f0a00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    7: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4d3b51ae69d301700a00007c017813.program_files_dvd_maker_405775de8763ce75.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_405775de8763ce75.cdf-ms"
    8: Move File: Source = [l:252{
2017-11-30 08:39:13, Info                  CSI    126}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4d3b51ae69d301710a00007c017813.program_files_dvd_maker_shared_a54613779b918be2.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_shared_a54613779b918be2.cdf-ms"
    9: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\81394751ae69d301720a00007c017813.$$_system32_msdtc_trace_f33466dc5bf36670.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_msdtc_trace_f33466dc5bf36670.cdf-ms"
    10: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\43255351ae69d301730a00007c017813.$$_system32_com_066545e3d047e7c7.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_system32_com_066545e3d047e7c7.cdf-ms"
    11: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d875551ae69d301740a00007c017813.$$_servicing_fc2045b9046cc796.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_servicing_fc2045b9046cc796.cdf-ms"
    12: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d875551ae69d301750a00007c017813.$$_servicing_editions_596ea20ddafb9f7d.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_servicing_editions_596ea20ddafb9f7d.cdf-ms"
POQ 25 ends.
2017-11-30 08:39:13, Info                  CSI    00000076 [SR] Verify complete
2017-11-30 08:39:13, Info                  CSI    00000077 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:13, Info                  CSI    00000078 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:14, Info                  CSI    00000079 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pt-BR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pt-BR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ar-SA" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ar-SA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\el-GR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"el-GR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007c Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ko-KR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ko-KR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\da-DK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"da-DK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\et-EE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"et-EE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    0000007f Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\nl-NL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"nl-NL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    00000080 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sk-SK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sk-SK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    00000081 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pl-PL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    00000082 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\hr-HR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"hr-HR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:14, Info                  CSI    00000083 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\hu-HU" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"hu-HU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000084 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\es-ES" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"es-ES", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000085 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ro-RO" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ro-RO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000086 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\bg-BG" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"bg-BG", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000087 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\cs-CZ" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"cs-CZ", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000088 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sv-SE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sv-SE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000089 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\lv-LV" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"lv-LV", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\lt-LT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"lt-LT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\de-DE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"de-DE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008c Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\th-TH" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"th-TH", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\tr-TR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"tr-TR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\it-IT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"it-IT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    0000008f Ignoring duplicate ownership for directory [l:102{51}]"\??\C:\ProgramData\Microsoft\Crypto\DSS\MachineKeys" in component Microsoft-Windows-Crypto-keys, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000090 Ignoring duplicate ownership for directory [l:80{40}]"\??\C:\ProgramData\Microsoft\Crypto\Keys" in component Microsoft-Windows-Crypto-keys, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000091 Ignoring duplicate ownership for directory [l:102{51}]"\??\C:\ProgramData\Microsoft\Crypto\RSA\MachineKeys" in component Microsoft-Windows-Crypto-keys, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:15, Info                  CSI    00000092 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\fr-FR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"fr-FR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000093 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\fi-FI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"fi-FI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000094 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ja-JP" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ja-JP", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000095 Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\System32\sr-Latn-CS" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:20{10}]"sr-Latn-CS", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000096 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\he-IL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"he-IL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000097 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\uk-UA" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"uk-UA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000098 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sl-SI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sl-SI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    00000099 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\en-US" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    0000009a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\zh-CN" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"zh-CN", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    0000009b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\zh-TW" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"zh-TW", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:16, Info                  CSI    0000009c Repair results created:
POQ 26 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\61aab951ae69d301da0a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\61aab951ae69d301db0a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\6fd1c051ae69d301dc0a00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c933c351ae69d301dd0a00007c017813.$$_system32_pt-br_5783f3346581bed3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-br_5783f3346581bed3.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\31bdcc51ae69d301de0a00007c017813.$$_system32_ar-sa_3b02d130904371b4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ar-sa_3b02d130904371b4.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\9946d651ae69d301df0a00007c017813.$$_system32_el-gr_429cd0b684dc71bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_el-gr_429cd0b684dc71bd.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b594e451ae69d301e00a00007c017813.$$_system32_ko-kr_4e039de673c23e4a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ko-kr_4e039de673c23e4a.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\47930352ae69d301e10a00007c017813.$$_system32_da-dk_40b64d5e87b63595.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_da-dk_40b64d5e87b63595.cdf-ms"
    8: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames
2017-11-30 08:39:16, Info                  CSI    \af1c0d52ae69d301e20a00007c017813.$$_system32_et-ee_429cb6e884dc9948.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_et-ee_429cb6e884dc9948.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\71081952ae69d301e30a00007c017813.$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\33f42452ae69d301e40a00007c017813.$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9a43552ae69d301e50a00007c017813.$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b904152ae69d301e60a00007c017813.$$_system32_hr-hr_485036ac7c4f596f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hr-hr_485036ac7c4f596f.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3194b52ae69d301e70a00007c017813.$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3ba35452ae69d301e80a00007c017813.$$_system32_pt-pt_5783f7006581b92f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-pt_5783f7006581b92f.cdf-ms"
    15: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\fd8e6052ae69d301e90a00007c017813.$$_system32_es-es_429cd1a084dc7119.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_es-es_429cd1a084dc7119.cdf-ms"
    16: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf7a6c52
2017-11-30 08:39:16, Info                  CSI    ae69d301ea0a00007c017813.$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms"
    17: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\27047652ae69d301eb0a00007c017813.$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms"
    18: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e9ef8152ae69d301ec0a00007c017813.$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms"
    19: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\abdb8d52ae69d301ed0a00007c017813.$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms"
    20: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\13659752ae69d301ee0a00007c017813.$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms"
    21: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d550a352ae69d301ef0a00007c017813.$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3ddaac52ae69d301f00a00007c017813.$$_system32_lt-lt_4fea189870e886c7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lt-lt_4fea189870e886c7.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ffc5b852ae69d301f10a00007c017813.$$_system32_de-de_40b6416a87b647ef.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_de-de_40b6416a87b647ef.cdf-ms"
    24: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\674fc252ae69d301
2017-11-30 08:39:16, Info                  CSI    f20a00007c017813.$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\293bce52ae69d301f30a00007c017813.$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\91c4d752ae69d301f40a00007c017813.$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms"
    27: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\eb26da52ae69d301f50a00007c017813.programdata_microsoft_crypto_dss_machinekeys_43de8c451bf80cb4.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_dss_machinekeys_43de8c451bf80cb4.cdf-ms"
    28: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\eb26da52ae69d301f60a00007c017813.programdata_microsoft_crypto_keys_584b284368b25bef.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_keys_584b284368b25bef.cdf-ms"
    29: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\eb26da52ae69d301f70a00007c017813.programdata_microsoft_crypto_rsa_machinekeys_aa739417efae0d58.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_rsa_machinekeys_aa739417efae0d58.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\53b0e352ae69d301f80a00007c017813.$$_system32_fr-fr_448347788202c03b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_fr-fr_448347788202c03b.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\159cef52ae69d301f90a00007c017813.$$_system32_fi-fi_448337a68202d703.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syste
2017-11-30 08:39:16, Info                  CSI    m32_fi-fi_448337a68202d703.cdf-ms"
    32: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7d25f952ae69d301fa0a00007c017813.$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms"
    33: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\e5ae0253ae69d301fb0a00007c017813.$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\01fd1053ae69d301fc0a00007c017813.$$_system32_he-il_48502d1c7c4f6669.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_he-il_48502d1c7c4f6669.cdf-ms"
    35: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\69861a53ae69d301fd0a00007c017813.$$_system32_uk-ua_61042a3457416b73.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_uk-ua_61042a3457416b73.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b722653ae69d301fe0a00007c017813.$$_system32_nb-no_53b700d66b352886.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nb-no_53b700d66b352886.cdf-ms"
    37: Move File: Source = [l:206{103}]"\SystemRoot\WinSxS\Temp\PendingRenames\85d42853ae69d301ff0a00007c017813.$$_temp_401038c9a18c18c0.cdf-ms", Destination = [l:118{59}]"\SystemRoot\WinSxS\FileMaps\$$_temp_401038c9a18c18c0.cdf-ms"
    38: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\93fb2f53ae69d301000b00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    39: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd704553ae69d301010b00007c017813.$$_system32_sl-si_5d374a0c5cf4bbc8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sl-si_5d374a0c5cf4bbc8.cdf
2017-11-30 08:39:16, Info                  CSI    -ms"
    40: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f5c5153ae69d301020b00007c017813.$$_system32_en-us_429cd25484dc6f94.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_429cd25484dc6f94.cdf-ms"
    41: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e7e55a53ae69d301030b00007c017813.$$_system32_zh-cn_6a8499504900c466.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-cn_6a8499504900c466.cdf-ms"
    42: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9d16653ae69d301040b00007c017813.$$_system32_zh-hk_6a84939e4900ccf6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-hk_6a84939e4900ccf6.cdf-ms"
    43: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\115b7053ae69d301050b00007c017813.$$_system32_zh-tw_6a84aa664900aad6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-tw_6a84aa664900aad6.cdf-ms"
POQ 26 ends.
2017-11-30 08:39:16, Info                  CSI    0000009d [SR] Verify complete
2017-11-30 08:39:17, Info                  CSI    0000009e [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:17, Info                  CSI    0000009f [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:18, Info                  CSI    000000a0 Repair results created:
POQ 27 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\15c92054ae69d3016a0b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\15c92054ae69d3016b0b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\7d522a54ae69d3016c0b00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\d7b42c54ae69d3016d0b00007c017813.$$_system32_drivers_dc1b782427b5ee1b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_dc1b782427b5ee1b.cdf-ms"
    4: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\d7b42c54ae69d3016e0b00007c017813.$$_system32_drivers_umdf_a531b5dc588477d3.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_umdf_a531b5dc588477d3.cdf-ms"
    5: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\d7b42c54ae69d3016f0b00007c017813.$$_system32_logfiles_wudf_082845cc19e06817.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_logfiles_wudf_082845cc19e06817.cdf-ms"
    6: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\5b8c4454ae69d301700b00007c017813.$$_system32_dism_066548addf2fbd4b.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_dism_066548addf2fbd4b.cdf-ms"
    7: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\b5ee4654ae69d301710b00007c017813.$$_diagnostics_system_device_9d2d754600160183.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_device_9d2d754600160183.cdf-ms"
2017-11-30 08:39:18, Info                  CSI     = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\b5ee4654ae69d301720b00007c017813.$$_diagnostics_system_device_pl-pl_3c0bb80af1b8810a.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_device_pl-pl_3c0bb80af1b8810a.cdf-ms"
    9: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\77da5254ae69d301730b00007c017813.$$_system32_wdi_perftrack_e5904ddd3f58b556.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wdi_perftrack_e5904ddd3f58b556.cdf-ms"
    10: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\d13c5554ae69d301740b00007c017813.$$_diagnostics_system_devicecenter_0e1655bf357f4c22.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_devicecenter_0e1655bf357f4c22.cdf-ms"
    11: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\d13c5554ae69d301750b00007c017813.$$_diagnostics_system_devicecenter_pl-pl_63ad5e2e34f41861.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_devicecenter_pl-pl_63ad5e2e34f41861.cdf-ms"
    12: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\93286154ae69d301760b00007c017813.$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms"
    13: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\93286154ae69d301770b00007c017813.$$_system32_ime_shared_res_791e6438104a0cf8.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_shared_res_791e6438104a0cf8.cdf-ms"
POQ 27 ends.
2017-11-30 08:39:18, Info                  CSI    000000a1 [SR] Verify complete
2017-11-30 08:39:18, Info                  CSI    000000a2 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:18, Info                  CSI    000000a3 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:20, Info                  CSI    000000a4 Repair results created:
POQ 28 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab35f054ae69d301dc0b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab35f054ae69d301dd0b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab35f054ae69d301de0b00007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    3: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab35f054ae69d301df0b00007c017813.$$_ime_imejp10_dicts_281006c600450618.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imejp10_dicts_281006c600450618.cdf-ms"
    4: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab35f054ae69d301e00b00007c017813.$$_ime_imejp10_help_280ffde19e779392.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imejp10_help_280ffde19e779392.cdf-ms"
    5: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\13bff954ae69d301e10b00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    6: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\6d21fc54ae69d301e20b00007c017813.$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms"
    7: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\6d21fc54ae69d301e30b00007c017813.$$_system32_ime_imejp10_aead4918eed09977.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imejp10_aead4918eed09977.cdf-ms"
    8: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\Pend
2017-11-30 08:39:20, Info                  CSI    ingRenames\6d21fc54ae69d301e40b00007c017813.$$_system32_ime_imejp10_applets_bad04da37647b46c.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imejp10_applets_bad04da37647b46c.cdf-ms"
    9: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\97961155ae69d301e50b00007c017813.$$_system32_dism_066548addf2fbd4b.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_dism_066548addf2fbd4b.cdf-ms"
    10: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\97961155ae69d301e60b00007c017813.$$_system32_dism_pl-pl_04c2d0b670843030.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_dism_pl-pl_04c2d0b670843030.cdf-ms"
POQ 28 ends.
2017-11-30 08:39:20, Info                  CSI    000000a5 [SR] Verify complete
2017-11-30 08:39:20, Info                  CSI    000000a6 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:20, Info                  CSI    000000a7 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:21, Info                  CSI    000000a8 Repair results created:
POQ 29 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\b1daf855ae69d3014b0c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\b1daf855ae69d3014c0c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\0b3dfb55ae69d3014d0c00007c017813.$$_diagnostics_system_device_9d2d754600160183.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_device_9d2d754600160183.cdf-ms"
    3: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\659ffd55ae69d3014e0c00007c017813.$$_diagnostics_system_devicecenter_0e1655bf357f4c22.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_devicecenter_0e1655bf357f4c22.cdf-ms"
    4: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{456390a1-55f7-353b-b1a6-321233838362}", Type = REG_SZ (1), Data = {l:110 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00640068006300700063007300760063002e0064006c006c002c00440068006300700043006c00690065006e0074005f00470065006e006500720061006c0069007a0065000000}
POQ 29 ends.
2017-11-30 08:39:21, Info                  CSI    000000a9 [SR] Verify complete
2017-11-30 08:39:21, Info                  CSI    000000aa [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:21, Info                  CSI    000000ab [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:22, Info                  CSI    000000ac Repair results created:
POQ 30 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\4ff6f756ae69d301b30c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\a958fa56ae69d301b40c00007c017813.programdata_microsoft_windows_devicemetadatastore_en-us_cc94fe8746890b55.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_devicemetadatastore_en-us_cc94fe8746890b55.cdf-ms"
    2: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\a958fa56ae69d301b50c00007c017813.programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9__0ce7c057892d5774.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9__0ce7c057892d5774.cdf-ms"
    3: Move File: Source = [l:350{175}]"\SystemRoot\WinSxS\Temp\PendingRenames\a958fa56ae69d301b60c00007c017813.programdata_microsoft_device_stage_device_8702d817-5aad-4674-9ef3-4d3decd87120__8740ea4a07ab72cd.cdf-ms", Destination = [l:262{131}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_device_8702d817-5aad-4674-9ef3-4d3decd87120__8740ea4a07ab72cd.cdf-ms"
    4: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\11e20357ae69d301b70c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    5: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\11e20357ae69d301b80c00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    6: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\11e20357ae69d301b90c00007c017813.$$_ehome_mcx_022df17cf4546600.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_mcx_022df17cf4546600.cdf-ms"
2017-11-30 08:39:22, Info                  CSI    = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\11e20357ae69d301ba0c00007c017813.$$_ehome_mcx_x02_7afb1a3b86c42e5e.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_mcx_x02_7afb1a3b86c42e5e.cdf-ms"
POQ 30 ends.
2017-11-30 08:39:22, Info                  CSI    000000ad [SR] Verify complete
2017-11-30 08:39:23, Info                  CSI    000000ae [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:23, Info                  CSI    000000af [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:24, Info                  CSI    000000b0 Repair results created:
POQ 31 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d3011f0d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d301200d00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d301210d00007c017813.program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms"
    3: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d301220d00007c017813.program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms"
    4: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d301230d00007c017813.program_files_windows_sidebar_gadgets_mediacenter.gadget_f08b590d17819d36.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_mediacenter.gadget_f08b590d17819d36.cdf-ms"
    5: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d8e7157ae69d301240d00007c017813.program_files_windows_sidebar_gadgets_mediacenter.gadget_pl-pl_0d4dd7e7810869fb.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_mediacenter.gadget_pl-pl_0d4dd7e7810869fb.cdf-ms"
    6: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\a5177b57ae69d301250d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    7: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\a5177b57ae69d30
2017-11-30 08:39:24, Info                  CSI    1260d00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    8: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff797d57ae69d301270d00007c017813.$$_inf_esent_0ef70656e1d1b1ac.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_esent_0ef70656e1d1b1ac.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff797d57ae69d301280d00007c017813.$$_inf_esent_0415_5aeb7f6b4bde632e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_esent_0415_5aeb7f6b4bde632e.cdf-ms"
    10: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\0da18457ae69d301290d00007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    11: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\0da18457ae69d3012a0d00007c017813.$$_schemas_eapmethods_2935fdc1307d3ad6.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_eapmethods_2935fdc1307d3ad6.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\83519557ae69d3012b0d00007c017813.$$_inf_esent_0000_5aeb75e54bde718e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_esent_0000_5aeb75e54bde718e.cdf-ms"
    13: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\ebda9e57ae69d3012c0d00007c017813.program_files_windows_sidebar_gadgets_mediacenter.gadget_js_8dda2a54ef707137.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_mediacenter.gadget_js_8dda2a54ef707137.cdf-ms"
    14: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\ebda9e57ae69d3012d0d00007c017813.program_files_windows_sidebar_gadgets_mediacenter.gadget_images_15a18af15dc71ee0.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_mediacenter.gadge
2017-11-30 08:39:24, Info                  CSI    t_images_15a18af15dc71ee0.cdf-ms"
    15: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\ebda9e57ae69d3012e0d00007c017813.program_files_windows_sidebar_gadgets_mediacenter.gadget_css_8dda2b51661abce9.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_mediacenter.gadget_css_8dda2b51661abce9.cdf-ms"
    16: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\453da157ae69d3012f0d00007c017813.$$_schemas_eaphost_52e2de002c0b1796.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_eaphost_52e2de002c0b1796.cdf-ms"
    17: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\5364a857ae69d301300d00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    18: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\5364a857ae69d301310d00007c017813.$$_ehome_mediarenderer_923295b945ee30c7.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_mediarenderer_923295b945ee30c7.cdf-ms"
POQ 31 ends.
2017-11-30 08:39:24, Info                  CSI    000000b1 [SR] Verify complete
2017-11-30 08:39:24, Info                  CSI    000000b2 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:24, Info                  CSI    000000b3 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:26, Info                  CSI    000000b4 Repair results created:
POQ 32 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\43337a58ae69d301960d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\43337a58ae69d301970d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\43337a58ae69d301980d00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    3: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\43337a58ae69d301990d00007c017813.$$_ehome_pl-pl_1882b78f368525f9.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_pl-pl_1882b78f368525f9.cdf-ms"
    4: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\291cc458ae69d3019a0d00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    5: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\3743cb58ae69d3019b0d00007c017813.users_public_recorded_tv_a6d3315b447834ed.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\users_public_recorded_tv_a6d3315b447834ed.cdf-ms"
    6: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\91a5cd58ae69d3019c0d00007c017813.users_public_recorded_tv_sample_media_273d5f336c167723.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\users_public_recorded_tv_sample_media_273d5f336c167723.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d190259ae69d3019d0d00007c017813.$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms"
    8: Move File: Source = [l:246{123}]"\SystemR
2017-11-30 08:39:26, Info                  CSI    oot\WinSxS\Temp\PendingRenames\a77b0459ae69d3019e0d00007c017813.$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms"
    9: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\a77b0459ae69d3019f0d00007c017813.$$_system32_tasks_microsoft_windows_media_center_ad67db1bbb2dd336.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_windows_media_center_ad67db1bbb2dd336.cdf-ms"
    10: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\a77b0459ae69d301a00d00007c017813.$$_system32_tasks_microsoft_windows_media_center_extender_02bff096ccf79441.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_windows_media_center_extender_02bff096ccf79441.cdf-ms"
    11: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\a77b0459ae69d301a10d00007c017813.programdata_microsoft_ehome_72ce881aee6c0ff2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_ehome_72ce881aee6c0ff2.cdf-ms"
    12: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\a77b0459ae69d301a20d00007c017813.programdata_microsoft_ehome_logs_c9da3df2b39c6e43.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_ehome_logs_c9da3df2b39c6e43.cdf-ms"
    13: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\a77b0459ae69d301a30d00007c017813.users_default_appdata_roaming_media_center_programs_b8fc97cb3886dd3f.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\users_default_appdata_roaming_media_center_programs_b8fc97cb3886dd3f.cdf-ms"
    14: Set File Information: File = [l:116{58}]"\??\C:\Users\Default\AppData\Roaming\Media Center Programs", Attributes = 00000080
    15: Set File Information: File = [l:68{34}]"\??\C:\ProgramData\Microsoft\eHome", Attributes = 00000080
    16: Set File Information: File = [l:78{3
2017-11-30 08:39:26, Info                  CSI    9}]"\??\C:\ProgramData\Microsoft\eHome\logs", Attributes = 00000080
    17: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\397a2359ae69d301a40d00007c017813.programdata_microsoft_windows_power_efficiency_diagnostics_acddb9fca5769337.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_power_efficiency_diagnostics_acddb9fca5769337.cdf-ms"
    18: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{35cf872f-4be2-7ee8-2062-3fd9d1266740}", Type = REG_SZ (1), Data = {l:58 b:7700650072002e0064006c006c002c005700650072005300790073007000720065007000470065006e006500720061006c0069007a0065000000}
    19: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{35cf872f-4be2-7ee8-71c7-f5472ac291e2}", Type = REG_SZ (1), Data = {l:58 b:7700650072002e0064006c006c002c0057006500720053007900730070007200650070005300700065006300690061006c0069007a0065000000}
    20: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{35cf872f-4be2-7ee8-ac99-fda4b6fe1603}", Type = REG_SZ (1), Data = {l:52 b:7700650072002e0064006c006c002c00570065007200530079007300700072006500700043006c00650061006e00750070000000}
    21: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{8a2650e9-70de-392f-b444-cecbac9864f2}", Type = REG_SZ (1), Data = {l:116 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073007900730070007200650070004d00430045002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a0065005f004d00430045000000}
    22: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{2978b9c5-6189-3aea-c4d8-ce732d
2017-11-30 08:39:26, Info                  CSI    dcc48e}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0077006500760074006100700069002e0064006c006c002c0045007600740049006e007400530079007300700072006500700043006c00650061006e00750070000000}
POQ 32 ends.
2017-11-30 08:39:26, Info                  CSI    000000b5 [SR] Verify complete
2017-11-30 08:39:26, Info                  CSI    000000b6 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:26, Info                  CSI    000000b7 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:28, Info                  CSI    000000b8 Ignoring duplicate ownership for directory [l:28{14}]"\??\C:\Windows" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000b9 Ignoring duplicate ownership for directory [l:56{28}]"\??\C:\Windows\Microsoft.NET" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000ba Ignoring duplicate ownership for directory [l:76{38}]"\??\C:\Windows\Microsoft.NET\Framework" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000bb Ignoring duplicate ownership for directory [l:98{49}]"\??\C:\Windows\Microsoft.NET\Framework\v2.0.50727" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000bc Ignoring duplicate ownership for directory [l:112{56}]"\??\C:\Windows\Microsoft.NET\Framework\v2.0.50727\CONFIG" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000bd Ignoring duplicate ownership for directory [l:96{48}]"\??\C:\Windows\Microsoft.NET\Framework\v1.0.3705" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000be Ignoring duplicate ownership for directory [l:38{19}]"\??\C:\Windows\temp" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000bf Ignoring duplicate ownership for directory [l:40{20}]"\??\C:\Windows\media" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c0 Ignoring duplicate ownership for directory [l:52{26}]"\??\C:\Windows\media\Delta" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c1 Ignoring duplicate ownership for directory [l:54{27}]"\??\C:\Windows\media\Sonata" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c2 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\media\Afternoon" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c3 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\media\Landscape" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c4 Ignoring duplicate ownership for directory [l:54{27}]"\??\C:\Windows\media\Quirky" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c5 Ignoring duplicate ownership for directory [l:56{28}]"\??\C:\Windows\media\Savanna" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c6 Ignoring duplicate ownership for directory [l:54{27}]"\??\C:\Windows\media\Garden" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c7 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\media\Festival" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c8 Ignoring duplicate ownership for directory [l:50{25}]"\??\C:\Windows\media\Raga" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000c9 Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\media\Calligraphy" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000ca Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\media\Characters" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000cb Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\media\Cityscape" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000cc Ignoring duplicate ownership for directory [l:36{18}]"\??\C:\Windows\inf" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000cd Ignoring duplicate ownership for directory [l:48{24}]"\??\C:\Windows\L2Schemas" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000ce Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\PolicyDefinitions" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000cf Ignoring duplicate ownership for directory [l:42{21}]"\??\C:\Windows\system" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d0 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\setup" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d1 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\System32\drivers" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d2 Ignoring duplicate ownership for directory [l:70{35}]"\??\C:\Windows\System32\drivers\etc" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d3 Ignoring duplicate ownership for directory [l:40{20}]"\??\C:\Windows\fonts" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d4 Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\apppatch" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d5 Ignoring duplicate ownership for directory [l:36{18}]"\??\C:\Windows\Web" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:28, Info                  CSI    000000d6 Ignoring duplicate ownership for directory [l:48{24}]"\??\C:\Windows\resources" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:29, Info                  CSI    000000d7 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:29, Info                  CSI    000000d8 Ignoring duplicate ownership for directory [l:120{60}]"\??\C:\Program Files\Common Files\microsoft shared\ink\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:29, Info                  CSI    000000d9 Repair results created:
POQ 33 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d301090e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010a0e00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010b0e00007c017813.program_files_internet_explorer_a421d1bfaf856e2b.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\program_files_internet_explorer_a421d1bfaf856e2b.cdf-ms"
    3: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010c0e00007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    4: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010d0e00007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    5: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010e0e00007c017813.program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms"
    6: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d3010f0e00007c017813.program_files_common_files_microsoft_shared_stationery_3f6c21eb4ac66a56.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_stationery_3f6c21eb4ac66a56.cdf-ms"
2017-11-30 08:39:29, Info                  CSI    :258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\39a7545aae69d301100e00007c017813.program_files_common_files_system_b13078daf1286f60.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_b13078daf1286f60.cdf-ms"
    8: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301110e00007c017813.program_files_common_files_system_ado_149a784bc852a2c0.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_ado_149a784bc852a2c0.cdf-ms"
    9: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301120e00007c017813.program_files_common_files_system_msadc_48cda3763ecb3874.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_msadc_48cda3763ecb3874.cdf-ms"
    10: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301130e00007c017813.program_files_common_files_system_ole_db_48d1b11cd4e5cabe.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_ole_db_48d1b11cd4e5cabe.cdf-ms"
    11: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301140e00007c017813.program_files_windows_nt_6101456faac5015c.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_6101456faac5015c.cdf-ms"
    12: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301150e00007c017813.program_files_windows_nt_tabletextservice_9475b2de2d92bc74.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_tabletextservice_9475b2de2d92bc74.cdf-ms"
    13: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301160e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    14: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301170e00007c017813.$$_microsoft.net_3296b36
2017-11-30 08:39:29, Info                  CSI    dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    15: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\9309575aae69d301180e00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    16: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d301190e00007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    17: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011a0e00007c017813.$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms"
    18: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011b0e00007c017813.$$_microsoft.net_framework_v1.0.3705_b19cf3207984c497.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v1.0.3705_b19cf3207984c497.cdf-ms"
    19: Move File: Source = [l:206{103}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011c0e00007c017813.$$_temp_401038c9a18c18c0.cdf-ms", Destination = [l:118{59}]"\SystemRoot\WinSxS\FileMaps\$$_temp_401038c9a18c18c0.cdf-ms"
    20: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011d0e00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    21: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011e0e00007c017813.$$_media_delta_0f36d7d9b4f7293c.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_media_delta_0f36d7d9b4f7293c.cdf-ms"
    22: Move File: Source = [l:222{111}]"
2017-11-30 08:39:29, Info                  CSI    \SystemRoot\WinSxS\Temp\PendingRenames\ed6b595aae69d3011f0e00007c017813.$$_media_sonata_6b55eb3f91aab49e.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_sonata_6b55eb3f91aab49e.cdf-ms"
    23: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301200e00007c017813.$$_media_afternoon_ae5d080a6a887942.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_afternoon_ae5d080a6a887942.cdf-ms"
    24: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301210e00007c017813.$$_media_landscape_e9488ca8249a3acf.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_landscape_e9488ca8249a3acf.cdf-ms"
    25: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301220e00007c017813.$$_media_quirky_6baa21a590d24b57.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_quirky_6baa21a590d24b57.cdf-ms"
    26: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301230e00007c017813.$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms"
    27: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301240e00007c017813.$$_media_garden_6cea56938e5bd6b1.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_garden_6cea56938e5bd6b1.cdf-ms"
    28: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301250e00007c017813.$$_media_festival_d2aa354bee3f11cc.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_media_festival_d2aa354bee3f11cc.cdf-ms"
    29: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\47ce5b5aae69d301260e00007c017813.$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms"
    30: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\Pe
2017-11-30 08:39:29, Info                  CSI    ndingRenames\47ce5b5aae69d301270e00007c017813.$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms"
    31: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d301280e00007c017813.$$_media_characters_8ee06d90f7dead3a.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_media_characters_8ee06d90f7dead3a.cdf-ms"
    32: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d301290e00007c017813.$$_media_cityscape_b0cbff7c81824cc5.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_cityscape_b0cbff7c81824cc5.cdf-ms"
    33: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d3012a0e00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    34: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d3012b0e00007c017813.$$_l2schemas_d7bb5637381de58c.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_l2schemas_d7bb5637381de58c.cdf-ms"
    35: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d3012c0e00007c017813.$$_policydefinitions_89130cdfc4d9c27c.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_policydefinitions_89130cdfc4d9c27c.cdf-ms"
    36: Move File: Source = [l:210{105}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1305e5aae69d3012d0e00007c017813.$$_system_4c3aa2308f9f8f41.cdf-ms", Destination = [l:122{61}]"\SystemRoot\WinSxS\FileMaps\$$_system_4c3aa2308f9f8f41.cdf-ms"
    37: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\09ba675aae69d3012e0e00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    38: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d3012f0e00007c017813.$$_s
2017-11-30 08:39:29, Info                  CSI    ystem32_oobe_06655c95df2fa06f.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_oobe_06655c95df2fa06f.cdf-ms"
    39: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d301300e00007c017813.$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms"
    40: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d301310e00007c017813.$$_system32_inetsrv_e6240a381854fe3d.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_e6240a381854fe3d.cdf-ms"
    41: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d301320e00007c017813.$$_system32_setup_5d3758a05cf4a445.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_setup_5d3758a05cf4a445.cdf-ms"
    42: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d301330e00007c017813.$$_system32_migration_927a21df1acd7c18.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_927a21df1acd7c18.cdf-ms"
    43: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\631c6a5aae69d301340e00007c017813.$$_system32_drivers_dc1b782427b5ee1b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_dc1b782427b5ee1b.cdf-ms"
    44: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd7e6c5aae69d301350e00007c017813.$$_system32_drivers_etc_a531967eb3dfecbd.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_etc_a531967eb3dfecbd.cdf-ms"
    45: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd7e6c5aae69d301360e00007c017813.$$_system32_wbem_06656d9fdf2f8577.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wbem_06656d9fdf2f8577.cdf-ms"
    46: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd7e6c5aae69d301370
2017-11-30 08:39:29, Info                  CSI    e00007c017813.$$_system32_wbem_tmf_026f0fb07227ea72.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wbem_tmf_026f0fb07227ea72.cdf-ms"
    47: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd7e6c5aae69d301380e00007c017813.$$_system32_com_066545e3d047e7c7.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_system32_com_066545e3d047e7c7.cdf-ms"
    48: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd7e6c5aae69d301390e00007c017813.$$_fonts_40104ba9a1d20dac.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_fonts_40104ba9a1d20dac.cdf-ms"
    49: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\17e16e5aae69d3013a0e00007c017813.$$_apppatch_1143992cbbbebcab.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_1143992cbbbebcab.cdf-ms"
    50: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\17e16e5aae69d3013b0e00007c017813.$$_web_3f580d25a4c8e0a0.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_web_3f580d25a4c8e0a0.cdf-ms"
    51: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\17e16e5aae69d3013c0e00007c017813.$$_resources_fbee56ab048ab239.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_resources_fbee56ab048ab239.cdf-ms"
    52: Set File Information: File = [l:40{20}]"\??\C:\Program Files", Attributes = 00000080
    53: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\6bcb995aae69d3013d0e00007c017813.$$_system32_en_9da4492827ac64e5.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en_9da4492827ac64e5.cdf-ms"
    54: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\8950005bae69d3013e0e00007c017813.$$_digitallocker_en-us_ff53d45933582902.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_digitallocker_en-us_ff53d45933582902.cdf-ms"
    55: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\Pend
2017-11-30 08:39:29, Info                  CSI    ingRenames\8950005bae69d3013f0e00007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    56: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\8950005bae69d301400e00007c017813.$$_ime_en-us_0d349188e45a5789.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_ime_en-us_0d349188e45a5789.cdf-ms"
    57: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b2025bae69d301410e00007c017813.$$_inf_en-us_0ef70046e1d1b811.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_en-us_0ef70046e1d1b811.cdf-ms"
    58: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b2025bae69d301420e00007c017813.$$_inf_remoteaccess_110554180baafc8b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_110554180baafc8b.cdf-ms"
    59: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b2025bae69d301430e00007c017813.$$_inf_remoteaccess_0409_86bc979ae65d5e96.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_0409_86bc979ae65d5e96.cdf-ms"
    60: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b2025bae69d301440e00007c017813.$$_en-us_40104e69a1d105cc.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_en-us_40104e69a1d105cc.cdf-ms"
    61: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d15055bae69d301450e00007c017813.$$_policydefinitions_en-us_3b1c5b998da0d4ae.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_policydefinitions_en-us_3b1c5b998da0d4ae.cdf-ms"
    62: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae69d301460e00007c017813.$$_system32_oobe_en-us_e44fe14df02b3595.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_oobe_en-us_e44fe14df02b3595.cdf-ms"
    63: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae6
2017-11-30 08:39:29, Info                  CSI    9d301470e00007c017813.$$_system32_sysprep_f7b45b8dfed1b768.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sysprep_f7b45b8dfed1b768.cdf-ms"
    64: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae69d301480e00007c017813.$$_system32_sysprep_en-us_ed807a30a752749a.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sysprep_en-us_ed807a30a752749a.cdf-ms"
    65: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae69d301490e00007c017813.$$_system32_0409_06652563df2ff0c1.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_0409_06652563df2ff0c1.cdf-ms"
    66: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae69d3014a0e00007c017813.$$_system32_setup_en-us_afa35959583f5dbd.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_setup_en-us_afa35959583f5dbd.cdf-ms"
    67: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\a59e0e5bae69d3014b0e00007c017813.$$_system32_migration_en-us_815d10948a0810a2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_en-us_815d10948a0810a2.cdf-ms"
    68: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d3014c0e00007c017813.$$_system32_en-us_429cd25484dc6f94.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_429cd25484dc6f94.cdf-ms"
    69: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d3014d0e00007c017813.$$_system32_en-us_licenses_205e682c4ad0fe50.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_licenses_205e682c4ad0fe50.cdf-ms"
    70: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d3014e0e00007c017813.$$_system32_drivers_en-us_4bb913fc5eb96bcf.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_en-us_4bb913fc5eb96bcf.cdf-ms"
    71: Move Fi
2017-11-30 08:39:29, Info                  CSI    le: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d3014f0e00007c017813.$$_system32_drivers_umdf_a531b5dc588477d3.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_umdf_a531b5dc588477d3.cdf-ms"
    72: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d301500e00007c017813.$$_system32_drivers_umdf_en-us_b8ba9f5b7f1c3933.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_umdf_en-us_b8ba9f5b7f1c3933.cdf-ms"
    73: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d301510e00007c017813.$$_system32_mui_dispspec_d93de566344a36d0.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_system32_mui_dispspec_d93de566344a36d0.cdf-ms"
    74: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\ff00115bae69d301520e00007c017813.$$_system32_mui_0409_ecc96e0e9498d62e.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_system32_mui_0409_ecc96e0e9498d62e.cdf-ms"
    75: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\5963135bae69d301530e00007c017813.$$_system32_wbem_en-us_4555b1beb1c13883.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wbem_en-us_4555b1beb1c13883.cdf-ms"
    76: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\5963135bae69d301540e00007c017813.$$_system32_com_en-us_4019834316e68b9b.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_com_en-us_4019834316e68b9b.cdf-ms"
    77: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\5963135bae69d301550e00007c017813.$$_resources_themes_4d0d4910e83c2273.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_4d0d4910e83c2273.cdf-ms"
    78: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\5963135bae69d301560e00007c017813.$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms", Destination = [l:152{76}]"\Syste
2017-11-30 08:39:29, Info                  CSI    mRoot\WinSxS\FileMaps\$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms"
    79: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d301570e00007c017813.$$_resources_themes_aero_en-us_ab16867f204414fa.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_en-us_ab16867f204414fa.cdf-ms"
    80: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d301580e00007c017813.$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms"
    81: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d301590e00007c017813.$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms"
    82: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d3015a0e00007c017813.$$_resources_themes_aero_shell_normalcolor_en-us_8f1a9ecd4c3325e8.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_normalcolor_en-us_8f1a9ecd4c3325e8.cdf-ms"
    83: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d3015b0e00007c017813.$$_help_mui_0409_c7942094fabea651.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_help_mui_0409_c7942094fabea651.cdf-ms"
    84: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d3015c0e00007c017813.$$_apppatch_en-us_098dc872781aebb9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_en-us_098dc872781aebb9.cdf-ms"
    85: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3c5155bae69d3015d0e00007c017813.program_files_internet_explorer_en-us_2650c83f8a48b821.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_internet_explorer_en-us_2650c83f8a48b
2017-11-30 08:39:29, Info                  CSI    821.cdf-ms"
    86: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d3015e0e00007c017813.program_files_common_files_microsoft_shared_ink_en-us_8a16130a1a0cde0c.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_en-us_8a16130a1a0cde0c.cdf-ms"
    87: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d3015f0e00007c017813.program_files_common_files_microsoft_shared_triedit_en-us_59ae2daa07429081.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_triedit_en-us_59ae2daa07429081.cdf-ms"
    88: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d301600e00007c017813.program_files_common_files_microsoft_shared_msinfo_817ad0c7c1c8e490.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_msinfo_817ad0c7c1c8e490.cdf-ms"
    89: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d301610e00007c017813.program_files_common_files_microsoft_shared_msinfo_en-us_98319174bb92bc08.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_msinfo_en-us_98319174bb92bc08.cdf-ms"
    90: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d301620e00007c017813.program_files_common_files_microsoft_shared_textconv_dfb016a4185c8725.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_textconv_dfb016a4185c8725.cdf-ms"
    91: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d28185bae69d301630e00007c017813.program_files_common_files_microsoft_shared_textconv_en-us_c7ff7b7c6290f6ab.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_textconv_en-us_c7ff7b7c6290f6ab.cdf-ms"
    92: Move File: Source = [l:282{141}]"\SystemRoo
2017-11-30 08:39:29, Info                  CSI    t\WinSxS\Temp\PendingRenames\678a1a5bae69d301640e00007c017813.program_files_common_files_system_msadc_en-us_58bb034fa66b57cc.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_msadc_en-us_58bb034fa66b57cc.cdf-ms"
    93: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\678a1a5bae69d301650e00007c017813.program_files_common_files_system_ado_en-us_9c12689ac1360dc2.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_ado_en-us_9c12689ac1360dc2.cdf-ms"
    94: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\678a1a5bae69d301660e00007c017813.program_files_common_files_system_en-us_48bd774a3f1387ec.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_en-us_48bd774a3f1387ec.cdf-ms"
    95: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\678a1a5bae69d301670e00007c017813.program_files_common_files_system_ole_db_en-us_5ff73071fce05070.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_ole_db_en-us_5ff73071fce05070.cdf-ms"
    96: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\c1ec1c5bae69d301680e00007c017813.program_files_windows_nt_tabletextservice_en-us_0e46adde4b3af550.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_tabletextservice_en-us_0e46adde4b3af550.cdf-ms"
    97: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\c1ec1c5bae69d301690e00007c017813.program_files_windows_nt_accessories_156d2b9b22040474.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_accessories_156d2b9b22040474.cdf-ms"
    98: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\c1ec1c5bae69d3016a0e00007c017813.program_files_windows_nt_accessories_en-us_4cfa7c92c2470350.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_
2017-11-30 08:39:29, Info                  CSI    accessories_en-us_4cfa7c92c2470350.cdf-ms"
POQ 33 ends.
2017-11-30 08:39:29, Info                  CSI    000000da [SR] Verify complete
2017-11-30 08:39:29, Info                  CSI    000000db [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:29, Info                  CSI    000000dc [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:31, Info                  CSI    000000dd Repair results created:
POQ 34 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\13cd205cae69d301cf0e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\13cd205cae69d301d00e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\21f4275cae69d301d10e00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\7b562a5cae69d301d20e00007c017813.programdata_microsoft_windows_nt_msscan_549c401cd5c756f4.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msscan_549c401cd5c756f4.cdf-ms"
    4: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\7b562a5cae69d301d30e00007c017813.programdata_microsoft_windows_nt_msfax_common_coverpages_642a277e0ccb775c.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msfax_common_coverpages_642a277e0ccb775c.cdf-ms"
    5: Set File Information: File = [l:126{63}]"\??\C:\ProgramData\Microsoft\Windows NT\MSFax\Common Coverpages", Attributes = 00000080
    6: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3df335cae69d301d40e00007c017813.programdata_microsoft_windows_nt_msfax_common_coverpages_pl-pl_ed39cbeb8776ad61.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msfax_common_coverpages_pl-pl_ed39cbeb8776ad61.cdf-ms"
    7: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3df335cae69d301d50e00007c017813.programdata_microsoft_windows_nt_msfax_virtualinbox_pl-pl_b1457358d98e3d60.cdf-ms", Destination = [l:218{109}]"\SystemRoot\
2017-11-30 08:39:31, Info                  CSI    WinSxS\FileMaps\programdata_microsoft_windows_nt_msfax_virtualinbox_pl-pl_b1457358d98e3d60.cdf-ms"
POQ 34 ends.
