DISM returned clean logs. Try to install your Windows Updates again please. If they fail, upload the two files below for me to review.
C:\Windows\WindowsUpdate.log
C:\Windows\Logs\CBS\CBS.log
I have enterd the commands. Must I try to do the updates now?Follow the instructions below please.
SoftwareDistribution - Rename![]()
Follow the instructions below to rename the folders in SoftwareDistribution.
- On Windows Vista & 7, click on the Windows Start Menu, then enter cmd in the search box, right-click on the cmd icon and select
Run as Administrator![]()
- On Windows 8, drag your cursor in the bottom-left corner, and right-click on the metro menu preview, then select Command Prompt (Admin);
- On Windows 8.1, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
- Enter the commands below one at the time (press Enter to send it);
- net stop wuauserv
- ren %SystemRoot%\SoftwareDistribution\Download DL.bak
- ren %SystemRoot%\SoftwareDistribution\DataStore DS.bak
- net start wuauserv
Yes please. If they fail, upload the following files again for me to review.
The choice is yours RORUI. If you want to perform a clean install, you can go for it. If you want to keep on troubleshooting the issue, you can as well. The clean install might get you back up and running faster due to the response delay, but it's up to you.
If you did a clean install, we'll need to make sure that the SFC and DISM scans still returns clean logs :) So let's start with SFC first.
System File Checker (SFC)![]()
- Enter the command below and press on Enter;
Note: There's a space between "sfc" and "/scannow";Code:sfc /scannow
- Once the scan is complete, enter the command below and press on Enter
Code:copy %windir%\logs\cbs\cbs.log "%userprofile%\Desktop\cbs.txt"
- A file called cbs.txt will have appeared on your Desktop. Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
