[SOLVED] [W7SP1 x64] Won't Update, Error 80073701
Re: Windows 7 Won't Update - Error Code 80073701
For some reason the fix failed again.
Please restart the machine and perform the step in message #57 again.
I restarted the machine and followed the instructions in message 57. When I restarted the machine, I chose Restart rather than Shutdown, because shutdown would have tried to update before shutting down. I hope that was the correct choice.
Here are the Fixlog.txt and SearchReg.txt files.
Thank you
Go to Control Panel - Windows Update - Change settings.
Select Never check for updates (not recommended).
Click OK.
Restart the machine.
Perform the steps in message #57 again.
I changed the windows update setting and followed the steps in message #57.
Here are the fixlog.txt and SeachReg.txt files
3. Press the Fix button.
FRST Registry Search
3. Select the Programs group.
6. Copy and paste KB4019264 into the Search box and click the Search Registry button.
That went well.
5. Please download the Farbar Recovery Scan Tool and save it to your Desktop:
6. Right-click on the file FRST64.exe and choose Run as administrator.
7. Copy and paste KB4019264 into the Search box and click the Search Registry button.
8. When the scan is complete, a message will display that 'SearchReg.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'SearchReg.txt' to your next reply.
It worked!!! It seemed like the update installed completely, but I haven't checked the windows update history, because I didn't want to do anything that might mess something up.
It looked like the update installed successfully, but I figured I should wait until you tell me if there's anything else that needs to be done.
Thank you!!
Great, which other Windows Updates are available ?
I ran Windows Update and had it search for updates. It came back saying there were no new updates and 14 optional ones. None of the optional ones seemed needed, except maybe the service pack for sql server.
Also, we had turned off the automatic windows update feature in this process. Do you think I should re-enable that, or leave it off and manually run windows update periodically?
Thank you
Yes, you can re-enable WU or select Download updates but let me choose whether to install them.
Hi Peter,
Thank you very much for all of your help getting this issue sorted out! I really appreciate it!
Now, I'm off to visit the donation page!
Best regards,
Mark
Your welcome.
You may remove all the tools and logfiles used in this thread to clean up.
Thanks for the donation and all the best.