2017-11-30 08:39:31, Info                  CSI    000000de [SR] Verify complete
2017-11-30 08:39:32, Info                  CSI    000000df [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:32, Info                  CSI    000000e0 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:37, Info                  CSI    000000e1 Repair results created:
POQ 35 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013a0f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013b0f00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013c0f00007c017813.program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms"
    3: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013d0f00007c017813.program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms"
    4: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013e0f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_b054eca6667f3063.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_calendar.gadget_b054eca6667f3063.cdf-ms"
    5: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d3013f0f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_pl-pl_e8c010f296fe42b8.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_calendar.gadget_pl-pl_e8c010f296fe42b8.cdf-ms"
    6: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d301400f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_pl-pl_js_467313adbebebc97.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_
2017-11-30 08:39:37, Info                  CSI    calendar.gadget_pl-pl_js_467313adbebebc97.cdf-ms"
    7: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3db365eae69d301410f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_pl-pl_css_58fed03d6b49c431.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_calendar.gadget_pl-pl_css_58fed03d6b49c431.cdf-ms"
    8: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\87a03b5eae69d301420f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_1d53bb9c29c0aa6d.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_1d53bb9c29c0aa6d.cdf-ms"
    9: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\87a03b5eae69d301430f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_images_db83d22ffb6579d1.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_images_db83d22ffb6579d1.cdf-ms"
    10: Move File: Source = [l:336{168}]"\SystemRoot\WinSxS\Temp\PendingRenames\87a03b5eae69d301440f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_images_in_sidebar_845277d664af085f.cdf-ms", Destination = [l:248{124}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_images_in_sidebar_845277d664af085f.cdf-ms"
    11: Move File: Source = [l:336{168}]"\SystemRoot\WinSxS\Temp\PendingRenames\87a03b5eae69d301450f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_images_on_desktop_8c4fbdc6458a98d1.cdf-ms", Destination = [l:248{124}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_images_on_desktop_8c4fbdc6458a98d1.cdf-ms"
    12: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d76725eae69d301460f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_964bdce27d2d6734.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMap
2017-11-30 08:39:37, Info                  CSI    s\program_files_windows_sidebar_gadgets_currency.gadget_964bdce27d2d6734.cdf-ms"
    13: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d76725eae69d301470f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_8198f5a51feee8d5.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_8198f5a51feee8d5.cdf-ms"
    14: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d76725eae69d301480f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_js_910182b091d3e81c.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_js_910182b091d3e81c.cdf-ms"
    15: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d76725eae69d301490f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_css_db0d16e7c49fa554.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_currency.gadget_pl-pl_css_db0d16e7c49fa554.cdf-ms"
    16: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\c922e05eae69d3014a0f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_85cde96256fb59df.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_clock.gadget_85cde96256fb59df.cdf-ms"
    17: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\c922e05eae69d3014b0f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_pl-pl_b92190e88e838cf8.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_clock.gadget_pl-pl_b92190e88e838cf8.cdf-ms"
    18: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\c922e05eae69d3014c0f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_pl-pl_js_22b9ee43c6e3a843.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_
2017-11-30 08:39:37, Info                  CSI    sidebar_gadgets_clock.gadget_pl-pl_js_22b9ee43c6e3a843.cdf-ms"
    19: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\c922e05eae69d3014d0f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_pl-pl_css_22b9ef3f9f56bda7.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_clock.gadget_pl-pl_css_22b9ef3f9f56bda7.cdf-ms"
    20: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\33e3415fae69d3014e0f00007c017813.program_files_windows_sidebar_gadgets_rssfeeds.gadget_22ec6b16cd2d39ce.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_22ec6b16cd2d39ce.cdf-ms"
    21: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d45445fae69d3014f0f00007c017813.program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_4219730020858fbd.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_4219730020858fbd.cdf-ms"
    22: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d45445fae69d301500f00007c017813.program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_js_ef8623d59d0b7902.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_js_ef8623d59d0b7902.cdf-ms"
    23: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d45445fae69d301510f00007c017813.program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_css_b96645c6909ab86c.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_css_b96645c6909ab86c.cdf-ms"
    24: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\d308685fae69d301520f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_pl-pl_23311b2c0fe88c52.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sid
2017-11-30 08:39:37, Info                  CSI    ebar_gadgets_slideshow.gadget_pl-pl_23311b2c0fe88c52.cdf-ms"
    25: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\d308685fae69d301530f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_pl-pl_js_c662d7e16aa9e933.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_pl-pl_js_c662d7e16aa9e933.cdf-ms"
    26: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\d308685fae69d301540f00007c017813.program_files_windows_sidebar_gadgets_slideshow.gadget_pl-pl_css_c662d8dd768b94cd.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_slideshow.gadget_pl-pl_css_c662d8dd768b94cd.cdf-ms"
POQ 35 ends.
2017-11-30 08:39:37, Info                  CSI    000000e2 [SR] Verify complete
2017-11-30 08:39:37, Info                  CSI    000000e3 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:37, Info                  CSI    000000e4 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:38, Info                  CSI    000000e5 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Program Files\DVD Maker" in component Microsoft-Windows-GPUPipeline, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:38, Info                  CSI    000000e6 Ignoring duplicate ownership for directory [l:74{37}]"\??\C:\Program Files\DVD Maker\Shared" in component Microsoft-Windows-GPUPipeline, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:39, Info                  CSI    000000e7 Repair results created:
POQ 36 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\99622460ae69d301b90f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\99622460ae69d301ba0f00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301bb0f00007c017813.program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms"
    3: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301bc0f00007c017813.program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms"
    4: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301bd0f00007c017813.program_files_windows_sidebar_gadgets_cpu.gadget_3ea229fc96d38c13.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_cpu.gadget_3ea229fc96d38c13.cdf-ms"
    5: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301be0f00007c017813.program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_24fe3fb55f1eb7bc.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_24fe3fb55f1eb7bc.cdf-ms"
    6: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301bf0f00007c017813.program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_js_d59014448aa53355.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_js_d5901
2017-11-30 08:39:39, Info                  CSI    4448aa53355.cdf-ms"
    7: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c42660ae69d301c00f00007c017813.program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_css_5a2a3844204a6233.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_cpu.gadget_pl-pl_css_5a2a3844204a6233.cdf-ms"
    8: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d272960ae69d301c10f00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    9: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d272960ae69d301c20f00007c017813.$$_diagnostics_system_homegroup_1909584eb21c73e3.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_homegroup_1909584eb21c73e3.cdf-ms"
    10: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\a7892b60ae69d301c30f00007c017813.$$_diagnostics_system_homegroup_pl-pl_b8717029b6981566.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_homegroup_pl-pl_b8717029b6981566.cdf-ms"
    11: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\b5b03260ae69d301c40f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_b054eca6667f3063.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_calendar.gadget_b054eca6667f3063.cdf-ms"
    12: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\b5b03260ae69d301c50f00007c017813.program_files_windows_sidebar_gadgets_calendar.gadget_images_e8b234ae384ba7b1.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_calendar.gadget_images_e8b234ae384ba7b1.cdf-ms"
    13: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\69753760ae69d301c60f00007c017813.program_files_windows_sidebar_gadgets_picturepuzzle.gadget_284c80f2b12171b5.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\pr
2017-11-30 08:39:39, Info                  CSI    ogram_files_windows_sidebar_gadgets_picturepuzzle.gadget_284c80f2b12171b5.cdf-ms"
    14: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\69753760ae69d301c70f00007c017813.program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_40e1f2c176d2ec56.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_40e1f2c176d2ec56.cdf-ms"
    15: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\69753760ae69d301c80f00007c017813.program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_js_ea75663e46e15a2f.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_js_ea75663e46e15a2f.cdf-ms"
    16: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\69753760ae69d301c90f00007c017813.program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_css_ea75673a2a3d35c9.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_css_ea75673a2a3d35c9.cdf-ms"
    17: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1fe4060ae69d301ca0f00007c017813.program_files_windows_sidebar_gadgets_picturepuzzle.gadget_images_113209543e53c7d7.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_picturepuzzle.gadget_images_113209543e53c7d7.cdf-ms"
    18: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b614360ae69d301cb0f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_a4898b91b8575c47.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_a4898b91b8575c47.cdf-ms"
    19: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b614360ae69d301cc0f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_d77eb102caf65d64.cdf-ms", Destination = [l:220{110}
2017-11-30 08:39:39, Info                  CSI    ]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_d77eb102caf65d64.cdf-ms"
    20: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b614360ae69d301cd0f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_js_43fb3fe41b0e722d.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_js_43fb3fe41b0e722d.cdf-ms"
    21: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b614360ae69d301ce0f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_css_baaa7e275004268b.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_pl-pl_css_baaa7e275004268b.cdf-ms"
    22: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\39884a60ae69d301cf0f00007c017813.program_files_windows_sidebar_gadgets_cpu.gadget_images_987b0ad259a4806b.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_cpu.gadget_images_987b0ad259a4806b.cdf-ms"
    23: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\63fd5f60ae69d301d00f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_85cde96256fb59df.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_clock.gadget_85cde96256fb59df.cdf-ms"
    24: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\63fd5f60ae69d301d10f00007c017813.program_files_windows_sidebar_gadgets_clock.gadget_images_11f95cf60938de7b.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_clock.gadget_images_11f95cf60938de7b.cdf-ms"
    25: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9ad7060ae69d301d20f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_images_585d106689450aab.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps
2017-11-30 08:39:39, Info                  CSI    \program_files_windows_sidebar_gadgets_weather.gadget_images_585d106689450aab.cdf-ms"
    26: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9ad7060ae69d301d30f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_images_144dpi_12b2fa65af7b87ad.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_images_144dpi_12b2fa65af7b87ad.cdf-ms"
    27: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9ad7060ae69d301d40f00007c017813.program_files_windows_sidebar_gadgets_weather.gadget_images_120dpi_12fb0c15aed95ff3.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_weather.gadget_images_120dpi_12fb0c15aed95ff3.cdf-ms"
    28: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\e7d47760ae69d301d50f00007c017813.program_files_dvd_maker_405775de8763ce75.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_405775de8763ce75.cdf-ms"
    29: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\e7d47760ae69d301d60f00007c017813.program_files_dvd_maker_shared_a54613779b918be2.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_dvd_maker_shared_a54613779b918be2.cdf-ms"
    30: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7e78a60ae69d301d70f00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    31: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\6bac8f60ae69d301d80f00007c017813.program_files_windows_sidebar_gadgets_rssfeeds.gadget_22ec6b16cd2d39ce.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_22ec6b16cd2d39ce.cdf-ms"
    32: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\6bac8f60ae69d301d90f00007c017813.program_files_windows
2017-11-30 08:39:39, Info                  CSI    _sidebar_gadgets_rssfeeds.gadget_images_420b96bc9fb8ab54.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_rssfeeds.gadget_images_420b96bc9fb8ab54.cdf-ms"
    33: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3359960ae69d301da0f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_964bdce27d2d6734.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_currency.gadget_964bdce27d2d6734.cdf-ms"
    34: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3359960ae69d301db0f00007c017813.program_files_windows_sidebar_gadgets_currency.gadget_images_818b19610434093a.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_currency.gadget_images_818b19610434093a.cdf-ms"
POQ 36 ends.
2017-11-30 08:39:39, Info                  CSI    000000e8 [SR] Verify complete
2017-11-30 08:39:39, Info                  CSI    000000e9 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:39, Info                  CSI    000000ea [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:40, Info                  CSI    000000eb Repair results created:
POQ 37 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\0f406661ae69d301401000007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\0f406661ae69d301411000007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\0f406661ae69d301421000007c017813.$$_globalization_els_hyphenationdictionaries_62199cb34951fc74.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_els_hyphenationdictionaries_62199cb34951fc74.cdf-ms"
POQ 37 ends.
2017-11-30 08:39:40, Info                  CSI    000000ec [SR] Verify complete
2017-11-30 08:39:40, Info                  CSI    000000ed [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:40, Info                  CSI    000000ee [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:41, Info                  CSI    000000ef Repair results created:
POQ 38 starts:
POQ 38 ends.
2017-11-30 08:39:41, Info                  CSI    000000f0 [SR] Verify complete
2017-11-30 08:39:41, Info                  CSI    000000f1 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:41, Info                  CSI    000000f2 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:42, Info                  CSI    000000f3 Repair results created:
POQ 39 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d818b62ae69d3010b1100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\a7e38d62ae69d3010c1100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Create Directory: Directory = [l:58{29}]"\??\C:\Windows\Logs\HomeGroup", Attributes = 00000080
    3: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\df7faa62ae69d3010d1100007c017813.$$_diagnostics_system_homegroup_1909584eb21c73e3.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_homegroup_1909584eb21c73e3.cdf-ms"
POQ 39 ends.
2017-11-30 08:39:42, Info                  CSI    000000f4 [SR] Verify complete
2017-11-30 08:39:43, Info                  CSI    000000f5 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:43, Info                  CSI    000000f6 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:44, Info                  CSI    000000f7 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\lt-LT" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"lt-LT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:44, Info                  CSI    000000f8 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\tr-TR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"tr-TR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000f9 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\fi-FI" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"fi-FI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000fa Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\fr-FR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"fr-FR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000fb Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\nl-NL" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"nl-NL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000fc Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\hr-HR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"hr-HR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000fd Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pl-PL" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000fe Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pt-PT" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pt-PT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    000000ff Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\bg-BG" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"bg-BG", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    00000100 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ru-RU" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ru-RU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:45, Info                  CSI    00000101 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\cs-CZ" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"cs-CZ", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:46, Info                  CSI    00000102 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ja-JP" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ja-JP", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000103 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\he-IL" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"he-IL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000104 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\nb-NO" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"nb-NO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000105 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sl-SI" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sl-SI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000106 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\en-US" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000107 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ko-KR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ko-KR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:47, Info                  CSI    00000108 Repair results created:
POQ 40 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a7ce163ae69d301721100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a7ce163ae69d301731100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\0206eb63ae69d301741100007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\5c68ed63ae69d301751100007c017813.$$_system32_da-dk_40b64d5e87b63595.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_da-dk_40b64d5e87b63595.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c4f1f663ae69d301761100007c017813.$$_system32_lt-lt_4fea189870e886c7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lt-lt_4fea189870e886c7.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c7b0064ae69d301771100007c017813.$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee660c64ae69d301781100007c017813.$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\56f01564ae69d301791100007c017813.$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms"
2017-11-30 08:39:47, Info                  CSI    \b0521864ae69d3017a1100007c017813.$$_globalization_els_transliteration_1547068d18bc2738.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_els_transliteration_1547068d18bc2738.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\18dc2164ae69d3017b1100007c017813.$$_system32_et-ee_429cb6e884dc9948.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_et-ee_429cb6e884dc9948.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\dac72d64ae69d3017c1100007c017813.$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\42513764ae69d3017d1100007c017813.$$_system32_fi-fi_448337a68202d703.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_fi-fi_448337a68202d703.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\043d4364ae69d3017e1100007c017813.$$_system32_fr-fr_448347788202c03b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_fr-fr_448347788202c03b.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6cc64c64ae69d3017f1100007c017813.$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2eb25864ae69d301801100007c017813.$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms"
    15: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\963b6264ae69d301811100007c017813.$$_system32_hr-hr_485036ac7c4f596f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hr-hr_485036ac7c4f596f.cdf-ms"
    16: Move File: Source = [l:226{113}]"\SystemRo
2017-11-30 08:39:47, Info                  CSI    ot\WinSxS\Temp\PendingRenames\58276e64ae69d301821100007c017813.$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms"
    17: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\74757c64ae69d301831100007c017813.$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms"
    18: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\dcfe8564ae69d301841100007c017813.$$_system32_pt-pt_5783f7006581b92f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-pt_5783f7006581b92f.cdf-ms"
    19: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\9eea9164ae69d301851100007c017813.$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms"
    20: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\60d69d64ae69d301861100007c017813.$$_system32_es-es_429cd1a084dc7119.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_es-es_429cd1a084dc7119.cdf-ms"
    21: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c85fa764ae69d301871100007c017813.$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\30e9b064ae69d301881100007c017813.$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2d4bc64ae69d301891100007c017813.$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms"
    24: Move File: Source = [l:226{113}]"\System
2017-11-30 08:39:47, Info                  CSI    Root\WinSxS\Temp\PendingRenames\b4c0c864ae69d3018a1100007c017813.$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\76acd464ae69d3018b1100007c017813.$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\de35de64ae69d3018c1100007c017813.$$_system32_de-de_40b6416a87b647ef.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_de-de_40b6416a87b647ef.cdf-ms"
    27: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\46bfe764ae69d3018d1100007c017813.$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms"
    28: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\08abf364ae69d3018e1100007c017813.$$_system32_zh-cn_6a8499504900c466.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-cn_6a8499504900c466.cdf-ms"
    29: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7034fd64ae69d3018f1100007c017813.$$_system32_zh-tw_6a84aa664900aad6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-tw_6a84aa664900aad6.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ce06a65ae69d301901100007c017813.$$_system32_he-il_48502d1c7c4f6669.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_he-il_48502d1c7c4f6669.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\046a7465ae69d301911100007c017813.$$_system32_uk-ua_61042a3457416b73.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_uk-ua_61042a3457416b73.cdf-ms"
    32: Move File: Source = [l:226{113}]"\SystemRoot\Win
2017-11-30 08:39:47, Info                  CSI    SxS\Temp\PendingRenames\c6558065ae69d301921100007c017813.$$_system32_ar-sa_3b02d130904371b4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ar-sa_3b02d130904371b4.cdf-ms"
    33: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\88418c65ae69d301931100007c017813.$$_system32_nb-no_53b700d66b352886.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nb-no_53b700d66b352886.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a2d9865ae69d301941100007c017813.$$_system32_sl-si_5d374a0c5cf4bbc8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sl-si_5d374a0c5cf4bbc8.cdf-ms"
    35: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0c19a465ae69d301951100007c017813.$$_system32_en-us_429cd25484dc6f94.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_429cd25484dc6f94.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\44b5c065ae69d301961100007c017813.$$_system32_pt-br_5783f3346581bed3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-br_5783f3346581bed3.cdf-ms"
    37: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ac3eca65ae69d301971100007c017813.$$_system32_el-gr_429cd0b684dc71bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_el-gr_429cd0b684dc71bd.cdf-ms"
    38: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c88cd865ae69d301981100007c017813.$$_system32_ko-kr_4e039de673c23e4a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ko-kr_4e039de673c23e4a.cdf-ms"
    39: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\0029f565ae69d301991100007c017813.$$_system32_ime_imetc10_aead306aeed0be86.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imetc10_aead306aeed0be86.cdf-ms"
    40: Move File: Source = [l:254{127}]"\SystemRoot
2017-11-30 08:39:47, Info                  CSI    \WinSxS\Temp\PendingRenames\0029f565ae69d3019a1100007c017813.$$_system32_ime_imetc10_applets_93adac07b5e841fb.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imetc10_applets_93adac07b5e841fb.cdf-ms"
POQ 40 ends.
2017-11-30 08:39:47, Info                  CSI    00000109 [SR] Verify complete
2017-11-30 08:39:48, Info                  CSI    0000010a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:48, Info                  CSI    0000010b [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:48, Info                  CSI    0000010c Repair results created:
POQ 41 starts:
POQ 41 ends.
2017-11-30 08:39:48, Info                  CSI    0000010d [SR] Verify complete
2017-11-30 08:39:48, Info                  CSI    0000010e [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:48, Info                  CSI    0000010f [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:49, Info                  CSI    00000110 Repair results created:
POQ 42 starts:
POQ 42 ends.
2017-11-30 08:39:49, Info                  CSI    00000111 [SR] Verify complete
2017-11-30 08:39:49, Info                  CSI    00000112 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:49, Info                  CSI    00000113 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:50, Info                  CSI    00000114 Repair results created:
POQ 43 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e4071867ae69d301c71200007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e4071867ae69d301c81200007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\e4071867ae69d301c91200007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    3: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\e4071867ae69d301ca1200007c017813.$$_ime_imesc5_dicts_32255cd579e8854e.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imesc5_dicts_32255cd579e8854e.cdf-ms"
    4: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\3e6a1a67ae69d301cb1200007c017813.$$_ime_imesc5_help_693c441c0201a8fa.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imesc5_help_693c441c0201a8fa.cdf-ms"
    5: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c912167ae69d301cc1200007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    6: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\a6f32367ae69d301cd1200007c017813.$$_system32_ime_imesc5_46a6606042ef6565.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imesc5_46a6606042ef6565.cdf-ms"
    7: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\a6f32367ae69d301ce1200007c017813.$$_system32_ime_imesc5_applets_7ab7847ddb9a9a48.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imesc5_applets_7ab7847ddb9a9a48.cdf-ms"
    8: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS
2017-11-30 08:39:50, Info                  CSI    \Temp\PendingRenames\842d3e67ae69d301cf1200007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    9: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\842d3e67ae69d301d01200007c017813.$$_system32_windowspowershell_v1.0_modules_webadministration_db64c88f44b4aab8.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_webadministration_db64c88f44b4aab8.cdf-ms"
    10: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\842d3e67ae69d301d11200007c017813.$$_system32_windowspowershell_v1.0_modules_webadministration_en-us_a476cdb0f2ef95be.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_webadministration_en-us_a476cdb0f2ef95be.cdf-ms"
    11: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\162c5d67ae69d301d21200007c017813.$$_system32_inetsrv_e6240a381854fe3d.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_e6240a381854fe3d.cdf-ms"
    12: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\162c5d67ae69d301d31200007c017813.$$_system32_inetsrv_pl-pl_5dc3ee5e993dea82.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_pl-pl_5dc3ee5e993dea82.cdf-ms"
    13: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{93227638-103d-6fd3-0470-6c42dc9b8f85}", Type = REG_SZ (1), Data = {l:118 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c006900700068006c0070007300760063002e0064006c006c002c004900700068006c0070007300760063005300790073007000720065007000470065006e006500720061006c0069007a0065000000}
POQ 43 ends.
2017-11-30 08:39:50, Info                  CSI    00000115 [SR] Verify complete
2017-11-30 08:39:50, Info                  CSI    00000116 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:50, Info                  CSI    00000117 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:51, Info                  CSI    00000118 Repair results created:
POQ 44 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4d6e967ae69d301381300007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4d6e967ae69d301391300007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4d6e967ae69d3013a1300007c017813.$$_globalization_sorting_04883de290c6ef1b.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_sorting_04883de290c6ef1b.cdf-ms"
    3: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\b2100468ae69d3013b1300007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    4: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\b2100468ae69d3013c1300007c017813.$$_ime_imetc10_dicts_31e93cd9cd8cc931.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imetc10_dicts_31e93cd9cd8cc931.cdf-ms"
    5: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\b2100468ae69d3013d1300007c017813.$$_ime_imetc10_help_31e933f572191d05.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imetc10_help_31e933f572191d05.cdf-ms"
    6: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a9a0d68ae69d3013e1300007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    7: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a9a0d68ae69d3013f1300007c017813.$$_system32_ime_imetc10_aead306aeed0be86.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imetc10_aead306aeed0be86.cdf-ms"
    8: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\
2017-11-30 08:39:51, Info                  CSI    PendingRenames\1a9a0d68ae69d301401300007c017813.$$_system32_ime_imetc10_applets_93adac07b5e841fb.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imetc10_applets_93adac07b5e841fb.cdf-ms"
POQ 44 ends.
2017-11-30 08:39:51, Info                  CSI    00000119 [SR] Verify complete
2017-11-30 08:39:51, Info                  CSI    0000011a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:51, Info                  CSI    0000011b [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:53, Info                  CSI    0000011c Ignoring duplicate ownership for directory [l:108{54}]"\??\C:\Program Files\Common Files\microsoft shared\vgx" in component Microsoft-Windows-IE-VGX, Version = 11.2.9600.18792, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:54, Info                  CSI    0000011d Ignoring duplicate ownership for directory [l:80{40}]"\??\C:\ProgramData\Microsoft\IdentityCRL" in component Microsoft-Windows-IdentityCRL, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:39:54, Info                  CSI    0000011e Repair results created:
POQ 45 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\f8005969ae69d301a51300007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\52635b69ae69d301a61300007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\52635b69ae69d301a71300007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    3: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\52635b69ae69d301a81300007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    4: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\52635b69ae69d301a91300007c017813.program_files_common_files_microsoft_shared_vgx_3c86fd9f0b3afd9b.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_vgx_3c86fd9f0b3afd9b.cdf-ms"
    5: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\7897f169ae69d301aa1300007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    6: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a83fd69ae69d301ab1300007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    7: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a83fd69ae69d301ac1300007c017813.$$_system32_spool_drivers_color_714407f67ff22f9d.cdf-ms", Destination = [l:166{83}]"\SystemRoot\Wi
2017-11-30 08:39:54, Info                  CSI    nSxS\FileMaps\$$_system32_spool_drivers_color_714407f67ff22f9d.cdf-ms"
    8: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\64f8126aae69d301ad1300007c017813.programdata_microsoft_identitycrl_9ceb7e1568e6c6e7.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_identitycrl_9ceb7e1568e6c6e7.cdf-ms"
POQ 45 ends.
2017-11-30 08:39:54, Info                  CSI    0000011f [SR] Verify complete
2017-11-30 08:39:55, Info                  CSI    00000120 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:55, Info                  CSI    00000121 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:57, Info                  CSI    00000122 Repair results created:
POQ 46 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4a1be6aae69d301121400007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4a1be6aae69d301131400007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4a1be6aae69d301141400007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    3: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4a1be6aae69d301151400007c017813.$$_ime_imekr8_dicts_2ff7cb9394decb12.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imekr8_dicts_2ff7cb9394decb12.cdf-ms"
    4: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4a1be6aae69d301161400007c017813.$$_ime_imekr8_help_6edfa6f9f9cba42e.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imekr8_help_6edfa6f9f9cba42e.cdf-ms"
    5: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c2bc86aae69d301171400007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    6: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c2bc86aae69d301181400007c017813.$$_system32_ime_imekr8_46a67c6e42ef3b99.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imekr8_46a67c6e42ef3b99.cdf-ms"
    7: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\768dca6aae69d301191400007c017813.$$_system32_ime_imekr8_applets_4b4e797746aa967c.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imekr8_applets_4b4e797746aa967c.cdf-ms"
    8: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS
2017-11-30 08:39:57, Info                  CSI    \Temp\PendingRenames\92dbd86aae69d3011a1400007c017813.$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_shared_5a5b3a5824d8fee4.cdf-ms"
    9: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a8a086bae69d3011b1400007c017813.$$_system32_ime_imekr8_dicts_4b36d5aba5194cae.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ime_imekr8_dicts_4b36d5aba5194cae.cdf-ms"
    10: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\0214126bae69d3011c1400007c017813.$$_system32_bestpractices_v1.0_models_microsoft_windows_webserver_d4c8fed1335fca61.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_system32_bestpractices_v1.0_models_microsoft_windows_webserver_d4c8fed1335fca61.cdf-ms"
    11: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee74336bae69d3011d1400007c017813.$$_system32_inetsrv_e6240a381854fe3d.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_e6240a381854fe3d.cdf-ms"
    12: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee74336bae69d3011e1400007c017813.$$_system32_inetsrv_config_37b3fe8d5c5ab2d1.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_config_37b3fe8d5c5ab2d1.cdf-ms"
    13: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee74336bae69d3011f1400007c017813.$$_system32_inetsrv_config_export_669b235ed7d353c7.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_config_export_669b235ed7d353c7.cdf-ms"
    14: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee74336bae69d301201400007c017813.$$_system32_inetsrv_config_schema_3eb330b713bd4294.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_system32_inetsrv_config_schema_3eb330b713bd4294.cdf-ms"
    15: Move File: Source = [l:172{86}]"\SystemRoot\WinSxS\Temp\PendingRenames\48d7356bae69d301211400007c017
2017-11-30 08:39:57, Info                  CSI    813.inetpub.cdf-ms", Destination = [l:84{42}]"\SystemRoot\WinSxS\FileMaps\inetpub.cdf-ms"
    16: Set File Information: File = [l:28{14}]"\??\C:\inetpub", Attributes = 00000080
    17: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\0ac3416bae69d301221400007c017813.$$_system32_bestpractices_v1.0_models_microsoft_windows_webserver_pl-pl_60713b1b9d9c0aa6.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_system32_bestpractices_v1.0_models_microsoft_windows_webserver_pl-pl_60713b1b9d9c0aa6.cdf-ms"
    18: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\3438576bae69d301231400007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    19: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\3438576bae69d301241400007c017813.$$_system32_windowspowershell_v1.0_modules_webadministration_db64c88f44b4aab8.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_webadministration_db64c88f44b4aab8.cdf-ms"
    20: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\7afb7a6bae69d301251400007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    21: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\7afb7a6bae69d301261400007c017813.$$_inf_w3svc_0ef6c7aee1e4154f.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_w3svc_0ef6c7aee1e4154f.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7afb7a6bae69d301271400007c017813.$$_inf_w3svc_0415_6ed52ac03816468b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_w3svc_0415_6ed52ac03816468b.cdf-ms"
    23: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76
2017-11-30 08:39:57, Info                  CSI    {38}]"{cb91621d-3e7f-6ee5-2d00-e35ade2ecb27}", Type = REG_SZ (1), Data = {l:112 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0069006e00650074007300720076005c00690069007300730079007300700072002e0064006c006c002c004900490053005f00470065006e006500720061006c0069007a0065000000}
    24: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{cb91621d-3e7f-6ee5-f406-3107ceba5d5b}", Type = REG_SZ (1), Data = {l:112 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0069006e00650074007300720076005c00690069007300730079007300700072002e0064006c006c002c004900490053005f005300700065006300690061006c0069007a0065000000}
POQ 46 ends.
2017-11-30 08:39:57, Info                  CSI    00000123 [SR] Verify complete
2017-11-30 08:39:57, Info                  CSI    00000124 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:57, Info                  CSI    00000125 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:57, Info                  CSI    00000126 Repair results created:
POQ 47 starts:
POQ 47 ends.
2017-11-30 08:39:57, Info                  CSI    00000127 [SR] Verify complete
2017-11-30 08:39:58, Info                  CSI    00000128 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:58, Info                  CSI    00000129 [SR] Beginning Verify and Repair transaction
2017-11-30 08:39:58, Info                  CSI    0000012a Repair results created:
POQ 48 starts:
     0: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{8318015d-6678-7f7f-f9a8-572bb66ac5ae}", Type = REG_SZ (1), Data = {l:166 ml:166 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c004c0061006e00670043006c00650061006e00750070005300..730070007200650070005f00470065006e006500720061006c0069007a0065005f004d00550049004c0061006e00670043006c00650061006e00750070000000}
POQ 48 ends.
2017-11-30 08:39:58, Info                  CSI    0000012b [SR] Verify complete
2017-11-30 08:39:58, Info                  CSI    0000012c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:39:58, Info                  CSI    0000012d [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:00, Info                  CSI    0000012e Repair results created:
POQ 49 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc39de6cae69d301541500007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc39de6cae69d301551500007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc39de6cae69d301561500007c017813.$$_globalization_mct_0b932a9a9cc9f99b.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_mct_0b932a9a9cc9f99b.cdf-ms"
    3: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\90fee26cae69d301571500007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    4: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\90fee26cae69d301581500007c017813.program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms"
    5: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\90fee26cae69d301591500007c017813.program_files_windows_media_player_pl-pl_94ff93be3fd1205a.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_pl-pl_94ff93be3fd1205a.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\06aff36cae69d3015a1500007c017813.program_files_windows_mail_e07902f329fe05e9.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_mail_e07902f329fe05e9.cdf-ms"
    7: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\06aff36cae69d3015b1500007c017813.program_files_windows_mail_pl-pl_4eeceeae83c5b620.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps
2017-11-30 08:40:00, Info                  CSI    \program_files_windows_mail_pl-pl_4eeceeae83c5b620.cdf-ms"
    8: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba73f86cae69d3015c1500007c017813.$$_globalization_mct_mct-pl_link_6013e4152b2a0a1e.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_mct_mct-pl_link_6013e4152b2a0a1e.cdf-ms"
    9: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c852a6dae69d3015d1500007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    10: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\76e72c6dae69d3015e1500007c017813.$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms"
    11: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\76e72c6dae69d3015f1500007c017813.$$_system32_migwiz_dlmanifests_f1386c432966667b.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_f1386c432966667b.cdf-ms"
    12: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\76e72c6dae69d301601500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-ie-esc_881b20a0d2777648.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-ie-esc_881b20a0d2777648.cdf-ms"
    13: Move File: Source = [l:358{179}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301611500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-textservicesframework-migration-dl_549205906affe6bf.cdf-ms", Destination = [l:270{135}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-textservicesframework-migration-dl_549205906affe6bf.cdf-ms"
    14: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301621500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-mediaplayer_644fa9f0de4025eb.cdf-ms", Dest
2017-11-30 08:40:00, Info                  CSI    ination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-mediaplayer_644fa9f0de4025eb.cdf-ms"
    15: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301631500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-storagemigration_d55783f2ccb64b27.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-storagemigration_d55783f2ccb64b27.cdf-ms"
    16: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301641500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-com-complus-setup-dl_1ee4026d5f5876ce.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-com-complus-setup-dl_1ee4026d5f5876ce.cdf-ms"
    17: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301651500007c017813.$$_system32_migwiz_dlmanifests_networking-mpssvc-svc_e23ab12e0e23ec55.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_networking-mpssvc-svc_e23ab12e0e23ec55.cdf-ms"
    18: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301661500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-mediaplayer-drm-dl_552be0fd1dd444d0.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-mediaplayer-drm-dl_552be0fd1dd444d0.cdf-ms"
    19: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301671500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-ndis_f0ef0c61452d5b28.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-ndis_f0ef0c61452d5b28.cdf-ms"
    20: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301681500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-unimodem-config_2000ab3161
2017-11-30 08:40:00, Info                  CSI    15550f.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-unimodem-config_2000ab316115550f.cdf-ms"
    21: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0492f6dae69d301691500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-shmig-dl_45622e527f470963.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-shmig-dl_45622e527f470963.cdf-ms"
    22: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016a1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-tapisetup_0be6007940c10533.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-tapisetup_0be6007940c10533.cdf-ms"
    23: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016b1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-networkloadbalancing-core_c9b56fe0156d9ead.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-networkloadbalancing-core_c9b56fe0156d9ead.cdf-ms"
    24: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016c1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-dhcpservermigplugin-dl_0534ab06e10ae139.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-dhcpservermigplugin-dl_0534ab06e10ae139.cdf-ms"
    25: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016d1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-directoryservices-adam-dl_6c3018cc6f347ede.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-directoryservices-adam-dl_6c3018cc6f347ede.cdf-ms"
    26: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016e1500007c01
2017-11-30 08:40:00, Info                  CSI    7813.$$_system32_migwiz_dlmanifests_microsoft-windows-offlinefiles-dl_ed0c7082ff497ba5.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-offlinefiles-dl_ed0c7082ff497ba5.cdf-ms"
    27: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d3016f1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-rasapi_86cec7ccd5753cec.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-rasapi_86cec7ccd5753cec.cdf-ms"
    28: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d301701500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-iis-dl_8822f736d253acda.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-iis-dl_8822f736d253acda.cdf-ms"
    29: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d301711500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-rasserver-migplugin_9fbe397ae34120be.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-rasserver-migplugin_9fbe397ae34120be.cdf-ms"
    30: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d301721500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-wmi-core_0fa6ec0ad029fddb.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-wmi-core_0fa6ec0ad029fddb.cdf-ms"
    31: Move File: Source = [l:360{180}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aac316dae69d301731500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-performancecounterinfrastructure-dl_887290e36ed2c960.cdf-ms", Destination = [l:272{136}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-performancecounterinfrastructure-dl_887290e36ed2c960.cdf-ms"
    32: Move File: Source = [l:304{152}]"\SystemRoot\WinSx
2017-11-30 08:40:00, Info                  CSI    S\Temp\PendingRenames\840e346dae69d301741500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-adfs-dl_893986f097ae8ea9.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-adfs-dl_893986f097ae8ea9.cdf-ms"
    33: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d301751500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-com-dtc-setup-dl_a3b468532c03dbe0.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-com-dtc-setup-dl_a3b468532c03dbe0.cdf-ms"
    34: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d301761500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-msmq-messagingcoreservice_a2ca72db0bdebee3.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-msmq-messagingcoreservice_a2ca72db0bdebee3.cdf-ms"
    35: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d301771500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-bluetooth-config_40d5c57bfa898bfd.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-bluetooth-config_40d5c57bfa898bfd.cdf-ms"
    36: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d301781500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-iasserver-migplugin_96e6769f772696e5.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-iasserver-migplugin_96e6769f772696e5.cdf-ms"
    37: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d301791500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-sxs_214556d37cabee6c.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-sxs_214556d37cabee6c.cdf-ms"
    38: Move F
2017-11-30 08:40:00, Info                  CSI    ile: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d3017a1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-rasconnectionmanager_2597396f593c1559.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-rasconnectionmanager_2597396f593c1559.cdf-ms"
    39: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d3017b1500007c017813.$$_system32_migwiz_dlmanifests_bitsextensions-server_7d542a16c26409f3.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_bitsextensions-server_7d542a16c26409f3.cdf-ms"
    40: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\PendingRenames\840e346dae69d3017c1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-international-core-dl_d66e65e1080457e5.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-international-core-dl_d66e65e1080457e5.cdf-ms"
    41: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\de70366dae69d3017d1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-activedirectory-webservices-dl_b2cdce29afb29e47.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-activedirectory-webservices-dl_b2cdce29afb29e47.cdf-ms"
    42: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\de70366dae69d3017e1500007c017813.$$_system32_migwiz_dlmanifests_microsoft-windows-networkbridge_6f3babcf8612f78b.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_dlmanifests_microsoft-windows-networkbridge_6f3babcf8612f78b.cdf-ms"
POQ 49 ends.
2017-11-30 08:40:00, Info                  CSI    0000012f [SR] Verify complete
2017-11-30 08:40:00, Info                  CSI    00000130 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:00, Info                  CSI    00000131 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:01, Info                  CSI    00000132 Repair results created:
POQ 50 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2dee66dae69d301e31500007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2dee66dae69d301e41500007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\f005ee6dae69d301e51500007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a68f06dae69d301e61500007c017813.$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_2650d8d30fee1fe9.cdf-ms"
    4: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a68f06dae69d301e71500007c017813.$$_system32_migwiz_postmigres_data_8383ed297796e30e.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_postmigres_data_8383ed297796e30e.cdf-ms"
    5: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a68f06dae69d301e81500007c017813.$$_system32_migwiz_postmigres_web_997c3ff186280ede.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_postmigres_web_997c3ff186280ede.cdf-ms"
    6: Move File: Source = [l:282{141}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a68f06dae69d301e91500007c017813.$$_system32_migwiz_postmigres_web_base_images_0e64dea9756e1d4c.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_postmigres_web_base_images_0e64dea9756e1d4c.cdf-ms"
    7: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\82040d6eae69d301ea1500007c017813.$$_system32_migwiz_pl-pl_b32d8c9c52dee900.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\
2017-11-30 08:40:01, Info                  CSI    FileMaps\$$_system32_migwiz_pl-pl_b32d8c9c52dee900.cdf-ms"
    8: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e521b6eae69d301eb1500007c017813.$$_diagnostics_scheduled_maintenance_6bb1b174b39bb442.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_scheduled_maintenance_6bb1b174b39bb442.cdf-ms"
    9: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e521b6eae69d301ec1500007c017813.$$_diagnostics_scheduled_maintenance_pl-pl_1a7416315b1977ab.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_scheduled_maintenance_pl-pl_1a7416315b1977ab.cdf-ms"
    10: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c8c356eae69d301ed1500007c017813.$$_system32_migwiz_replacementmanifests_174c7b92bb7d581f.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_174c7b92bb7d581f.cdf-ms"
    11: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c8c356eae69d301ee1500007c017813.$$_system32_migwiz_replacementmanifests_usb_395978177bf6d5e1.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_usb_395978177bf6d5e1.cdf-ms"
    12: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c8c356eae69d301ef1500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-ndis_b44547c729f73574.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-ndis_b44547c729f73574.cdf-ms"
    13: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f01500007c017813.$$_system32_migwiz_replacementmanifests_windowssearchengine_145004789b880a4a.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_windowssearchengine_145004789b880a4a.cdf-ms"
    14: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f115
2017-11-30 08:40:01, Info                  CSI    00007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-iis-rm_9ee468490d6de347.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-iis-rm_9ee468490d6de347.cdf-ms"
    15: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f21500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-shmig_9ef85dcb89d16c58.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-shmig_9ef85dcb89d16c58.cdf-ms"
    16: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f31500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-international-core_05a14960964e6af4.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-international-core_05a14960964e6af4.cdf-ms"
    17: Move File: Source = [l:342{171}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f41500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-offlinefiles-core_3b64983f65339578.cdf-ms", Destination = [l:254{127}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-offlinefiles-core_3b64983f65339578.cdf-ms"
    18: Move File: Source = [l:368{184}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f51500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-terminalservices-licenseserver_cff2bf5f876a8fcd.cdf-ms", Destination = [l:280{140}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-terminalservices-licenseserver_cff2bf5f876a8fcd.cdf-ms"
    19: Move File: Source = [l:380{190}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f61500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-terminalservices-appserver-licensing_10d3d9d862990d9c.cdf-ms", Destination = [l:292{146}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementman
2017-11-30 08:40:01, Info                  CSI    ifests_microsoft-windows-terminalservices-appserver-licensing_10d3d9d862990d9c.cdf-ms"
    20: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f71500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-windows-audio-mmecore-other_5137bedd30b4e5d8.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-windows-audio-mmecore-other_5137bedd30b4e5d8.cdf-ms"
    21: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6ee376eae69d301f81500007c017813.$$_system32_migwiz_replacementmanifests_microsoft-activedirectory-webservices_fbfc8031b6420fb6.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migwiz_replacementmanifests_microsoft-activedirectory-webservices_fbfc8031b6420fb6.cdf-ms"
POQ 50 ends.
