[SOLVED] [W7SP1 x64] Won't Update, Error 80073701
Re: Windows 7 Won't Update - Error Code 80073701
Unfortunately, the update failed. The error code was 80073712.
Here is the link to the CBS.log file:
https://1drv.ms/u/s!AhqT3Ll8HZ6BgRDrCr6Cxrtb4RYa - CBS_LogFile.zip - Approx. 9 MB
I wasn't sure if you wanted me to do a CheckSUR.log. Please let me know if you'd like that done also.
Here is the result of the SFCFix.txt file:
Start time: 2017-11-02 18:24:45.291
Using .zip script file at C:\Users\Mark\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_1_for_kb2952664~31bf3856ad364e35~amd64~~6.1.20.1.cat to C:\Windows\servicing\Packages\package_1_for_kb2952664~31bf3856ad364e35~amd64~~6.1.20.1.cat.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_1_for_kb2952664~31bf3856ad364e35~amd64~~6.1.20.1.mum to C:\Windows\servicing\Packages\package_1_for_kb2952664~31bf3856ad364e35~amd64~~6.1.20.1.mum.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_2_for_kb3138901~31bf3856ad364e35~amd64~~6.1.1.0.cat to C:\Windows\servicing\Packages\package_2_for_kb3138901~31bf3856ad364e35~amd64~~6.1.1.0.cat.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Packages\package_2_for_kb3138901~31bf3856ad364e35~amd64~~6.1.1.0.mum to C:\Windows\servicing\Packages\package_2_for_kb3138901~31bf3856ad364e35~amd64~~6.1.1.0.mum.
Successfully restored ownership for C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored permissions on C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored ownership for C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum
Successfully restored permissions on C:\Windows\servicing\Packages\package_111_for_kb4019264~31bf3856ad364e35~amd64~~6.1.1.3.mum
Currently storing 16 datablocks.
Finish time: 2017-11-02 18:24:49.113
Script hash: gCFTxWElzgTfGuDKUPKjfbk/skM1sbmBQ4AqVD16qRU=
Thank you.
There are still issues to fix, please be patient.
Do you have Avast still installed and if so, which version ?
No, Avast is no longer installed on the computer. I'm now using malwarebytes.
The update failed with error code was 80073701.
https://1drv.ms/u/s!AhqT3Ll8HZ6BgRFg5tgnDAMFCqP- - CBS_Log.zip - approx. 18 MB
Here are the results of the SFCFix.txt file:
Start time: 2017-11-02 19:38:48.332
Successfully took permissions for file or folder C:\Windows\winsxs\Manifests
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Manifests\amd64_972ba38c73ee4a814d11ece13c14fc1d_31bf3856ad364e35_6.1.7601.23796_none_3e189994e37eab05.manifest to C:\Windows\winsxs\Manifests\amd64_972ba38c73ee4a814d11ece13c14fc1d_31bf3856ad364e35_6.1.7601.23796_none_3e189994e37eab05.manifest.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Manifests\amd64_a5dc2733df943b0216ff277e66cbacbd_31bf3856ad364e35_6.1.7601.23769_none_844f07cd5d4f0240.manifest to C:\Windows\winsxs\Manifests\amd64_a5dc2733df943b0216ff277e66cbacbd_31bf3856ad364e35_6.1.7601.23769_none_844f07cd5d4f0240.manifest.
Successfully copied file C:\Users\Mark\AppData\Local\niemiro\Archive\Manifests\amd64_b6e5b7ffcce70fffd283f3bf30b058e5_31bf3856ad364e35_6.1.7601.23688_none_cf8e0f47ae2a9e80.manifest to C:\Windows\winsxs\Manifests\amd64_b6e5b7ffcce70fffd283f3bf30b058e5_31bf3856ad364e35_6.1.7601.23688_none_cf8e0f47ae2a9e80.manifest.
Successfully restored ownership for C:\Windows\winsxs\Manifests
Successfully restored permissions on C:\Windows\winsxs\Manifests
Currently storing 17 datablocks.
Finish time: 2017-11-02 19:39:03.635
Script hash: 42MU2KhiAG3HgfKE6Gnz5uhf/K9SgkZiH8IGIA7BdvE=
Thank you.
3. Press the Fix button.
Please follow the instructions below, the previous fix didn't work.
Here are the Fixlog.txt and CheckSUR.log files.
Btw, I haven't tried the Windows update the last two times. The SURT app asks if I want to install the Windows hotfix update, which I agree to. At the end of the app, the screen says Installation Complete, but I still see that the Start>Shutdown would try to do an update.
I haven't tried the update, because I don't know if that can cause a problem with the repair process. So, I'll wait until you tell me to try the windows update.
Thank you.
Allow Windows Update to install it and report which update it is and if it was successful.
When I clicked the Shutdown button, even though there was a yellow icon indicating it would install an update, the machine shut down normally, without any indication that it attempted an update. When I turned the machine back on, it started up normally. So, I ran Windows Update and it did not indicate that there were any important updates waiting. So I clicked on the Check for Updates button.
It eventually came back and said there was 1 important update to install, the same one which has been a problem. When it tried to install that update, the update failed with the same error code: 80073701.
The update which won't install is:
2017-10 Security Monthly Quality Rollup for Windows 7 for x64 based Systems (KB4041681)
Thank you
Follow the instructions below.
FRST Registry Search
3. Select the Programs group.
6. Copy and paste KB4019264 into the Search box and click the Search Registry button.
Here is the SearchReg.txt file.
Btw, I searched for KB4019264, but the update which won't install is KB4041681. Just mentioning it to be sure that's the one you wanted to search for.
Thank you
There is a problem with KB4019264, which prevents KB4041681 to install properly.
Here's the Fixlog.txt file. I didn't try the update yet, in case there's more to do.
Looks good. Perform the instructions in message #51 again to verify the cleanup.
The script didn't cleanup everything.
Hi Peter,
When I didn't hear back, I figured I was supposed to try the windows update. It failed again with the same error code.
I ran the sfc /scannow and the CBS.log is much smaller than before, so I'll attach it to this message.
What do you think I should do next?
Again, thank you for all of your help trying to sort out this windows problem.
Best regards,
Mark
Oops.. Sorry, I didn't see your earlier message (#57).
Please disregard message #58. I'll follow the instructions in #57 and then attach the SearchReg.txt file.
Here are the Fixlog.txt and SearchReg.txt files. Again, sorry about any confusion. The forum used to send me an email when a new message posted, but it doesn't seem to do that anymore, so I periodically check for any new messages but must have missed the last one.
Thank you