2017-11-30 08:40:01, Info                  CSI    00000133 [SR] Verify complete
2017-11-30 08:40:02, Info                  CSI    00000134 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:02, Info                  CSI    00000135 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:04, Info                  CSI    00000136 Repair results created:
POQ 51 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\28cf3b6fae69d3015d1600007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\28cf3b6fae69d3015e1600007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\28cf3b6fae69d3015f1600007c017813.$$_diagnostics_scheduled_maintenance_6bb1b174b39bb442.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_scheduled_maintenance_6bb1b174b39bb442.cdf-ms"
    3: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\441d4a6fae69d301601600007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    4: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\441d4a6fae69d301611600007c017813.program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms"
    5: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\441d4a6fae69d301621600007c017813.program_files_windows_media_player_skins_94ff8de43fd42ce5.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_skins_94ff8de43fd42ce5.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e7f4c6fae69d301631600007c017813.program_files_windows_mail_e07902f329fe05e9.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_mail_e07902f329fe05e9.cdf-ms"
    7: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e7f4c6fae69d301641600007c017813.program_files_windows_mail_pl-pl_4eeceeae83c5b620.cdf-ms", Destination = [l:168{
2017-11-30 08:40:04, Info                  CSI    84}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_mail_pl-pl_4eeceeae83c5b620.cdf-ms"
    8: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\00917e6fae69d301651600007c017813.program_files_windows_media_player_icons_94ff7ddc3fca431d.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_icons_94ff7ddc3fca431d.cdf-ms"
    9: Move File: Source = [l:290{145}]"\SystemRoot\WinSxS\Temp\PendingRenames\00917e6fae69d301661600007c017813.program_files_windows_media_player_visualizations_e380711fc66b5d12.cdf-ms", Destination = [l:202{101}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_visualizations_e380711fc66b5d12.cdf-ms"
    10: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\681a886fae69d301671600007c017813.programdata_microsoft_windows_drm_1409f63e8e701274.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_drm_1409f63e8e701274.cdf-ms"
    11: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\681a886fae69d301681600007c017813.programdata_microsoft_windows_drm_cache_0462a9ca8b56f2bc.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_drm_cache_0462a9ca8b56f2bc.cdf-ms"
    12: Set File Information: File = [l:92{46}]"\??\C:\ProgramData\Microsoft\Windows\DRM\Cache", Attributes = 00000086
    13: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\1cdf8c6fae69d301691600007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    14: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\1cdf8c6fae69d3016a1600007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    15: Move File: Source = [l:300{150}]"\SystemRoo
2017-11-30 08:40:04, Info                  CSI    t\WinSxS\Temp\PendingRenames\1cdf8c6fae69d3016b1600007c017813.program_files_common_files_microsoft_shared_stationery_3f6c21eb4ac66a56.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_stationery_3f6c21eb4ac66a56.cdf-ms"
    16: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\382d9b6fae69d3016c1600007c017813.$$_globalization_mct_0b932a9a9cc9f99b.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_mct_0b932a9a9cc9f99b.cdf-ms"
    17: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\382d9b6fae69d3016d1600007c017813.$$_globalization_mct_mct-pl_wallpaper_4ec19d1f00d6cbea.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_mct_mct-pl_wallpaper_4ec19d1f00d6cbea.cdf-ms"
    18: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\382d9b6fae69d3016e1600007c017813.$$_globalization_mct_mct-pl_theme_891fabd06d985f19.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_mct_mct-pl_theme_891fabd06d985f19.cdf-ms"
    19: Move File: Source = [l:290{145}]"\SystemRoot\WinSxS\Temp\PendingRenames\488bfa6fae69d3016f1600007c017813.program_files_windows_media_player_media_renderer_5001a1a5de706f6e.cdf-ms", Destination = [l:202{101}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_media_renderer_5001a1a5de706f6e.cdf-ms"
    20: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\488bfa6fae69d301701600007c017813.program_files_windows_media_player_network_sharing_aed05552f451fd7d.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_network_sharing_aed05552f451fd7d.cdf-ms"
    21: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{f4bdace9-abba-cc99-6049-1807de6941d3}", Type = REG_SZ (1), Data = {l:42 b:640072006d007600320063006c0074002e0064006c006c002c005300790073007
2017-11-30 08:40:04, Info                  CSI    0007200650070000000}
    22: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{7ed465c0-36c1-6a1c-1b30-cf21359228e2}", Type = REG_SZ (1), Data = {l:66 b:7300700077006d0070002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a0065005f0057004d0050000000}
    23: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{b3257dc1-2617-6667-c3b8-8689a568f16e}", Type = REG_SZ (1), Data = {l:180 ml:180 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0041007500780069006c006900610072007900440069007300..64006f00770073005300690064006500530068006f0077005f0053007900730070007200650070005f00470065006e006500720061006c0069007a0065000000}
POQ 51 ends.
2017-11-30 08:40:04, Info                  CSI    00000137 [SR] Verify complete
2017-11-30 08:40:04, Info                  CSI    00000138 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:04, Info                  CSI    00000139 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:05, Info                  CSI    0000013a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pt-BR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pt-BR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    0000013b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\el-GR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"el-GR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    0000013c Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\da-DK" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"da-DK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    0000013d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ro-RO" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ro-RO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    0000013e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ru-RU" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ru-RU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    0000013f Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\de-DE" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"de-DE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    00000140 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\lv-LV" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"lv-LV", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    00000141 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\th-TH" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"th-TH", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:06, Info                  CSI    00000142 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\et-EE" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"et-EE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000143 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\it-IT" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"it-IT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000144 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sk-SK" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sk-SK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000145 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\hu-HU" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"hu-HU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000146 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\pt-PT" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pt-PT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000147 Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\System32\sr-Latn-CS" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:20{10}]"sr-Latn-CS", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:07, Info                  CSI    00000148 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\es-ES" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"es-ES", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    00000149 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\uk-UA" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"uk-UA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\sv-SE" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"sv-SE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\zh-CN" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"zh-CN", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014c Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\zh-HK" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"zh-HK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\zh-TW" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"zh-TW", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\ar-SA" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"ar-SA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:08, Info                  CSI    0000014f Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\System32\nb-NO" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"nb-NO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:09, Info                  CSI    00000150 Repair results created:
POQ 52 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e46fa170ae69d301d51600007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\3ed2a370ae69d301d61600007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\4cf9aa70ae69d301d71600007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a65bad70ae69d301d81600007c017813.$$_system32_pt-br_5783f3346581bed3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-br_5783f3346581bed3.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0ee5b670ae69d301d91600007c017813.$$_system32_el-gr_429cd0b684dc71bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_el-gr_429cd0b684dc71bd.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\92bcce70ae69d301da1600007c017813.$$_system32_ko-kr_4e039de673c23e4a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ko-kr_4e039de673c23e4a.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\086ddf70ae69d301db1600007c017813.$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms"
    7: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\086ddf70ae69d301dc1600007c017813.$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms"
    8: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS
2017-11-30 08:40:09, Info                  CSI    \Temp\PendingRenames\086ddf70ae69d301dd1600007c017813.$$_system32_tasks_microsoft_windows_synccenter_6c995d37b2976a17.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_windows_synccenter_6c995d37b2976a17.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\70f6e870ae69d301de1600007c017813.$$_system32_da-dk_40b64d5e87b63595.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_da-dk_40b64d5e87b63595.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4009fc70ae69d301df1600007c017813.$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ro-ro_5b50dd6a5fce5f0b.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a8920571ae69d301e01600007c017813.$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ru-ru_5b50e7f65fce4fdb.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a7e1171ae69d301e11600007c017813.$$_system32_lt-lt_4fea189870e886c7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lt-lt_4fea189870e886c7.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c6a1d71ae69d301e21600007c017813.$$_system32_de-de_40b6416a87b647ef.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_de-de_40b6416a87b647ef.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\94f32671ae69d301e31600007c017813.$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_lv-lv_4fea1c1c70e881b7.cdf-ms"
    15: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\fc7c3071ae69d301e41600007c017813.$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_th-th_5f1dc0505a1b09f7.cdf-ms"
    16: Mo
2017-11-30 08:40:09, Info                  CSI    ve File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\64063a71ae69d301e51600007c017813.$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tr-tr_5f1dd1e45a1af0a7.cdf-ms"
    17: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\26f24571ae69d301e61600007c017813.$$_system32_et-ee_429cb6e884dc9948.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_et-ee_429cb6e884dc9948.cdf-ms"
    18: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e7b4f71ae69d301e71600007c017813.$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_it-it_4a36b1ca7975a0f9.cdf-ms"
    19: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\50675b71ae69d301e81600007c017813.$$_system32_fr-fr_448347788202c03b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_fr-fr_448347788202c03b.cdf-ms"
    20: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b8f06471ae69d301e91600007c017813.$$_system32_fi-fi_448337a68202d703.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_fi-fi_448337a68202d703.cdf-ms"
    21: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\207a6e71ae69d301ea1600007c017813.$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nl-nl_53b6f9bc6b35343b.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2657a71ae69d301eb1600007c017813.$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ja-jp_4c1d2478769bf2f4.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4aef8371ae69d301ec1600007c017813.$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sk-sk_5d374dfc5cf4b5c5.cdf-ms"
    24: Move File:
2017-11-30 08:40:09, Info                  CSI     Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0cdb8f71ae69d301ed1600007c017813.$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hu-hu_48503bf27c4f51d7.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\cec69b71ae69d301ee1600007c017813.$$_system32_hr-hr_485036ac7c4f596f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_hr-hr_485036ac7c4f596f.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea14aa71ae69d301ef1600007c017813.$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pl-pl_5783e8f06581cd6f.cdf-ms"
    27: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\529eb371ae69d301f01600007c017813.$$_system32_pt-pt_5783f7006581b92f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_pt-pt_5783f7006581b92f.cdf-ms"
    28: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\148abf71ae69d301f11600007c017813.$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sr-latn-cs_36d1c3d11e65ce00.cdf-ms"
    29: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\30d8cd71ae69d301f21600007c017813.$$_system32_es-es_429cd1a084dc7119.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_es-es_429cd1a084dc7119.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\5a4de371ae69d301f31600007c017813.$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_bg-bg_3ce955ba8d69a9ab.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c2d6ec71ae69d301f41600007c017813.$$_system32_uk-ua_61042a3457416b73.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_uk-ua_61042a3457416b73.cdf-ms"
    32: Move Fil
2017-11-30 08:40:09, Info                  CSI    e: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2a60f671ae69d301f51600007c017813.$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_cs-cz_3ecfefb68a8fc3f6.cdf-ms"
    33: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ec4b0272ae69d301f61600007c017813.$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sv-se_5d37410c5cf4ca56.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\70231a72ae69d301f71600007c017813.$$_system32_zh-cn_6a8499504900c466.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-cn_6a8499504900c466.cdf-ms"
    35: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8ac2372ae69d301f81600007c017813.$$_system32_zh-hk_6a84939e4900ccf6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-hk_6a84939e4900ccf6.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\40362d72ae69d301f91600007c017813.$$_system32_zh-tw_6a84aa664900aad6.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_zh-tw_6a84aa664900aad6.cdf-ms"
    37: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\5c843b72ae69d301fa1600007c017813.$$_system32_he-il_48502d1c7c4f6669.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_he-il_48502d1c7c4f6669.cdf-ms"
    38: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2475f72ae69d301fb1600007c017813.$$_system32_ar-sa_3b02d130904371b4.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ar-sa_3b02d130904371b4.cdf-ms"
    39: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\64336b72ae69d301fc1600007c017813.$$_system32_nb-no_53b700d66b352886.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_nb-no_53b700d66b352886.cdf-ms"
2017-11-30 08:40:09, Info                  CSI    e = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\261f7772ae69d301fd1600007c017813.$$_system32_sl-si_5d374a0c5cf4bbc8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sl-si_5d374a0c5cf4bbc8.cdf-ms"
    41: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\aaf68e72ae69d301fe1600007c017813.$$_system32_en-us_429cd25484dc6f94.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_429cd25484dc6f94.cdf-ms"
    42: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{36bbe5e7-6cde-5151-af73-72df2987e480}", Type = REG_SZ (1), Data = {l:62 b:6d0073006d006d00730070002e0064006c006c002c004d006f0075006e0074004d00670072005f00470065006e006500720061006c0069007a0065000000}
POQ 52 ends.
2017-11-30 08:40:09, Info                  CSI    00000151 [SR] Verify complete
2017-11-30 08:40:09, Info                  CSI    00000152 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:09, Info                  CSI    00000153 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:10, Info                  CSI    00000154 Repair results created:
POQ 53 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\bc8b4673ae69d301631700007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\bc8b4673ae69d301641700007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\cab24d73ae69d301651700007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    3: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\cab24d73ae69d301661700007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    4: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\cab24d73ae69d301671700007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    5: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\cab24d73ae69d301681700007c017813.program_files_common_files_microsoft_shared_msinfo_817ad0c7c1c8e490.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_msinfo_817ad0c7c1c8e490.cdf-ms"
    6: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\323c5773ae69d301691700007c017813.program_files_common_files_speechengines_microsoft_tts20_01244a1856097a63.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_speechengines_microsoft_tts20_01244a1856097a63.cdf-ms"
    7: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\323c5773ae69d3016a1700007c017813.
2017-11-30 08:40:10, Info                  CSI    program_files_common_files_speechengines_microsoft_tts20_en-us_d560227d1a443333.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_speechengines_microsoft_tts20_en-us_d560227d1a443333.cdf-ms"
    8: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\024f6a73ae69d3016b1700007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    9: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\10767173ae69d3016c1700007c017813.$$_diagnostics_system_networking_29c6b61ce45e9171.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_networking_29c6b61ce45e9171.cdf-ms"
    10: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d3016d1700007c017813.program_files_reference_assemblies_microsoft_framework_v3.5_44577da22216c264.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.5_44577da22216c264.cdf-ms"
    11: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d3016e1700007c017813.program_files_reference_assemblies_microsoft_framework_v3.5_pl_4221170769c47258.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.5_pl_4221170769c47258.cdf-ms"
    12: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d3016f1700007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    13: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d301701700007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
2017-11-30 08:40:10, Info                  CSI    enames\a2749073ae69d301711700007c017813.$$_microsoft.net_framework64_v3.5_d97e7b06b51e52d9.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.5_d97e7b06b51e52d9.cdf-ms"
    15: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d301721700007c017813.$$_microsoft.net_framework64_v3.5_1045_5fdb15f3511a0bc3.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.5_1045_5fdb15f3511a0bc3.cdf-ms"
    16: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2749073ae69d301731700007c017813.$$_microsoft.net_framework64_v3.5_pl_d84b0da4a32e652b.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.5_pl_d84b0da4a32e652b.cdf-ms"
POQ 53 ends.
2017-11-30 08:40:10, Info                  CSI    00000155 [SR] Verify complete
2017-11-30 08:40:11, Info                  CSI    00000156 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:11, Info                  CSI    00000157 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:18, Info                  CSI    00000158 Repair results created:
POQ 54 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\8680e475ae69d301d81700007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e0e2e675ae69d301d91700007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee09ee75ae69d301da1700007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\486cf075ae69d301db1700007c017813.$$_system32_ias_0665534bd047d20d.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ias_0665534bd047d20d.cdf-ms"
    4: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\307efc75ae69d301dc1700007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    5: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\307efc75ae69d301dd1700007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
    6: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\307efc75ae69d301de1700007c017813.$$_microsoft.net_framework64_v3.5_d97e7b06b51e52d9.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.5_d97e7b06b51e52d9.cdf-ms"
    7: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\307efc75ae69d301df1700007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    8: Move File: Source = [l:310{155}
2017-11-30 08:40:18, Info                  CSI    ]"\SystemRoot\WinSxS\Temp\PendingRenames\8ae0fe75ae69d301e01700007c017813.program_files_reference_assemblies_microsoft_framework_v3.5_44577da22216c264.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.5_44577da22216c264.cdf-ms"
    9: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\8ae0fe75ae69d301e11700007c017813.program_files_msbuild_microsoft_windows_workflow_foundation_v3.5_06f0ac2a38886194.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_msbuild_microsoft_windows_workflow_foundation_v3.5_06f0ac2a38886194.cdf-ms"
    10: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\e8dde277ae69d301e21700007c017813.$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms"
    11: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\e8dde277ae69d301e31700007c017813.$$_microsoft.net_framework64_v2.0.50727_mui_0415_ffa7e0a4ff8e4b4d.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_mui_0415_ffa7e0a4ff8e4b4d.cdf-ms"
    12: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e41700007c017813.$$_microsoft.net_framework64_v2.0.50727_1045_b3c88eb313ae6c50.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_1045_b3c88eb313ae6c50.cdf-ms"
    13: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e51700007c017813.$$_microsoft.net_framework64_v2.0.50727_pl_3760120dd4125c80.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_pl_3760120dd4125c80.cdf-ms"
    14: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e61700007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{
2017-11-30 08:40:18, Info                  CSI    58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    15: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e71700007c017813.$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms"
    16: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e81700007c017813.$$_inf_.net_clr_data_0415_9334eaa7f0277011.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0415_9334eaa7f0277011.cdf-ms"
    17: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301e91700007c017813.$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms"
    18: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301ea1700007c017813.$$_inf_.net_clr_networking_0415_417ab27890926525.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_0415_417ab27890926525.cdf-ms"
    19: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301eb1700007c017813.$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms"
    20: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\4240e577ae69d301ec1700007c017813.$$_inf_.net_data_provider_for_oracle_0415_1ac87e0ef00b1c90.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_0415_1ac87e0ef00b1c90.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ca2e777ae69d301ed1700007c017813.$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms"
    22: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ca2e777ae69d301ee1700007c017813.$$_inf_.net_data_provider_for_sqlserver_0415_22ef188b81b08c6b.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_0415_22ef188b81b08c6b.cdf-ms"
    23: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ca2e777ae69d301ef1700007c017813.$$_inf_.netframework_266880c2626e99c6.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_266880c2626e99c6.cdf-ms"
    24: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ca2e777ae69d301f01700007c017813.$$_inf_.netframework_0415_fd6b68e949272494.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_0415_fd6b68e949272494.cdf-ms"
    25: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\042cf177ae69d301f11700007c017813.$$_system32_mui_0415_ecc96e109498d621.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_system32_mui_0415_ecc96e109498d621.cdf-ms"
    26: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e8ef377ae69d301f21700007c017813.$$_diagnostics_system_networking_29c6b61ce45e9171.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_networking_29c6b61ce45e9171.cdf-ms"
    27: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e8ef377ae69d301f31700007c017813.$$_diagnostics_system_networking_pl-pl_9c2bfa2c26c57b20.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_networking_pl-pl_9c2bfa2c26c57b20.cdf-ms"
    28: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\c617fd77ae69d301f41700007c017813.$$_microsoft.net_framework64_v3.5_1033_5fdb1455511a0dfa.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.5_1033_5fdb1455511a0dfa.cdf-ms"
    29: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\P
2017-11-30 08:40:18, Info                  CSI    endingRenames\207aff77ae69d301f51700007c017813.program_files_reference_assemblies_microsoft_framework_v3.5_redistlist_bd550cc45cc12a27.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.5_redistlist_bd550cc45cc12a27.cdf-ms"
    30: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ea10678ae69d301f61700007c017813.$$_microsoft.net_framework64_v2.0.50727_mui_0409_ffa7e0a2ff8e4b5a.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_mui_0409_ffa7e0a2ff8e4b5a.cdf-ms"
    31: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ea10678ae69d301f71700007c017813.$$_microsoft.net_framework64_v2.0.50727_config_9c095e05b3055fa6.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_config_9c095e05b3055fa6.cdf-ms"
    32: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ea10678ae69d301f81700007c017813.$$_microsoft.net_framework64_v2.0.50727_1033_b3c88eb113ae6c57.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_1033_b3c88eb113ae6c57.cdf-ms"
    33: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ea10678ae69d301f91700007c017813.$$_inf_.net_clr_data_0000_9334e121f0277e71.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0000_9334e121f0277e71.cdf-ms"
    34: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ea10678ae69d301fa1700007c017813.$$_inf_.net_clr_networking_0000_417aaafa90927065.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_0000_417aaafa90927065.cdf-ms"
    35: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\88030978ae69d301fb1700007c017813.$$_inf_.net_data_provider_for_oracle_0000_1ac87488f00b2af0.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provid
2017-11-30 08:40:18, Info                  CSI    er_for_oracle_0000_1ac87488f00b2af0.cdf-ms"
    36: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\88030978ae69d301fc1700007c017813.$$_inf_.net_data_provider_for_sqlserver_0000_22ef191981b08b2b.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_0000_22ef191981b08b2b.cdf-ms"
    37: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\88030978ae69d301fd1700007c017813.$$_inf_.netframework_0000_fd6b5f63492732f4.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_0000_fd6b5f63492732f4.cdf-ms"
    38: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\f08c1278ae69d301fe1700007c017813.$$_system32_mui_0409_ecc96e0e9498d62e.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_system32_mui_0409_ecc96e0e9498d62e.cdf-ms"
POQ 54 ends.
2017-11-30 08:40:18, Info                  CSI    00000159 [SR] Verify complete
2017-11-30 08:40:18, Info                  CSI    0000015a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:18, Info                  CSI    0000015b [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:20, Info                  CSI    0000015c Repair results created:
POQ 55 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\16c1a878ae69d301631800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\16c1a878ae69d301641800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e4ab278ae69d301651800007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e4ab278ae69d301661800007c017813.$$_system32_networklist_029a48465a9cac56.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_networklist_029a48465a9cac56.cdf-ms"
    4: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e4ab278ae69d301671800007c017813.$$_system32_networklist_icons_2b49083c03963dec.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_networklist_icons_2b49083c03963dec.cdf-ms"
    5: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\86f9e178ae69d301681800007c017813.$$_system32_networklist_icons_stockicons_c7f9dde8d52dc62c.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_system32_networklist_icons_stockicons_c7f9dde8d52dc62c.cdf-ms"
POQ 55 ends.
2017-11-30 08:40:20, Info                  CSI    0000015d [SR] Verify complete
2017-11-30 08:40:20, Info                  CSI    0000015e [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:20, Info                  CSI    0000015f [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:21, Info                  CSI    00000160 Repair results created:
POQ 56 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\0018a379ae69d301cd1800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5a7aa579ae69d301ce1800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\5a7aa579ae69d301cf1800007c017813.$$_diagnostics_system_printer_22190c3ab8798fd9.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_printer_22190c3ab8798fd9.cdf-ms"
    3: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\5a7aa579ae69d301d01800007c017813.$$_diagnostics_system_printer_pl-pl_21300b4df755ac5c.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_printer_pl-pl_21300b4df755ac5c.cdf-ms"
    4: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\9216c279ae69d301d11800007c017813.programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42__96ac8d0751fb5c2c.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42__96ac8d0751fb5c2c.cdf-ms"
    5: Move File: Source = [l:356{178}]"\SystemRoot\WinSxS\Temp\PendingRenames\9216c279ae69d301d21800007c017813.programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42_pl-pl_98bc147303d1408b.cdf-ms", Destination = [l:268{134}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42_pl-pl_98bc147303d1408b.cdf-ms"
    6: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\ec78c479ae69d301d31800007c017813.$$_diagnostics_system_performance_d48bf95b5c828123.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_performance_d4
2017-11-30 08:40:21, Info                  CSI    8bf95b5c828123.cdf-ms"
    7: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\ec78c479ae69d301d41800007c017813.$$_diagnostics_system_performance_pl-pl_0e2f2c92c54e0682.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_performance_pl-pl_0e2f2c92c54e0682.cdf-ms"
    8: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\6229d579ae69d301d51800007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    9: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\bc8bd779ae69d301d61800007c017813.$$_system32_printing_admin_scripts_pl-pl_f2429c6b7389c19f.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_system32_printing_admin_scripts_pl-pl_f2429c6b7389c19f.cdf-ms"
    10: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e77e379ae69d301d71800007c017813.$$_system32_spool_tools_e03b2d8f300154a4.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spool_tools_e03b2d8f300154a4.cdf-ms"
    11: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e77e379ae69d301d81800007c017813.$$_system32_spool_tools_microsoft_xps_document_writer_6c7957555c36cebb.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spool_tools_microsoft_xps_document_writer_6c7957555c36cebb.cdf-ms"
    12: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8d9e579ae69d301d91800007c017813.$$_diagnostics_system_pcw_2115168e47eaddb7.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_pcw_2115168e47eaddb7.cdf-ms"
    13: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8d9e579ae69d301da1800007c017813.$$_diagnostics_system_pcw_pl-pl_30bff52c79132886.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_pcw_pl-pl_30bff52c79132886.cdf-ms"
    14: Move File: Source = [l:246{
2017-11-30 08:40:21, Info                  CSI    123}]"\SystemRoot\WinSxS\Temp\PendingRenames\8c9eea79ae69d301db1800007c017813.$$_diagnostics_system_power_9d457dc1c7c54838.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_power_9d457dc1c7c54838.cdf-ms"
    15: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\8c9eea79ae69d301dc1800007c017813.$$_diagnostics_system_power_pl-pl_8700a072559d1adf.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_power_pl-pl_8700a072559d1adf.cdf-ms"
    16: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\4e8af679ae69d301dd1800007c017813.$$_system32_spool_tools_pl-pl_251e3c99f1f4a663.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spool_tools_pl-pl_251e3c99f1f4a663.cdf-ms"
    17: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\024ffb79ae69d301de1800007c017813.$$_pla_reports_a2604845b2b380ca.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_pla_reports_a2604845b2b380ca.cdf-ms"
    18: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\024ffb79ae69d301df1800007c017813.$$_pla_reports_pl-pl_04eb7d4c9a83e841.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_pla_reports_pl-pl_04eb7d4c9a83e841.cdf-ms"
    19: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\5cb1fd79ae69d301e01800007c017813.$$_pla_rules_0bde462ce96f215e.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_pla_rules_0bde462ce96f215e.cdf-ms"
    20: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\5cb1fd79ae69d301e11800007c017813.$$_pla_rules_pl-pl_8b463dc854621dff.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_pla_rules_pl-pl_8b463dc854621dff.cdf-ms"
    21: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\b09b287aae69d301e21800007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$
2017-11-30 08:40:21, Info                  CSI    _system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    22: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\b09b287aae69d301e31800007c017813.$$_system32_windowspowershell_v1.0_en-us_028e6949cac04f1d.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_en-us_028e6949cac04f1d.cdf-ms"
POQ 56 ends.
2017-11-30 08:40:21, Info                  CSI    00000161 [SR] Verify complete
2017-11-30 08:40:22, Info                  CSI    00000162 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:22, Info                  CSI    00000163 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:23, Info                  CSI    00000164 Repair results created:
POQ 57 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\220bba7aae69d301481900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\220bba7aae69d301491900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\3032c17aae69d3014a1900007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\8a94c37aae69d3014b1900007c017813.$$_system32_spool_tools_e03b2d8f300154a4.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spool_tools_e03b2d8f300154a4.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b409d97aae69d3014c1900007c017813.$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms"
    5: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\b409d97aae69d3014d1900007c017813.$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms"
    6: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\b409d97aae69d3014e1900007c017813.$$_pla_reports_a2604845b2b380ca.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_pla_reports_a2604845b2b380ca.cdf-ms"
    7: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\b409d97aae69d3014f1900007c017813.$$_pla_rules_0bde462ce96f215e.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_pla_rules_0bde462ce96f215e.cdf-ms"
    8: Create Directory: Directory = [l:30{15}]"\??\C:\PerfLog
2017-11-30 08:40:23, Info                  CSI    s", Attributes = 00000080
    9: Create Directory: Directory = [l:42{21}]"\??\C:\PerfLogs\Admin", Attributes = 00000080
    10: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\76f5e47aae69d301501900007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    11: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\76f5e47aae69d301511900007c017813.$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms"
    12: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\76f5e47aae69d301521900007c017813.$$_inf_pnrpsvc_0415_43734285fe2eacff.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_0415_43734285fe2eacff.cdf-ms"
POQ 57 ends.
2017-11-30 08:40:23, Info                  CSI    00000165 [SR] Verify complete
2017-11-30 08:40:23, Info                  CSI    00000166 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:23, Info                  CSI    00000167 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:24, Info                  CSI    00000168 Repair results created:
POQ 58 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\f68b7d7bae69d301b71900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\f68b7d7bae69d301b81900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\04b3847bae69d301b91900007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e15877bae69d301ba1900007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    4: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\b877897bae69d301bb1900007c017813.$$_diagnostics_system_pcw_2115168e47eaddb7.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_pcw_2115168e47eaddb7.cdf-ms"
    5: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\12da8b7bae69d301bc1900007c017813.programdata_microsoft_windows_devicemetadatastore_en-us_cc94fe8746890b55.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_devicemetadatastore_en-us_cc94fe8746890b55.cdf-ms"
    6: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\6c3c8e7bae69d301bd1900007c017813.programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42__96ac8d0751fb5c2c.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_e35be42d-f742-4d96-a50a-1775fb1a7a42__96ac8d0751fb5c2c.cdf-ms"
    7: Move File: Source = [l:350{175}]"\SystemRoot\WinSxS\Temp\PendingRenames\6c3c8
2017-11-30 08:40:24, Info                  CSI    e7bae69d301be1900007c017813.programdata_microsoft_device_stage_device_113527a4-45d4-4b6f-b567-97838f1b04b0__5d055d2c3e7e3719.cdf-ms", Destination = [l:262{131}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_device_113527a4-45d4-4b6f-b567-97838f1b04b0__5d055d2c3e7e3719.cdf-ms"
    8: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\888a9c7bae69d301bf1900007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    9: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\888a9c7bae69d301c01900007c017813.program_files_windows_photo_viewer_6eb173d8debcda9a.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_photo_viewer_6eb173d8debcda9a.cdf-ms"
    10: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2ec9e7bae69d301c11900007c017813.program_files_windows_photo_viewer_pl-pl_bb188f9e8d4d4969.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_photo_viewer_pl-pl_bb188f9e8d4d4969.cdf-ms"
    11: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\0c62b47bae69d301c21900007c017813.$$_diagnostics_system_printer_22190c3ab8798fd9.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_printer_22190c3ab8798fd9.cdf-ms"
    12: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\66c4b67bae69d301c31900007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    13: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\66c4b67bae69d301c41900007c017813.$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms"
    14: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\66c4b67bae69d301c51900007c017813.$$_inf_pnrpsvc_0000_43733b07fe2eb83f.cdf-ms"
2017-11-30 08:40:24, Info                  CSI    , Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_0000_43733b07fe2eb83f.cdf-ms"
    15: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea9bce7bae69d301c61900007c017813.$$_diagnostics_system_performance_d48bf95b5c828123.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_performance_d48bf95b5c828123.cdf-ms"
    16: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e60d37bae69d301c71900007c017813.$$_diagnostics_system_power_9d457dc1c7c54838.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_power_9d457dc1c7c54838.cdf-ms"
    17: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{cdb1e969-80eb-9fe3-b74d-4e1efd035af7}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c007300700070006e0070002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a0065005f0050006e0070000000}
    18: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{cdb1e969-80eb-9fe3-a63c-82c27e3d227b}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c007300700070006e0070002e0064006c006c002c0053007900730070007200650070005f005300700065006300690061006c0069007a0065005f0050006e0070000000}
POQ 58 ends.
2017-11-30 08:40:24, Info                  CSI    00000169 [SR] Verify complete
2017-11-30 08:40:24, Info                  CSI    0000016a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:24, Info                  CSI    0000016b [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:25, Info                  CSI    0000016c Repair results created:
POQ 59 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e65a4f7cae69d3012c1a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:172{86}]"\SystemRoot\WinSxS\Temp\PendingRenames\b66d627cae69d3012d1a00007c017813.inetpub.cdf-ms", Destination = [l:84{42}]"\SystemRoot\WinSxS\FileMaps\inetpub.cdf-ms"
    2: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\b66d627cae69d3012e1a00007c017813.inetpub_history_544341bbdb3f6a63.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\inetpub_history_544341bbdb3f6a63.cdf-ms"
    3: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\b66d627cae69d3012f1a00007c017813.inetpub_temp_apppools_d45254d8326d1687.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\inetpub_temp_apppools_d45254d8326d1687.cdf-ms"
    4: Set File Information: File = [l:56{28}]"\??\C:\inetpub\temp\appPools", Attributes = 00000080
    5: Set File Information: File = [l:44{22}]"\??\C:\inetpub\history", Attributes = 00000080
    6: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\10d0647cae69d301301a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    7: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\78596e7cae69d301311a00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
POQ 59 ends.
2017-11-30 08:40:25, Info                  CSI    0000016d [SR] Verify complete
2017-11-30 08:40:26, Info                  CSI    0000016e [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:26, Info                  CSI    0000016f [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:27, Info                  CSI    00000170 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Inf\RemoteAccess" in component Microsoft-Windows-Rasctrs, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:27, Info                  CSI    00000171 Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\Inf\RemoteAccess\0000" in component Microsoft-Windows-Rasctrs, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:27, Info                  CSI    00000172 Repair results created:
POQ 60 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\442b027dae69d301961a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\442b027dae69d301971a00007c017813.programdata_microsoft_network_connections_2e5c3accd04dd407.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_network_connections_2e5c3accd04dd407.cdf-ms"
    2: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5252097dae69d301981a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    3: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\badb127dae69d301991a00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\badb127dae69d3019a1a00007c017813.$$_system32_setup_5d3758a05cf4a445.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_setup_5d3758a05cf4a445.cdf-ms"
    5: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\d629217dae69d3019b1a00007c017813.$$_system32_ras_06656461d047b86c.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_system32_ras_06656461d047b86c.cdf-ms"
    6: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\a63c347dae69d3019c1a00007c017813.$$_system32_migration_927a21df1acd7c18.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_927a21df1acd7c18.cdf-ms"
    7: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\a63c347dae69d3019d1a00007c017813.$$_system32_migration_wsmt_rras_replacementmanifests_475f557ec0a59abb.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_wsmt_rras_re
2017-11-30 08:40:27, Info                  CSI    placementmanifests_475f557ec0a59abb.cdf-ms"
    8: Move File: Source = [l:366{183}]"\SystemRoot\WinSxS\Temp\PendingRenames\a63c347dae69d3019e1a00007c017813.$$_system32_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasapi-migplugin_4c5cfbc1ceebb383.cdf-ms", Destination = [l:278{139}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasapi-migplugin_4c5cfbc1ceebb383.cdf-ms"
    9: Move File: Source = [l:372{186}]"\SystemRoot\WinSxS\Temp\PendingRenames\009f367dae69d3019f1a00007c017813.$$_system32_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasserver-migplugin_b1d9b81e0b884bcc.cdf-ms", Destination = [l:284{142}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasserver-migplugin_b1d9b81e0b884bcc.cdf-ms"
    10: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\009f367dae69d301a01a00007c017813.$$_system32_migration_wsmt_rras_dlmanifests_3797d36d4dbe18ed.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_wsmt_rras_dlmanifests_3797d36d4dbe18ed.cdf-ms"
    11: Move File: Source = [l:354{177}]"\SystemRoot\WinSxS\Temp\PendingRenames\009f367dae69d301a11a00007c017813.$$_system32_migration_wsmt_rras_dlmanifests_microsoft-windows-rasserver-migplugin_60ef4b1ac8368ae4.cdf-ms", Destination = [l:266{133}]"\SystemRoot\WinSxS\FileMaps\$$_system32_migration_wsmt_rras_dlmanifests_microsoft-windows-rasserver-migplugin_60ef4b1ac8368ae4.cdf-ms"
    12: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0b1497dae69d301a21a00007c017813.$$_tracing_bca9e27848ac4cc0.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_tracing_bca9e27848ac4cc0.cdf-ms"
    13: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\46625a7dae69d301a31a00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
2017-11-30 08:40:27, Info                  CSI    SystemRoot\WinSxS\Temp\PendingRenames\46625a7dae69d301a41a00007c017813.$$_inf_remoteaccess_110554180baafc8b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_110554180baafc8b.cdf-ms"
    15: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\a0c45c7dae69d301a51a00007c017813.$$_inf_remoteaccess_0000_86bc982ae65d5d49.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_0000_86bc982ae65d5d49.cdf-ms"
POQ 60 ends.
2017-11-30 08:40:27, Info                  CSI    00000173 [SR] Verify complete
2017-11-30 08:40:27, Info                  CSI    00000174 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:27, Info                  CSI    00000175 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:28, Info                  CSI    00000176 Repair results created:
POQ 61 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1234ee7dae69d3010a1b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\6c96f07dae69d3010b1b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\6c96f07dae69d3010c1b00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    3: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\6c96f07dae69d3010d1b00007c017813.$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms"
    4: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\d41ffa7dae69d3010e1b00007c017813.$$_media_quirky_6baa21a590d24b57.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_quirky_6baa21a590d24b57.cdf-ms"
    5: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\2e82fc7dae69d3010f1b00007c017813.$$_media_sonata_6b55eb3f91aab49e.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_sonata_6b55eb3f91aab49e.cdf-ms"
    6: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\e246017eae69d301101b00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    7: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\e246017eae69d301111b00007c017813.$$_inf_rdyboost_95e76b07334dd353.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_inf_rdyboost_95e76b07334dd353.cdf-ms"
    8: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\e246017eae69d301121b00007c017813.
2017-11-30 08:40:28, Info                  CSI    $$_inf_rdyboost_0415_50c6198f7330ca5d.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_rdyboost_0415_50c6198f7330ca5d.cdf-ms"
    9: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\960b067eae69d301131b00007c017813.$$_media_garden_6cea56938e5bd6b1.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_garden_6cea56938e5bd6b1.cdf-ms"
    10: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\960b067eae69d301141b00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    11: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\960b067eae69d301151b00007c017813.$$_ehome_createdisc_ed3f8f2e7a4426af.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_ed3f8f2e7a4426af.cdf-ms"
    12: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\f06d087eae69d301161b00007c017813.$$_ehome_createdisc_filters_5fe1b967f204215a.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_filters_5fe1b967f204215a.cdf-ms"
    13: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\0cbc167eae69d301171b00007c017813.$$_web_3f580d25a4c8e0a0.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_web_3f580d25a4c8e0a0.cdf-ms"
    14: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\0cbc167eae69d301181b00007c017813.$$_web_wallpaper_characters_a0a6ad47bc54d5d2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_characters_a0a6ad47bc54d5d2.cdf-ms"
    15: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\cea7227eae69d301191b00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    16: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\cea7227eae69d3011a1b00007c017813.$$_system32_spp
2017-11-30 08:40:28, Info                  CSI    _tokens_issuance_2c48fd0ccc1c41cc.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_issuance_2c48fd0ccc1c41cc.cdf-ms"
    17: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\527f3a7eae69d3011b1b00007c017813.$$_web_wallpaper_landscapes_dd1321c96ffce30a.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_landscapes_dd1321c96ffce30a.cdf-ms"
    18: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\6ecd487eae69d3011c1b00007c017813.$$_ehome_createdisc_sfxplugins_5b043573249413c8.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_sfxplugins_5b043573249413c8.cdf-ms"
POQ 61 ends.
2017-11-30 08:40:28, Info                  CSI    00000177 [SR] Verify complete
2017-11-30 08:40:28, Info                  CSI    00000178 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:28, Info                  CSI    00000179 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:30, Info                  CSI    0000017a Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\Web\Wallpaper\Windows" in component Microsoft-Windows-Shell-Wallpaper-Windows, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:30, Info                  CSI    0000017b Repair results created:
POQ 62 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\b6c7c47eae69d301811b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\b6c7c47eae69d301821b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\b6c7c47eae69d301831b00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    3: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\b6c7c47eae69d301841b00007c017813.$$_media_characters_8ee06d90f7dead3a.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_media_characters_8ee06d90f7dead3a.cdf-ms"
    4: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\102ac77eae69d301851b00007c017813.$$_diagnostics_index_6f9ad1a80c4f7ad6.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_index_6f9ad1a80c4f7ad6.cdf-ms"
    5: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c78d57eae69d301861b00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    6: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\86dad77eae69d301871b00007c017813.$$_system32_speech_speechux_bf4b53e8d47da913.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_speech_speechux_bf4b53e8d47da913.cdf-ms"
    7: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee63e17eae69d301881b00007c017813.$$_prefetch_1688e4e8b2f89473.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_prefetch_1688e4e8b2f89473.cdf-ms"
    8: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames
2017-11-30 08:40:30, Info                  CSI    \ee63e17eae69d301891b00007c017813.$$_prefetch_readyboot_925024bb73d7b5a6.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_prefetch_readyboot_925024bb73d7b5a6.cdf-ms"
    9: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee63e17eae69d3018a1b00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    10: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee63e17eae69d3018b1b00007c017813.$$_inf_rdyboost_95e76b07334dd353.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_inf_rdyboost_95e76b07334dd353.cdf-ms"
    11: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\ee63e17eae69d3018c1b00007c017813.$$_inf_rdyboost_0000_50c61a1d7330c91d.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_rdyboost_0000_50c61a1d7330c91d.cdf-ms"
    12: Set File Information: File = [l:46{23}]"\??\C:\Windows\prefetch", Attributes = 00000080
    13: Set File Information: File = [l:66{33}]"\??\C:\Windows\prefetch\ReadyBoot", Attributes = 00000080
    14: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\b04fed7eae69d3018d1b00007c017813.$$_system32_spp_tokens_identity_11b267e2f2add041.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_identity_11b267e2f2add041.cdf-ms"
    15: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\6414f27eae69d3018e1b00007c017813.$$_media_delta_0f36d7d9b4f7293c.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_media_delta_0f36d7d9b4f7293c.cdf-ms"
    16: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\f612117fae69d3018f1b00007c017813.$$_system32_spp_tokens_skus_security-spp-component-sku-professional_b76e8f28df7dd879.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_skus_security-spp-component-sku-professional_b76e8f28df7dd879.cdf-ms"
2017-11-30 08:40:30, Info                  CSI    [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e9c1a7fae69d301901b00007c017813.$$_diagnostics_system_search_9d4b5385ff8f1ef3.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_search_9d4b5385ff8f1ef3.cdf-ms"
    18: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e9c1a7fae69d301911b00007c017813.$$_diagnostics_system_search_pl-pl_0997d12588c0a066.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_search_pl-pl_0997d12588c0a066.cdf-ms"
    19: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\7aea287fae69d301921b00007c017813.$$_web_3f580d25a4c8e0a0.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_web_3f580d25a4c8e0a0.cdf-ms"
    20: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\7aea287fae69d301931b00007c017813.$$_web_wallpaper_architecture_7e5377d6faf00937.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_architecture_7e5377d6faf00937.cdf-ms"
    21: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\2eaf2d7fae69d301941b00007c017813.$$_web_wallpaper_windows_bcf8a09f6400ad61.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_windows_bcf8a09f6400ad61.cdf-ms"
    22: Set File Information: File = [l:72{36}]"\??\C:\Windows\Web\Wallpaper\Windows", Attributes = 00000081
    23: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{f6e809e0-4867-9b5d-5fbc-2ce1ce25c0e2}", Type = REG_SZ (1), Data = {l:102 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c007300790073006d00610069006e002e0064006c006c002c005000660053007600530079007300700072006500700043006c00650061006e00750070000000}
POQ 62 ends.
2017-11-30 08:40:30, Info                  CSI    0000017c [SR] Verify complete
2017-11-30 08:40:30, Info                  CSI    0000017d [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:30, Info                  CSI    0000017e [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:31, Info                  CSI    0000017f Repair results created:
POQ 63 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c47a77fae69d301f91b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c47a77fae69d301fa1b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c47a77fae69d301fb1b00007c017813.$$_security_fe3ad40cd6e08c7c.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_security_fe3ad40cd6e08c7c.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c47a77fae69d301fc1b00007c017813.$$_security_audit_073f574e8f328f85.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_security_audit_073f574e8f328f85.cdf-ms"
    4: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\de32b37fae69d301fd1b00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    5: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\de32b37fae69d301fe1b00007c017813.$$_system32_spp_tokens_pkeyconfig_d8fc0830c525895a.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_pkeyconfig_d8fc0830c525895a.cdf-ms"
    6: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\92f7b77fae69d301ff1b00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    7: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\92f7b77fae69d301001c00007c017813.$$_media_afternoon_ae5d080a6a887942.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_afternoon_ae5d080a6a887942.cdf-ms"
2017-11-30 08:40:31, Info                  CSI    ames\620acb7fae69d301011c00007c017813.$$_media_heritage_bd7af0f60e3b0705.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_media_heritage_bd7af0f60e3b0705.cdf-ms"
    9: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\620acb7fae69d301021c00007c017813.$$_globalization_els_spelldictionaries_f8bab08f83431341.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\$$_globalization_els_spelldictionaries_f8bab08f83431341.cdf-ms"
    10: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\7031d27fae69d301031c00007c017813.$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms"
    11: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8badb7fae69d301041c00007c017813.$$_system32_slmgr_0415_c09c74920002f779.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_slmgr_0415_c09c74920002f779.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b6f4f57fae69d301051c00007c017813.$$_media_festival_d2aa354bee3f11cc.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_media_festival_d2aa354bee3f11cc.cdf-ms"
POQ 63 ends.
2017-11-30 08:40:31, Info                  CSI    00000180 [SR] Verify complete
2017-11-30 08:40:31, Info                  CSI    00000181 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:31, Info                  CSI    00000182 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:33, Info                  CSI    00000183 Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\security" in component Microsoft-Windows-Security-Security Configuration Engine Client, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:33, Info                  CSI    00000184 Repair results created:
POQ 64 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\82c68980ae69d3016a1c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\82c68980ae69d3016b1c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\90ed9080ae69d3016c1c00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea4f9380ae69d3016d1c00007c017813.$$_system32_sppui_5d3749c25cf4bbd3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sppui_5d3749c25cf4bbd3.cdf-ms"
    4: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\14c5a880ae69d3016e1c00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    5: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\14c5a880ae69d3016f1c00007c017813.$$_media_landscape_e9488ca8249a3acf.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_landscape_e9488ca8249a3acf.cdf-ms"
    6: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c4eb280ae69d301701c00007c017813.$$_diagnostics_system_search_9d4b5385ff8f1ef3.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_search_9d4b5385ff8f1ef3.cdf-ms"
    7: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4eace80ae69d301711c00007c017813.$$_system32_spp_plugin-manifests-signed_d1e9d31c180bebd2.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_plugin-manifests-signed_d1e9d31c180bebd2.cdf-ms"
2017-11-30 08:40:33, Info                  CSI    l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\68afd380ae69d301721c00007c017813.$$_security_fe3ad40cd6e08c7c.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_security_fe3ad40cd6e08c7c.cdf-ms"
    9: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\76d6da80ae69d301731c00007c017813.$$_media_cityscape_b0cbff7c81824cc5.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_cityscape_b0cbff7c81824cc5.cdf-ms"
    10: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\38c2e680ae69d301741c00007c017813.$$_system32_speech_speechux_bf4b53e8d47da913.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_speech_speechux_bf4b53e8d47da913.cdf-ms"
    11: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\38c2e680ae69d301751c00007c017813.$$_system32_speech_speechux_pl-pl_99def1c839df61d2.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_system32_speech_speechux_pl-pl_99def1c839df61d2.cdf-ms"
    12: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\6237fc80ae69d301761c00007c017813.$$_system32_spp_tokens_ppdlic_0f09ba294211a24b.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_ppdlic_0f09ba294211a24b.cdf-ms"
    13: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{efbaf953-e7ca-9633-88bf-66c14455b53b}", Type = REG_SZ (1), Data = {l:84 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073006300650063006c0069002e0064006c006c002c0053006300650053007900730050007200650070000000}
    14: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{37927d27-5ce7-7887-533f-7db889fff253}", Type = REG_SZ (1), Data = {l:86 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073006c0063002e0064006c006c002c0053004c0052
2017-11-30 08:40:33, Info                  CSI    006500410072006d00570069006e0064006f00770073000000}
POQ 64 ends.
2017-11-30 08:40:33, Info                  CSI    00000185 [SR] Verify complete
2017-11-30 08:40:33, Info                  CSI    00000186 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:33, Info                  CSI    00000187 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:36, Info                  CSI    00000188 Ignoring duplicate ownership for directory [l:44{22}]"\??\C:\Windows\Cursors" in component Microsoft-Windows-Shell-Cursors, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:36, Info                  CSI    00000189 Repair results created:
POQ 65 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\7a522182ae69d301db1c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ebc42182ae69d301dc1c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\36112282ae69d301dd1c00007c017813.$$_cursors_bff8b8b245707919.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_cursors_bff8b8b245707919.cdf-ms"
    3: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4c52882ae69d301de1c00007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    4: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\1f122982ae69d301df1c00007c017813.$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms"
    5: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ccd3a82ae69d301e01c00007c017813.$$_web_3f580d25a4c8e0a0.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_web_3f580d25a4c8e0a0.cdf-ms"
    6: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\e7193b82ae69d301e11c00007c017813.$$_web_wallpaper_nature_be2d0c211d1167a9.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_nature_be2d0c211d1167a9.cdf-ms"
    7: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\75c94482ae69d301e21c00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    8: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\84df4682ae69d301e31c00007c017813.$$_system32_en-u
2017-11-30 08:40:36, Info                  CSI    s_429cd25484dc6f94.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_en-us_429cd25484dc6f94.cdf-ms"
    9: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ae7ab82ae69d301e41c00007c017813.$$_system32_icsxml_1f8f393b196e65ae.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_system32_icsxml_1f8f393b196e65ae.cdf-ms"
    10: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3e4c382ae69d301e51c00007c017813.$$_system32_advancedinstallers_dfe2cf200b391371.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_system32_advancedinstallers_dfe2cf200b391371.cdf-ms"
    11: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\40acdd82ae69d301e61c00007c017813.$$_web_wallpaper_scenes_bd7cd5771e94d62b.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_web_wallpaper_scenes_bd7cd5771e94d62b.cdf-ms"
    12: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{c3e1d2d8-83bd-9052-4561-c2be81045f3e}", Type = REG_SZ (1), Data = {l:140 ml:140 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c006f006f00620065005c00770069006e007300650074007500..53007000530065007400750070004f006e006c0069006e006500530065007400740069006e00670073005300700065006300690061006c0069007a0065000000}
    13: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{003fb8dd-d81b-3080-3200-c2f12d89732a}", Type = REG_SZ (1), Data = {l:108 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073006800730065007400750070002e0064006c006c002c0053007900730070007200650070005f0043006c00650061006e00750070005f005300680065006c006c000000}
    14: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{003fb8dd-d81b-3080-5ee6-b970cace3cd8}",
2017-11-30 08:40:36, Info                  CSI    Type = REG_SZ (1), Data = {l:114 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073006800730065007400750070002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a0065005f005300680065006c006c000000}
    15: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{003fb8dd-d81b-3080-0753-7a178cea9807}", Type = REG_SZ (1), Data = {l:114 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c0073006800730065007400750070002e0064006c006c002c0053007900730070007200650070005f005300700065006300690061006c0069007a0065005f005300680065006c006c000000}
POQ 65 ends.
2017-11-30 08:40:36, Info                  CSI    0000018a [SR] Verify complete
2017-11-30 08:40:36, Info                  CSI    0000018b [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:36, Info                  CSI    0000018c [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:38, Info                  CSI    0000018d Repair results created:
POQ 66 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\fe566a83ae69d3014b1d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\4aa36a83ae69d3014c1d00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\95ef6a83ae69d3014d1d00007c017813.program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_8d6dbc4becba56da.cdf-ms"
    3: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\e03b6b83ae69d3014e1d00007c017813.program_files_windows_sidebar_pl-pl_46939081f3dc1d19.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_pl-pl_46939081f3dc1d19.cdf-ms"
    4: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ef516d83ae69d3014f1d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    5: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\85ea6d83ae69d301501d00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    6: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1366e83ae69d301511d00007c017813.$$_ehome_createdisc_ed3f8f2e7a4426af.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_ed3f8f2e7a4426af.cdf-ms"
    7: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c836e83ae69d301521d00007c017813.$$_ehome_createdisc_style_0d4521df11573950.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_style_0d4521df11573950.cdf-ms"
    8: Move
2017-11-30 08:40:38, Info                  CSI    File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\f8ef9783ae69d301531d00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    9: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\4a479983ae69d301541d00007c017813.$$_system32_speech_common_8c297630658eaa3d.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_speech_common_8c297630658eaa3d.cdf-ms"
    10: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\baca9e83ae69d301551d00007c017813.program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_sidebar_gadgets_265d2ddf4d58a723.cdf-ms"
    11: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\2a4ea483ae69d301561d00007c017813.$$_speech_common_76cd6f1aaba6e83b.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_speech_common_76cd6f1aaba6e83b.cdf-ms"
    12: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\c0f7a983ae69d301571d00007c017813.$$_ehome_createdisc_styles_ntsc_c4d1e502f2c449b1.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_ntsc_c4d1e502f2c449b1.cdf-ms"
    13: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\0b44aa83ae69d301581d00007c017813.$$_ehome_createdisc_styles_ntsc_symphony_daaa4003771a0c78.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_ntsc_symphony_daaa4003771a0c78.cdf-ms"
    14: Move File: Source = [l:290{145}]"\SystemRoot\WinSxS\Temp\PendingRenames\5790aa83ae69d301591d00007c017813.$$_ehome_createdisc_styles_ntsc_symphony_symphony_97a43ae95f09b239.cdf-ms", Destination = [l:202{101}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_ntsc_symphony_symphony_97a43ae95f09b239.cdf-ms"
    15: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\f533ac83ae69d301
2017-11-30 08:40:38, Info                  CSI    5a1d00007c017813.$$_ehome_createdisc_components_ccfb52aef0cf0151.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_components_ccfb52aef0cf0151.cdf-ms"
    16: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\4080ac83ae69d3015b1d00007c017813.$$_ehome_createdisc_components_tables_c2b8c3e0749098d8.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_components_tables_c2b8c3e0749098d8.cdf-ms"
    17: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\65b7b183ae69d3015c1d00007c017813.$$_ehome_createdisc_sonicresources_7e22c968e006c522.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_sonicresources_7e22c968e006c522.cdf-ms"
    18: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd3bbe83ae69d3015d1d00007c017813.$$_system32_smi_schema_b445cd341d59fadc.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_smi_schema_b445cd341d59fadc.cdf-ms"
    19: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\16c0ca83ae69d3015e1d00007c017813.$$_system32_spp_tokens_channels_ocur_c1b54526a616e8b6.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_system32_spp_tokens_channels_ocur_c1b54526a616e8b6.cdf-ms"
    20: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\e305ed83ae69d3015f1d00007c017813.$$_ehome_createdisc_styles_pal_55d264f56641a00e.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_pal_55d264f56641a00e.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\2f52ed83ae69d301601d00007c017813.$$_ehome_createdisc_styles_pal_symphony_b9729623521ab9e5.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_pal_symphony_b9729623521ab9e5.cdf-ms"
    22: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\5478ed83ae69d301611d00007c017813.$$_ehome_createdisc_styles_p
2017-11-30 08:40:38, Info                  CSI    al_symphony_symphony_f1d008156719fefe.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_createdisc_styles_pal_symphony_symphony_f1d008156719fefe.cdf-ms"
    23: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\4ba0fb83ae69d301621d00007c017813.$$_system32_speech_engines_sr_f5f77fb9283237d8.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_speech_engines_sr_f5f77fb9283237d8.cdf-ms"
POQ 66 ends.
2017-11-30 08:40:38, Info                  CSI    0000018e [SR] Verify complete
2017-11-30 08:40:38, Info                  CSI    0000018f [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:38, Info                  CSI    00000190 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:39, Info                  CSI    00000191 Repair results created:
POQ 67 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\29337884ae69d301c71d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\747f7884ae69d301c81d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\204a8184ae69d301c91d00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\8c33a584ae69d301ca1d00007c017813.programdata_microsoft_devicesync_d6b7928aa153816d.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_devicesync_d6b7928aa153816d.cdf-ms"
    4: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\40f8a984ae69d301cb1d00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    5: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\8b44aa84ae69d301cc1d00007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    6: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\d690aa84ae69d301cd1d00007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    7: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\6d29ab84ae69d301ce1d00007c017813.program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\
2017-11-30 08:40:39, Info                  CSI    program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms"
    8: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\b875ab84ae69d301cf1d00007c017813.program_files_common_files_microsoft_shared_ink_hwrcustomization_198fbcb0f379ad82.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_hwrcustomization_198fbcb0f379ad82.cdf-ms"
    9: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d30b684ae69d301d01d00007c017813.$$_system32_sysprep_f7b45b8dfed1b768.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_sysprep_f7b45b8dfed1b768.cdf-ms"
    10: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{6407eabf-ba2e-75d7-07bd-00f3276e41cf}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730070006f0070006b002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a0065005f004f0070006b000000}
    11: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{6407eabf-ba2e-75d7-a048-412e48a3b856}", Type = REG_SZ (1), Data = {l:96 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730070006f0070006b002e0064006c006c002c0053007900730070007200650070005f0043006c00650061006e005f004f0070006b000000}
    12: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{6407eabf-ba2e-75d7-f6ab-3497d0a40953}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730070006f0070006b002e0064006c006c002c0053007900730070007200650070005f005300700065006300690061006c0069007a0065005f004f0070006b000000}
2017-11-30 08:40:39, Info                  CSI    \Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{e330980e-9a5b-a548-ee22-e585dac90889}", Type = REG_SZ (1), Data = {l:58 b:7300720063006f00720065002e0064006c006c002c005300790073007000720065007000470065006e006500720061006c0069007a0065000000}
    14: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{e330980e-9a5b-a548-b4ea-08ccb5259f11}", Type = REG_SZ (1), Data = {l:52 b:7300720063006f00720065002e0064006c006c002c00530079007300700072006500700043006c00650061006e00750070000000}
    15: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{1b6dc7ec-b87c-5c63-5cc0-12a85b132913}", Type = REG_SZ (1), Data = {l:64 b:730071006d006100700069002e0064006c006c002c00530071006d005300790073007000720065007000470065006e006500720061006c0069007a0065000000}
    16: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{1b6dc7ec-b87c-5c63-23c7-60544b9fbb46}", Type = REG_SZ (1), Data = {l:64 b:730071006d006100700069002e0064006c006c002c00530071006d0053007900730070007200650070005300700065006300690061006c0069007a0065000000}
    17: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{1b6dc7ec-b87c-5c63-d01e-70397b096ced}", Type = REG_SZ (1), Data = {l:58 b:730071006d006100700069002e0064006c006c002c00530071006d00530079007300700072006500700043006c00650061006e00750070000000}
    18: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{67599346-69ce-7099-410d-e7bf974f5136}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730070006200630064002e0064006c006c002c0053007900730070007200650070005f00470065006e006500720061006c0069007a00650
2017-11-30 08:40:39, Info                  CSI    05f004200630064000000}
    19: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{67599346-69ce-7099-30fc-1a64408619ba}", Type = REG_SZ (1), Data = {l:106 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730070006200630064002e0064006c006c002c0053007900730070007200650070005f005300700065006300690061006c0069007a0065005f004200630064000000}
POQ 67 ends.
2017-11-30 08:40:39, Info                  CSI    00000192 [SR] Verify complete
2017-11-30 08:40:39, Info                  CSI    00000193 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:39, Info                  CSI    00000194 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:41, Info                  CSI    00000195 Repair results created:
POQ 68 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\6fb96585ae69d301351e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e02b6685ae69d301361e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c786685ae69d301371e00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\77c46685ae69d301381e00007c017813.$$_inf_termservice_f0fb244350031192.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_termservice_f0fb244350031192.cdf-ms"
    4: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\9cea6685ae69d301391e00007c017813.$$_inf_termservice_0415_f96d64636bc76488.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_inf_termservice_0415_f96d64636bc76488.cdf-ms"
    5: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\6fca6a85ae69d3013a1e00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\94f06a85ae69d3013b1e00007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    7: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\e03c6b85ae69d3013c1e00007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    8: Move
2017-11-30 08:40:41, Info                  CSI    File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b896b85ae69d3013d1e00007c017813.program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms"
    9: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\76d56b85ae69d3013e1e00007c017813.program_files_common_files_microsoft_shared_ink_ko-kr_957cde9c08f2acc2.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_ko-kr_957cde9c08f2acc2.cdf-ms"
    10: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\04747085ae69d3013f1e00007c017813.program_files_common_files_microsoft_shared_ink_da-dk_882f8e141ce6a40d.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_da-dk_882f8e141ce6a40d.cdf-ms"
    11: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\66e17385ae69d301401e00007c017813.program_files_common_files_microsoft_shared_ink_et-ee_8a15f79e1a0d07c0.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_et-ee_8a15f79e1a0d07c0.cdf-ms"
    12: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\6cfd7985ae69d301411e00007c017813.program_files_common_files_microsoft_shared_ink_pl-pl_9efd29a5fab23be7.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_pl-pl_9efd29a5fab23be7.cdf-ms"
    13: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\0aa17b85ae69d301421e00007c017813.program_files_common_files_microsoft_shared_ink_pt-pt_9efd37b5fab227a7.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_pt-pt_9efd37b5fab227a7.cdf-ms"
    14: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\81408785ae69d301431e00007c0
2017-11-30 08:40:41, Info                  CSI    17813.program_files_common_files_microsoft_shared_ink_es-es_8a1612561a0cdf91.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_es-es_8a1612561a0cdf91.cdf-ms"
    15: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a308985ae69d301441e00007c017813.program_files_common_files_microsoft_shared_ink_bg-bg_84629670229a1823.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_bg-bg_84629670229a1823.cdf-ms"
    16: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\08d48a85ae69d301451e00007c017813.program_files_common_files_microsoft_shared_ink_ro-ro_a2ca1e1ff4fecd83.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_ro-ro_a2ca1e1ff4fecd83.cdf-ms"
    17: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\80518c85ae69d301461e00007c017813.program_files_common_files_microsoft_shared_ink_ru-ru_a2ca28abf4febe53.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_ru-ru_a2ca28abf4febe53.cdf-ms"
    18: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\4b268f85ae69d301471e00007c017813.program_files_common_files_microsoft_shared_ink_de-de_882f82201ce6b667.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_de-de_882f82201ce6b667.cdf-ms"
    19: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\e9c99085ae69d301481e00007c017813.program_files_common_files_microsoft_shared_ink_lt-lt_9763594e0618f53f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_lt-lt_9763594e0618f53f.cdf-ms"
    20: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\f8df9285ae69d301491e00007c017813.program_files_common_files_microsoft_shared_ink_lv-lv_97635cd20618f02f.cdf
2017-11-30 08:40:41, Info                  CSI    -ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_lv-lv_97635cd20618f02f.cdf-ms"
    21: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\b1e2a785ae69d3014a1e00007c017813.program_files_common_files_microsoft_shared_ink_it-it_91aff2800ea60f71.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_it-it_91aff2800ea60f71.cdf-ms"
    22: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\1250ab85ae69d3014b1e00007c017813.program_files_common_files_microsoft_shared_ink_fi-fi_8bfc785c1733457b.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fi-fi_8bfc785c1733457b.cdf-ms"
    23: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\b0f3ac85ae69d3014c1e00007c017813.program_files_common_files_microsoft_shared_ink_fr-fr_8bfc882e17332eb3.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fr-fr_8bfc882e17332eb3.cdf-ms"
    24: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\4e97ae85ae69d3014d1e00007c017813.program_files_common_files_microsoft_shared_ink_nl-nl_9b303a720065a2b3.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_nl-nl_9b303a720065a2b3.cdf-ms"
    25: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\1261b085ae69d3014e1e00007c017813.program_files_common_files_microsoft_shared_ink_ja-jp_9396652e0bcc616c.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_ja-jp_9396652e0bcc616c.cdf-ms"
    26: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\2f8db485ae69d3014f1e00007c017813.program_files_common_files_microsoft_shared_ink_sk-sk_a4b08eb1f225243d.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_commo
2017-11-30 08:40:41, Info                  CSI    n_files_microsoft_shared_ink_sk-sk_a4b08eb1f225243d.cdf-ms"
    27: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\178ebb85ae69d301501e00007c017813.program_files_common_files_microsoft_shared_ink_hr-hr_8fc97762117fc7e7.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_hr-hr_8fc97762117fc7e7.cdf-ms"
    28: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\b531bd85ae69d301511e00007c017813.program_files_common_files_microsoft_shared_ink_hu-hu_8fc97ca8117fc04f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_hu-hu_8fc97ca8117fc04f.cdf-ms"
    29: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea6dbf85ae69d301521e00007c017813.program_files_common_files_microsoft_shared_ink_cs-cz_8649306c1fc0326e.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_cs-cz_8649306c1fc0326e.cdf-ms"
    30: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\43e1c685ae69d301531e00007c017813.program_files_common_files_microsoft_shared_ink_en-us_8a16130a1a0cde0c.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_en-us_8a16130a1a0cde0c.cdf-ms"
    31: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\a44eca85ae69d301541e00007c017813.program_files_common_files_microsoft_shared_ink_he-il_8fc96dd2117fd4e1.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_he-il_8fc96dd2117fd4e1.cdf-ms"
    32: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\42f2cb85ae69d301551e00007c017813.program_files_common_files_microsoft_shared_ink_pt-br_9efd33e9fab22d4b.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_pt-br_9efd33e9fab22d4b.cdf-ms"
    33: Move File:
2017-11-30 08:40:41, Info                  CSI    Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\e095cd85ae69d301561e00007c017813.program_files_common_files_microsoft_shared_ink_ar-sa_827c11e62573e02c.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_ar-sa_827c11e62573e02c.cdf-ms"
    34: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\763fd385ae69d301571e00007c017813.program_files_common_files_microsoft_shared_ink_el-gr_8a16116c1a0ce035.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_el-gr_8a16116c1a0ce035.cdf-ms"
    35: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\3909d585ae69d301581e00007c017813.program_files_common_files_microsoft_shared_ink_nb-no_9b30418c006596fe.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_nb-no_9b30418c006596fe.cdf-ms"
POQ 68 ends.
2017-11-30 08:40:41, Info                  CSI    00000196 [SR] Verify complete
2017-11-30 08:40:41, Info                  CSI    00000197 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:41, Info                  CSI    00000198 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:42, Info                  CSI    00000199 Ignoring duplicate ownership for directory [l:108{54}]"\??\C:\Program Files\Common Files\Microsoft Shared\Ink" in component Microsoft-Windows-TabletPC-Platform-COMRuntime, Version = 6.1.7601.23375, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:43, Info                  CSI    0000019a Repair results created:
POQ 69 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\357d8986ae69d301bd1e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\80c98986ae69d301be1e00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\cc158a86ae69d301bf1e00007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    3: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d888a86ae69d301c01e00007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    4: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\adfa8a86ae69d301c11e00007c017813.program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms"
    5: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\da2b8c86ae69d301c21e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    6: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\4b9e8c86ae69d301c31e00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    7: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\71c48c86ae69d301c41e00007c017813.$$_inf_termservice_f0fb244350031192.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_te
2017-11-30 08:40:43, Info                  CSI    rmservice_f0fb244350031192.cdf-ms"
    8: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\bc108d86ae69d301c51e00007c017813.$$_inf_termservice_0000_f96d5ce56bc76fc8.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_inf_termservice_0000_f96d5ce56bc76fc8.cdf-ms"
    9: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1ca09a86ae69d301c61e00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\50dc9c86ae69d301c71e00007c017813.$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms"
    11: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\c14e9d86ae69d301c81e00007c017813.$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms"
    12: Move File: Source = [l:344{172}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d9b9d86ae69d301c91e00007c017813.$$_system32_tasks_microsoft_windows_remoteapp_and_desktop_connections_update_c0beaecbfc21a5e1.cdf-ms", Destination = [l:256{128}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_windows_remoteapp_and_desktop_connections_update_c0beaecbfc21a5e1.cdf-ms"
    13: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\7d0d9e86ae69d301ca1e00007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    14: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\a3339e86ae69d301cb1e00007c017813.$$_schemas_tsworkspace_8eac79c1e59127ee.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_tsworkspace_8eac79c1e59127ee.cdf-ms"
    15: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\dd9cab86ae69d3
2017-11-30 08:40:43, Info                  CSI    01cc1e00007c017813.program_files_common_files_microsoft_shared_ink_th-th_a6970105ef4b786f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_th-th_a6970105ef4b786f.cdf-ms"
    16: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\a166ad86ae69d301cd1e00007c017813.program_files_common_files_microsoft_shared_ink_tr-tr_a6971299ef4b5f1f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_tr-tr_a6971299ef4b5f1f.cdf-ms"
    17: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d31b686ae69d301ce1e00007c017813.program_files_common_files_microsoft_shared_ink_sr-latn-cs_c779913ce1dfaa20.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_sr-latn-cs_c779913ce1dfaa20.cdf-ms"
    18: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\dbcfba86ae69d301cf1e00007c017813.program_files_common_files_microsoft_shared_ink_uk-ua_a87d6ae9ec71d9eb.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_uk-ua_a87d6ae9ec71d9eb.cdf-ms"
    19: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\6faccf86ae69d301d01e00007c017813.program_files_common_files_microsoft_shared_ink_sv-se_a4b081c1f22538ce.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_sv-se_a4b081c1f22538ce.cdf-ms"
    20: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\4897d486ae69d301d11e00007c017813.program_files_common_files_microsoft_shared_ink_zh-tw_b1fdeb1bde31194e.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_zh-tw_b1fdeb1bde31194e.cdf-ms"
    21: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\e63ad686ae69d301d21e00007c017813.program_files_common_files_microsoft_shared_ink_zh-
2017-11-30 08:40:43, Info                  CSI    cn_b1fdda05de3132de.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_zh-cn_b1fdda05de3132de.cdf-ms"
    22: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\8200e286ae69d301d31e00007c017813.program_files_common_files_microsoft_shared_ink_sl-si_a4b08ac1f2252a40.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_sl-si_a4b08ac1f2252a40.cdf-ms"
    23: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{e0053bef-049c-9ba1-cee8-4db7f94b5638}", Type = REG_SZ (1), Data = {l:188 ml:188 b:43003a005c00500072006f006700720061006d002000460069006c00650073005c0043006f006d006d006f006e002000460069006c00650073005c004d006900..6e0050006c007500670069006e002e0064006c006c002c0053007900730070007200650070005f0043006c00650061006e00750070005f004900500053000000}
    24: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{212a39ce-d230-036a-f4c8-f1c87dade9d7}", Type = REG_SZ (1), Data = {l:114 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730065007400750070005c007400730073007900730070007200650070002e0064006c006c002c004c0053004d0053007900730050007200650070004200610063006b00750070000000}
    25: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{212a39ce-d230-036a-2848-d06e242bc47b}", Type = REG_SZ (1), Data = {l:116 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730065007400750070005c007400730073007900730070007200650070002e0064006c006c002c004c0053004d00530079007300500072006500700052006500730074006f00720065000000}
    26: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{060a08cd
2017-11-30 08:40:43, Info                  CSI    -a7ae-479d-2e23-229f6b9bef89}", Type = REG_SZ (1), Data = {l:116 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730065007400750070005c007400730073007900730070007200650070002e0064006c006c002c00520064007000530079007300500072006500700052006500730074006f00720065000000}
    27: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{060a08cd-a7ae-479d-86d6-c722da22bf5b}", Type = REG_SZ (1), Data = {l:122 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730065007400750070005c007400730073007900730070007200650070002e0064006c006c002c005200640070005300790073005000720065007000470065006e006500720061006c0069007a0065000000}
    28: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Specialize", Value = [l:76{38}]"{6af13c52-935b-ecb2-0218-900956130400}", Type = REG_SZ (1), Data = {l:116 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00730065007400750070005c007400730073007900730070007200650070002e0064006c006c002c00520043004d00530079007300500072006500700052006500730074006f00720065000000}
POQ 69 ends.
2017-11-30 08:40:43, Info                  CSI    0000019b [SR] Verify complete
2017-11-30 08:40:43, Info                  CSI    0000019c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:43, Info                  CSI    0000019d [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:44, Info                  CSI    0000019e Repair results created:
POQ 70 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9237387ae69d301381f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a967387ae69d301391f00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\65e27387ae69d3013a1f00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\b12e7487ae69d3013b1f00007c017813.$$_inf_tapisrv_20c65cafb424239c.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_20c65cafb424239c.cdf-ms"
    4: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6547487ae69d3013c1f00007c017813.$$_inf_tapisrv_0000_2e9995ea1b86323e.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_0000_2e9995ea1b86323e.cdf-ms"
    5: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\cc8d8787ae69d3013d1f00007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\17da8787ae69d3013e1f00007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    7: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d008887ae69d3013f1f00007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
2017-11-30 08:40:44, Info                  CSI    l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\ae728887ae69d301401f00007c017813.program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_3c86e3db0b3b254c.cdf-ms"
    9: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\f9be8887ae69d301411f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_92b215ec670a7f35.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_92b215ec670a7f35.cdf-ms"
    10: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\440b8987ae69d301421f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_oskmenu_4ada925d6aba5911.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_oskmenu_4ada925d6aba5911.cdf-ms"
    11: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a318987ae69d301431f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_numbers_4ea57ed36511f733.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_numbers_4ea57ed36511f733.cdf-ms"
    12: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\b57d8987ae69d301441f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_osknumpad_ee37ed195958108b.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_osknumpad_ee37ed195958108b.cdf-ms"
    13: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\00ca8987ae69d301451f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_keypad_bb29f287c24d4a93.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_keypad_bb2
2017-11-30 08:40:44, Info                  CSI    9f287c24d4a93.cdf-ms"
    14: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\4b168a87ae69d301461f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_symbols_4eaf815d64e8ecbc.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_symbols_4eaf815d64e8ecbc.cdf-ms"
    15: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\97628a87ae69d301471f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_oskpred_4ada71c56aba89ef.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_oskpred_4ada71c56aba89ef.cdf-ms"
    16: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\bc888a87ae69d301481f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_auxpad_bb15ebb5c2b76782.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_auxpad_bb15ebb5c2b76782.cdf-ms"
    17: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\08d58a87ae69d301491f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_main_992db4c6307e339e.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_main_992db4c6307e339e.cdf-ms"
    18: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\53218b87ae69d3014a1f00007c017813.program_files_common_files_microsoft_shared_ink_fsdefinitions_web_310c2550dac9ac6b.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_ink_fsdefinitions_web_310c2550dac9ac6b.cdf-ms"
    19: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\7ca7a587ae69d3014b1f00007c017813.$$_resources_fbee56ab048ab239.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_resources_fbee56ab048ab239.cdf-m
2017-11-30 08:40:44, Info                  CSI    s"
    20: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\c7f3a587ae69d3014c1f00007c017813.$$_resources_themes_4d0d4910e83c2273.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_4d0d4910e83c2273.cdf-ms"
    21: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\98f5b387ae69d3014d1f00007c017813.$$_inf_tapisrv_0415_2e999d681b8626fe.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_0415_2e999d681b8626fe.cdf-ms"
    22: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\d26fc687ae69d3014e1f00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\24c7c787ae69d3014f1f00007c017813.$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_5f1dd67a5a1ae70e.cdf-ms"
    24: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\6f13c887ae69d301501f00007c017813.$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_system32_tasks_microsoft_b7abd682baafefc2.cdf-ms"
POQ 70 ends.
2017-11-30 08:40:44, Info                  CSI    0000019f [SR] Verify complete
2017-11-30 08:40:44, Info                  CSI    000001a0 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:44, Info                  CSI    000001a1 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:45, Info                  CSI    000001a2 Repair results created:
POQ 71 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\04383a88ae69d301b51f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\4f843a88ae69d301b61f00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\9bd03a88ae69d301b71f00007c017813.$$_logs_measuredboot_ab1fadc53c86b337.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_logs_measuredboot_ab1fadc53c86b337.cdf-ms"
    3: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\e61c3b88ae69d301b81f00007c017813.programdata_microsoft_crypto_pcpksp_windowsaik_cb9775b914a8e5a2.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_pcpksp_windowsaik_cb9775b914a8e5a2.cdf-ms"
    4: Set File Information: File = [l:106{53}]"\??\C:\ProgramData\Microsoft\Crypto\PCPKSP\WindowsAIK", Attributes = 00000084
    5: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\6db03e88ae69d301b91f00007c017813.programdata_microsoft_diagnosis_af2ddc54e6a8e491.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_af2ddc54e6a8e491.cdf-ms"
    6: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\b8fc3e88ae69d301ba1f00007c017813.programdata_microsoft_diagnosis_sideload_1bd7d65b4945242a.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_sideload_1bd7d65b4945242a.cdf-ms"
    7: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\de223f88ae69d301bb1f00007c017813.programdata_microsoft_diagnosis_downloadedsettings_f4a4d355cda0ca19.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_downloadedsettings_f4a4d355cda0ca
2017-11-30 08:40:45, Info                  CSI    19.cdf-ms"
    8: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\296f3f88ae69d301bc1f00007c017813.programdata_microsoft_diagnosis_downloadedscenarios_995fa01e94b9ae39.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_downloadedscenarios_995fa01e94b9ae39.cdf-ms"
    9: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\74bb3f88ae69d301bd1f00007c017813.programdata_microsoft_diagnosis_asimovuploader_0413bca0c3dfdda4.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_asimovuploader_0413bca0c3dfdda4.cdf-ms"
    10: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ae13f88ae69d301be1f00007c017813.programdata_microsoft_diagnosis_localtracestore_b69b398684e58a86.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_localtracestore_b69b398684e58a86.cdf-ms"
    11: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\e52d4088ae69d301bf1f00007c017813.programdata_microsoft_diagnosis_etllogs_ffc0f561f3797ceb.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_etllogs_ffc0f561f3797ceb.cdf-ms"
    12: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\307a4088ae69d301c01f00007c017813.programdata_microsoft_diagnosis_etllogs_shutdownlogger_5ca7b57d60632f51.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_etllogs_shutdownlogger_5ca7b57d60632f51.cdf-ms"
    13: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\56a04088ae69d301c11f00007c017813.programdata_microsoft_diagnosis_etllogs_autologger_91adf7c94bd2d1fa.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_diagnosis_etllogs_autologger_91adf7c94bd2d1fa.cdf-ms"
    14: Set File Information: File = [l:76{38}]"\??\C:\ProgramData\Microsoft\Diagnosis", Attributes = 00000084
    15: Set File Inform
2017-11-30 08:40:45, Info                  CSI    ation: File = [l:92{46}]"\??\C:\ProgramData\Microsoft\Diagnosis\ETLLogs", Attributes = 00000084
    16: Set File Information: File = [l:114{57}]"\??\C:\ProgramData\Microsoft\Diagnosis\ETLLogs\AutoLogger", Attributes = 00000084
    17: Set File Information: File = [l:122{61}]"\??\C:\ProgramData\Microsoft\Diagnosis\ETLLogs\ShutdownLogger", Attributes = 00000084
    18: Set File Information: File = [l:108{54}]"\??\C:\ProgramData\Microsoft\Diagnosis\LocalTraceStore", Attributes = 00000084
    19: Set File Information: File = [l:106{53}]"\??\C:\ProgramData\Microsoft\Diagnosis\AsimovUploader", Attributes = 00000084
    20: Set File Information: File = [l:116{58}]"\??\C:\ProgramData\Microsoft\Diagnosis\DownloadedScenarios", Attributes = 00000084
    21: Set File Information: File = [l:114{57}]"\??\C:\ProgramData\Microsoft\Diagnosis\DownloadedSettings", Attributes = 00000084
    22: Set File Information: File = [l:94{47}]"\??\C:\ProgramData\Microsoft\Diagnosis\Sideload", Attributes = 00000084
    23: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\4cd95388ae69d301c21f00007c017813.$$_servicing_fc2045b9046cc796.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_servicing_fc2045b9046cc796.cdf-ms"
POQ 71 ends.
2017-11-30 08:40:45, Info                  CSI    000001a3 [SR] Verify complete
2017-11-30 08:40:45, Info                  CSI    000001a4 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:45, Info                  CSI    000001a5 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:46, Info                  CSI    000001a6 Ignoring duplicate ownership for directory [l:78{39}]"\??\C:\Windows\schemas\AvailableNetwork" in component Microsoft-Windows-VAN, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:47, Info                  CSI    000001a7 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\Inf\usbhub\0415" in component Microsoft-Windows-usbperf.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:47, Info                  CSI    000001a8 Repair results created:
POQ 72 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\f14a2089ae69d301272000007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\3c972089ae69d301282000007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\88e32089ae69d301292000007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    3: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\d32f2189ae69d3012a2000007c017813.$$_schemas_availablenetwork_aaf14dcc87fea431.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_availablenetwork_aaf14dcc87fea431.cdf-ms"
    4: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\e9502489ae69d3012b2000007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    5: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\349d2489ae69d3012c2000007c017813.$$_inf_usbhub_299dea1039e75d30.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_299dea1039e75d30.cdf-ms"
    6: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\5ac32489ae69d3012d2000007c017813.$$_inf_usbhub_0000_1bec33bb3c8ba8f4.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_0000_1bec33bb3c8ba8f4.cdf-ms"
    7: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\20b37989ae69d3012e2000007c017813.$$_inf_usbhub_0415_1bec34ed3c8ba7b4.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_0415_1bec34ed3c8ba7b4.cdf-ms"
    8: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\431d8e8
2017-11-30 08:40:47, Info                  CSI    9ae69d3012f2000007c017813.programdata_microsoft_user_account_pictures_default_pictures_e70ab2484087f163.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_user_account_pictures_default_pictures_e70ab2484087f163.cdf-ms"
POQ 72 ends.
2017-11-30 08:40:47, Info                  CSI    000001a9 [SR] Verify complete
2017-11-30 08:40:47, Info                  CSI    000001aa [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:47, Info                  CSI    000001ab [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:49, Info                  CSI    000001ac Repair results created:
POQ 73 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\a71a4c8aae69d301942000007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2664c8aae69d301952000007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\3db34c8aae69d301962000007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    3: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\88ff4c8aae69d301972000007c017813.$$_schemas_wcn_b437fb7b7751c8a8.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_wcn_b437fb7b7751c8a8.cdf-ms"
    4: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\72ef4e8aae69d301982000007c017813.$$_diagnostics_system_windowsmediaplayermedialibrary_64611465e9119df8.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsmediaplayermedialibrary_64611465e9119df8.cdf-ms"
    5: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\472f6d8aae69d301992000007c017813.$$_performance_02bd33cc045df684.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_performance_02bd33cc045df684.cdf-ms"
    6: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\dec76d8aae69d3019a2000007c017813.$$_performance_winsat_ac47b36afb2fa68e.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_performance_winsat_ac47b36afb2fa68e.cdf-ms"
    7: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f79b28aae69d3019b2000007c017813.$$_diagnostics_system_windowsupdate_0862ad88ff233b9d.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsupdate_086
2017-11-30 08:40:49, Info                  CSI    2ad88ff233b9d.cdf-ms"
    8: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\5b38b38aae69d3019c2000007c017813.$$_diagnostics_system_windowsupdate_pl-pl_82a6d5a04521a1ce.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsupdate_pl-pl_82a6d5a04521a1ce.cdf-ms"
    9: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\00e7b58aae69d3019d2000007c017813.$$_diagnostics_system_windowsmediaplayerplaydvd_3aa04961f831b79d.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsmediaplayerplaydvd_3aa04961f831b79d.cdf-ms"
    10: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\6870bf8aae69d3019e2000007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    11: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\bbc7c08aae69d3019f2000007c017813.$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms"
    12: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\0614c18aae69d301a02000007c017813.$$_system32_winbioplugins_en-us_4600b46a9eff5ffa.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbioplugins_en-us_4600b46a9eff5ffa.cdf-ms"
    13: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\acc2c38aae69d301a12000007c017813.$$_diagnostics_system_windowsmediaplayerconfiguration_537e287f67955d9f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsmediaplayerconfiguration_537e287f67955d9f.cdf-ms"
    14: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\f70ec48aae69d301a22000007c017813.$$_diagnostics_system_windowsmediaplayerconfiguration_pl-pl_b56dbe9758462118.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsm
2017-11-30 08:40:49, Info                  CSI    ediaplayerconfiguration_pl-pl_b56dbe9758462118.cdf-ms"
    15: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\9cbdc68aae69d301a32000007c017813.$$_diagnostics_system_windowsmediaplayerplaydvd_pl-pl_2cbe3003ab9bc7f2.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsmediaplayerplaydvd_pl-pl_2cbe3003ab9bc7f2.cdf-ms"
    16: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9f5d28aae69d301a42000007c017813.$$_system32_wcn_06656d8dd047aafe.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wcn_06656d8dd047aafe.cdf-ms"
    17: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a68d38aae69d301a52000007c017813.$$_system32_wcn_pl-pl_090fae88e82af917.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wcn_pl-pl_090fae88e82af917.cdf-ms"
    18: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\4eb5da8aae69d301a62000007c017813.$$_diagnostics_system_windowsmediaplayermedialibrary_pl-pl_8e7c05fee4191e8f.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsmediaplayermedialibrary_pl-pl_8e7c05fee4191e8f.cdf-ms"
POQ 73 ends.
2017-11-30 08:40:49, Info                  CSI    000001ad [SR] Verify complete
2017-11-30 08:40:50, Info                  CSI    000001ae [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:50, Info                  CSI    000001af [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:51, Info                  CSI    000001b0 Ignoring duplicate ownership for directory [l:86{43}]"\??\C:\Windows\System32\WinBioPlugIns\en-US" in component Microsoft-Windows-WBioSensorAdapter.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:51, Info                  CSI    000001b1 Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\twain_32" in component Microsoft-Windows-WindowsImageAcquisition-WIATwainCompat, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:51, Info                  CSI    000001b2 Repair results created:
POQ 74 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\100b4e8bae69d3010b2100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\100b4e8bae69d3010c2100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1e32558bae69d3010d2100007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\7894578bae69d3010e2100007c017813.$$_system32_wbem_06656d9fdf2f8577.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wbem_06656d9fdf2f8577.cdf-ms"
    4: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\d2f6598bae69d3010f2100007c017813.$$_system32_wbem_xml_026f0f207227ebbc.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_system32_wbem_xml_026f0f207227ebbc.cdf-ms"
    5: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\be577b8bae69d301102100007c017813.$$_system32_winrm_0415_a992650bfab42823.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winrm_0415_a992650bfab42823.cdf-ms"
    6: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\cc7e828bae69d301112100007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    7: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\cc7e828bae69d301122100007c017813.program_files_windows_mail_e07902f329fe05e9.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_mail_e07902f329fe05e9.cdf-ms"
    8: Move File: Source = [l:224{112}]"\SystemRoot\Wi
2017-11-30 08:40:51, Info                  CSI    nSxS\Temp\PendingRenames\26e1848bae69d301132100007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    9: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\26e1848bae69d301142100007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
    10: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\26e1848bae69d301152100007c017813.$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms"
    11: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\26e1848bae69d301162100007c017813.$$_microsoft.net_framework64_v2.0.50727_temporary_asp.net_files_60f33deddb5b75c9.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_temporary_asp.net_files_60f33deddb5b75c9.cdf-ms"
    12: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\8043878bae69d301172100007c017813.$$_diagnostics_system_windowsupdate_0862ad88ff233b9d.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_system_windowsupdate_0862ad88ff233b9d.cdf-ms"
    13: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\aab89c8bae69d301182100007c017813.$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms"
    14: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\aab89c8bae69d301192100007c017813.$$_system32_winbioplugins_en-us_4600b46a9eff5ffa.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbioplugins_en-us_4600b46a9eff5ffa.cdf-ms"
    15: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\04
2017-11-30 08:40:51, Info                  CSI    1b9f8bae69d3011a2100007c017813.$$_twain_32_209f76caa35c9a77.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_twain_32_209f76caa35c9a77.cdf-ms"
    16: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\1242a68bae69d3011b2100007c017813.$$_performance_02bd33cc045df684.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_performance_02bd33cc045df684.cdf-ms"
    17: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\1242a68bae69d3011c2100007c017813.$$_performance_winsat_ac47b36afb2fa68e.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_performance_winsat_ac47b36afb2fa68e.cdf-ms"
    18: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\1242a68bae69d3011d2100007c017813.$$_performance_winsat_datastore_34fe222e5de27d61.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_performance_winsat_datastore_34fe222e5de27d61.cdf-ms"
    19: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cb7bb8bae69d3011e2100007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    20: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cb7bb8bae69d3011f2100007c017813.program_files_common_files_system_b13078daf1286f60.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_b13078daf1286f60.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cb7bb8bae69d301202100007c017813.program_files_common_files_system_pl-pl_48d37d5a3eb06e37.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_system_pl-pl_48d37d5a3eb06e37.cdf-ms"
    22: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{7e2c4dfd-247b-e7f9-d3d1-771286930ef6}", Type = REG_SZ (1), Data = {l:106 b:43003a005c
2017-11-30 08:40:51, Info                  CSI    00570069006e0064006f00770073005c00530079007300740065006d00330032005c00770075006100750065006e0067002e0064006c006c002c00470065006e006500720061006c0069007a00650046006f00720049006d006100670069006e0067000000}
POQ 74 ends.
2017-11-30 08:40:51, Info                  CSI    000001b3 [SR] Verify complete
2017-11-30 08:40:51, Info                  CSI    000001b4 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:51, Info                  CSI    000001b5 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:53, Info                  CSI    000001b6 Repair results created:
POQ 75 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\a8ae758cae69d301852100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\0211788cae69d301862100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\10387f8cae69d301872100007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a9a818cae69d301882100007c017813.$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbioplugins_071a28c5b510fb6a.cdf-ms"
    4: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a9a818cae69d301892100007c017813.$$_system32_winbiodatabase_8ca29eba075c22c3.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_system32_winbiodatabase_8ca29eba075c22c3.cdf-ms"
    5: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018a2100007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    6: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018b2100007c017813.program_files_reference_assemblies_microsoft_framework_v3.0_44577d982216c291.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.0_44577d982216c291.cdf-ms"
    7: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018c2100007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft
2017-11-30 08:40:53, Info                  CSI    .net_3296b36dbe4c7fa3.cdf-ms"
    8: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018d2100007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
    9: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018e2100007c017813.$$_microsoft.net_framework64_v3.0_windows_communication_foundation_7de82ac14fafbb1e.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_windows_communication_foundation_7de82ac14fafbb1e.cdf-ms"
    10: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d3018f2100007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    11: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\18e7ae8cae69d301902100007c017813.$$_inf_smsvchost_3.0.0.0_0000_2d6d90735cb61780.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_inf_smsvchost_3.0.0.0_0000_2d6d90735cb61780.cdf-ms"
    12: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\7249b18cae69d301912100007c017813.$$_inf_servicemodeloperation_3.0.0.0_0000_9b92bb9ad51f70d3.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodeloperation_3.0.0.0_0000_9b92bb9ad51f70d3.cdf-ms"
    13: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\7249b18cae69d301922100007c017813.$$_inf_servicemodelservice_3.0.0.0_0000_2fd4d7f498bba769.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelservice_3.0.0.0_0000_2fd4d7f498bba769.cdf-ms"
    14: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\7249b18cae69d301932100007c017813.$$_inf_msdtc_bridge_3.0.0.0_0000_5d60388d7f35c25e.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_bridge_3.0.0.0_0000_5d60388d7f35c25
2017-11-30 08:40:53, Info                  CSI    e.cdf-ms"
    15: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\7249b18cae69d301942100007c017813.$$_inf_servicemodelendpoint_3.0.0.0_0000_1441b5e36e0dde07.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelendpoint_3.0.0.0_0000_1441b5e36e0dde07.cdf-ms"
    16: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\3435bd8cae69d301952100007c017813.program_files_reference_assemblies_microsoft_framework_v3.0_pl_422116fd69c47285.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.0_pl_422116fd69c47285.cdf-ms"
    17: Move File: Source = [l:336{168}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d301962100007c017813.$$_microsoft.net_framework64_v3.0_windows_communication_foundation_pl-pl_8a6a06022f25b4ad.cdf-ms", Destination = [l:248{124}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_windows_communication_foundation_pl-pl_8a6a06022f25b4ad.cdf-ms"
    18: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d301972100007c017813.$$_microsoft.net_framework64_v3.0_windows_communication_foundation_pl_af920fd066efc0d0.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_windows_communication_foundation_pl_af920fd066efc0d0.cdf-ms"
    19: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d301982100007c017813.$$_inf_smsvchost_3.0.0.0_0415_2d6d99f95cb60920.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_inf_smsvchost_3.0.0.0_0415_2d6d99f95cb60920.cdf-ms"
    20: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d301992100007c017813.$$_inf_servicemodeloperation_3.0.0.0_0415_9b92c520d51f6273.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodeloperation_3.0.0.0_0415_9b92c520d51f6273.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e
2017-11-30 08:40:53, Info                  CSI    97bf8cae69d3019a2100007c017813.$$_inf_servicemodelservice_3.0.0.0_0415_2fd4df7298bb9c29.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelservice_3.0.0.0_0415_2fd4df7298bb9c29.cdf-ms"
    22: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d3019b2100007c017813.$$_inf_msdtc_bridge_3.0.0.0_0415_5d6037ff7f35c39e.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_bridge_3.0.0.0_0415_5d6037ff7f35c39e.cdf-ms"
    23: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\8e97bf8cae69d3019c2100007c017813.$$_inf_servicemodelendpoint_3.0.0.0_0415_1441b5556e0ddf47.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelendpoint_3.0.0.0_0415_1441b5556e0ddf47.cdf-ms"
    24: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{86830449-a353-18f2-58aa-df121c7314ed}", Type = REG_SZ (1), Data = {l:98 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00720065006100670065006e0074002e0064006c006c002c00570069006e00520045005f00470065006e006500720061006c0069007a0065000000}
POQ 75 ends.
2017-11-30 08:40:53, Info                  CSI    000001b7 [SR] Verify complete
2017-11-30 08:40:53, Info                  CSI    000001b8 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:53, Info                  CSI    000001b9 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:55, Info                  CSI    000001ba Ignoring duplicate ownership for directory [l:114{57}]"\??\C:\Program Files\Windows Media Player\Network Sharing" in component Microsoft-Windows-WMPNSS-Service, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:40:55, Info                  CSI    000001bb Repair results created:
POQ 76 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\7a25128eae69d301012200007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\7a25128eae69d301022200007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\d487148eae69d301032200007c017813.program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_da4e5f6eb3198de9.cdf-ms"
    3: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\d487148eae69d301042200007c017813.program_files_windows_media_player_network_sharing_aed05552f451fd7d.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_media_player_network_sharing_aed05552f451fd7d.cdf-ms"
    4: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba705e8eae69d301052200007c017813.program_files_common_files_d7a65bb2f0e854e7.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_d7a65bb2f0e854e7.cdf-ms"
    5: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba705e8eae69d301062200007c017813.program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_818c5a0e45020fba.cdf-ms"
    6: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba705e8eae69d301072200007c017813.program_files_common_files_microsoft_shared_textconv_dfb016a4185c8725.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\program_files_common_files_microsoft_shared_textconv_dfb016a4185c8725.cdf-ms"
    7: Move File: So
2017-11-30 08:40:55, Info                  CSI    urce = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba705e8eae69d301082200007c017813.program_files_windows_nt_6101456faac5015c.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_6101456faac5015c.cdf-ms"
    8: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba705e8eae69d301092200007c017813.program_files_windows_nt_accessories_156d2b9b22040474.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_nt_accessories_156d2b9b22040474.cdf-ms"
POQ 76 ends.
2017-11-30 08:40:55, Info                  CSI    000001bc [SR] Verify complete
2017-11-30 08:40:55, Info                  CSI    000001bd [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:55, Info                  CSI    000001be [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:57, Info                  CSI    000001bf Repair results created:
POQ 77 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\5655058fae69d3016e2200007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\b0b7078fae69d3016f2200007c017813.programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9__0ce7c057892d5774.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9__0ce7c057892d5774.cdf-ms"
    2: Move File: Source = [l:356{178}]"\SystemRoot\WinSxS\Temp\PendingRenames\b0b7078fae69d301702200007c017813.programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9_pl-pl_66e935f9450e2151.cdf-ms", Destination = [l:268{134}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_device_stage_task_07deb856-fc6e-4fb9-8add-d8f2cf8722c9_pl-pl_66e935f9450e2151.cdf-ms"
    3: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\b0b7078fae69d301712200007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    4: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\1841118fae69d301722200007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    5: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\1841118fae69d301732200007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    6: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\72a3138fae69d301742200007c017813.$$_system32_windowspowershell_v1.0_modules_bitstransfer_935cce3b0456eb87.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_bitstran
2017-11-30 08:40:57, Info                  CSI    sfer_935cce3b0456eb87.cdf-ms"
    7: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\72a3138fae69d301752200007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    8: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\72a3138fae69d301762200007c017813.$$_microsoft.net_authman_27829e1b3df01691.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_authman_27829e1b3df01691.cdf-ms"
    9: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\2668188fae69d301772200007c017813.$$_security_fe3ad40cd6e08c7c.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_security_fe3ad40cd6e08c7c.cdf-ms"
    10: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\04a2328fae69d301782200007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    11: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e04358fae69d301792200007c017813.program_files_windows_portable_devices_8ef3f2c72e8bb2ba.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_portable_devices_8ef3f2c72e8bb2ba.cdf-ms"
    12: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e04358fae69d3017a2200007c017813.program_files_reference_assemblies_microsoft_framework_v3.0_44577d982216c291.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.0_44577d982216c291.cdf-ms"
    13: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e04358fae69d3017b2200007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
    14: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e04358fae69d3
2017-11-30 08:40:57, Info                  CSI    017c2200007c017813.$$_microsoft.net_framework64_v3.0_wpf_f80a7f17f38f3771.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_wpf_f80a7f17f38f3771.cdf-ms"
    15: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\b866378fae69d3017d2200007c017813.$$_microsoft.net_framework64_v3.0_wpf_xamlviewer_2a5223adddc9e767.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_wpf_xamlviewer_2a5223adddc9e767.cdf-ms"
    16: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\b866378fae69d3017e2200007c017813.$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms"
    17: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\b866378fae69d3017f2200007c017813.programdata_microsoft_wwansvc_b22df3b43960e1d3.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_wwansvc_b22df3b43960e1d3.cdf-ms"
    18: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\b866378fae69d301802200007c017813.programdata_microsoft_wwansvc_profiles_d39df26c249b675d.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_wwansvc_profiles_d39df26c249b675d.cdf-ms"
    19: Set File Information: File = [l:72{36}]"\??\C:\ProgramData\Microsoft\WwanSvc", Attributes = 00000082
    20: Set File Information: File = [l:90{45}]"\??\C:\ProgramData\Microsoft\WwanSvc\Profiles", Attributes = 00000082
    21: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\588c5d8fae69d301812200007c017813.$$_system32_windowspowershell_v1.0_modules_bitstransfer_en-us_8f6d5322d8d680dd.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_bitstransfer_en-us_8f6d5322d8d680dd.cdf-ms"
    22: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\1
2017-11-30 08:40:57, Info                  CSI    a78698fae69d301822200007c017813.program_files_reference_assemblies_microsoft_framework_v3.0_pl_422116fd69c47285.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_reference_assemblies_microsoft_framework_v3.0_pl_422116fd69c47285.cdf-ms"
    23: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a78698fae69d301832200007c017813.$$_microsoft.net_framework64_v3.0_wpf_pl-pl_19a79255775ff3f6.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_wpf_pl-pl_19a79255775ff3f6.cdf-ms"
    24: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\74da6b8fae69d301842200007c017813.$$_microsoft.net_framework64_v3.0_wpf_pl_3f0495099b9aab55.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v3.0_wpf_pl_3f0495099b9aab55.cdf-ms"
    25: Move File: Source = [l:282{141}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea8a7c8fae69d301852200007c017813.$$_system32_logfiles_windows_portable_devices_dcf2285bde880198.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\$$_system32_logfiles_windows_portable_devices_dcf2285bde880198.cdf-ms"
POQ 77 ends.
2017-11-30 08:40:57, Info                  CSI    000001c0 [SR] Verify complete
2017-11-30 08:40:57, Info                  CSI    000001c1 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:57, Info                  CSI    000001c2 [SR] Beginning Verify and Repair transaction
2017-11-30 08:40:58, Info                  CSI    000001c3 Repair results created:
POQ 78 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d822f68fae69d301ea2200007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\d822f68fae69d301eb2200007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\40acff8fae69d301ec2200007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a0e0290ae69d301ed2200007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    4: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a0e0290ae69d301ee2200007c017813.$$_system32_windowspowershell_v1.0_modules_troubleshootingpack_aa01ee5573cb1655.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_troubleshootingpack_aa01ee5573cb1655.cdf-ms"
    5: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\9a0e0290ae69d301ef2200007c017813.$$_system32_windowspowershell_v1.0_modules_troubleshootingpack_en-us_53560fea81cb8acf.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_troubleshootingpack_en-us_53560fea81cb8acf.cdf-ms"
POQ 78 ends.
2017-11-30 08:40:58, Info                  CSI    000001c4 [SR] Verify complete
2017-11-30 08:40:58, Info                  CSI    000001c5 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:40:58, Info                  CSI    000001c6 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:00, Info                  CSI    000001c7 Repair results created:
POQ 79 starts:
POQ 79 ends.
2017-11-30 08:41:00, Info                  CSI    000001c8 [SR] Verify complete
2017-11-30 08:41:00, Info                  CSI    000001c9 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:00, Info                  CSI    000001ca [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:00, Info                  CSI    000001cb Repair results created:
POQ 80 starts:
POQ 80 ends.
2017-11-30 08:41:00, Info                  CSI    000001cc [SR] Verify complete
2017-11-30 08:41:01, Info                  CSI    000001cd [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:01, Info                  CSI    000001ce [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:02, Info                  CSI    000001cf Repair results created:
POQ 81 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\baf7f191ae69d3011c2400007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\baf7f191ae69d3011d2400007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\baf7f191ae69d3011e2400007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    3: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\baf7f191ae69d3011f2400007c017813.$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_083d4e330e766c5d.cdf-ms"
    4: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\145af491ae69d301202400007c017813.$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_443de60f3f6e0828.cdf-ms"
    5: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\145af491ae69d301212400007c017813.$$_microsoft.net_framework64_v2.0.50727_redistlist_8ebec5e3be6c804f.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework64_v2.0.50727_redistlist_8ebec5e3be6c804f.cdf-ms"
POQ 81 ends.
2017-11-30 08:41:02, Info                  CSI    000001d0 [SR] Verify complete
2017-11-30 08:41:02, Info                  CSI    000001d1 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:02, Info                  CSI    000001d2 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:04, Info                  CSI    000001d3 Repair results created:
POQ 82 starts:
POQ 82 ends.
2017-11-30 08:41:04, Info                  CSI    000001d4 [SR] Verify complete
2017-11-30 08:41:04, Info                  CSI    000001d5 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:04, Info                  CSI    000001d6 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:04, Info                  CSI    000001d7 Repair results created:
POQ 83 starts:
POQ 83 ends.
2017-11-30 08:41:04, Info                  CSI    000001d8 [SR] Verify complete
2017-11-30 08:41:05, Info                  CSI    000001d9 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:05, Info                  CSI    000001da [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:06, Info                  CSI    000001db Repair results created:
POQ 84 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1073d794ae69d3014e2500007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1073d794ae69d3014f2500007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\78fce094ae69d301502500007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    3: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\78fce094ae69d301512500007c017813.$$_system32_logfiles_firewall_488be49cc4415d55.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_system32_logfiles_firewall_488be49cc4415d55.cdf-ms"
POQ 84 ends.
2017-11-30 08:41:06, Info                  CSI    000001dc [SR] Verify complete
2017-11-30 08:41:06, Info                  CSI    000001dd [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:06, Info                  CSI    000001de [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:10, Info                  CSI    000001df Repair results created:
POQ 85 starts:
POQ 85 ends.
2017-11-30 08:41:10, Info                  CSI    000001e0 [SR] Verify complete
2017-11-30 08:41:10, Info                  CSI    000001e1 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:10, Info                  CSI    000001e2 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:14, Info                  CSI    000001e3 Repair results created:
POQ 86 starts:
POQ 86 ends.
2017-11-30 08:41:14, Info                  CSI    000001e4 [SR] Verify complete
2017-11-30 08:41:14, Info                  CSI    000001e5 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:14, Info                  CSI    000001e6 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:15, Info                  CSI    000001e7 Repair results created:
POQ 87 starts:
POQ 87 ends.
2017-11-30 08:41:15, Info                  CSI    000001e8 [SR] Verify complete
2017-11-30 08:41:15, Info                  CSI    000001e9 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:15, Info                  CSI    000001ea [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:16, Info                  CSI    000001eb Repair results created:
POQ 88 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\8cb67c9aae69d301e22600007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\8cb67c9aae69d301e32600007c017813.program_files_ffd0cbfc813cc4f1.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\program_files_ffd0cbfc813cc4f1.cdf-ms"
    2: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\e6187f9aae69d301e42600007c017813.program_files_windows_defender_3e33901162166ae9.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_defender_3e33901162166ae9.cdf-ms"
    3: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\e6187f9aae69d301e52600007c017813.program_files_windows_defender_pl-pl_a607f77b0bab0822.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\program_files_windows_defender_pl-pl_a607f77b0bab0822.cdf-ms"
    4: Set Key Value: Key = [l:168{84}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Generalize", Value = [l:76{38}]"{6f030a55-b729-b59d-05f0-8c48a330cb4c}", Type = REG_SZ (1), Data = {l:114 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c00770069006e00730068006600680063002e0064006c006c002c004d005200540043006f006d0070006f006e0065006e0074005f00470065006e006500720061006c0069007a0065000000}
POQ 88 ends.
2017-11-30 08:41:16, Info                  CSI    000001ec [SR] Verify complete
2017-11-30 08:41:16, Info                  CSI    000001ed [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:16, Info                  CSI    000001ee [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:17, Info                  CSI    000001ef Repair results created:
POQ 89 starts:
POQ 89 ends.
2017-11-30 08:41:17, Info                  CSI    000001f0 [SR] Verify complete
2017-11-30 08:41:17, Info                  CSI    000001f1 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:17, Info                  CSI    000001f2 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:18, Info                  CSI    000001f3 Repair results created:
POQ 90 starts:
POQ 90 ends.
2017-11-30 08:41:18, Info                  CSI    000001f4 [SR] Verify complete
2017-11-30 08:41:18, Info                  CSI    000001f5 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:18, Info                  CSI    000001f6 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:19, Info                  CSI    000001f7 Repair results created:
POQ 91 starts:
POQ 91 ends.
2017-11-30 08:41:19, Info                  CSI    000001f8 [SR] Verify complete
2017-11-30 08:41:19, Info                  CSI    000001f9 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:19, Info                  CSI    000001fa [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:19, Info                  CSI    000001fb Repair results created:
POQ 92 starts:
POQ 92 ends.
2017-11-30 08:41:19, Info                  CSI    000001fc [SR] Verify complete
2017-11-30 08:41:20, Info                  CSI    000001fd [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:20, Info                  CSI    000001fe [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:20, Info                  CSI    000001ff Repair results created:
POQ 93 starts:
POQ 93 ends.
2017-11-30 08:41:20, Info                  CSI    00000200 [SR] Verify complete
2017-11-30 08:41:20, Info                  CSI    00000201 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:20, Info                  CSI    00000202 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:22, Info                  CSI    00000203 Ignoring duplicate ownership for directory [l:54{27}]"\??\C:\Windows\Inf\UGTHRSVC" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:22, Info                  CSI    00000204 Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\Inf\UGTHRSVC\0000" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:22, Info                  CSI    00000205 Ignoring duplicate ownership for directory [l:56{28}]"\??\C:\Windows\Inf\UGatherer" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:22, Info                  CSI    00000206 Ignoring duplicate ownership for directory [l:66{33}]"\??\C:\Windows\Inf\UGatherer\0000" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:22, Info                  CSI    00000207 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Inf\wsearchidxpi" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:22, Info                  CSI    00000208 Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\Inf\wsearchidxpi\0000" in component WindowsSearchEngine, Version = 7.0.7601.23877, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:23, Info                  CSI    00000209 Repair results created:
POQ 94 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\88fc909eae69d3013e2900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\88fc909eae69d3013f2900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\88fc909eae69d301402900007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\e25e939eae69d301412900007c017813.$$_inf_ugthrsvc_9c5b081f28f83f11.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_9c5b081f28f83f11.cdf-ms"
    4: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\e25e939eae69d301422900007c017813.$$_inf_ugthrsvc_0000_8451c300df70be5f.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_0000_8451c300df70be5f.cdf-ms"
    5: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cc1959eae69d301432900007c017813.$$_inf_ugatherer_9f1f9c5b6cd50d98.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_9f1f9c5b6cd50d98.cdf-ms"
    6: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cc1959eae69d301442900007c017813.$$_inf_ugatherer_0000_046b5203f9ca3f14.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_0000_046b5203f9ca3f14.cdf-ms"
    7: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\3cc1959eae69d301452900007c017813.$$_inf_wsearchidxpi_a2c41dc1731a4204.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_a2c41dc1731a4204.cdf-ms"
2017-11-30 08:41:23, Info                  CSI    es\9623989eae69d301462900007c017813.$$_inf_wsearchidxpi_0000_2e6e3f1caf9fca20.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_0000_2e6e3f1caf9fca20.cdf-ms"
    9: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\feaca19eae69d301472900007c017813.$$_inf_ugthrsvc_0415_8451c272df70bf9f.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_0415_8451c272df70bf9f.cdf-ms"
    10: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\feaca19eae69d301482900007c017813.$$_inf_ugatherer_0415_046b5b89f9ca30b4.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_0415_046b5b89f9ca30b4.cdf-ms"
    11: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\580fa49eae69d301492900007c017813.$$_inf_wsearchidxpi_0415_2e6e3e8eaf9fcb60.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_0415_2e6e3e8eaf9fcb60.cdf-ms"
    12: Set Key Value: Key = [l:162{81}]"\Registry\MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Setup\Sysprep\Cleanup", Value = [l:76{38}]"{4b60bb7c-bc84-d1cb-feb3-aa882aa02408}", Type = REG_SZ (1), Data = {l:108 b:43003a005c00570069006e0064006f00770073005c00530079007300740065006d00330032005c006d00730073007200630068002e0064006c006c002c004d00530053007200630068005f0053007900730050007200650070005f0043006c00650061006e00750070000000}
POQ 94 ends.
2017-11-30 08:41:23, Info                  CSI    0000020a [SR] Verify complete
2017-11-30 08:41:23, Info                  CSI    0000020b [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:23, Info                  CSI    0000020c [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:24, Info                  CSI    0000020d Repair results created:
POQ 95 starts:
POQ 95 ends.
2017-11-30 08:41:24, Info                  CSI    0000020e [SR] Verify complete
2017-11-30 08:41:24, Info                  CSI    0000020f [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:24, Info                  CSI    00000210 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:25, Info                  CSI    00000211 Repair results created:
POQ 96 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\c63db69fae69d301122a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\c63db69fae69d301132a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\c63db69fae69d301142a00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    3: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ec7bf9fae69d301152a00007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    4: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\8829c29fae69d301162a00007c017813.$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_3f102d555ee05d33.cdf-ms"
    5: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\e28bc49fae69d301172a00007c017813.$$_system32_windowspowershell_v1.0_modules_applocker_b50db0a500311141.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_applocker_b50db0a500311141.cdf-ms"
    6: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\b29ed79fae69d301182a00007c017813.$$_system32_windowspowershell_v1.0_modules_applocker_en-us_0185315044ae185f.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\$$_system32_windowspowershell_v1.0_modules_applocker_en-us_0185315044ae185f.cdf-ms"
POQ 96 ends.
2017-11-30 08:41:25, Info                  CSI    00000212 [SR] Verify complete
2017-11-30 08:41:25, Info                  CSI    00000213 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:25, Info                  CSI    00000214 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:26, Info                  CSI    00000215 Repair results created:
POQ 97 starts:
POQ 97 ends.
2017-11-30 08:41:26, Info                  CSI    00000216 [SR] Verify complete
2017-11-30 08:41:26, Info                  CSI    00000217 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:26, Info                  CSI    00000218 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:27, Info                  CSI    00000219 Repair results created:
POQ 98 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\220442a1ae69d301e12a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\220442a1ae69d301e22a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c6644a1ae69d301e32a00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c6644a1ae69d301e42a00007c017813.$$_inf_bits_0ef6f148bde367d9.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0ef6f148bde367d9.cdf-ms"
    4: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\7c6644a1ae69d301e52a00007c017813.$$_inf_bits_0415_a03dbeef63e834fd.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0415_a03dbeef63e834fd.cdf-ms"
    5: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\98b452a1ae69d301e62a00007c017813.$$_inf_bits_0000_a03dbf7d63e833bd.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_bits_0000_a03dbf7d63e833bd.cdf-ms"
    6: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\003e5ca1ae69d301e72a00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    7: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\5aa05ea1ae69d301e82a00007c017813.$$_syswow64_manifeststore_a956b56fc4a68862.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_manifeststore_a956b56fc4a68862.cdf-ms"
    8: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\b40261a1ae69d301e92a0
2017-11-30 08:41:27, Info                  CSI    0007c017813.$$_apppatch_1143992cbbbebcab.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_1143992cbbbebcab.cdf-ms"
POQ 98 ends.
2017-11-30 08:41:27, Info                  CSI    0000021a [SR] Verify complete
2017-11-30 08:41:28, Info                  CSI    0000021b [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:28, Info                  CSI    0000021c [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:30, Info                  CSI    0000021d Ignoring duplicate ownership for directory [l:126{63}]"\??\C:\ProgramData\Microsoft\Windows NT\MSFax\Common Coverpages" in component Microsoft-Windows-Fax-Common, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:30, Info                  CSI    0000021e Repair results created:
POQ 99 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\20fa1aa2ae69d3014e2b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\7a5c1da2ae69d3014f2b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\888324a2ae69d301502b00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\888324a2ae69d301512b00007c017813.$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms"
    4: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\888324a2ae69d301522b00007c017813.$$_syswow64_installshield_setupdir_0008_5cf9475aecb98866.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0008_5cf9475aecb98866.cdf-ms"
    5: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\28a94aa2ae69d301532b00007c017813.$$_syswow64_installshield_setupdir_0009_5cf9475cecb9885d.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0009_5cf9475cecb9885d.cdf-ms"
    6: Move File: Source = [l:210{105}]"\SystemRoot\WinSxS\Temp\PendingRenames\ea9456a2ae69d301542b00007c017813.$$_addins_2452dff8cb692cdd.cdf-ms", Destination = [l:122{61}]"\SystemRoot\WinSxS\FileMaps\$$_addins_2452dff8cb692cdd.cdf-ms"
    7: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\44f758a2ae69d301552b00007c017813.programdata_microsoft_windows_nt_msfax_common_coverpages_642a277e0ccb775c.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\Fil
2017-11-30 08:41:30, Info                  CSI    eMaps\programdata_microsoft_windows_nt_msfax_common_coverpages_642a277e0ccb775c.cdf-ms"
    8: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e595ba2ae69d301562b00007c017813.programdata_microsoft_windows_nt_msfax_common_coverpages_pl-pl_ed39cbeb8776ad61.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msfax_common_coverpages_pl-pl_ed39cbeb8776ad61.cdf-ms"
    9: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e595ba2ae69d301572b00007c017813.programdata_microsoft_windows_nt_msfax_virtualinbox_pl-pl_b1457358d98e3d60.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msfax_virtualinbox_pl-pl_b1457358d98e3d60.cdf-ms"
    10: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\140a6ca2ae69d301582b00007c017813.$$_syswow64_installshield_setupdir_0003_5cf94750ecb98893.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0003_5cf94750ecb98893.cdf-ms"
    11: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\6e6c6ea2ae69d301592b00007c017813.$$_ehome_40103e2da1d121de.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_40103e2da1d121de.cdf-ms"
    12: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\c8ce70a2ae69d3015a2b00007c017813.$$_ehome_wow_022df02cf45468bd.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_wow_022df02cf45468bd.cdf-ms"
    13: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\d6f577a2ae69d3015b2b00007c017813.$$_ehome_wow_en-us_5d2ec4ea8393e3f7.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_ehome_wow_en-us_5d2ec4ea8393e3f7.cdf-ms"
    14: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\761b9ea2ae69d3015c2b00007c017813.$$_syswow64_installshield_setupdir_0005_5cf94754ecb98881.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswo
2017-11-30 08:41:30, Info                  CSI    w64_installshield_setupdir_0005_5cf94754ecb98881.cdf-ms"
    15: Move File: Source = [l:206{103}]"\SystemRoot\WinSxS\Temp\PendingRenames\d07da0a2ae69d3015d2b00007c017813.$$_temp_401038c9a18c18c0.cdf-ms", Destination = [l:118{59}]"\SystemRoot\WinSxS\FileMaps\$$_temp_401038c9a18c18c0.cdf-ms"
    16: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\a090b3a2ae69d3015e2b00007c017813.$$_syswow64_com_1bf23555a7667cfb.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_com_1bf23555a7667cfb.cdf-ms"
    17: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\328fd2a2ae69d3015f2b00007c017813.$$_syswow64_installshield_setupdir_0006_5cf94756ecb98878.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0006_5cf94756ecb98878.cdf-ms"
    18: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\4edde0a2ae69d301602b00007c017813.$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms"
    19: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\a83fe3a2ae69d301612b00007c017813.$$_syswow64_ime_imejp10_a6d59fe98f8fd4ab.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imejp10_a6d59fe98f8fd4ab.cdf-ms"
    20: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\a83fe3a2ae69d301622b00007c017813.$$_syswow64_ime_imejp10_applets_b0508b85ceb495a0.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imejp10_applets_b0508b85ceb495a0.cdf-ms"
    21: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\a83fe3a2ae69d301632b00007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    22: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\a83fe3a2ae69d301642b00007c017813.$$_ime_imejp10_dicts_281006c600450618.cdf-ms
2017-11-30 08:41:30, Info                  CSI    ", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imejp10_dicts_281006c600450618.cdf-ms"
    23: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\a83fe3a2ae69d301652b00007c017813.$$_ime_imejp10_help_280ffde19e779392.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imejp10_help_280ffde19e779392.cdf-ms"
    24: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\c48df1a2ae69d301662b00007c017813.$$_syswow64_installshield_setupdir_0007_5cf94758ecb9886f.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0007_5cf94758ecb9886f.cdf-ms"
    25: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a3e02a3ae69d301672b00007c017813.programdata_microsoft_windows_nt_msscan_549c401cd5c756f4.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_nt_msscan_549c401cd5c756f4.cdf-ms"
    26: Set File Information: File = [l:126{63}]"\??\C:\ProgramData\Microsoft\Windows NT\MSFax\Common Coverpages", Attributes = 00000080
POQ 99 ends.
2017-11-30 08:41:30, Info                  CSI    0000021f [SR] Verify complete
2017-11-30 08:41:30, Info                  CSI    00000220 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:30, Info                  CSI    00000221 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:32, Info                  CSI    00000222 Repair results created:
POQ 100 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\c6c449a3ae69d301cc2b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\c6c449a3ae69d301cd2b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4eb50a3ae69d301ce2b00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\d4eb50a3ae69d301cf2b00007c017813.$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms"
    4: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\2e4e53a3ae69d301d02b00007c017813.$$_syswow64_installshield_setupdir_0011_5cf94728ecb988f6.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0011_5cf94728ecb988f6.cdf-ms"
    5: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\3c755aa3ae69d301d12b00007c017813.$$_syswow64_installshield_setupdir_001a_5cf94748ecb98866.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_001a_5cf94748ecb98866.cdf-ms"
    6: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\a4fe63a3ae69d301d22b00007c017813.$$_syswow64_installshield_setupdir_0404_5cf94eeaecb97d26.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0404_5cf94eeaecb97d26.cdf-ms"
    7: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\0c886da3ae69d301d32b00007c017813.$$_syswow64_installshield_setupdir_0019_5cf94738ecb988ae.cdf-ms", Desti
2017-11-30 08:41:32, Info                  CSI    nation = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0019_5cf94738ecb988ae.cdf-ms"
    8: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\28d67ba3ae69d301d42b00007c017813.$$_syswow64_installshield_setupdir_001b_5cf9474aecb9885d.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_001b_5cf9474aecb9885d.cdf-ms"
    9: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\905f85a3ae69d301d52b00007c017813.$$_syswow64_installshield_setupdir_0416_5cf94ecaecb97d65.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0416_5cf94ecaecb97d65.cdf-ms"
    10: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\f8e88ea3ae69d301d62b00007c017813.$$_syswow64_installshield_setupdir_000a_5cf9476cecb98815.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_000a_5cf9476cecb98815.cdf-ms"
    11: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\607298a3ae69d301d72b00007c017813.$$_syswow64_installshield_setupdir_0012_5cf9472aecb988ed.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0012_5cf9472aecb988ed.cdf-ms"
    12: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\c8fba1a3ae69d301d82b00007c017813.$$_syswow64_installshield_setupdir_0024_5cf9470aecb9892c.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0024_5cf9470aecb9892c.cdf-ms"
    13: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\3085aba3ae69d301d92b00007c017813.$$_syswow64_installshield_setupdir_002d_5cf9472aecb9889c.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_002d_5cf9472aecb9889c.cdf-ms"
    14: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\980eb5a3ae69d301da2b00007c017813.$$_syswow64_installshield_se
2017-11-30 08:41:32, Info                  CSI    tupdir_000b_5cf9476eecb9880c.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_000b_5cf9476eecb9880c.cdf-ms"
    15: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\0098bea3ae69d301db2b00007c017813.$$_syswow64_installshield_setupdir_0013_5cf9472cecb988e4.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0013_5cf9472cecb988e4.cdf-ms"
    16: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\c283caa3ae69d301dc2b00007c017813.$$_syswow64_installshield_setupdir_0014_5cf9472eecb988db.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0014_5cf9472eecb988db.cdf-ms"
    17: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\d0aad1a3ae69d301dd2b00007c017813.$$_syswow64_installshield_setupdir_001d_5cf9474eecb9884b.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_001d_5cf9474eecb9884b.cdf-ms"
    18: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\ecf8dfa3ae69d301de2b00007c017813.$$_syswow64_installshield_setupdir_0015_5cf94730ecb988d2.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0015_5cf94730ecb988d2.cdf-ms"
    19: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\5482e9a3ae69d301df2b00007c017813.$$_syswow64_installshield_setupdir_001e_5cf94750ecb98842.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_001e_5cf94750ecb98842.cdf-ms"
    20: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\62a9f0a3ae69d301e02b00007c017813.$$_syswow64_installshield_setupdir_0804_5cf95682ecb971c2.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0804_5cf95682ecb971c2.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\7ef7fea3ae69d301
2017-11-30 08:41:32, Info                  CSI    e12b00007c017813.$$_syswow64_installshield_setupdir_001f_5cf94752ecb98839.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_001f_5cf94752ecb98839.cdf-ms"
    22: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\e68008a4ae69d301e22b00007c017813.$$_syswow64_installshield_setupdir_0816_5cf95662ecb97201.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0816_5cf95662ecb97201.cdf-ms"
    23: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\f4a70fa4ae69d301e32b00007c017813.$$_syswow64_installshield_setupdir_000e_5cf94774ecb987f1.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_000e_5cf94774ecb987f1.cdf-ms"
    24: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\6a5820a4ae69d301e42b00007c017813.$$_syswow64_installshield_setupdir_0c0c_5cf96b82ecb951e8.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0c0c_5cf96b82ecb951e8.cdf-ms"
    25: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\d2e129a4ae69d301e52b00007c017813.$$_syswow64_installshield_setupdir_040c_5cf94f08ecb97c9f.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_040c_5cf94f08ecb97c9f.cdf-ms"
    26: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a6b33a4ae69d301e62b00007c017813.$$_syswow64_installshield_setupdir_0010_5cf94726ecb988ff.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0010_5cf94726ecb988ff.cdf-ms"
    27: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2f43ca4ae69d301e72b00007c017813.$$_syswow64_installshield_setupdir_0021_5cf94704ecb98947.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_setupdir_0021_5cf94704ecb98947.cdf-ms"
POQ 100 ends.
2017-11-30 08:41:32, Info                  CSI    00000223 [SR] Verify complete
2017-11-30 08:41:32, Info                  CSI    00000224 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:32, Info                  CSI    00000225 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:32, Info                  CSI    00000226 Repair results created:
POQ 101 starts:
POQ 101 ends.
2017-11-30 08:41:32, Info                  CSI    00000227 [SR] Verify complete
2017-11-30 08:41:33, Info                  CSI    00000228 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:33, Info                  CSI    00000229 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:35, Info                  CSI    0000022a Repair results created:
POQ 102 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1e4a56a5ae69d301b02c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\78ac58a5ae69d301b12c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\86d35fa5ae69d301b22c00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\e03562a5ae69d301b32c00007c017813.$$_syswow64_bestpractices_v1.0_models_microsoft_windows_webserver_c41798e722b5feb5.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_bestpractices_v1.0_models_microsoft_windows_webserver_c41798e722b5feb5.cdf-ms"
    4: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\e03562a5ae69d301b42c00007c017813.$$_syswow64_bestpractices_v1.0_models_microsoft_windows_webserver_pl-pl_aef479edcbb029da.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_bestpractices_v1.0_models_microsoft_windows_webserver_pl-pl_aef479edcbb029da.cdf-ms"
    5: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2216ea5ae69d301b52c00007c017813.$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms"
    6: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\fc8370a5ae69d301b62c00007c017813.$$_syswow64_windowspowershell_v1.0_modules_webadministration_5b2072c611c9e2f0.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_webadministration_5b2072c611c9e2f0.cdf-ms"
2017-11-30 08:41:35, Info                  CSI    7: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\fc8370a5ae69d301b72c00007c017813.$$_syswow64_windowspowershell_v1.0_modules_webadministration_en-us_cd977fcee02d13b8.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_webadministration_en-us_cd977fcee02d13b8.cdf-ms"
    8: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\cc9683a5ae69d301b82c00007c017813.$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_installshield_b5853d7fd6c30e20.cdf-ms"
    9: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\8292e0a5ae69d301b92c00007c017813.$$_syswow64_ime_imetc10_a6d5873b8f8ff9ba.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imetc10_a6d5873b8f8ff9ba.cdf-ms"
    10: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\8292e0a5ae69d301ba2c00007c017813.$$_syswow64_ime_imetc10_applets_892de9ea0e55232f.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imetc10_applets_892de9ea0e55232f.cdf-ms"
    11: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\8292e0a5ae69d301bb2c00007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    12: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\8292e0a5ae69d301bc2c00007c017813.$$_ime_imetc10_dicts_31e93cd9cd8cc931.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imetc10_dicts_31e93cd9cd8cc931.cdf-ms"
    13: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\8292e0a5ae69d301bd2c00007c017813.$$_ime_imetc10_help_31e933f572191d05.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imetc10_help_31e933f572191d05.cdf-ms"
    14: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ee0eea5ae69d301be2c00007c017813.programdata_mi
2017-11-30 08:41:35, Info                  CSI    crosoft_identitycrl_9ceb7e1568e6c6e7.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_identitycrl_9ceb7e1568e6c6e7.cdf-ms"
    15: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\60ccfaa5ae69d301bf2c00007c017813.$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms"
    16: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\60ccfaa5ae69d301c02c00007c017813.$$_syswow64_inetsrv_pl-pl_89e4f29ec1ffb0d6.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_pl-pl_89e4f29ec1ffb0d6.cdf-ms"
    17: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\b4b625a6ae69d301c12c00007c017813.$$_syswow64_ime_imesc5_064a5cb2620237eb.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imesc5_064a5cb2620237eb.cdf-ms"
    18: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\0e1928a6ae69d301c22c00007c017813.$$_syswow64_ime_imesc5_applets_a74069db3c6089ce.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imesc5_applets_a74069db3c6089ce.cdf-ms"
    19: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\0e1928a6ae69d301c32c00007c017813.$$_ime_imesc5_dicts_32255cd579e8854e.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imesc5_dicts_32255cd579e8854e.cdf-ms"
    20: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\0e1928a6ae69d301c42c00007c017813.$$_ime_imesc5_help_693c441c0201a8fa.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imesc5_help_693c441c0201a8fa.cdf-ms"
POQ 102 ends.
2017-11-30 08:41:35, Info                  CSI    0000022b [SR] Verify complete
2017-11-30 08:41:35, Info                  CSI    0000022c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:35, Info                  CSI    0000022d [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:38, Info                  CSI    0000022e Ignoring duplicate ownership for directory [l:80{40}]"\??\C:\ProgramData\Microsoft\Windows\DRM" in component Microsoft-Windows-MediaPlayer-DRM, Version = 6.1.7601.23471, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:38, Info                  CSI    0000022f Ignoring duplicate ownership for directory [l:92{46}]"\??\C:\ProgramData\Microsoft\Windows\DRM\Cache" in component Microsoft-Windows-MediaPlayer-DRM, Version = 6.1.7601.23471, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:39, Info                  CSI    00000230 Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\SysWOW64" in component Microsoft-Windows-LSA, Version = 6.1.7601.23889, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:39, Info                  CSI    00000231 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\Inf\W3SVC\0415" in component Microsoft-Windows-IIS-W3SVC.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:40, Info                  CSI    00000232 Ignoring duplicate ownership for directory [l:48{24}]"\??\C:\Windows\Inf\W3SVC" in component Microsoft-Windows-IIS-W3SVC, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:40, Info                  CSI    00000233 Repair results created:
POQ 103 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\9acca0a7ae69d301292d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\9acca0a7ae69d3012a2d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\9acca0a7ae69d3012b2d00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    3: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\9acca0a7ae69d3012c2d00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    4: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\9acca0a7ae69d3012d2d00007c017813.$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms"
    5: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\f42ea3a7ae69d3012e2d00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    6: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\f42ea3a7ae69d3012f2d00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms"
    7: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\4e91a5a7ae69d301302d00007c017813.program_files_x86_msbuild_microsoft_windows_workflow_foundation_v3.5
2017-11-30 08:41:40, Info                  CSI    _2a4717de8ec5d881.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_msbuild_microsoft_windows_workflow_foundation_v3.5_2a4717de8ec5d881.cdf-ms"
    8: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\a8f3a7a7ae69d301312d00007c017813.program_files_x86_windows_media_player_e9607c93dd43c2ea.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_e9607c93dd43c2ea.cdf-ms"
    9: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\0256aaa7ae69d301322d00007c017813.program_files_x86_windows_media_player_pl-pl_af5bf6a7fe756467.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_pl-pl_af5bf6a7fe756467.cdf-ms"
    10: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\e83ef4a7ae69d301332d00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    11: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\e83ef4a7ae69d301342d00007c017813.program_files_x86_common_files_speechengines_microsoft_tts20_295900c68c9b1d40.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_speechengines_microsoft_tts20_295900c68c9b1d40.cdf-ms"
    12: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\42a1f6a7ae69d301352d00007c017813.program_files_x86_common_files_speechengines_microsoft_tts20_en-us_cd26f44bf3192ef2.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_speechengines_microsoft_tts20_en-us_cd26f44bf3192ef2.cdf-ms"
    13: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\42a1f6a7ae69d301362d00007c017813.program_files_x86_common_files_speechengines_microsoft_tts20_en-us_enu-dsk_05357e3121c0b741.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_com
2017-11-30 08:41:40, Info                  CSI    mon_files_speechengines_microsoft_tts20_en-us_enu-dsk_05357e3121c0b741.cdf-ms"
    14: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\b85107a8ae69d301372d00007c017813.programdata_microsoft_windows_drm_1409f63e8e701274.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_drm_1409f63e8e701274.cdf-ms"
    15: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\12b409a8ae69d301382d00007c017813.programdata_microsoft_windows_drm_cache_0462a9ca8b56f2bc.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_windows_drm_cache_0462a9ca8b56f2bc.cdf-ms"
    16: Set File Information: File = [l:92{46}]"\??\C:\ProgramData\Microsoft\Windows\DRM\Cache", Attributes = 00000086
    17: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2c61ca8ae69d301392d00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    18: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\3c291fa8ae69d3013a2d00007c017813.$$_syswow64_ime_imekr8_064a78c062020e1f.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imekr8_064a78c062020e1f.cdf-ms"
    19: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\3c291fa8ae69d3013b2d00007c017813.$$_syswow64_ime_imekr8_dicts_b3961c9ea5dcf4e6.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imekr8_dicts_b3961c9ea5dcf4e6.cdf-ms"
    20: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\58772da8ae69d3013c2d00007c017813.$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms"
    21: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\58772da8ae69d3013d2d00007c017813.$$_syswow64_windowspowershell_v1.0_modules_webadministration_5b2072c611c9e2
2017-11-30 08:41:40, Info                  CSI    f0.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_webadministration_5b2072c611c9e2f0.cdf-ms"
    22: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\44d84ea8ae69d3013e2d00007c017813.$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms"
    23: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\44d84ea8ae69d3013f2d00007c017813.$$_syswow64_inetsrv_config_5cfcff5ad48281cb.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_config_5cfcff5ad48281cb.cdf-ms"
    24: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\44d84ea8ae69d301402d00007c017813.$$_syswow64_inetsrv_config_export_409d10cc596f301b.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_config_export_409d10cc596f301b.cdf-ms"
    25: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\9e3a51a8ae69d301412d00007c017813.$$_syswow64_inetsrv_config_schema_18b51e2495591ee8.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_config_schema_18b51e2495591ee8.cdf-ms"
    26: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\303970a8ae69d301422d00007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    27: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\303970a8ae69d301432d00007c017813.$$_microsoft.net_framework_v2.0.50727_gac_pl_9a1532ffc04b43d3.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_gac_pl_9a1532ffc04b43d3.cdf-ms"
    28: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\303970a8ae69d301442d00007c017813.$$_microsoft.net_framework_v2.0.50727_mui_0415_fbbb4736c63bce4f.cdf-ms"
2017-11-30 08:41:40, Info                  CSI    , Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_mui_0415_fbbb4736c63bce4f.cdf-ms"
    29: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\8a9b72a8ae69d301452d00007c017813.$$_microsoft.net_framework_v2.0.50727_1045_7994ecae0abd51fe.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_1045_7994ecae0abd51fe.cdf-ms"
    30: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\8a9b72a8ae69d301462d00007c017813.$$_microsoft.net_framework_v2.0.50727_pl_9d42e4693d1bb634.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_pl_9d42e4693d1bb634.cdf-ms"
    31: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2247ca8ae69d301472d00007c017813.$$_syswow64_mui_0415_29ea5b14e6ab1a59.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_mui_0415_29ea5b14e6ab1a59.cdf-ms"
    32: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2247ca8ae69d301482d00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    33: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2247ca8ae69d301492d00007c017813.$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms"
    34: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\f2247ca8ae69d3014a2d00007c017813.$$_inf_.net_clr_data_0415_9334eaa7f0277011.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0415_9334eaa7f0277011.cdf-ms"
    35: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d3014b2d00007c017813.$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms"
    36: Move F
2017-11-30 08:41:40, Info                  CSI    ile: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d3014c2d00007c017813.$$_inf_.net_clr_networking_0415_417ab27890926525.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_0415_417ab27890926525.cdf-ms"
    37: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d3014d2d00007c017813.$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms"
    38: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d3014e2d00007c017813.$$_inf_.net_data_provider_for_oracle_0415_1ac87e0ef00b1c90.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_0415_1ac87e0ef00b1c90.cdf-ms"
    39: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d3014f2d00007c017813.$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms"
    40: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d301502d00007c017813.$$_inf_.net_data_provider_for_sqlserver_0415_22ef188b81b08c6b.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_0415_22ef188b81b08c6b.cdf-ms"
    41: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d301512d00007c017813.$$_inf_.netframework_266880c2626e99c6.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_266880c2626e99c6.cdf-ms"
    42: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\4c877ea8ae69d301522d00007c017813.$$_inf_.netframework_0415_fd6b68e949272494.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_0415_fd6b68e949272494.cdf-ms"
    43: Move File: Source = [l:216{108}]"\S
2017-11-30 08:41:40, Info                  CSI    ystemRoot\WinSxS\Temp\PendingRenames\b41088a8ae69d301532d00007c017813.$$_inf_w3svc_0ef6c7aee1e4154f.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_w3svc_0ef6c7aee1e4154f.cdf-ms"
    44: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b41088a8ae69d301542d00007c017813.$$_inf_w3svc_0415_6ed52ac03816468b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_inf_w3svc_0415_6ed52ac03816468b.cdf-ms"
    45: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\68d58ca8ae69d301552d00007c017813.$$_microsoft.net_framework_v3.5_1033_b573e20073d26166.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_1033_b573e20073d26166.cdf-ms"
    46: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\68d58ca8ae69d301562d00007c017813.$$_microsoft.net_framework_v2.0.50727_subsetlist_2a1589056b6db300.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_subsetlist_2a1589056b6db300.cdf-ms"
    47: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\c2378fa8ae69d301572d00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms"
    48: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c9a91a8ae69d301582d00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_subsetlist_fe5eff8713e368f0.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_subsetlist_fe5eff8713e368f0.cdf-ms"
    49: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\1c9a91a8ae69d301592d00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.5_redistlist_af4b5c850431ef86.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\Fi
2017-11-30 08:41:40, Info                  CSI    leMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_redistlist_af4b5c850431ef86.cdf-ms"
    50: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\76fc93a8ae69d3015a2d00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.5_subsetlist_aaf62cd71100a933.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_subsetlist_aaf62cd71100a933.cdf-ms"
    51: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\e634cda8ae69d3015b2d00007c017813.program_files_x86_windows_media_player_media_renderer_750773e49fdbfa5b.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_media_renderer_750773e49fdbfa5b.cdf-ms"
    52: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\4097cfa8ae69d3015c2d00007c017813.program_files_x86_windows_media_player_network_sharing_f29a3dd721834a7e.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_network_sharing_f29a3dd721834a7e.cdf-ms"
    53: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\865af3a8ae69d3015d2d00007c017813.$$_syswow64_migwiz_4d49015779604be3.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_4d49015779604be3.cdf-ms"
    54: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\865af3a8ae69d3015e2d00007c017813.$$_syswow64_migwiz_postmigres_data_5e22428c37d2d508.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_postmigres_data_5e22428c37d2d508.cdf-ms"
    55: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\e0bcf5a8ae69d3015f2d00007c017813.$$_syswow64_migwiz_postmigres_web_737e2d6907c3eb32.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_postmigres_web_737e2d6907c3eb32.cdf-ms"
    56: Move File: Source = [l:282{141}]"\SystemRoot\WinSxS\Temp\PendingRenames
2017-11-30 08:41:40, Info                  CSI    \e0bcf5a8ae69d301602d00007c017813.$$_syswow64_migwiz_postmigres_web_base_images_1f07dfcc37b3bff8.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_postmigres_web_base_images_1f07dfcc37b3bff8.cdf-ms"
POQ 103 ends.
2017-11-30 08:41:40, Info                  CSI    00000234 [SR] Verify complete
2017-11-30 08:41:40, Info                  CSI    00000235 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:40, Info                  CSI    00000236 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:41, Info                  CSI    00000237 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Inf\PNRPSvc\0415" in component Microsoft-Windows-PeerToPeerPNRP.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:41, Info                  CSI    00000238 Ignoring duplicate ownership for directory [l:52{26}]"\??\C:\Windows\Inf\PNRPSvc" in component Microsoft-Windows-PeerToPeerPNRP, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:41, Info                  CSI    00000239 Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Inf\PNRPSvc\0000" in component Microsoft-Windows-PeerToPeerPNRP, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:42, Info                  CSI    0000023a Repair results created:
POQ 104 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\1cc7c2a9ae69d301c52d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1cc7c2a9ae69d301c62d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\2aeec9a9ae69d301c72d00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\8450cca9ae69d301c82d00007c017813.$$_syswow64_tasks_bad86ed64cd79762.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_bad86ed64cd79762.cdf-ms"
    4: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\8450cca9ae69d301c92d00007c017813.$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms"
    5: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\8450cca9ae69d301ca2d00007c017813.$$_pla_reports_a2604845b2b380ca.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_pla_reports_a2604845b2b380ca.cdf-ms"
    6: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\8450cca9ae69d301cb2d00007c017813.$$_pla_rules_0bde462ce96f215e.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_pla_rules_0bde462ce96f215e.cdf-ms"
    7: Create Directory: Directory = [l:30{15}]"\??\C:\PerfLogs", Attributes = 00000080
    8: Create Directory: Directory = [l:42{21}]"\??\C:\PerfLogs\Admin", Attributes = 00000080
    9: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\deb2cea9ae69d301cc2d00007c017813.$$_inf_3f581daba4c8c835.cdf-ms"
2017-11-30 08:41:42, Info                  CSI    , Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    10: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\deb2cea9ae69d301cd2d00007c017813.$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_3932681b8fb41c9d.cdf-ms"
    11: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\deb2cea9ae69d301ce2d00007c017813.$$_inf_pnrpsvc_0415_43734285fe2eacff.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_0415_43734285fe2eacff.cdf-ms"
    12: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\5463dfa9ae69d301cf2d00007c017813.$$_inf_pnrpsvc_0000_43733b07fe2eb83f.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_pnrpsvc_0000_43733b07fe2eb83f.cdf-ms"
    13: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\628ae6a9ae69d301d02d00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    14: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\628ae6a9ae69d301d12d00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    15: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\628ae6a9ae69d301d22d00007c017813.$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms"
    16: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\628ae6a9ae69d301d32d00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    17: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcece8a9ae69d301d42d00007c017813.program_files
2017-11-30 08:41:42, Info                  CSI    _x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms"
    18: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\70b1eda9ae69d301d52d00007c017813.$$_pla_reports_pl-pl_04eb7d4c9a83e841.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_pla_reports_pl-pl_04eb7d4c9a83e841.cdf-ms"
    19: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\70b1eda9ae69d301d62d00007c017813.$$_pla_rules_pl-pl_8b463dc854621dff.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_pla_rules_pl-pl_8b463dc854621dff.cdf-ms"
    20: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\8cfffba9ae69d301d72d00007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    21: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\e661fea9ae69d301d82d00007c017813.$$_microsoft.net_framework_v2.0.50727_mui_0409_fbbb44c0c63bd26c.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_mui_0409_fbbb44c0c63bd26c.cdf-ms"
    22: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\e661fea9ae69d301d92d00007c017813.$$_microsoft.net_framework_v2.0.50727_1033_7994eb100abd5435.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_1033_7994eb100abd5435.cdf-ms"
    23: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\e661fea9ae69d301da2d00007c017813.$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms"
    24: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\e661fe
2017-11-30 08:41:42, Info                  CSI    a9ae69d301db2d00007c017813.$$_microsoft.net_framework_v1.0.3705_b19cf3207984c497.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v1.0.3705_b19cf3207984c497.cdf-ms"
    25: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\4eeb07aaae69d301dc2d00007c017813.$$_syswow64_mui_0409_29ea5b12e6ab1a66.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_mui_0409_29ea5b12e6ab1a66.cdf-ms"
    26: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\4eeb07aaae69d301dd2d00007c017813.$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0864fda87da3c851.cdf-ms"
    27: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\4eeb07aaae69d301de2d00007c017813.$$_inf_.net_clr_data_0000_9334e121f0277e71.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_data_0000_9334e121f0277e71.cdf-ms"
    28: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301df2d00007c017813.$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_d061836896f4f29d.cdf-ms"
    29: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e02d00007c017813.$$_inf_.net_clr_networking_0000_417aaafa90927065.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_clr_networking_0000_417aaafa90927065.cdf-ms"
    30: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e12d00007c017813.$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_07838adde9419766.cdf-ms"
    31: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e22d00007c017813.$$_inf_.net_data_provider_for_oracle_0000_1ac87488f00b2af0.cdf-ms", Destination = [l:1
2017-11-30 08:41:42, Info                  CSI    86{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_oracle_0000_1ac87488f00b2af0.cdf-ms"
    32: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e32d00007c017813.$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_7cfd5f3e72497ce1.cdf-ms"
    33: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e42d00007c017813.$$_inf_.net_data_provider_for_sqlserver_0000_22ef191981b08b2b.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.net_data_provider_for_sqlserver_0000_22ef191981b08b2b.cdf-ms"
    34: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e52d00007c017813.$$_inf_.netframework_266880c2626e99c6.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_266880c2626e99c6.cdf-ms"
    35: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\a84d0aaaae69d301e62d00007c017813.$$_inf_.netframework_0000_fd6b5f63492732f4.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_inf_.netframework_0000_fd6b5f63492732f4.cdf-ms"
    36: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\e0e926aaae69d301e72d00007c017813.$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms"
    37: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a4c29aaae69d301e82d00007c017813.$$_syswow64_windowspowershell_v1.0_en-us_79e30ca972b850e5.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_en-us_79e30ca972b850e5.cdf-ms"
    38: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\be2341aaae69d301e92d00007c017813.$$_syswow64_networklist_fac29f16fb5be78a.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMa
2017-11-30 08:41:42, Info                  CSI    ps\$$_syswow64_networklist_fac29f16fb5be78a.cdf-ms"
    39: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\be2341aaae69d301ea2d00007c017813.$$_syswow64_networklist_icons_0ad2dfa4d19a0c98.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_networklist_icons_0ad2dfa4d19a0c98.cdf-ms"
POQ 104 ends.
2017-11-30 08:41:42, Info                  CSI    0000023b [SR] Verify complete
2017-11-30 08:41:42, Info                  CSI    0000023c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:42, Info                  CSI    0000023d [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:45, Info                  CSI    0000023e Repair results created:
POQ 105 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\a0cb0babae69d3014f2e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\a0cb0babae69d301502e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\aef212abae69d301512e00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\085515abae69d301522e00007c017813.$$_syswow64_setup_b8f1f0fc4fb15499.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_setup_b8f1f0fc4fb15499.cdf-ms"
    4: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e0526abae69d301532e00007c017813.$$_syswow64_ras_1bf253d3a7664da0.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ras_1bf253d3a7664da0.cdf-ms"
    5: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\a87a3babae69d301542e00007c017813.$$_syswow64_migration_bdcfa47e8790e0c4.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_bdcfa47e8790e0c4.cdf-ms"
    6: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\02dd3dabae69d301552e00007c017813.$$_syswow64_migration_wsmt_rras_replacementmanifests_a4cea69872d16ef3.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_wsmt_rras_replacementmanifests_a4cea69872d16ef3.cdf-ms"
    7: Move File: Source = [l:366{183}]"\SystemRoot\WinSxS\Temp\PendingRenames\02dd3dabae69d301562e00007c017813.$$_syswow64_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasapi-migplugin_8ee28867d4841eb7.cdf-ms", Destination = [l:278{139}]"\Sy
2017-11-30 08:41:45, Info                  CSI    stemRoot\WinSxS\FileMaps\$$_syswow64_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasapi-migplugin_8ee28867d4841eb7.cdf-ms"
    8: Move File: Source = [l:372{186}]"\SystemRoot\WinSxS\Temp\PendingRenames\02dd3dabae69d301572e00007c017813.$$_syswow64_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasserver-migplugin_294b707969a732c6.cdf-ms", Destination = [l:284{142}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_wsmt_rras_replacementmanifests_microsoft-windows-rasserver-migplugin_294b707969a732c6.cdf-ms"
    9: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\5c3f40abae69d301582e00007c017813.$$_syswow64_migration_wsmt_rras_dlmanifests_39de4a9ff72c5eb9.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_wsmt_rras_dlmanifests_39de4a9ff72c5eb9.cdf-ms"
    10: Move File: Source = [l:354{177}]"\SystemRoot\WinSxS\Temp\PendingRenames\5c3f40abae69d301592e00007c017813.$$_syswow64_migration_wsmt_rras_dlmanifests_microsoft-windows-rasserver-migplugin_93433b6bee67eb38.cdf-ms", Destination = [l:266{133}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_wsmt_rras_dlmanifests_microsoft-windows-rasserver-migplugin_93433b6bee67eb38.cdf-ms"
    11: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\3a795aabae69d3015a2e00007c017813.$$_security_fe3ad40cd6e08c7c.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_security_fe3ad40cd6e08c7c.cdf-ms"
    12: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\a20264abae69d3015b2e00007c017813.$$_syswow64_speech_speechux_27aa9ae49ec13adf.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_speech_speechux_27aa9ae49ec13adf.cdf-ms"
    13: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\a20264abae69d3015c2e00007c017813.$$_syswow64_speech_speechux_pl-pl_73e0df3fbb7b3e26.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_speech_speechux_pl-pl_73e0df3fbb7b3e26.cdf-ms"
    14: Move
2017-11-30 08:41:45, Info                  CSI    File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\64ee6fabae69d3015d2e00007c017813.$$_syswow64_spp_tokens_ppdlic_ee939189101570f7.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_spp_tokens_ppdlic_ee939189101570f7.cdf-ms"
    15: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\18b374abae69d3015e2e00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    16: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\721577abae69d3015f2e00007c017813.program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms"
    17: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\721577abae69d301602e00007c017813.program_files_x86_windows_sidebar_gadgets_6f6d1ec3860a4a26.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_6f6d1ec3860a4a26.cdf-ms"
    18: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\803c7eabae69d301612e00007c017813.$$_speech_common_76cd6f1aaba6e83b.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_speech_common_76cd6f1aaba6e83b.cdf-ms"
    19: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\2811d4abae69d301622e00007c017813.$$_syswow64_icsxml_468761bf82e091a8.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_icsxml_468761bf82e091a8.cdf-ms"
    20: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\8273d6abae69d301632e00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    21: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\8273d6abae69d301642e00007c017813.$$_inf_remoteaccess_110554180baafc8b.cdf-ms", Destination = [l:142{71}]"\System
2017-11-30 08:41:45, Info                  CSI    Root\WinSxS\FileMaps\$$_inf_remoteaccess_110554180baafc8b.cdf-ms"
    22: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\8273d6abae69d301652e00007c017813.$$_inf_remoteaccess_0000_86bc982ae65d5d49.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_0000_86bc982ae65d5d49.cdf-ms"
    23: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\3638dbabae69d301662e00007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
POQ 105 ends.
2017-11-30 08:41:45, Info                  CSI    0000023f [SR] Verify complete
2017-11-30 08:41:45, Info                  CSI    00000240 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:45, Info                  CSI    00000241 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:46, Info                  CSI    00000242 Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\schemas\TSWorkSpace" in component Microsoft-Windows-TerminalServices-Workspace, Version = 6.1.7601.18546, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:46, Info                  CSI    00000243 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\Inf\TermService" in component Microsoft-Windows-TerminalServices-PerfCounters, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:46, Info                  CSI    00000244 Ignoring duplicate ownership for directory [l:70{35}]"\??\C:\Windows\Inf\TermService\0000" in component Microsoft-Windows-TerminalServices-PerfCounters, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:46, Info                  CSI    00000245 Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\Logs\MeasuredBoot" in component Microsoft-Windows-TPM-TBS-Core, Version = 6.1.7601.19146, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:46, Info                  CSI    00000246 Ignoring duplicate ownership for directory [l:106{53}]"\??\C:\ProgramData\Microsoft\Crypto\PCPKSP\WindowsAIK" in component Microsoft-Windows-TPM-TBS-Core, Version = 6.1.7601.19146, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    00000247 Ignoring duplicate ownership for directory [l:78{39}]"\??\C:\ProgramData\Microsoft\DeviceSync" in component Microsoft-Windows-SyncInfrastructure, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    00000248 Ignoring duplicate ownership for directory [l:50{25}]"\??\C:\Windows\Inf\usbhub" in component Microsoft-Windows-usbperf, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    00000249 Ignoring duplicate ownership for directory [l:60{30}]"\??\C:\Windows\Inf\usbhub\0000" in component Microsoft-Windows-usbperf, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    0000024a Ignoring duplicate ownership for directory [l:52{26}]"\??\C:\Windows\schemas\WCN" in component Microsoft-Windows-Wireless-Network-Setup-Wizard, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    0000024b Ignoring duplicate ownership for directory [l:52{26}]"\??\C:\Windows\Inf\TAPISRV" in component Microsoft-Windows-TAPICore, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    0000024c Ignoring duplicate ownership for directory [l:62{31}]"\??\C:\Windows\Inf\TAPISRV\0000" in component Microsoft-Windows-TAPICore, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:47, Info                  CSI    0000024d Repair results created:
POQ 106 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\914ca2acae69d301cb2e00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\914ca2acae69d301cc2e00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f73a9acae69d301cd2e00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f73a9acae69d301ce2e00007c017813.$$_syswow64_tasks_bad86ed64cd79762.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_bad86ed64cd79762.cdf-ms"
    4: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f73a9acae69d301cf2e00007c017813.$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms"
    5: Move File: Source = [l:344{172}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f73a9acae69d301d02e00007c017813.$$_syswow64_tasks_microsoft_windows_remoteapp_and_desktop_connections_update_537d8a8a24b3a619.cdf-ms", Destination = [l:256{128}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_microsoft_windows_remoteapp_and_desktop_connections_update_537d8a8a24b3a619.cdf-ms"
    6: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\f9d5abacae69d301d12e00007c017813.$$_schemas_9f2c881475a483d6.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_9f2c881475a483d6.cdf-ms"
    7: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\f9d5abacae69d301d22e00007c017813.$$_schemas_tsworkspace_8eac79c1e59127ee.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\
2017-11-30 08:41:47, Info                  CSI    FileMaps\$$_schemas_tsworkspace_8eac79c1e59127ee.cdf-ms"
    8: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\3172c8acae69d301d32e00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    9: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\3172c8acae69d301d42e00007c017813.$$_inf_termservice_f0fb244350031192.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_termservice_f0fb244350031192.cdf-ms"
    10: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\3172c8acae69d301d52e00007c017813.$$_inf_termservice_0000_f96d5ce56bc76fc8.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_inf_termservice_0000_f96d5ce56bc76fc8.cdf-ms"
    11: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\99fbd1acae69d301d62e00007c017813.$$_logs_measuredboot_ab1fadc53c86b337.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_logs_measuredboot_ab1fadc53c86b337.cdf-ms"
    12: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\99fbd1acae69d301d72e00007c017813.programdata_microsoft_crypto_pcpksp_windowsaik_cb9775b914a8e5a2.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_pcpksp_windowsaik_cb9775b914a8e5a2.cdf-ms"
    13: Set File Information: File = [l:106{53}]"\??\C:\ProgramData\Microsoft\Crypto\PCPKSP\WindowsAIK", Attributes = 00000084
    14: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1aa01adae69d301d82e00007c017813.$$_inf_usbhub_299dea1039e75d30.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_299dea1039e75d30.cdf-ms"
    15: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1aa01adae69d301d92e00007c017813.$$_inf_usbhub_0415_1bec34ed3c8ba7b4.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_0415_1bec34ed3c8ba7b4.cdf-ms"
2017-11-30 08:41:47, Info                  CSI    l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\afd108adae69d301da2e00007c017813.programdata_microsoft_devicesync_d6b7928aa153816d.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_devicesync_d6b7928aa153816d.cdf-ms"
    17: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\09340badae69d301db2e00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    18: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\09340badae69d301dc2e00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    19: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\09340badae69d301dd2e00007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    20: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\63960dadae69d301de2e00007c017813.program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms"
    21: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\63960dadae69d301df2e00007c017813.program_files_x86_common_files_microsoft_shared_ink_hwrcustomization_3663d5717756d7ef.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_hwrcustomization_3663d5717756d7ef.cdf-ms"
    22: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\bdf80fadae69d301e02e00007c017813.$$_inf_tapisrv_20c65cafb424239c.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_20c65cafb424239c.cdf-ms"
    23:
2017-11-30 08:41:47, Info                  CSI    Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\bdf80fadae69d301e12e00007c017813.$$_inf_tapisrv_0415_2e999d681b8626fe.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_0415_2e999d681b8626fe.cdf-ms"
    24: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\7fe41badae69d301e22e00007c017813.$$_inf_usbhub_0000_1bec33bb3c8ba8f4.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_inf_usbhub_0000_1bec33bb3c8ba8f4.cdf-ms"
    25: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\b78038adae69d301e32e00007c017813.$$_schemas_wcn_b437fb7b7751c8a8.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_wcn_b437fb7b7751c8a8.cdf-ms"
    26: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\11e33aadae69d301e42e00007c017813.$$_inf_tapisrv_0000_2e9995ea1b86323e.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_tapisrv_0000_2e9995ea1b86323e.cdf-ms"
    27: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b453dadae69d301e52e00007c017813.$$_schemas_availablenetwork_aaf14dcc87fea431.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_schemas_availablenetwork_aaf14dcc87fea431.cdf-ms"
POQ 106 ends.
2017-11-30 08:41:47, Info                  CSI    0000024e [SR] Verify complete
2017-11-30 08:41:47, Info                  CSI    0000024f [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:47, Info                  CSI    00000250 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:48, Info                  CSI    00000251 Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\SysWOW64" in component Microsoft-Windows-WOW64, Version = 6.1.7601.23889, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:49, Info                  CSI    00000252 Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\Inf\UGTHRSVC\0415" in component WindowsSearchEngine.Resources, Version = 7.0.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:49, Info                  CSI    00000253 Ignoring duplicate ownership for directory [l:66{33}]"\??\C:\Windows\Inf\UGatherer\0415" in component WindowsSearchEngine.Resources, Version = 7.0.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:49, Info                  CSI    00000254 Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\Inf\wsearchidxpi\0415" in component WindowsSearchEngine.Resources, Version = 7.0.7600.16385, pA = PROCESSOR_ARCHITECTURE_IA32_ON_WIN64 (10), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:49, Info                  CSI    00000255 Repair results created:
POQ 107 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014a2f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014b2f00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014c2f00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014d2f00007c017813.$$_inf_ugthrsvc_9c5b081f28f83f11.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_9c5b081f28f83f11.cdf-ms"
    4: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014e2f00007c017813.$$_inf_ugthrsvc_0000_8451c300df70be5f.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_0000_8451c300df70be5f.cdf-ms"
    5: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\d73cf7adae69d3014f2f00007c017813.$$_inf_ugatherer_9f1f9c5b6cd50d98.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_9f1f9c5b6cd50d98.cdf-ms"
    6: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\319ff9adae69d301502f00007c017813.$$_inf_ugatherer_0000_046b5203f9ca3f14.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_0000_046b5203f9ca3f14.cdf-ms"
    7: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\319ff9adae69d301512f00007c017813.$$_inf_wsearchidxpi_a2c41dc1731a4204.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_a2c41dc1731a4204.cdf-ms"
    8: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRena
2017-11-30 08:41:49, Info                  CSI    mes\319ff9adae69d301522f00007c017813.$$_inf_wsearchidxpi_0000_2e6e3f1caf9fca20.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_0000_2e6e3f1caf9fca20.cdf-ms"
    9: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\992803aeae69d301532f00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    10: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\f38a05aeae69d301542f00007c017813.$$_syswow64_drivers_193c6528ad70a5e7.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_drivers_193c6528ad70a5e7.cdf-ms"
    11: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\01b20caeae69d301552f00007c017813.$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_19ae85881f1c4f2d.cdf-ms"
    12: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\5b140faeae69d301562f00007c017813.$$_syswow64_windowspowershell_v1.0_modules_troubleshootingpack_f5b178e0926c79db.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_troubleshootingpack_f5b178e0926c79db.cdf-ms"
    13: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\5b140faeae69d301572f00007c017813.$$_syswow64_windowspowershell_v1.0_modules_troubleshootingpack_en-us_62c19280c3582707.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_troubleshootingpack_en-us_62c19280c3582707.cdf-ms"
    14: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\1d001baeae69d301582f00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    15: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\77621daeae69d301592f0000
2017-11-30 08:41:49, Info                  CSI    7c017813.program_files_x86_windows_portable_devices_f72051b1beb5aba9.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_portable_devices_f72051b1beb5aba9.cdf-ms"
    16: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\77621daeae69d3015a2f00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    17: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1c41faeae69d3015b2f00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    18: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1c41faeae69d3015c2f00007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    19: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1c41faeae69d3015d2f00007c017813.$$_microsoft.net_framework_v2.0.50727_temporary_asp.net_files_9293298c41821e1f.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_temporary_asp.net_files_9293298c41821e1f.cdf-ms"
    20: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\93b02baeae69d3015e2f00007c017813.$$_inf_ugthrsvc_0415_8451c272df70bf9f.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugthrsvc_0415_8451c272df70bf9f.cdf-ms"
    21: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\93b02baeae69d3015f2f00007c017813.$$_inf_ugatherer_0415_046b5b89f9ca30b4.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_inf_ugatherer_0415_046b5b89f9ca30b4.cdf-ms"
    22: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\93b02baeae69d301602f00007c017813.$$_inf_wsearchidxpi_0415_2e6e3e8eaf9fcb60.cdf
2017-11-30 08:41:49, Info                  CSI    -ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_wsearchidxpi_0415_2e6e3e8eaf9fcb60.cdf-ms"
    23: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\559c37aeae69d301612f00007c017813.program_files_x86_windows_defender_2ba1d62d9bcc00c8.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_defender_2ba1d62d9bcc00c8.cdf-ms"
    24: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\33d651aeae69d301622f00007c017813.$$_syswow64_windowspowershell_v1.0_modules_bitstransfer_e2cfc222371abebb.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_bitstransfer_e2cfc222371abebb.cdf-ms"
    25: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d3854aeae69d301632f00007c017813.$$_syswow64_windowspowershell_v1.0_modules_bitstransfer_en-us_dfbf7fd96d09f789.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_windowspowershell_v1.0_modules_bitstransfer_en-us_dfbf7fd96d09f789.cdf-ms"
    26: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b726eaeae69d301642f00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    27: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b726eaeae69d301652f00007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    28: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\c5d470aeae69d301662f00007c017813.program_files_x86_common_files_microsoft_shared_textconv_29960047434e3e28.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_textconv_29960047434e3e28.cdf-ms"
    29: Move File: Source = [l:248{124}]"\
2017-11-30 08:41:49, Info                  CSI    SystemRoot\WinSxS\Temp\PendingRenames\c5d470aeae69d301672f00007c017813.program_files_x86_windows_nt_75867948982b5de9.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_75867948982b5de9.cdf-ms"
    30: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\1f3773aeae69d301682f00007c017813.program_files_x86_windows_nt_accessories_6b5e9ec4fa2598e7.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_accessories_6b5e9ec4fa2598e7.cdf-ms"
    31: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\87c07caeae69d301692f00007c017813.$$_syswow64_wbem_1bf25d11bb30b33f.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wbem_1bf25d11bb30b33f.cdf-ms"
    32: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\87c07caeae69d3016a2f00007c017813.$$_syswow64_wbem_xml_3f8ffc24c43a2ff4.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wbem_xml_3f8ffc24c43a2ff4.cdf-ms"
    33: Create Directory: Directory = [l:78{39}]"\??\C:\Windows\SysWOW64\wbem\Repository", Attributes = 00000080
    34: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\57d38faeae69d3016b2f00007c017813.$$_security_fe3ad40cd6e08c7c.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_security_fe3ad40cd6e08c7c.cdf-ms"
    35: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\b13592aeae69d3016c2f00007c017813.program_files_x86_windows_defender_pl-pl_7a6d341918a55ed5.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_defender_pl-pl_7a6d341918a55ed5.cdf-ms"
POQ 107 ends.
2017-11-30 08:41:49, Info                  CSI    00000256 [SR] Verify complete
2017-11-30 08:41:49, Info                  CSI    00000257 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:49, Info                  CSI    00000258 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:51, Info                  CSI    00000259 Repair results created:
POQ 108 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\397b5aafae69d301d12f00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\93dd5cafae69d301d22f00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\93dd5cafae69d301d32f00007c017813.$$_schcache_f995a5d4decb8cc0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_schcache_f995a5d4decb8cc0.cdf-ms"
POQ 108 ends.
2017-11-30 08:41:51, Info                  CSI    0000025a [SR] Verify complete
2017-11-30 08:41:51, Info                  CSI    0000025b [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:51, Info                  CSI    0000025c [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:52, Info                  CSI    0000025d Ignoring duplicate ownership for directory [l:46{23}]"\??\C:\Windows\Branding" in component Microsoft-Windows-Branding-Engine, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:52, Info                  CSI    0000025e Ignoring duplicate ownership for directory [l:64{32}]"\??\C:\Windows\Branding\ShellBrd" in component Microsoft-Windows-Branding-Engine, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:52, Info                  CSI    0000025f Repair results created:
POQ 109 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\5faff0afae69d301383000007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5faff0afae69d301393000007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\5faff0afae69d3013a3000007c017813.$$_branding_1728f5d8b15e5263.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_branding_1728f5d8b15e5263.cdf-ms"
    3: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\b911f3afae69d3013b3000007c017813.$$_branding_shellbrd_be1f632087fb0947.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_branding_shellbrd_be1f632087fb0947.cdf-ms"
POQ 109 ends.
2017-11-30 08:41:52, Info                  CSI    00000260 [SR] Verify complete
2017-11-30 08:41:52, Info                  CSI    00000261 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:52, Info                  CSI    00000262 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:53, Info                  CSI    00000263 Repair results created:
POQ 110 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f6bafb0ae69d301a03000007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f6bafb0ae69d301a13000007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d92b6b0ae69d301a23000007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d92b6b0ae69d301a33000007c017813.$$_syswow64_msdtc_trace_eb5cbdacfcb2a1a4.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_msdtc_trace_eb5cbdacfcb2a1a4.cdf-ms"
POQ 110 ends.
2017-11-30 08:41:53, Info                  CSI    00000264 [SR] Verify complete
2017-11-30 08:41:53, Info                  CSI    00000265 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:53, Info                  CSI    00000266 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:54, Info                  CSI    00000267 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sk-SK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sk-SK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    00000268 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\hr-HR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"hr-HR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    00000269 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\hu-HU" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"hu-HU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pl-PL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pt-PT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pt-PT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026c Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\SysWOW64\sr-Latn-CS" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20{10}]"sr-Latn-CS", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\es-ES" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"es-ES", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\bg-BG" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"bg-BG", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    0000026f Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\uk-UA" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"uk-UA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    00000270 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\cs-CZ" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"cs-CZ", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:54, Info                  CSI    00000271 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sv-SE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sv-SE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000272 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\zh-CN" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"zh-CN", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000273 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\zh-HK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"zh-HK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000274 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\zh-TW" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"zh-TW", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000275 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\he-IL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"he-IL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000276 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ar-SA" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ar-SA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000277 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\nb-NO" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"nb-NO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000278 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sl-SI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sl-SI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    00000279 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\en-US" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    0000027a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pt-BR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pt-BR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    0000027b Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\el-GR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"el-GR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    0000027c Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ko-KR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ko-KR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    0000027d Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\da-DK" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"da-DK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:55, Info                  CSI    0000027e Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ro-RO" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ro-RO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    0000027f Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ru-RU" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ru-RU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000280 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\de-DE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"de-DE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000281 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\lt-LT" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"lt-LT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000282 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\lv-LV" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"lv-LV", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000283 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\th-TH" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"th-TH", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000284 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\tr-TR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"tr-TR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000285 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\et-EE" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"et-EE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000286 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\fi-FI" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"fi-FI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000287 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\fr-FR" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"fr-FR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000288 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\nl-NL" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"nl-NL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    00000289 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ja-JP" in component Microsoft-Windows-comdlg32.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ja-JP", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:41:56, Info                  CSI    0000028a Repair results created:
POQ 111 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b339b1ae69d301083100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e3b339b1ae69d301093100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\f1da40b1ae69d3010a3100007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\f1da40b1ae69d3010b3100007c017813.$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\59644ab1ae69d3010c3100007c017813.$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c1ed53b1ae69d3010d3100007c017813.$$_syswow64_hu-hu_a40ad44e6f0c022b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hu-hu_a40ad44e6f0c022b.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\dd3b62b1ae69d3010e3100007c017813.$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\9f276eb1ae69d3010f3100007c017813.$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms"
    8: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRename
2017-11-30 08:41:56, Info                  CSI    s\ad4e75b1ae69d301103100007c017813.$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6f3a81b1ae69d301113100007c017813.$$_syswow64_es-es_9e5769fc7799216d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_es-es_9e5769fc7799216d.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d7c38ab1ae69d301123100007c017813.$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e5ea91b1ae69d301133100007c017813.$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a7d69db1ae69d301143100007c017813.$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0f60a7b1ae69d301153100007c017813.$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d14bb3b1ae69d301163100007c017813.$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms"
    15: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\39d5bcb1ae69d301173100007c017813.$$_syswow64_zh-hk_c63f2bfa3bbd7d4a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-hk_c63f2bfa3bbd7d4a.cdf-ms"
    16: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenam
2017-11-30 08:41:56, Info                  CSI    es\a15ec6b1ae69d301183100007c017813.$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms"
    17: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bdacd4b1ae69d301193100007c017813.$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms"
    18: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f98e0b1ae69d3011a3100007c017813.$$_syswow64_ar-sa_96bd698c83002208.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ar-sa_96bd698c83002208.cdf-ms"
    19: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e721eab1ae69d3011b3100007c017813.$$_syswow64_nb-no_af7199325df1d8da.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nb-no_af7199325df1d8da.cdf-ms"
    20: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a90df6b1ae69d3011c3100007c017813.$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms"
    21: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\1197ffb1ae69d3011d3100007c017813.$$_syswow64_en-us_9e576ab077991fe8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_9e576ab077991fe8.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d3820bb2ae69d3011e3100007c017813.$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\956e17b2ae69d3011f3100007c017813.$$_syswow64_el-gr_9e57691277992211.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_el-gr_9e57691277992211.cdf-ms"
    24: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\575a2
2017-11-30 08:41:56, Info                  CSI    3b2ae69d301203100007c017813.$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bfe32cb2ae69d301213100007c017813.$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\35943db2ae69d301223100007c017813.$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms"
    27: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\9d1d47b2ae69d301233100007c017813.$$_syswow64_ru-ru_b70b8052528b002f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ru-ru_b70b8052528b002f.cdf-ms"
    28: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\5f0953b2ae69d301243100007c017813.$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms"
    29: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6d305ab2ae69d301253100007c017813.$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d5b963b2ae69d301263100007c017813.$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3d436db2ae69d301273100007c017813.$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms"
    32: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a5cc76b2ae69d
2017-11-30 08:41:56, Info                  CSI    301283100007c017813.$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms"
    33: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0d5680b2ae69d301293100007c017813.$$_syswow64_et-ee_9e574f447799499c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_et-ee_9e574f447799499c.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\75df89b2ae69d3012a3100007c017813.$$_syswow64_it-it_a5f14a266c32514d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_it-it_a5f14a266c32514d.cdf-ms"
    35: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\dd6893b2ae69d3012b3100007c017813.$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\45f29cb2ae69d3012c3100007c017813.$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms"
    37: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\07dea8b2ae69d3012d3100007c017813.$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms"
    38: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6f67b2b2ae69d3012e3100007c017813.$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms"
POQ 111 ends.
2017-11-30 08:41:56, Info                  CSI    0000028b [SR] Verify complete
2017-11-30 08:41:56, Info                  CSI    0000028c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:56, Info                  CSI    0000028d [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:58, Info                  CSI    0000028e Repair results created:
POQ 112 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\9b1320b3ae69d301933100007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\9b1320b3ae69d301943100007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\a93a27b3ae69d301953100007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\039d29b3ae69d301963100007c017813.$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms"
    4: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\039d29b3ae69d301973100007c017813.$$_syswow64_ime_shared_res_9e6764b48871dbf2.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_shared_res_9e6764b48871dbf2.cdf-ms"
    5: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b2633b3ae69d301983100007c017813.programdata_microsoft_crypto_dss_machinekeys_43de8c451bf80cb4.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_dss_machinekeys_43de8c451bf80cb4.cdf-ms"
    6: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b2633b3ae69d301993100007c017813.programdata_microsoft_crypto_keys_584b284368b25bef.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_crypto_keys_584b284368b25bef.cdf-ms"
    7: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\6b2633b3ae69d3019a3100007c017813.programdata_microsoft_crypto_rsa_machinekeys_aa739417efae0d58.cdf-ms", Destination = [l:192{96}]"\SystemR
2017-11-30 08:41:58, Info                  CSI    oot\WinSxS\FileMaps\programdata_microsoft_crypto_rsa_machinekeys_aa739417efae0d58.cdf-ms"
    8: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\578754b3ae69d3019b3100007c017813.$$_syswow64_dism_1bf2381fbb30eb13.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_dism_1bf2381fbb30eb13.cdf-ms"
    9: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\578754b3ae69d3019c3100007c017813.$$_syswow64_dism_pl-pl_c466cd088f9702b6.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_dism_pl-pl_c466cd088f9702b6.cdf-ms"
POQ 112 ends.
2017-11-30 08:41:58, Info                  CSI    0000028f [SR] Verify complete
2017-11-30 08:41:58, Info                  CSI    00000290 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:58, Info                  CSI    00000291 [SR] Beginning Verify and Repair transaction
2017-11-30 08:41:59, Info                  CSI    00000292 Repair results created:
POQ 113 starts:
POQ 113 ends.
2017-11-30 08:41:59, Info                  CSI    00000293 [SR] Verify complete
2017-11-30 08:41:59, Info                  CSI    00000294 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:41:59, Info                  CSI    00000295 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:00, Info                  CSI    00000296 Repair results created:
POQ 114 starts:
POQ 114 ends.
2017-11-30 08:42:00, Info                  CSI    00000297 [SR] Verify complete
2017-11-30 08:42:00, Info                  CSI    00000298 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:00, Info                  CSI    00000299 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:01, Info                  CSI    0000029a Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    0000029b Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\DigitalLocker\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    0000029c Ignoring duplicate ownership for directory [l:48{24}]"\??\C:\Windows\ime\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    0000029d Ignoring duplicate ownership for directory [l:48{24}]"\??\C:\Windows\Inf\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    0000029e Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\Inf\RemoteAccess\0409" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    0000029f Ignoring duplicate ownership for directory [l:40{20}]"\??\C:\Windows\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a0 Ignoring duplicate ownership for directory [l:76{38}]"\??\C:\Windows\PolicyDefinitions\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a1 Ignoring duplicate ownership for directory [l:84{42}]"\??\C:\Windows\Resources\Themes\aero\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a2 Ignoring duplicate ownership for directory [l:120{60}]"\??\C:\Windows\Resources\Themes\aero\Shell\NormalColor\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a3 Ignoring duplicate ownership for directory [l:56{28}]"\??\C:\Windows\Help\mui\0409" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a4 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\apppatch\en-US" in component Microsoft-Windows-Foundation-Default-Security.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-US", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a5 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\setup" in component Microsoft-Windows-Foundation-Default-Security, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:01, Info                  CSI    000002a6 Repair results created:
POQ 115 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b3549b5ae69d301c93200007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\2b3549b5ae69d301ca3200007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\395c50b5ae69d301cb3200007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\93be52b5ae69d301cc3200007c017813.$$_syswow64_oobe_1bf24c07bb30ce37.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_oobe_1bf24c07bb30ce37.cdf-ms"
    4: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed2055b5ae69d301cd3200007c017813.$$_syswow64_oobe_en-us_a3f3dda00f3e081b.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_oobe_en-us_a3f3dda00f3e081b.cdf-ms"
    5: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed2055b5ae69d301ce3200007c017813.$$_syswow64_sysprep_en-us_19a17e70d0143aee.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sysprep_en-us_19a17e70d0143aee.cdf-ms"
    6: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed2055b5ae69d301cf3200007c017813.$$_syswow64_0409_1bf214d5bb311e89.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_0409_1bf214d5bb311e89.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\478357b5ae69d301d03200007c017813.$$_syswow64_setup_b8f1f0fc4fb15499.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_setup_b8f1f0fc4fb15499.cdf-ms"
    8: Move File: Source = [l:238{119}]"\SystemRoot\Win
2017-11-30 08:42:01, Info                  CSI    SxS\Temp\PendingRenames\478357b5ae69d301d13200007c017813.$$_syswow64_setup_en-us_a7cbb029f8fe98f1.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_setup_en-us_a7cbb029f8fe98f1.cdf-ms"
    9: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\478357b5ae69d301d23200007c017813.$$_syswow64_migration_bdcfa47e8790e0c4.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_bdcfa47e8790e0c4.cdf-ms"
    10: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\478357b5ae69d301d33200007c017813.$$_syswow64_migration_en-us_e9bc5790544ba26e.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migration_en-us_e9bc5790544ba26e.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1e559b5ae69d301d43200007c017813.$$_syswow64_en-us_9e576ab077991fe8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_9e576ab077991fe8.cdf-ms"
    12: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1e559b5ae69d301d53200007c017813.$$_syswow64_en-us_licenses_45a768f9c2f8cd4a.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_licenses_45a768f9c2f8cd4a.cdf-ms"
    13: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1e559b5ae69d301d63200007c017813.$$_syswow64_drivers_193c6528ad70a5e7.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_drivers_193c6528ad70a5e7.cdf-ms"
    14: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\fb475cb5ae69d301d73200007c017813.$$_syswow64_drivers_en-us_77da183c877b3223.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_drivers_en-us_77da183c877b3223.cdf-ms"
    15: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\fb475cb5ae69d301d83200007c017813.$$_syswow64_drivers_umdf_en-us_e54384c1dfe228b9.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_driver
2017-11-30 08:42:01, Info                  CSI    s_umdf_en-us_e54384c1dfe228b9.cdf-ms"
    16: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\fb475cb5ae69d301d93200007c017813.$$_syswow64_mui_dispspec_d1663c36ab010098.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_mui_dispspec_d1663c36ab010098.cdf-ms"
    17: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\fb475cb5ae69d301da3200007c017813.$$_syswow64_mui_0409_29ea5b12e6ab1a66.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_mui_0409_29ea5b12e6ab1a66.cdf-ms"
    18: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\55aa5eb5ae69d301db3200007c017813.$$_syswow64_wbem_1bf25d11bb30b33f.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wbem_1bf25d11bb30b33f.cdf-ms"
    19: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\55aa5eb5ae69d301dc3200007c017813.$$_syswow64_wbem_en-us_04f9ae10d0d40b09.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wbem_en-us_04f9ae10d0d40b09.cdf-ms"
    20: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\55aa5eb5ae69d301dd3200007c017813.$$_syswow64_com_1bf23555a7667cfb.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_com_1bf23555a7667cfb.cdf-ms"
    21: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301de3200007c017813.$$_syswow64_com_en-us_6b6f05e283a9f047.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_com_en-us_6b6f05e283a9f047.cdf-ms"
    22: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301df3200007c017813.$$_digitallocker_en-us_ff53d45933582902.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_digitallocker_en-us_ff53d45933582902.cdf-ms"
    23: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e03200007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoo
2017-11-30 08:42:01, Info                  CSI    t\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    24: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e13200007c017813.$$_ime_en-us_0d349188e45a5789.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_ime_en-us_0d349188e45a5789.cdf-ms"
    25: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e23200007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    26: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e33200007c017813.$$_inf_en-us_0ef70046e1d1b811.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_inf_en-us_0ef70046e1d1b811.cdf-ms"
    27: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e43200007c017813.$$_inf_remoteaccess_110554180baafc8b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_110554180baafc8b.cdf-ms"
    28: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\af0c61b5ae69d301e53200007c017813.$$_inf_remoteaccess_0409_86bc979ae65d5e96.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_inf_remoteaccess_0409_86bc979ae65d5e96.cdf-ms"
    29: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301e63200007c017813.$$_en-us_40104e69a1d105cc.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_en-us_40104e69a1d105cc.cdf-ms"
    30: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301e73200007c017813.$$_policydefinitions_89130cdfc4d9c27c.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_policydefinitions_89130cdfc4d9c27c.cdf-ms"
    31: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301e83200007c017813.$$_policydefinitions_en-us_3b1c5b998da0d4ae.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_policydefinitions_en-us_3
2017-11-30 08:42:01, Info                  CSI    b1c5b998da0d4ae.cdf-ms"
    32: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301e93200007c017813.$$_resources_fbee56ab048ab239.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_resources_fbee56ab048ab239.cdf-ms"
    33: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301ea3200007c017813.$$_resources_themes_4d0d4910e83c2273.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_4d0d4910e83c2273.cdf-ms"
    34: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\096f63b5ae69d301eb3200007c017813.$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_3fd78bf4cb5fa2c4.cdf-ms"
    35: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301ec3200007c017813.$$_resources_themes_aero_en-us_ab16867f204414fa.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_en-us_ab16867f204414fa.cdf-ms"
    36: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301ed3200007c017813.$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_a91dfa5124b343c4.cdf-ms"
    37: Move File: Source = [l:276{138}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301ee3200007c017813.$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms", Destination = [l:188{94}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_normalcolor_10be8ec981b35fb6.cdf-ms"
    38: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301ef3200007c017813.$$_resources_themes_aero_shell_normalcolor_en-us_8f1a9ecd4c3325e8.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_resources_themes_aero_shell_normalcolor_en-us_8f1a9ecd4c3325e8.cdf-ms"
    39: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\
2017-11-30 08:42:01, Info                  CSI    PendingRenames\63d165b5ae69d301f03200007c017813.$$_help_mui_0409_c7942094fabea651.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_help_mui_0409_c7942094fabea651.cdf-ms"
    40: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301f13200007c017813.$$_apppatch_1143992cbbbebcab.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_1143992cbbbebcab.cdf-ms"
    41: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301f23200007c017813.$$_apppatch_en-us_098dc872781aebb9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_apppatch_en-us_098dc872781aebb9.cdf-ms"
    42: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\63d165b5ae69d301f33200007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    43: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd3368b5ae69d301f43200007c017813.program_files_x86_internet_explorer_cafab575245eacb0.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_internet_explorer_cafab575245eacb0.cdf-ms"
    44: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd3368b5ae69d301f53200007c017813.program_files_x86_internet_explorer_en-us_1a6a9dd9f26fbb24.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_internet_explorer_en-us_1a6a9dd9f26fbb24.cdf-ms"
    45: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd3368b5ae69d301f63200007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    46: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\17966ab5ae69d301f73200007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSx
2017-11-30 08:42:01, Info                  CSI    S\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    47: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\17966ab5ae69d301f83200007c017813.program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms"
    48: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\17966ab5ae69d301f93200007c017813.program_files_x86_common_files_microsoft_shared_ink_en-us_f2244367f0317ebf.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_en-us_f2244367f0317ebf.cdf-ms"
    49: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\17966ab5ae69d301fa3200007c017813.program_files_x86_common_files_microsoft_shared_triedit_en-us_dc2a336d6f48a65e.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_triedit_en-us_dc2a336d6f48a65e.cdf-ms"
    50: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\71f86cb5ae69d301fb3200007c017813.program_files_x86_common_files_microsoft_shared_msinfo_4536eb45a5f97101.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_msinfo_4536eb45a5f97101.cdf-ms"
    51: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\71f86cb5ae69d301fc3200007c017813.program_files_x86_common_files_microsoft_shared_msinfo_en-us_b80acd2fe044c275.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_msinfo_en-us_b80acd2fe044c275.cdf-ms"
    52: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\71f86cb5ae69d301fd3200007c017813.program_files_x86_common_files_microsoft_shared_textconv_29960047434e3e28.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_micro
2017-11-30 08:42:01, Info                  CSI    soft_shared_textconv_29960047434e3e28.cdf-ms"
    53: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\cb5a6fb5ae69d301fe3200007c017813.program_files_x86_common_files_microsoft_shared_textconv_en-us_ccaa96de0e2684ec.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_textconv_en-us_ccaa96de0e2684ec.cdf-ms"
    54: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\cb5a6fb5ae69d301ff3200007c017813.program_files_x86_common_files_system_681b9383b994c86d.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_681b9383b994c86d.cdf-ms"
    55: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\25bd71b5ae69d301003300007c017813.program_files_x86_common_files_system_msadc_607f0693c9effa29.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_msadc_607f0693c9effa29.cdf-ms"
    56: Move File: Source = [l:290{145}]"\SystemRoot\WinSxS\Temp\PendingRenames\25bd71b5ae69d301013300007c017813.program_files_x86_common_files_system_msadc_en-us_93de3d05367723df.cdf-ms", Destination = [l:202{101}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_msadc_en-us_93de3d05367723df.cdf-ms"
    57: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\25bd71b5ae69d301023300007c017813.program_files_x86_common_files_system_ado_32a3d3ab7409acd3.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_ado_32a3d3ab7409acd3.cdf-ms"
    58: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f1f74b5ae69d301033300007c017813.program_files_x86_common_files_system_ado_en-us_9607f4bd7516dc6d.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_ado_en-us_9607f4bd7516dc6d.cdf-ms"
    59: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f1f74b5ae69d301043300007c017813.pr
2017-11-30 08:42:01, Info                  CSI    ogram_files_x86_common_files_system_en-us_514b68afe0bd6701.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_en-us_514b68afe0bd6701.cdf-ms"
    60: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\d98176b5ae69d301053300007c017813.program_files_x86_common_files_system_ole_db_17fcdbc86fee8f8b.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_ole_db_17fcdbc86fee8f8b.cdf-ms"
    61: Move File: Source = [l:292{146}]"\SystemRoot\WinSxS\Temp\PendingRenames\d98176b5ae69d301063300007c017813.program_files_x86_common_files_system_ole_db_en-us_f846875f746676bf.cdf-ms", Destination = [l:204{102}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_ole_db_en-us_f846875f746676bf.cdf-ms"
    62: Move File: Source = [l:248{124}]"\SystemRoot\WinSxS\Temp\PendingRenames\d98176b5ae69d301073300007c017813.program_files_x86_windows_nt_75867948982b5de9.cdf-ms", Destination = [l:160{80}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_75867948982b5de9.cdf-ms"
    63: Move File: Source = [l:282{141}]"\SystemRoot\WinSxS\Temp\PendingRenames\33e478b5ae69d301083300007c017813.program_files_x86_windows_nt_tabletextservice_7af8121010a6df81.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_tabletextservice_7af8121010a6df81.cdf-ms"
    64: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\33e478b5ae69d301093300007c017813.program_files_x86_windows_nt_tabletextservice_en-us_9db8d4aeeceb6765.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_tabletextservice_en-us_9db8d4aeeceb6765.cdf-ms"
    65: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\33e478b5ae69d3010a3300007c017813.program_files_x86_windows_nt_accessories_6b5e9ec4fa2598e7.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_accessories_6b5e9ec4fa2598e7.cdf-ms"
    66: Move
2017-11-30 08:42:01, Info                  CSI     File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\33e478b5ae69d3010b3300007c017813.program_files_x86_windows_nt_accessories_en-us_4984f8aeb9c597e1.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_nt_accessories_en-us_4984f8aeb9c597e1.cdf-ms"
    67: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\a99489b5ae69d3010c3300007c017813.program_files_x86_common_files_microsoft_shared_stationery_ea25573447e2dae5.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_stationery_ea25573447e2dae5.cdf-ms"
    68: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d3010d3300007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    69: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d3010e3300007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    70: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d3010f3300007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    71: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d301103300007c017813.$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_config_9a0d48f3c07d2a12.cdf-ms"
    72: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d301113300007c017813.$$_microsoft.net_framework_v1.0.3705_b19cf3207984c497.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v1.0.3705_b19cf3207984
2017-11-30 08:42:01, Info                  CSI    c497.cdf-ms"
    73: Move File: Source = [l:206{103}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d301123300007c017813.$$_temp_401038c9a18c18c0.cdf-ms", Destination = [l:118{59}]"\SystemRoot\WinSxS\FileMaps\$$_temp_401038c9a18c18c0.cdf-ms"
    74: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\03f78bb5ae69d301133300007c017813.$$_media_401039ffa1d92906.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_media_401039ffa1d92906.cdf-ms"
    75: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301143300007c017813.$$_media_delta_0f36d7d9b4f7293c.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_media_delta_0f36d7d9b4f7293c.cdf-ms"
    76: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301153300007c017813.$$_media_sonata_6b55eb3f91aab49e.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_sonata_6b55eb3f91aab49e.cdf-ms"
    77: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301163300007c017813.$$_media_afternoon_ae5d080a6a887942.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_afternoon_ae5d080a6a887942.cdf-ms"
    78: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301173300007c017813.$$_media_landscape_e9488ca8249a3acf.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_landscape_e9488ca8249a3acf.cdf-ms"
    79: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301183300007c017813.$$_media_quirky_6baa21a590d24b57.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_quirky_6baa21a590d24b57.cdf-ms"
    80: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d301193300007c017813.$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_media_savanna_6b39e54d8ae1e5ca.cdf-ms"
    81: Move File: Source = [l:222{111}]"\Sy
2017-11-30 08:42:01, Info                  CSI    stemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d3011a3300007c017813.$$_media_garden_6cea56938e5bd6b1.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_media_garden_6cea56938e5bd6b1.cdf-ms"
    82: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d3011b3300007c017813.$$_media_festival_d2aa354bee3f11cc.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_media_festival_d2aa354bee3f11cc.cdf-ms"
    83: Move File: Source = [l:218{109}]"\SystemRoot\WinSxS\Temp\PendingRenames\5d598eb5ae69d3011c3300007c017813.$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms", Destination = [l:130{65}]"\SystemRoot\WinSxS\FileMaps\$$_media_raga_d0fd3c9ac0f8ab1b.cdf-ms"
    84: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7bb90b5ae69d3011d3300007c017813.$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_media_calligraphy_7b7c7a996fa5cd3c.cdf-ms"
    85: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7bb90b5ae69d3011e3300007c017813.$$_media_characters_8ee06d90f7dead3a.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_media_characters_8ee06d90f7dead3a.cdf-ms"
    86: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7bb90b5ae69d3011f3300007c017813.$$_media_cityscape_b0cbff7c81824cc5.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_media_cityscape_b0cbff7c81824cc5.cdf-ms"
    87: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\c5e297b5ae69d301203300007c017813.$$_syswow64_migwiz_4d49015779604be3.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_4d49015779604be3.cdf-ms"
    88: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\1f459ab5ae69d301213300007c017813.$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_inetsrv_2344f73c9e0fb609.cdf-ms"
    89: Move File: Source = [l:232{116}]"\Syst
2017-11-30 08:42:01, Info                  CSI    emRoot\WinSxS\Temp\PendingRenames\1f459ab5ae69d301223300007c017813.$$_syswow64_wbem_tmf_3f8ffcb4c43a2eaa.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wbem_tmf_3f8ffcb4c43a2eaa.cdf-ms"
    90: Move File: Source = [l:216{108}]"\SystemRoot\WinSxS\Temp\PendingRenames\79a79cb5ae69d301233300007c017813.$$_l2schemas_d7bb5637381de58c.cdf-ms", Destination = [l:128{64}]"\SystemRoot\WinSxS\FileMaps\$$_l2schemas_d7bb5637381de58c.cdf-ms"
    91: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\87cea3b5ae69d301243300007c017813.$$_system32_21f9a9c4a2f8b514.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_system32_21f9a9c4a2f8b514.cdf-ms"
    92: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b93a8b5ae69d301253300007c017813.$$_system32_drivers_dc1b782427b5ee1b.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_dc1b782427b5ee1b.cdf-ms"
    93: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b93a8b5ae69d301263300007c017813.$$_system32_drivers_etc_a531967eb3dfecbd.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_system32_drivers_etc_a531967eb3dfecbd.cdf-ms"
    94: Move File: Source = [l:210{105}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b93a8b5ae69d301273300007c017813.$$_system_4c3aa2308f9f8f41.cdf-ms", Destination = [l:122{61}]"\SystemRoot\WinSxS\FileMaps\$$_system_4c3aa2308f9f8f41.cdf-ms"
    95: Move File: Source = [l:208{104}]"\SystemRoot\WinSxS\Temp\PendingRenames\95f5aab5ae69d301283300007c017813.$$_fonts_40104ba9a1d20dac.cdf-ms", Destination = [l:120{60}]"\SystemRoot\WinSxS\FileMaps\$$_fonts_40104ba9a1d20dac.cdf-ms"
    96: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\95f5aab5ae69d301293300007c017813.$$_web_3f580d25a4c8e0a0.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_web_3f580d25a4c8e0a0.cdf-ms"
    97: Move File: Source = [l:220{110}]"\SystemRoot\WinSxS\Temp\PendingRenames\732fc5b5ae69d3012a3300007c0178
2017-11-30 08:42:01, Info                  CSI    13.$$_syswow64_en_b03edc160c0d9a6b.cdf-ms", Destination = [l:132{66}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en_b03edc160c0d9a6b.cdf-ms"
POQ 115 ends.
2017-11-30 08:42:01, Info                  CSI    000002a7 [SR] Verify complete
2017-11-30 08:42:02, Info                  CSI    000002a8 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:02, Info                  CSI    000002a9 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:03, Info                  CSI    000002aa Repair results created:
POQ 116 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\8b3c54b6ae69d3018f3300007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\8b3c54b6ae69d301903300007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    2: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\8b3c54b6ae69d301913300007c017813.program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms"
    3: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\8b3c54b6ae69d301923300007c017813.program_files_x86_windows_sidebar_gadgets_6f6d1ec3860a4a26.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_6f6d1ec3860a4a26.cdf-ms"
    4: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\e59e56b6ae69d301933300007c017813.program_files_x86_windows_sidebar_gadgets_currency.gadget_1cd5d9038ef05167.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_currency.gadget_1cd5d9038ef05167.cdf-ms"
    5: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\e59e56b6ae69d301943300007c017813.program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_c723f13a1a00f130.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_c723f13a1a00f130.cdf-ms"
    6: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\e59e56b6ae69d301953300007c017813.program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_js_86c992537c7f37ab.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\
2017-11-30 08:42:03, Info                  CSI    FileMaps\program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_js_86c992537c7f37ab.cdf-ms"
    7: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\3f0159b6ae69d301963300007c017813.program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_css_f4d75dc5576a8989.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_currency.gadget_pl-pl_css_f4d75dc5576a8989.cdf-ms"
    8: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c55db6ae69d301973300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_f6c3bdb01a9a0acc.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_f6c3bdb01a9a0acc.cdf-ms"
    9: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\f3c55db6ae69d301983300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_8c6ecdd55e2fedc5.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_8c6ecdd55e2fedc5.cdf-ms"
    10: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d2860b6ae69d301993300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_js_6479632d4e028c58.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_js_6479632d4e028c58.cdf-ms"
    11: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\4d2860b6ae69d3019a3300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_css_5e738cde1b8fae6a.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_pl-pl_css_5e738cde1b8fae6a.cdf-ms"
    12: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\5b4f67b6ae69d3019b3300007c017813.program_files_x86_windows_sidebar_gadgets_clock.gadget_0df8776137925b40.cdf-ms
2017-11-30 08:42:03, Info                  CSI    ", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_clock.gadget_0df8776137925b40.cdf-ms"
    13: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\b5b169b6ae69d3019c3300007c017813.program_files_x86_windows_sidebar_gadgets_clock.gadget_images_da3cc1aebdbac718.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_clock.gadget_images_da3cc1aebdbac718.cdf-ms"
    14: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\c3d870b6ae69d3019d3300007c017813.program_files_x86_windows_sidebar_gadgets_currency.gadget_images_74447baf8a7dbb4d.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_currency.gadget_images_74447baf8a7dbb4d.cdf-ms"
    15: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\779d75b6ae69d3019e3300007c017813.program_files_x86_windows_sidebar_gadgets_cpu.gadget_1c7d3bb26daa1db0.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_cpu.gadget_1c7d3bb26daa1db0.cdf-ms"
    16: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\779d75b6ae69d3019f3300007c017813.program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_daf33e3bebd59b2b.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_daf33e3bebd59b2b.cdf-ms"
    17: Move File: Source = [l:314{157}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1ff77b6ae69d301a03300007c017813.program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_js_224f7eab8579c3f2.cdf-ms", Destination = [l:226{113}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_js_224f7eab8579c3f2.cdf-ms"
    18: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\d1ff77b6ae69d301a13300007c017813.program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_css_224f7fa7a4bb3c34.cdf-ms", Desti
2017-11-30 08:42:03, Info                  CSI    nation = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_cpu.gadget_pl-pl_css_224f7fa7a4bb3c34.cdf-ms"
    19: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\85c47cb6ae69d301a23300007c017813.program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_1b6a4e86a8ece5e1.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_1b6a4e86a8ece5e1.cdf-ms"
    20: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\df267fb6ae69d301a33300007c017813.program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_images_f897ad76a855c747.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_images_f897ad76a855c747.cdf-ms"
    21: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed4d86b6ae69d301a43300007c017813.program_files_x86_windows_sidebar_gadgets_calendar.gadget_e2d99ec9c7064586.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_calendar.gadget_e2d99ec9c7064586.cdf-ms"
    22: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed4d86b6ae69d301a53300007c017813.program_files_x86_windows_sidebar_gadgets_calendar.gadget_images_f4eb1c4563791634.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_calendar.gadget_images_f4eb1c4563791634.cdf-ms"
    23: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\55d78fb6ae69d301a63300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_b9f7736a93805f34.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_b9f7736a93805f34.cdf-ms"
    24: Move File: Source = [l:344{172}]"\SystemRoot\WinSxS\Temp\PendingRenames\55d78fb6ae69d301a73300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_in_sid
2017-11-30 08:42:03, Info                  CSI    ebar_4334f241cb9c661c.cdf-ms", Destination = [l:256{128}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_in_sidebar_4334f241cb9c661c.cdf-ms"
    25: Move File: Source = [l:344{172}]"\SystemRoot\WinSxS\Temp\PendingRenames\55d78fb6ae69d301a83300007c017813.program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_on_desktop_d567433971d74c4e.cdf-ms", Destination = [l:256{128}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_slideshow.gadget_images_on_desktop_d567433971d74c4e.cdf-ms"
    26: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd6099b6ae69d301a93300007c017813.program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_fa751af0c317f3f6.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_fa751af0c317f3f6.cdf-ms"
    27: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\bd6099b6ae69d301aa3300007c017813.program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_images_41ce2f5e65a6df74.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_images_41ce2f5e65a6df74.cdf-ms"
    28: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\71259eb6ae69d301ab3300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_62d937b3ecc7018a.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_62d937b3ecc7018a.cdf-ms"
    29: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\71259eb6ae69d301ac3300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_d1b32e97577e5d35.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_d1b32e97577e5d35.cdf-ms"
    30: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\cb87a0b6ae69d301ad3
2017-11-30 08:42:03, Info                  CSI    300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_js_ca9b53f03782fa30.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_js_ca9b53f03782fa30.cdf-ms"
    31: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\cb87a0b6ae69d301ae3300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_css_ca9b54ebe54cfcaa.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_pl-pl_css_ca9b54ebe54cfcaa.cdf-ms"
    32: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\25eaa2b6ae69d301af3300007c017813.program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_e2ac0f728f8914a3.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_e2ac0f728f8914a3.cdf-ms"
    33: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f4ca5b6ae69d301b03300007c017813.program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_js_6e0b7b3f963174ea.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_js_6e0b7b3f963174ea.cdf-ms"
    34: Move File: Source = [l:336{168}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f4ca5b6ae69d301b13300007c017813.program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_css_d83076ca675e3f0c.cdf-ms", Destination = [l:248{124}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_picturepuzzle.gadget_pl-pl_css_d83076ca675e3f0c.cdf-ms"
    35: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\8d73acb6ae69d301b23300007c017813.program_files_x86_windows_sidebar_gadgets_cpu.gadget_images_2d52a8dbf03f7b70.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_cpu.gadget_images_2d52a8dbf03f7b70.cdf-ms"
    36: Move
2017-11-30 08:42:03, Info                  CSI    File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\4138b1b6ae69d301b33300007c017813.program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_dcf43664235e9943.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_dcf43664235e9943.cdf-ms"
    37: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\9b9ab3b6ae69d301b43300007c017813.program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_js_d6d9def9ed180b56.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_js_d6d9def9ed180b56.cdf-ms"
    38: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\9b9ab3b6ae69d301b53300007c017813.program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_css_968df5c94d89e636.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_calendar.gadget_pl-pl_css_968df5c94d89e636.cdf-ms"
    39: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7e8c1b6ae69d301b63300007c017813.program_files_x86_windows_sidebar_gadgets_clock.gadget_pl-pl_30ade35f368654e5.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_clock.gadget_pl-pl_30ade35f368654e5.cdf-ms"
    40: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7e8c1b6ae69d301b73300007c017813.program_files_x86_windows_sidebar_gadgets_clock.gadget_pl-pl_js_84b6a4b70cfdf83e.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_clock.gadget_pl-pl_js_84b6a4b70cfdf83e.cdf-ms"
    41: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\b7e8c1b6ae69d301b83300007c017813.program_files_x86_windows_sidebar_gadgets_clock.gadget_pl-pl_css_dfd7efbcbff30f4a.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_clock.gadget
2017-11-30 08:42:03, Info                  CSI    _pl-pl_css_dfd7efbcbff30f4a.cdf-ms"
    42: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\87fbd4b6ae69d301b93300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_images_62a92568fe066a06.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_images_62a92568fe066a06.cdf-ms"
    43: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\PendingRenames\87fbd4b6ae69d301ba3300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_images_144dpi_a22054ba22c1ed6e.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_images_144dpi_a22054ba22c1ed6e.cdf-ms"
    44: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\PendingRenames\e15dd7b6ae69d301bb3300007c017813.program_files_x86_windows_sidebar_gadgets_weather.gadget_images_120dpi_a2204d2222bff854.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_weather.gadget_images_120dpi_a2204d2222bff854.cdf-ms"
    45: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\3bc0d9b6ae69d301bc3300007c017813.program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_14ee75d8328c8258.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_14ee75d8328c8258.cdf-ms"
    46: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\3bc0d9b6ae69d301bd3300007c017813.program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_js_da67e51b1a23beb1.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_js_da67e51b1a23beb1.cdf-ms"
    47: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\9522dcb6ae69d301be3300007c017813.program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_css_9f38394af2eb4261.cdf-ms", Destination = [l:238{119}]"\Sy
2017-11-30 08:42:03, Info                  CSI    stemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_gadgets_rssfeeds.gadget_pl-pl_css_9f38394af2eb4261.cdf-ms"
POQ 116 ends.
2017-11-30 08:42:03, Info                  CSI    000002ab [SR] Verify complete
2017-11-30 08:42:03, Info                  CSI    000002ac [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:03, Info                  CSI    000002ad [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:04, Info                  CSI    000002ae Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\da-DK" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"da-DK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:04, Info                  CSI    000002af Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\et-EE" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"et-EE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:04, Info                  CSI    000002b0 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sk-SK" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sk-SK", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:04, Info                  CSI    000002b1 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\hu-HU" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"hu-HU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b2 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\es-ES" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"es-ES", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b3 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ro-RO" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ro-RO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b4 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sv-SE" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sv-SE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b5 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\lv-LV" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"lv-LV", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b6 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\th-TH" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"th-TH", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:05, Info                  CSI    000002b7 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\it-IT" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"it-IT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:06, Info                  CSI    000002b8 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pt-BR" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pt-BR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:06, Info                  CSI    000002b9 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ar-SA" in component Microsoft-Windows-Installer-Engine.Resources, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ar-SA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:06, Info                  CSI    000002ba Repair results created:
POQ 117 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\4b1e39b7ae69d301233400007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\4b1e39b7ae69d301243400007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\594540b7ae69d301253400007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b3a742b7ae69d301263400007c017813.$$_syswow64_el-gr_9e57691277992211.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_el-gr_9e57691277992211.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\1b314cb7ae69d301273400007c017813.$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\45a661b7ae69d301283400007c017813.$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\07926db7ae69d301293400007c017813.$$_syswow64_et-ee_9e574f447799499c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_et-ee_9e574f447799499c.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c97d79b7ae69d3012a3400007c017813.$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms"
2017-11-30 08:42:06, Info                  CSI    s\d7a480b7ae69d3012b3400007c017813.$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3f2e8ab7ae69d3012c3400007c017813.$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a7b793b7ae69d3012d3400007c017813.$$_syswow64_hu-hu_a40ad44e6f0c022b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hu-hu_a40ad44e6f0c022b.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\69a39fb7ae69d3012e3400007c017813.$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d12ca9b7ae69d3012f3400007c017813.$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\39b6b2b7ae69d301303400007c017813.$$_syswow64_es-es_9e5769fc7799216d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_es-es_9e5769fc7799216d.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a13fbcb7ae69d301313400007c017813.$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms"
    15: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\09c9c5b7ae69d301323400007c017813.$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms"
    16: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7152cfb
2017-11-30 08:42:06, Info                  CSI    7ae69d301333400007c017813.$$_syswow64_ru-ru_b70b8052528b002f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ru-ru_b70b8052528b002f.cdf-ms"
    17: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9dbd8b7ae69d301343400007c017813.$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms"
    18: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4165e2b7ae69d301353400007c017813.$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms"
    19: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a9eeebb7ae69d301363400007c017813.$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms"
    20: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\1178f5b7ae69d301373400007c017813.$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms"
    21: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7901ffb7ae69d301383400007c017813.$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\872806b8ae69d301393400007c017813.$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\efb10fb8ae69d3013a3400007c017813.$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms"
    24: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\573b19b8ae69d30
2017-11-30 08:42:06, Info                  CSI    13b3400007c017813.$$_syswow64_it-it_a5f14a266c32514d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_it-it_a5f14a266c32514d.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bfc422b8ae69d3013c3400007c017813.$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\274e2cb8ae69d3013d3400007c017813.$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms"
    27: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\8fd735b8ae69d3013e3400007c017813.$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms"
    28: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\f7603fb8ae69d3013f3400007c017813.$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms"
    29: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\b94c4bb8ae69d301403400007c017813.$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\21d654b8ae69d301413400007c017813.$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\895f5eb8ae69d301423400007c017813.$$_syswow64_nb-no_af7199325df1d8da.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nb-no_af7199325df1d8da.cdf-ms"
    32: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\f1e867b8ae69d
2017-11-30 08:42:06, Info                  CSI    301433400007c017813.$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms"
    33: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c1fb7ab8ae69d301443400007c017813.$$_syswow64_en-us_9e576ab077991fe8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_9e576ab077991fe8.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\298584b8ae69d301453400007c017813.$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms"
    35: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\910e8eb8ae69d301463400007c017813.$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\53fa99b8ae69d301473400007c017813.$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms"
    37: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6121a1b8ae69d301483400007c017813.$$_syswow64_ar-sa_96bd698c83002208.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ar-sa_96bd698c83002208.cdf-ms"
POQ 117 ends.
2017-11-30 08:42:06, Info                  CSI    000002bb [SR] Verify complete
2017-11-30 08:42:06, Info                  CSI    000002bc [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:06, Info                  CSI    000002bd [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:07, Info                  CSI    000002be Repair results created:
POQ 118 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9080ab9ae69d301ad3400007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\d9080ab9ae69d301ae3400007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\e72f11b9ae69d301af3400007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\419213b9ae69d301b03400007c017813.$$_syswow64_ime_imetc10_a6d5873b8f8ff9ba.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imetc10_a6d5873b8f8ff9ba.cdf-ms"
    4: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\419213b9ae69d301b13400007c017813.$$_syswow64_ime_imetc10_applets_892de9ea0e55232f.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imetc10_applets_892de9ea0e55232f.cdf-ms"
POQ 118 ends.
2017-11-30 08:42:07, Info                  CSI    000002bf [SR] Verify complete
2017-11-30 08:42:07, Info                  CSI    000002c0 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:07, Info                  CSI    000002c1 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:08, Info                  CSI    000002c2 Repair results created:
POQ 119 starts:
POQ 119 ends.
2017-11-30 08:42:08, Info                  CSI    000002c3 [SR] Verify complete
2017-11-30 08:42:08, Info                  CSI    000002c4 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:08, Info                  CSI    000002c5 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:10, Info                  CSI    000002c6 Repair results created:
POQ 120 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\2d2066baae69d3017a3500007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\2d2066baae69d3017b3500007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b476dbaae69d3017c3500007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\3b476dbaae69d3017d3500007c017813.$$_syswow64_ime_imekr8_064a78c062020e1f.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imekr8_064a78c062020e1f.cdf-ms"
    4: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\95a96fbaae69d3017e3500007c017813.$$_syswow64_ime_imekr8_applets_77d75ed4a7708602.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_imekr8_applets_77d75ed4a7708602.cdf-ms"
    5: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\95a96fbaae69d3017f3500007c017813.$$_ime_3f581be9a4c8cabd.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_ime_3f581be9a4c8cabd.cdf-ms"
    6: Move File: Source = [l:230{115}]"\SystemRoot\WinSxS\Temp\PendingRenames\95a96fbaae69d301803500007c017813.$$_ime_imekr8_dicts_2ff7cb9394decb12.cdf-ms", Destination = [l:142{71}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imekr8_dicts_2ff7cb9394decb12.cdf-ms"
    7: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\95a96fbaae69d301813500007c017813.$$_ime_imekr8_help_6edfa6f9f9cba42e.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_ime_imekr8_help_6edfa6f9f9cba42e.cdf-ms"
2017-11-30 08:42:10, Info                  CSI    S\Temp\PendingRenames\db6c93baae69d301823500007c017813.$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ime_shared_19ff36aa43ebd16a.cdf-ms"
POQ 120 ends.
2017-11-30 08:42:10, Info                  CSI    000002c7 [SR] Verify complete
2017-11-30 08:42:10, Info                  CSI    000002c8 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:10, Info                  CSI    000002c9 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:10, Info                  CSI    000002ca Repair results created:
POQ 121 starts:
POQ 121 ends.
2017-11-30 08:42:10, Info                  CSI    000002cb [SR] Verify complete
2017-11-30 08:42:10, Info                  CSI    000002cc [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:10, Info                  CSI    000002cd [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:12, Info                  CSI    000002ce Repair results created:
POQ 122 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\95d6a0bbae69d3014b3600007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\95d6a0bbae69d3014c3600007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\a3fda7bbae69d3014d3600007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\a3fda7bbae69d3014e3600007c017813.$$_syswow64_migwiz_4d49015779604be3.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_4d49015779604be3.cdf-ms"
    4: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\fd5faabbae69d3014f3600007c017813.$$_syswow64_migwiz_dlmanifests_1dc151a98a2c5601.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_1dc151a98a2c5601.cdf-ms"
    5: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\fd5faabbae69d301503600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-ie-esc_d78e1437053b497c.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-ie-esc_d78e1437053b497c.cdf-ms"
    6: Move File: Source = [l:358{179}]"\SystemRoot\WinSxS\Temp\PendingRenames\57c2acbbae69d301513600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-textservicesframework-migration-dl_c487ba76d2956e8b.cdf-ms", Destination = [l:270{135}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-textservicesframework-migration-dl_c487ba76d2956e8b.cdf-ms"
    7: Move File: Source = [l:312{156}]"\SystemRoot\WinSxS\Temp\PendingRenames\57c2acbbae69d3
2017-11-30 08:42:12, Info                  CSI    01523600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-mediaplayer_e40b5427ab555e23.cdf-ms", Destination = [l:224{112}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-mediaplayer_e40b5427ab555e23.cdf-ms"
    8: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\b124afbbae69d301533600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-storagemigration_c4a61e07bc0c7f7b.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-storagemigration_c4a61e07bc0c7f7b.cdf-ms"
    9: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\b124afbbae69d301543600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-com-complus-setup-dl_9da603da79e3577a.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-com-complus-setup-dl_9da603da79e3577a.cdf-ms"
    10: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\b124afbbae69d301553600007c017813.$$_syswow64_migwiz_dlmanifests_networking-mpssvc-svc_3faa0247c04fc08d.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_networking-mpssvc-svc_3faa0247c04fc08d.cdf-ms"
    11: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\0b87b1bbae69d301563600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-mediaplayer-drm-dl_64976391fec1189c.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-mediaplayer-drm-dl_64976391fec1189c.cdf-ms"
    12: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\0b87b1bbae69d301573600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-ndis_68f6e3ec4f7467d4.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-ndis_68f6e3ec4f7467d4.cdf-ms"
    13: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\
2017-11-30 08:42:12, Info                  CSI    65e9b3bbae69d301583600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-unimodem-config_393d836711862ad7.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-unimodem-config_393d836711862ad7.cdf-ms"
    14: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\65e9b3bbae69d301593600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-shmig-dl_a565dd85136f27b7.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-shmig-dl_a565dd85136f27b7.cdf-ms"
    15: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4bb6bbae69d3015a3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-tapisetup_aa1f5c3888f0602d.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-tapisetup_aa1f5c3888f0602d.cdf-ms"
    16: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4bb6bbae69d3015b3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-networkloadbalancing-core_5181f9273cd7bfa7.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-networkloadbalancing-core_5181f9273cd7bfa7.cdf-ms"
    17: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\bf4bb6bbae69d3015c3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-dhcpservermigplugin-dl_53b7ecb10f1f006d.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-dhcpservermigplugin-dl_53b7ecb10f1f006d.cdf-ms"
    18: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\19aeb8bbae69d3015d3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-directoryservices-adam-dl_f3fca213969e9fd8.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-directoryservices-adam-dl_f3fca213969e9fd8.cdf-ms"
2017-11-30 08:42:12, Info                  CSI        19: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\19aeb8bbae69d3015e3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-offlinefiles-dl_064948b9afba516d.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-offlinefiles-dl_064948b9afba516d.cdf-ms"
    20: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\19aeb8bbae69d3015f3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasapi_d641bb6308391020.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasapi_d641bb6308391020.cdf-ms"
    21: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\7310bbbbae69d301603600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-iis-dl_d795eacd0517800e.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-iis-dl_d795eacd0517800e.cdf-ms"
    22: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\7310bbbbae69d301613600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasserver-migplugin_af29bc1924cdbcf6.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasserver-migplugin_af29bc1924cdbcf6.cdf-ms"
    23: Move File: Source = [l:306{153}]"\SystemRoot\WinSxS\Temp\PendingRenames\cd72bdbbae69d301623600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-wmi-core_6faa9b3d64521c2f.cdf-ms", Destination = [l:218{109}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-wmi-core_6faa9b3d64521c2f.cdf-ms"
    24: Move File: Source = [l:360{180}]"\SystemRoot\WinSxS\Temp\PendingRenames\cd72bdbbae69d301633600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-performancecounterinfrastructure-dl_f86845c089f82d98.cdf-ms", Destination = [l:272{136}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-performancec
2017-11-30 08:42:12, Info                  CSI    ounterinfrastructure-dl_f86845c089f82d98.cdf-ms"
    25: Move File: Source = [l:304{152}]"\SystemRoot\WinSxS\Temp\PendingRenames\cd72bdbbae69d301643600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-adfs-dl_d8ac7a8744afc871.cdf-ms", Destination = [l:216{108}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-adfs-dl_d8ac7a8744afc871.cdf-ms"
    26: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\27d5bfbbae69d301653600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-com-dtc-setup-dl_930302691b5a1034.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-com-dtc-setup-dl_930302691b5a1034.cdf-ms"
    27: Move File: Source = [l:340{170}]"\SystemRoot\WinSxS\Temp\PendingRenames\27d5bfbbae69d301663600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-msmq-messagingcoreservice_2a96fc723348dfdd.cdf-ms", Destination = [l:252{126}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-msmq-messagingcoreservice_2a96fc723348dfdd.cdf-ms"
    28: Move File: Source = [l:322{161}]"\SystemRoot\WinSxS\Temp\PendingRenames\8137c2bbae69d301673600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-bluetooth-config_30245f88e9dfc051.cdf-ms", Destination = [l:234{117}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-bluetooth-config_30245f88e9dfc051.cdf-ms"
    29: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\8137c2bbae69d301683600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-iasserver-migplugin_a651f93db8b3331d.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-iasserver-migplugin_a651f93db8b3331d.cdf-ms"
    30: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\8137c2bbae69d301693600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-sxs_7eb4a7ed2ed7c2a4.cdf-ms", Destination = [l:208{104}]"\SystemRoot\W
2017-11-30 08:42:12, Info                  CSI    inSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-sxs_7eb4a7ed2ed7c2a4.cdf-ms"
    31: Move File: Source = [l:330{165}]"\SystemRoot\WinSxS\Temp\PendingRenames\db99c4bbae69d3016a3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasconnectionmanager_a45937fa73c6f605.cdf-ms", Destination = [l:242{121}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-rasconnectionmanager_a45937fa73c6f605.cdf-ms"
    32: Move File: Source = [l:296{148}]"\SystemRoot\WinSxS\Temp\PendingRenames\db99c4bbae69d3016b3600007c017813.$$_syswow64_migwiz_dlmanifests_bitsextensions-server_dac37e08748fde2b.cdf-ms", Destination = [l:208{104}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_bitsextensions-server_dac37e08748fde2b.cdf-ms"
    33: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\PendingRenames\35fcc6bbae69d3016c3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-international-core-dl_a80c5905e820586b.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-international-core-dl_a80c5905e820586b.cdf-ms"
    34: Move File: Source = [l:334{167}]"\SystemRoot\WinSxS\Temp\PendingRenames\35fcc6bbae69d3016d3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-activedirectory-webservices-dl_01510d03ddc6bd7b.cdf-ms", Destination = [l:246{123}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-activedirectory-webservices-dl_01510d03ddc6bd7b.cdf-ms"
    35: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\35fcc6bbae69d3016e3600007c017813.$$_syswow64_migwiz_dlmanifests_microsoft-windows-networkbridge_baeb3381a4b45b11.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_dlmanifests_microsoft-windows-networkbridge_baeb3381a4b45b11.cdf-ms"
    36: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\1336e1bbae69d3016f3600007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\
2017-11-30 08:42:12, Info                  CSI    WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    37: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\1336e1bbae69d301703600007c017813.program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms"
    38: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\6d98e3bbae69d301713600007c017813.program_files_x86_windows_mail_pl-pl_26af41d3f2ff4fad.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_mail_pl-pl_26af41d3f2ff4fad.cdf-ms"
POQ 122 ends.
2017-11-30 08:42:12, Info                  CSI    000002cf [SR] Verify complete
2017-11-30 08:42:12, Info                  CSI    000002d0 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:12, Info                  CSI    000002d1 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:13, Info                  CSI    000002d2 Repair results created:
POQ 123 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\777e6bbcae69d301d63600007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\777e6bbcae69d301d73600007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\85a572bcae69d301d83600007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\df0775bcae69d301d93600007c017813.$$_syswow64_migwiz_4d49015779604be3.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_4d49015779604be3.cdf-ms"
    4: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\df0775bcae69d301da3600007c017813.$$_syswow64_migwiz_replacementmanifests_8ea121cb8324df53.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_8ea121cb8324df53.cdf-ms"
    5: Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\396a77bcae69d301db3600007c017813.$$_syswow64_migwiz_replacementmanifests_usb_3b9ff27325651bad.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_usb_3b9ff27325651bad.cdf-ms"
    6: Move File: Source = [l:316{158}]"\SystemRoot\WinSxS\Temp\PendingRenames\396a77bcae69d301dc3600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-ndis_fff4cf79489898fa.cdf-ms", Destination = [l:228{114}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-ndis_fff4cf79489898fa.cdf-ms"
    7: Move File: Source = [l:310{155}]"\SystemRoot\WinSxS\Temp\PendingRenames\396a77bcae69d301dd3600007c017813.$$_syswow64_migwiz_replacement
2017-11-30 08:42:13, Info                  CSI    manifests_windowssearchengine_940baeaeeced0416.cdf-ms", Destination = [l:222{111}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_windowssearchengine_940baeaeeced0416.cdf-ms"
    8: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\93cc79bcae69d301de3600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-iis-rm_b821407fbddeb90f.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-iis-rm_b821407fbddeb90f.cdf-ms"
    9: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\93cc79bcae69d301df3600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-shmig_b83536028b76e58c.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-shmig_b83536028b76e58c.cdf-ms"
    10: Move File: Source = [l:328{164}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed2e7cbcae69d301e03600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-international-core_150cced7d7db072c.cdf-ms", Destination = [l:240{120}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-international-core_150cced7d7db072c.cdf-ms"
    11: Move File: Source = [l:342{171}]"\SystemRoot\WinSxS\Temp\PendingRenames\ed2e7cbcae69d301e13600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-offlinefiles-core_ce2373fddb5b4344.cdf-ms", Destination = [l:254{127}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-offlinefiles-core_ce2373fddb5b4344.cdf-ms"
    12: Move File: Source = [l:368{184}]"\SystemRoot\WinSxS\Temp\PendingRenames\47917ebcae69d301e23600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-terminalservices-licenseserver_12784e8d99d63995.cdf-ms", Destination = [l:280{140}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-terminalservices-licenseserver_12784e8d99d63995.cdf-ms"
2017-11-30 08:42:13, Info                  CSI     [l:380{190}]"\SystemRoot\WinSxS\Temp\PendingRenames\47917ebcae69d301e33600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-terminalservices-appserver-licensing_2d620688732de522.cdf-ms", Destination = [l:292{146}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-terminalservices-appserver-licensing_2d620688732de522.cdf-ms"
    14: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\47917ebcae69d301e43600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-windows-audio-mmecore-other_99cf148948823084.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-windows-audio-mmecore-other_99cf148948823084.cdf-ms"
    15: Move File: Source = [l:346{173}]"\SystemRoot\WinSxS\Temp\PendingRenames\a1f380bcae69d301e53600007c017813.$$_syswow64_migwiz_replacementmanifests_microsoft-activedirectory-webservices_4493d5d4ce0f5a62.cdf-ms", Destination = [l:258{129}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_replacementmanifests_microsoft-activedirectory-webservices_4493d5d4ce0f5a62.cdf-ms"
    16: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\7f2d9bbcae69d301e63600007c017813.$$_syswow64_migwiz_pl-pl_ab55e36cc995b2c8.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_migwiz_pl-pl_ab55e36cc995b2c8.cdf-ms"
POQ 123 ends.
2017-11-30 08:42:13, Info                  CSI    000002d3 [SR] Verify complete
2017-11-30 08:42:13, Info                  CSI    000002d4 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:13, Info                  CSI    000002d5 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:14, Info                  CSI    000002d6 Repair results created:
POQ 124 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\f94b5cbdae69d3014b3700007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\f94b5cbdae69d3014c3700007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    2: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\f94b5cbdae69d3014d3700007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    3: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\f94b5cbdae69d3014e3700007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    4: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\f94b5cbdae69d3014f3700007c017813.program_files_x86_common_files_microsoft_shared_dao_9d0cb78256d5a29d.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_dao_9d0cb78256d5a29d.cdf-ms"
    5: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\ad1061bdae69d301503700007c017813.program_files_x86_windows_media_player_e9607c93dd43c2ea.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_e9607c93dd43c2ea.cdf-ms"
    6: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\077363bdae69d301513700007c017813.program_files_x86_windows_media_player_skins_aeefd749ff68a842.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_skins_aeefd749ff68a842.cdf-ms"
2017-11-30 08:42:14, Info                  CSI        7: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\6ffc6cbdae69d301523700007c017813.program_files_x86_windows_media_player_icons_b0582fd1fc3de13a.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_icons_b0582fd1fc3de13a.cdf-ms"
    8: Move File: Source = [l:298{149}]"\SystemRoot\WinSxS\Temp\PendingRenames\c95e6fbdae69d301533700007c017813.program_files_x86_windows_media_player_visualizations_93a092c4c2e55b5f.cdf-ms", Destination = [l:210{105}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_media_player_visualizations_93a092c4c2e55b5f.cdf-ms"
    9: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\c95e6fbdae69d301543700007c017813.program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms"
    10: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\23c171bdae69d301553700007c017813.program_files_x86_windows_mail_pl-pl_26af41d3f2ff4fad.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_mail_pl-pl_26af41d3f2ff4fad.cdf-ms"
    11: Move File: Source = [l:308{154}]"\SystemRoot\WinSxS\Temp\PendingRenames\a79889bdae69d301563700007c017813.program_files_x86_common_files_microsoft_shared_stationery_ea25573447e2dae5.cdf-ms", Destination = [l:220{110}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_stationery_ea25573447e2dae5.cdf-ms"
POQ 124 ends.
2017-11-30 08:42:14, Info                  CSI    000002d7 [SR] Verify complete
2017-11-30 08:42:15, Info                  CSI    000002d8 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:15, Info                  CSI    000002d9 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:16, Info                  CSI    000002da Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\he-IL" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"he-IL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002db Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\uk-UA" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"uk-UA", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002dc Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\nb-NO" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"nb-NO", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002dd Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\sl-SI" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"sl-SI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002de Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\en-US" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"en-us", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002df Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\zh-CN" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"zh-CN", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002e0 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\zh-TW" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"zh-TW", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:16, Info                  CSI    000002e1 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\el-GR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"el-GR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e2 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ko-KR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ko-KR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e3 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\tr-TR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"tr-TR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e4 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\it-IT" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"it-IT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e5 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\fr-FR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"fr-FR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e6 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\fi-FI" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"fi-FI", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:17, Info                  CSI    000002e7 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\nl-NL" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"nl-NL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002e8 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\hr-HR" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"hr-HR", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002e9 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pl-PL" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pl-PL", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002ea Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\pt-PT" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"pt-PT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002eb Ignoring duplicate ownership for directory [l:68{34}]"\??\C:\Windows\SysWOW64\sr-Latn-CS" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:20{10}]"sr-Latn-CS", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002ec Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\bg-BG" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"bg-BG", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002ed Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ru-RU" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ru-RU", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002ee Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\cs-CZ" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"cs-CZ", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002ef Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\lt-LT" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"lt-LT", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002f0 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\de-DE" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"de-DE", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002f1 Ignoring duplicate ownership for directory [l:58{29}]"\??\C:\Windows\SysWOW64\ja-JP" in component Microsoft-Windows-mlang.Resources, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture = [l:10{5}]"ja-JP", VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:18, Info                  CSI    000002f2 Repair results created:
POQ 125 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab063abeae69d301bb3700007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ab063abeae69d301bc3700007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\b92d41beae69d301bd3700007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\139043beae69d301be3700007c017813.$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_he-il_a40ac5786f0c16bd.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\7b194dbeae69d301bf3700007c017813.$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_uk-ua_bcbec29049fe1bc7.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\677a6ebeae69d301c03700007c017813.$$_syswow64_nb-no_af7199325df1d8da.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nb-no_af7199325df1d8da.cdf-ms"
    6: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\669c78beae69d301c13700007c017813.$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sl-si_b8f1e2684fb16c1c.cdf-ms"
    7: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ce2582beae69d301c23700007c017813.$$_syswow64_en-us_9e576ab077991fe8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_9e576ab077991fe8.cdf-ms"
2017-11-30 08:42:18, Info                  CSI    s\36af8bbeae69d301c33700007c017813.$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-cn_c63f31ac3bbd74ba.cdf-ms"
    9: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\44d692beae69d301c43700007c017813.$$_syswow64_zh-hk_c63f2bfa3bbd7d4a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-hk_c63f2bfa3bbd7d4a.cdf-ms"
    10: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\ac5f9cbeae69d301c53700007c017813.$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_zh-tw_c63f42c23bbd5b2a.cdf-ms"
    11: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c8adaabeae69d301c63700007c017813.$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-br_b33e8b90583e6f27.cdf-ms"
    12: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3037b4beae69d301c73700007c017813.$$_syswow64_ar-sa_96bd698c83002208.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ar-sa_96bd698c83002208.cdf-ms"
    13: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\98c0bdbeae69d301c83700007c017813.$$_syswow64_el-gr_9e57691277992211.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_el-gr_9e57691277992211.cdf-ms"
    14: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c235d3beae69d301c93700007c017813.$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ko-kr_a9be3642667eee9e.cdf-ms"
    15: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\d05cdabeae69d301ca3700007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    16: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\d05cd
2017-11-30 08:42:18, Info                  CSI    abeae69d301cb3700007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    17: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\d05cdabeae69d301cc3700007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    18: Move File: Source = [l:300{150}]"\SystemRoot\WinSxS\Temp\PendingRenames\d05cdabeae69d301cd3700007c017813.program_files_x86_common_files_microsoft_shared_msinfo_4536eb45a5f97101.cdf-ms", Destination = [l:212{106}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_msinfo_4536eb45a5f97101.cdf-ms"
    19: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\fad1efbeae69d301ce3700007c017813.$$_syswow64_tasks_bad86ed64cd79762.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_bad86ed64cd79762.cdf-ms"
    20: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\fad1efbeae69d301cf3700007c017813.$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_microsoft_200b1d7e84f3818e.cdf-ms"
    21: Move File: Source = [l:284{142}]"\SystemRoot\WinSxS\Temp\PendingRenames\5434f2beae69d301d03700007c017813.$$_syswow64_tasks_microsoft_windows_synccenter_bb7e945a68c8139d.cdf-ms", Destination = [l:196{98}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tasks_microsoft_windows_synccenter_bb7e945a68c8139d.cdf-ms"
    22: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcbdfbbeae69d301d13700007c017813.$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_da-dk_9c70e5ba7a72e5e9.cdf-ms"
    23: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\244705bfae69d301d23700007c017
2017-11-30 08:42:18, Info                  CSI    813.$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_th-th_bad858ac4cd7ba4b.cdf-ms"
    24: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\8cd00ebfae69d301d33700007c017813.$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_tr-tr_bad86a404cd7a0fb.cdf-ms"
    25: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\f45918bfae69d301d43700007c017813.$$_syswow64_et-ee_9e574f447799499c.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_et-ee_9e574f447799499c.cdf-ms"
    26: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\c46c2bbfae69d301d53700007c017813.$$_syswow64_it-it_a5f14a266c32514d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_it-it_a5f14a266c32514d.cdf-ms"
    27: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\2cf634bfae69d301d63700007c017813.$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fr-fr_a03ddfd474bf708f.cdf-ms"
    28: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\947f3ebfae69d301d73700007c017813.$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_fi-fi_a03dd00274bf8757.cdf-ms"
    29: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2a645bfae69d301d83700007c017813.$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_nl-nl_af7192185df1e48f.cdf-ms"
    30: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bef453bfae69d301d93700007c017813.$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sk-sk_b8f1e6584fb16619.cdf-ms"
    31: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\80e05fbfae69d301da3700007c017813.$$_s
2017-11-30 08:42:18, Info                  CSI    yswow64_hu-hu_a40ad44e6f0c022b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hu-hu_a40ad44e6f0c022b.cdf-ms"
    32: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e86969bfae69d301db3700007c017813.$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_hr-hr_a40acf086f0c09c3.cdf-ms"
    33: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\aa5575bfae69d301dc3700007c017813.$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pl-pl_b33e814c583e7dc3.cdf-ms"
    34: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\12df7ebfae69d301dd3700007c017813.$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_pt-pt_b33e8f5c583e6983.cdf-ms"
    35: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\7a6888bfae69d301de3700007c017813.$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sr-latn-cs_f675c0233d78a086.cdf-ms"
    36: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\e2f191bfae69d301df3700007c017813.$$_syswow64_es-es_9e5769fc7799216d.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_es-es_9e5769fc7799216d.cdf-ms"
    37: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\a4dd9dbfae69d301e03700007c017813.$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_bg-bg_98a3ee16802659ff.cdf-ms"
    38: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\0c67a7bfae69d301e13700007c017813.$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ro-ro_b70b75c6528b0f5f.cdf-ms"
    39: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\74f0b0bfae69d301e23700007c017813.$$
2017-11-30 08:42:18, Info                  CSI    _syswow64_ru-ru_b70b8052528b002f.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ru-ru_b70b8052528b002f.cdf-ms"
    40: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc79babfae69d301e33700007c017813.$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_cs-cz_9a8a88127d4c744a.cdf-ms"
    41: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\4403c4bfae69d301e43700007c017813.$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sv-se_b8f1d9684fb17aaa.cdf-ms"
    42: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\06efcfbfae69d301e53700007c017813.$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lv-lv_aba4b47863a5320b.cdf-ms"
    43: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\6e78d9bfae69d301e63700007c017813.$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_lt-lt_aba4b0f463a5371b.cdf-ms"
    44: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\d601e3bfae69d301e73700007c017813.$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_de-de_9c70d9c67a72f843.cdf-ms"
    45: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\3e8becbfae69d301e83700007c017813.$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_ja-jp_a7d7bcd46958a348.cdf-ms"
POQ 125 ends.
2017-11-30 08:42:18, Info                  CSI    000002f3 [SR] Verify complete
2017-11-30 08:42:19, Info                  CSI    000002f4 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:19, Info                  CSI    000002f5 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:25, Info                  CSI    000002f6 Repair results created:
POQ 126 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\58fc04c2ae69d3014d3800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\58fc04c2ae69d3014e3800007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    2: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\58fc04c2ae69d3014f3800007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_1dfadad07dc0f94f.cdf-ms"
    3: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\58fc04c2ae69d301503800007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.5_pl_cbb2d822956955e7.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.5_pl_cbb2d822956955e7.cdf-ms"
    4: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\ceac15c2ae69d301513800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    5: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\ceac15c2ae69d301523800007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    6: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\ceac15c2ae69d301533800007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    7: Move File: Source = [l:254{127}]"\SystemRoot\WinSxS\Temp\PendingRenames\ceac15c2ae69d301543800007c0178
2017-11-30 08:42:25, Info                  CSI    13.$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms", Destination = [l:166{83}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_5588a8293fdc4499.cdf-ms"
    8: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\280f18c2ae69d301553800007c017813.$$_microsoft.net_framework_v3.5_1045_b573e20273d2615f.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_1045_b573e20273d2615f.cdf-ms"
    9: Move File: Source = [l:260{130}]"\SystemRoot\WinSxS\Temp\PendingRenames\280f18c2ae69d301563800007c017813.$$_microsoft.net_framework_v3.5_pl_3cd0344e9aae9929.cdf-ms", Destination = [l:172{86}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.5_pl_3cd0344e9aae9929.cdf-ms"
    10: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\ba0d37c2ae69d301573800007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
POQ 126 ends.
2017-11-30 08:42:25, Info                  CSI    000002f7 [SR] Verify complete
2017-11-30 08:42:25, Info                  CSI    000002f8 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:25, Info                  CSI    000002f9 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:26, Info                  CSI    000002fa Repair results created:
POQ 127 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\74a475c4ae69d301bc3800007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\74a475c4ae69d301bd3800007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc2d7fc4ae69d301be3800007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:238{119}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc2d7fc4ae69d301bf3800007c017813.$$_syswow64_networklist_fac29f16fb5be78a.cdf-ms", Destination = [l:150{75}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_networklist_fac29f16fb5be78a.cdf-ms"
    4: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc2d7fc4ae69d301c03800007c017813.$$_syswow64_networklist_icons_0ad2dfa4d19a0c98.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_networklist_icons_0ad2dfa4d19a0c98.cdf-ms"
    5: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\dc2d7fc4ae69d301c13800007c017813.$$_syswow64_networklist_icons_stockicons_3f4e81997d25c7f4.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_networklist_icons_stockicons_3f4e81997d25c7f4.cdf-ms"
POQ 127 ends.
2017-11-30 08:42:26, Info                  CSI    000002fb [SR] Verify complete
2017-11-30 08:42:27, Info                  CSI    000002fc [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:27, Info                  CSI    000002fd [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:28, Info                  CSI    000002fe Repair results created:
POQ 128 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\e09b2fc5ae69d301263900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\e09b2fc5ae69d301273900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\eec236c5ae69d301283900007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\482539c5ae69d301293900007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    4: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2873bc5ae69d3012a3900007c017813.program_files_x86_windows_photo_viewer_a7a2292bcc87c94b.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_photo_viewer_a7a2292bcc87c94b.cdf-ms"
    5: Move File: Source = [l:280{140}]"\SystemRoot\WinSxS\Temp\PendingRenames\50d468c5ae69d3012b3900007c017813.program_files_x86_windows_photo_viewer_pl-pl_5d35cba14ab637c6.cdf-ms", Destination = [l:192{96}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_photo_viewer_pl-pl_5d35cba14ab637c6.cdf-ms"
    6: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\12c074c5ae69d3012c3900007c017813.$$_syswow64_printing_admin_scripts_pl-pl_69973fc21b81c367.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_printing_admin_scripts_pl-pl_69973fc21b81c367.cdf-ms"
POQ 128 ends.
2017-11-30 08:42:28, Info                  CSI    000002ff [SR] Verify complete
2017-11-30 08:42:28, Info                  CSI    00000300 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:28, Info                  CSI    00000301 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:28, Info                  CSI    00000302 Ignoring duplicate ownership for directory [l:96{48}]"\??\C:\ProgramData\Microsoft\Network\Connections" in component Microsoft-Windows-RasApi, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:29, Info                  CSI    00000303 Ignoring duplicate ownership for directory [l:44{22}]"\??\C:\Windows\tracing" in component Microsoft-Windows-RasRTUtils, Version = 6.1.7601.17514, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:29, Info                  CSI    00000304 Repair results created:
POQ 129 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\8aa7ddc5ae69d301913900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\f230e7c5ae69d301923900007c017813.programdata_microsoft_network_connections_2e5c3accd04dd407.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\programdata_microsoft_network_connections_2e5c3accd04dd407.cdf-ms"
    2: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\1ca6fcc5ae69d301933900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    3: Move File: Source = [l:212{106}]"\SystemRoot\WinSxS\Temp\PendingRenames\1ca6fcc5ae69d301943900007c017813.$$_tracing_bca9e27848ac4cc0.cdf-ms", Destination = [l:124{62}]"\SystemRoot\WinSxS\FileMaps\$$_tracing_bca9e27848ac4cc0.cdf-ms"
POQ 129 ends.
2017-11-30 08:42:29, Info                  CSI    00000305 [SR] Verify complete
2017-11-30 08:42:29, Info                  CSI    00000306 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:29, Info                  CSI    00000307 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:30, Info                  CSI    00000308 Repair results created:
POQ 130 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\d2a159c6ae69d301f93900007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\d2a159c6ae69d301fa3900007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\e0c860c6ae69d301fb3900007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:232{116}]"\SystemRoot\WinSxS\Temp\PendingRenames\a2b46cc6ae69d301fc3900007c017813.$$_diagnostics_index_6f9ad1a80c4f7ad6.cdf-ms", Destination = [l:144{72}]"\SystemRoot\WinSxS\FileMaps\$$_diagnostics_index_6f9ad1a80c4f7ad6.cdf-ms"
    4: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\18657dc6ae69d301fd3900007c017813.$$_syswow64_spp_tokens_pkeyconfig_b2fdf59e46c165ae.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_spp_tokens_pkeyconfig_b2fdf59e46c165ae.cdf-ms"
    5: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\da5089c6ae69d301fe3900007c017813.$$_syswow64_speech_speechux_27aa9ae49ec13adf.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_speech_speechux_27aa9ae49ec13adf.cdf-ms"
    6: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\c6b1aac6ae69d301ff3900007c017813.$$_syswow64_slmgr_0415_804070e41f15c9ff.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_slmgr_0415_804070e41f15c9ff.cdf-ms"
POQ 130 ends.
2017-11-30 08:42:30, Info                  CSI    00000309 [SR] Verify complete
2017-11-30 08:42:30, Info                  CSI    0000030a [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:30, Info                  CSI    0000030b [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:31, Info                  CSI    0000030c Repair results created:
POQ 131 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\5ae721c7ae69d301643a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5ae721c7ae69d301653a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\680e29c7ae69d301663a00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\c2702bc7ae69d301673a00007c017813.$$_syswow64_advancedinstallers_0c6bb4866bff02f7.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_advancedinstallers_0c6bb4866bff02f7.cdf-ms"
    4: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\38213cc7ae69d301683a00007c017813.$$_syswow64_sppui_b8f1e21e4fb16c27.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_sppui_b8f1e21e4fb16c27.cdf-ms"
    5: Move File: Source = [l:226{113}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcf853c7ae69d301693a00007c017813.$$_syswow64_en-us_9e576ab077991fe8.cdf-ms", Destination = [l:138{69}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_en-us_9e576ab077991fe8.cdf-ms"
POQ 131 ends.
2017-11-30 08:42:31, Info                  CSI    0000030d [SR] Verify complete
2017-11-30 08:42:31, Info                  CSI    0000030e [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:31, Info                  CSI    0000030f [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:32, Info                  CSI    00000310 Repair results created:
POQ 132 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e55d2c7ae69d301ce3a00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\5e55d2c7ae69d301cf3a00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\2041dec7ae69d301d03a00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:264{132}]"\SystemRoot\WinSxS\Temp\PendingRenames\7aa3e0c7ae69d301d13a00007c017813.$$_syswow64_spp_tokens_channels_ocur_69b663564b19f4ee.cdf-ms", Destination = [l:176{88}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_spp_tokens_channels_ocur_69b663564b19f4ee.cdf-ms"
    4: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\f053f1c7ae69d301d23a00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    5: Move File: Source = [l:258{129}]"\SystemRoot\WinSxS\Temp\PendingRenames\f053f1c7ae69d301d33a00007c017813.program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms", Destination = [l:170{85}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_478e9d8582f6df0d.cdf-ms"
    6: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\4ab6f3c7ae69d301d43a00007c017813.program_files_x86_windows_sidebar_pl-pl_ef88c76b8abd7c94.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_sidebar_pl-pl_ef88c76b8abd7c94.cdf-ms"
    7: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\1ac906c8ae69d301d53a00007c017813.$$_syswow64_speech_engines_sr_d5815721f6360684.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\Fi
2017-11-30 08:42:32, Info                  CSI    leMaps\$$_syswow64_speech_engines_sr_d5815721f6360684.cdf-ms"
    8: Move File: Source = [l:242{121}]"\SystemRoot\WinSxS\Temp\PendingRenames\6eb331c8ae69d301d63a00007c017813.$$_syswow64_speech_common_b84a7a708e507091.cdf-ms", Destination = [l:154{77}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_speech_common_b84a7a708e507091.cdf-ms"
POQ 132 ends.
2017-11-30 08:42:32, Info                  CSI    00000311 [SR] Verify complete
2017-11-30 08:42:32, Info                  CSI    00000312 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:32, Info                  CSI    00000313 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:33, Info                  CSI    00000314 Ignoring duplicate ownership for directory [l:120{60}]"\??\C:\Program Files (x86)\Common Files\Microsoft Shared\Ink" in component Microsoft-Windows-TabletPC-Platform-COMRuntime, Version = 6.1.7601.23375, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:33, Info                  CSI    00000315 Repair results created:
POQ 133 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c5ebec8ae69d3013b3b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\2c5ebec8ae69d3013c3b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\0a98d8c8ae69d3013d3b00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    3: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\0a98d8c8ae69d3013e3b00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    4: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\0a98d8c8ae69d3013f3b00007c017813.program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    5: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\0a98d8c8ae69d301403b00007c017813.program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms"
POQ 133 ends.
2017-11-30 08:42:33, Info                  CSI    00000316 [SR] Verify complete
2017-11-30 08:42:34, Info                  CSI    00000317 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:34, Info                  CSI    00000318 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:35, Info                  CSI    00000319 Repair results created:
POQ 134 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\147e60c9ae69d301a53b00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\147e60c9ae69d301a63b00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
POQ 134 ends.
2017-11-30 08:42:35, Info                  CSI    0000031a [SR] Verify complete
2017-11-30 08:42:35, Info                  CSI    0000031b [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:35, Info                  CSI    0000031c [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:36, Info                  CSI    0000031d Repair results created:
POQ 135 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\724e13caae69d3010b3c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\724e13caae69d3010c3c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\80751acaae69d3010d3c00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:222{111}]"\SystemRoot\WinSxS\Temp\PendingRenames\dad71ccaae69d3010e3c00007c017813.$$_syswow64_wcn_1bf25cffa7664032.cdf-ms", Destination = [l:134{67}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wcn_1bf25cffa7664032.cdf-ms"
    4: Move File: Source = [l:234{117}]"\SystemRoot\WinSxS\Temp\PendingRenames\343a1fcaae69d3010f3c00007c017813.$$_syswow64_wcn_pl-pl_3465312854ee5dc3.cdf-ms", Destination = [l:146{73}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_wcn_pl-pl_3465312854ee5dc3.cdf-ms"
    5: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\426126caae69d301103c00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    6: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\426126caae69d301113c00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    7: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\9cc328caae69d301123c00007c017813.program_files_x86_common_files_system_681b9383b994c86d.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_681b9383b994c86d.cdf-ms"
    8
2017-11-30 08:42:36, Info                  CSI    : Move File: Source = [l:278{139}]"\SystemRoot\WinSxS\Temp\PendingRenames\9cc328caae69d301133c00007c017813.program_files_x86_common_files_system_pl-pl_66327f4bc162c4dc.cdf-ms", Destination = [l:190{95}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_system_pl-pl_66327f4bc162c4dc.cdf-ms"
    9: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\7afd42caae69d301143c00007c017813.program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_windows_mail_fc7b184dbf576a4a.cdf-ms"
    10: Move File: Source = [l:236{118}]"\SystemRoot\WinSxS\Temp\PendingRenames\fed45acaae69d301153c00007c017813.$$_syswow64_winrm_0415_6936615e19c6faa9.cdf-ms", Destination = [l:148{74}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_winrm_0415_6936615e19c6faa9.cdf-ms"
    11: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\0cfc61caae69d301163c00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms"
    12: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\665e64caae69d301173c00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_pl_cbb2cea495696424.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_pl_cbb2cea495696424.cdf-ms"
    13: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\665e64caae69d301183c00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    14: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\665e64caae69d301193c00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_
2017-11-30 08:42:36, Info                  CSI    83386eac0379231b.cdf-ms"
    15: Move File: Source = [l:320{160}]"\SystemRoot\WinSxS\Temp\PendingRenames\c0c066caae69d3011a3c00007c017813.$$_microsoft.net_framework_v3.0_windows_communication_foundation_e07323de19ff1b52.cdf-ms", Destination = [l:232{116}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_windows_communication_foundation_e07323de19ff1b52.cdf-ms"
    16: Move File: Source = [l:332{166}]"\SystemRoot\WinSxS\Temp\PendingRenames\c0c066caae69d3011b3c00007c017813.$$_microsoft.net_framework_v3.0_windows_communication_foundation_pl-pl_fda50c965e7411ef.cdf-ms", Destination = [l:244{122}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_windows_communication_foundation_pl-pl_fda50c965e7411ef.cdf-ms"
    17: Move File: Source = [l:326{163}]"\SystemRoot\WinSxS\Temp\PendingRenames\c0c066caae69d3011c3c00007c017813.$$_microsoft.net_framework_v3.0_windows_communication_foundation_pl_602470e547753d00.cdf-ms", Destination = [l:238{119}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_windows_communication_foundation_pl_602470e547753d00.cdf-ms"
    18: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\c0c066caae69d3011d3c00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    19: Move File: Source = [l:250{125}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a2369caae69d3011e3c00007c017813.$$_inf_smsvchost_3.0.0.0_0415_2d6d99f95cb60920.cdf-ms", Destination = [l:162{81}]"\SystemRoot\WinSxS\FileMaps\$$_inf_smsvchost_3.0.0.0_0415_2d6d99f95cb60920.cdf-ms"
    20: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a2369caae69d3011f3c00007c017813.$$_inf_servicemodeloperation_3.0.0.0_0415_9b92c520d51f6273.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodeloperation_3.0.0.0_0415_9b92c520d51f6273.cdf-ms"
    21: Move File: Source = [l:270{135}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a2369caae69d301203c00007c017813.$$_inf_servicemodelservice
2017-11-30 08:42:36, Info                  CSI    _3.0.0.0_0415_2fd4df7298bb9c29.cdf-ms", Destination = [l:182{91}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelservice_3.0.0.0_0415_2fd4df7298bb9c29.cdf-ms"
    22: Move File: Source = [l:256{128}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a2369caae69d301213c00007c017813.$$_inf_msdtc_bridge_3.0.0.0_0415_5d6037ff7f35c39e.cdf-ms", Destination = [l:168{84}]"\SystemRoot\WinSxS\FileMaps\$$_inf_msdtc_bridge_3.0.0.0_0415_5d6037ff7f35c39e.cdf-ms"
    23: Move File: Source = [l:272{136}]"\SystemRoot\WinSxS\Temp\PendingRenames\1a2369caae69d301223c00007c017813.$$_inf_servicemodelendpoint_3.0.0.0_0415_1441b5556e0ddf47.cdf-ms", Destination = [l:184{92}]"\SystemRoot\WinSxS\FileMaps\$$_inf_servicemodelendpoint_3.0.0.0_0415_1441b5556e0ddf47.cdf-ms"
    24: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\82ac72caae69d301233c00007c017813.$$_twain_32_209f76caa35c9a77.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_twain_32_209f76caa35c9a77.cdf-ms"
POQ 135 ends.
2017-11-30 08:42:36, Info                  CSI    0000031e [SR] Verify complete
2017-11-30 08:42:36, Info                  CSI    0000031f [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:36, Info                  CSI    00000320 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:38, Info                  CSI    00000321 Repair results created:
POQ 136 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\6acc14cbae69d301883c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\6acc14cbae69d301893c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\78f31bcbae69d3018a3c00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    3: Move File: Source = [l:282{141}]"\SystemRoot\WinSxS\Temp\PendingRenames\d2551ecbae69d3018b3c00007c017813.$$_syswow64_logfiles_windows_portable_devices_ed9529c6a0cda444.cdf-ms", Destination = [l:194{97}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_logfiles_windows_portable_devices_ed9529c6a0cda444.cdf-ms"
POQ 136 ends.
2017-11-30 08:42:38, Info                  CSI    00000322 [SR] Verify complete
2017-11-30 08:42:38, Info                  CSI    00000323 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:38, Info                  CSI    00000324 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:39, Info                  CSI    00000325 Ignoring duplicate ownership for directory [l:72{36}]"\??\C:\Windows\microsoft.net\authman" in component Microsoft.Interop.Security.AzRoles, Version = 6.1.7600.16385, pA = PROCESSOR_ARCHITECTURE_INTEL (0), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral
2017-11-30 08:42:39, Info                  CSI    00000326 Repair results created:
POQ 137 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\08e813ccae69d301f03c00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\08e813ccae69d301f13c00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:204{102}]"\SystemRoot\WinSxS\Temp\PendingRenames\08e813ccae69d301f23c00007c017813.$$_inf_3f581daba4c8c835.cdf-ms", Destination = [l:116{58}]"\SystemRoot\WinSxS\FileMaps\$$_inf_3f581daba4c8c835.cdf-ms"
    3: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\624a16ccae69d301f33c00007c017813.$$_inf_windows_workflow_foundation_3.0.0.0_0000_c87be1b3a75f787b.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\$$_inf_windows_workflow_foundation_3.0.0.0_0000_c87be1b3a75f787b.cdf-ms"
    4: Move File: Source = [l:228{114}]"\SystemRoot\WinSxS\Temp\PendingRenames\624a16ccae69d301f43c00007c017813.program_files_x86__676bbe2c7241b694.cdf-ms", Destination = [l:140{70}]"\SystemRoot\WinSxS\FileMaps\program_files_x86__676bbe2c7241b694.cdf-ms"
    5: Move File: Source = [l:318{159}]"\SystemRoot\WinSxS\Temp\PendingRenames\624a16ccae69d301f53c00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms", Destination = [l:230{115}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_1dfad1527dc1078c.cdf-ms"
    6: Move File: Source = [l:252{126}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcac18ccae69d301f63c00007c017813.program_files_x86_common_files_dfa3680ec228c528.cdf-ms", Destination = [l:164{82}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_dfa3680ec228c528.cdf-ms"
    7: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcac18ccae69d301f73c00007c017813.program_files_x86_common_files_microsoft_shared_
2017-11-30 08:42:39, Info                  CSI    635c287ec97ec0a5.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_635c287ec97ec0a5.cdf-ms"
    8: Move File: Source = [l:294{147}]"\SystemRoot\WinSxS\Temp\PendingRenames\bcac18ccae69d301f83c00007c017813.program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms", Destination = [l:206{103}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_9d0caff456d5ade1.cdf-ms"
    9: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\160f1bccae69d301f93c00007c017813.program_files_x86_common_files_microsoft_shared_ink_1.0_5645a6a00c765d40.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_1.0_5645a6a00c765d40.cdf-ms"
    10: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\cad31fccae69d301fa3c00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    11: Move File: Source = [l:240{120}]"\SystemRoot\WinSxS\Temp\PendingRenames\cad31fccae69d301fb3c00007c017813.$$_microsoft.net_authman_27829e1b3df01691.cdf-ms", Destination = [l:152{76}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_authman_27829e1b3df01691.cdf-ms"
    12: Move File: Source = [l:324{162}]"\SystemRoot\WinSxS\Temp\PendingRenames\7e9824ccae69d301fc3c00007c017813.program_files_x86_reference_assemblies_microsoft_framework_v3.0_pl_cbb2cea495696424.cdf-ms", Destination = [l:236{118}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_reference_assemblies_microsoft_framework_v3.0_pl_cbb2cea495696424.cdf-ms"
    13: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8fa26ccae69d301fd3c00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    14: Move File: Source = [l:262{131}]"\SystemRoot\WinSxS\Temp\PendingRenames\d8fa26ccae6
2017-11-30 08:42:39, Info                  CSI    9d301fe3c00007c017813.$$_microsoft.net_framework_v3.0_wpf_b56a2354fbfa0c31.cdf-ms", Destination = [l:174{87}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_wpf_b56a2354fbfa0c31.cdf-ms"
    15: Move File: Source = [l:274{137}]"\SystemRoot\WinSxS\Temp\PendingRenames\325d29ccae69d301ff3c00007c017813.$$_microsoft.net_framework_v3.0_wpf_pl-pl_36f041ff706f3c50.cdf-ms", Destination = [l:186{93}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_wpf_pl-pl_36f041ff706f3c50.cdf-ms"
    16: Move File: Source = [l:268{134}]"\SystemRoot\WinSxS\Temp\PendingRenames\325d29ccae69d301003d00007c017813.$$_microsoft.net_framework_v3.0_wpf_pl_389aa09b979d5637.cdf-ms", Destination = [l:180{90}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v3.0_wpf_pl_389aa09b979d5637.cdf-ms"
    17: Move File: Source = [l:214{107}]"\SystemRoot\WinSxS\Temp\PendingRenames\408430ccae69d301013d00007c017813.$$_syswow64_21ffbdd2a2dd92e0.cdf-ms", Destination = [l:126{63}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_21ffbdd2a2dd92e0.cdf-ms"
    18: Move File: Source = [l:246{123}]"\SystemRoot\WinSxS\Temp\PendingRenames\9ae632ccae69d301023d00007c017813.$$_syswow64_xpsviewer_pl-pl_aeeb63f9810304ae.cdf-ms", Destination = [l:158{79}]"\SystemRoot\WinSxS\FileMaps\$$_syswow64_xpsviewer_pl-pl_aeeb63f9810304ae.cdf-ms"
    19: Move File: Source = [l:286{143}]"\SystemRoot\WinSxS\Temp\PendingRenames\2ce551ccae69d301033d00007c017813.$$_inf_windows_workflow_foundation_3.0.0.0_0415_c87be931a75f6d3b.cdf-ms", Destination = [l:198{99}]"\SystemRoot\WinSxS\FileMaps\$$_inf_windows_workflow_foundation_3.0.0.0_0415_c87be931a75f6d3b.cdf-ms"
    20: Move File: Source = [l:302{151}]"\SystemRoot\WinSxS\Temp\PendingRenames\e0a956ccae69d301043d00007c017813.program_files_x86_common_files_microsoft_shared_ink_1.7_5645b3ea0c764951.cdf-ms", Destination = [l:214{107}]"\SystemRoot\WinSxS\FileMaps\program_files_x86_common_files_microsoft_shared_ink_1.7_5645b3ea0c764951.cdf-ms"
POQ 137 ends.
2017-11-30 08:42:39, Info                  CSI    00000327 [SR] Verify complete
2017-11-30 08:42:39, Info                  CSI    00000328 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:39, Info                  CSI    00000329 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:41, Info                  CSI    0000032a Repair results created:
POQ 138 starts:
POQ 138 ends.
2017-11-30 08:42:41, Info                  CSI    0000032b [SR] Verify complete
2017-11-30 08:42:41, Info                  CSI    0000032c [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:41, Info                  CSI    0000032d [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:42, Info                  CSI    0000032e Repair results created:
POQ 139 starts:
     0: Move File: Source = [l:192{96}]"\SystemRoot\WinSxS\Temp\PendingRenames\88abddcdae69d301cd3d00007c017813._0000000000000000.cdf-ms", Destination = [l:104{52}]"\SystemRoot\WinSxS\FileMaps\_0000000000000000.cdf-ms"
    1: Move File: Source = [l:162{81}]"\SystemRoot\WinSxS\Temp\PendingRenames\88abddcdae69d301ce3d00007c017813.$$.cdf-ms", Destination = [l:74{37}]"\SystemRoot\WinSxS\FileMaps\$$.cdf-ms"
    2: Move File: Source = [l:224{112}]"\SystemRoot\WinSxS\Temp\PendingRenames\88abddcdae69d301cf3d00007c017813.$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms", Destination = [l:136{68}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_3296b36dbe4c7fa3.cdf-ms"
    3: Move File: Source = [l:244{122}]"\SystemRoot\WinSxS\Temp\PendingRenames\88abddcdae69d301d03d00007c017813.$$_microsoft.net_framework_83386eac0379231b.cdf-ms", Destination = [l:156{78}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_83386eac0379231b.cdf-ms"
    4: Move File: Source = [l:266{133}]"\SystemRoot\WinSxS\Temp\PendingRenames\e20de0cdae69d301d13d00007c017813.$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms", Destination = [l:178{89}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_e9368840261e60ee.cdf-ms"
    5: Move File: Source = [l:288{144}]"\SystemRoot\WinSxS\Temp\PendingRenames\e20de0cdae69d301d23d00007c017813.$$_microsoft.net_framework_v2.0.50727_redistlist_2e6ab8b35e9ef953.cdf-ms", Destination = [l:200{100}]"\SystemRoot\WinSxS\FileMaps\$$_microsoft.net_framework_v2.0.50727_redistlist_2e6ab8b35e9ef953.cdf-ms"
POQ 139 ends.
2017-11-30 08:42:42, Info                  CSI    0000032f [SR] Verify complete
2017-11-30 08:42:42, Info                  CSI    00000330 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:42, Info                  CSI    00000331 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:43, Info                  CSI    00000332 Repair results created:
POQ 140 starts:
POQ 140 ends.
2017-11-30 08:42:43, Info                  CSI    00000333 [SR] Verify complete
2017-11-30 08:42:44, Info                  CSI    00000334 [SR] Verifying 100 (0x0000000000000064) components
2017-11-30 08:42:44, Info                  CSI    00000335 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:45, Info                  CSI    00000336 Repair results created:
POQ 141 starts:
POQ 141 ends.
2017-11-30 08:42:45, Info                  CSI    00000337 [SR] Verify complete
2017-11-30 08:42:45, Info                  CSI    00000338 [SR] Verifying 3 components
2017-11-30 08:42:45, Info                  CSI    00000339 [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:45, Info                  CSI    0000033a Repair results created:
POQ 142 starts:
POQ 142 ends.
2017-11-30 08:42:45, Info                  CSI    0000033b [SR] Verify complete
2017-11-30 08:42:45, Info                  CSI    0000033c [SR] Repairing 0 components
2017-11-30 08:42:45, Info                  CSI    0000033d [SR] Beginning Verify and Repair transaction
2017-11-30 08:42:45, Info                  CSI    0000033e Repair results created:
POQ 143 starts:
POQ 143 ends.
2017-11-30 08:42:45, Info                  CSI    0000033f [SR] Repair complete
No errors.
KB4051034 was installed successfully along with problematic KB4048957.
There was a green checkmark after restart.
But there is no KB4048957 update on Update list.
There were new updates found, but with another 80070490 error.
Here it is CBS.log after new updates WU crash.
View attachment CBS.zip
