[SOLVED] Win10 update problems / Start menu and Right click not working / SFC and DISM fail
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-06 15:45:21.601
Microsoft Windows 10 Build 17134 - amd64
Using .zip script file at C:\Users\Eric\Desktop\SFCFix (1).zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-e..-protocol-host-peer_31bf3856ad364e35_10.0.17134.1_none_499417842c948e55\eappgnui.dll
Currently storing 91 datablocks.
Finish time: 2018-08-06 15:45:22.391
Script hash: qPyx4op/rI6QvXxZwGgBqnRFCSqcFru3nOrA7RdBayY=
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-06 17:15:20.091
Using .zip script file at C:\Users\Eric\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-e..ageengine-utilities_31bf3856ad364e35_10.0.17134.1_none_bf0c79552e6b8717\esentutl.exe
Currently storing 92 datablocks.
Finish time: 2018-08-06 17:15:21.270
Script hash: 7E2L4VRRPHuWgl8kcgQX7J/jG+cysX4af48uepBrsLc=
Scan ends at 26%
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-06 17:41:49.200
Using .zip script file at C:\Users\Eric\Desktop\SFCFix (1).zip [1]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-exfat_31bf3856ad364e35_10.0.17134.1_none_3ae76b6b8255f93e\exfat.sys
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-exfat_31bf3856ad364e35_10.0.17134.1_none_3ae76b6b8255f93e\exfat.sys to C:\WINDOWS\winsxs\amd64_microsoft-windows-exfat_31bf3856ad364e35_10.0.17134.1_none_3ae76b6b8255f93e\exfat.sys.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-exfat_31bf3856ad364e35_10.0.17134.1_none_3ae76b6b8255f93e\exfat.sys
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-exfat_31bf3856ad364e35_10.0.17134.1_none_3ae76b6b8255f93e\exfat.sys
Currently storing 93 datablocks.
Finish time: 2018-08-06 17:41:49.646
Script hash: Saxl1oZ1oJLlLRqw82Rv672JMsjAT5sF3hPcLTf4Fv0=
Sorry what do u mean by tested the HDD ?
i did not make any DISM scan.
Just made a Win10 repair install from the iso file directly inside Win10 ... had an install failure after 60% completed.
Let me know if this completes successfully.
Step 1 - DISM Scan
    Dism /Online /Get-Drivers
  8. Copy (Ctrl+C) and Paste (Ctrl+V) the contents of this file into your next post for me to analyse please - put
Afterwards, run DISM again and attach CBS.log if there's an error.
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-15 22:09:35.411
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-base-util-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-com-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-comm-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-console-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-delayload-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-handle-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-heap-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Heap-Obsolete-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-interlocked-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-localization-obsolete-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-2.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-namedpipe-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-2.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processtopology-obsolete-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-profile-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-realtime-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-rtlsupport-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-legacy-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-obsolete-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shutdown-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-string-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-l2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-obsolete-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-stringansi-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-stringloader-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-l1-2-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-legacy-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-private-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-timezone-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-url-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-util-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-version-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-wow64-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-xstate-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-xstate-l2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-conio-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-convert-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-environment-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-filesystem-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-heap-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-locale-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-math-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-multibyte-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-private-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-process-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-runtime-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-stdio-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-string-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-time-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-utility-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-ClassicProvider-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-eventing-consumer-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Controller-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Legacy-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Provider-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-EventLog-Legacy-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-base-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-cryptoapi-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-security-lsapolicy-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-security-provider-L1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-sddl-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l2-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-1.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-winsvc-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-shcore-stream-l1-1-0.dll
Successfully took permissions for file or folder C:\WINDOWS\system32\downlevel\ucrtbase.dll
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-base-util-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-base-util-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-com-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-com-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-comm-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-comm-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-console-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-console-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-datetime-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-datetime-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-debug-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-debug-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-delayload-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-delayload-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-errorhandling-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-errorhandling-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-fibers-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-fibers-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-file-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-file-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-file-l1-2-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-file-l2-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-file-l2-1-1.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-handle-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-handle-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-heap-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-heap-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Core-Heap-Obsolete-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Heap-Obsolete-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-interlocked-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-interlocked-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-io-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-io-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-kernel32-legacy-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-kernel32-legacy-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-1.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-libraryloader-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-libraryloader-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-localization-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-localization-l1-2-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-localization-obsolete-l1-2-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-localization-obsolete-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-memory-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-memory-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-memory-l1-1-2.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-2.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-namedpipe-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-namedpipe-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-privateprofile-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-privateprofile-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processenvironment-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processenvironment-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processthreads-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processthreads-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processthreads-l1-1-2.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-2.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-processtopology-obsolete-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-processtopology-obsolete-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-profile-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-profile-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-realtime-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-realtime-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-registry-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-registry-l2-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-rtlsupport-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-rtlsupport-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-shlwapi-legacy-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-legacy-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-shlwapi-obsolete-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-obsolete-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-shutdown-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-shutdown-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-string-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-string-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-string-l2-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-l2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-string-obsolete-l1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-obsolete-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-stringansi-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-stringansi-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-stringloader-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-stringloader-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-synch-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-synch-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-sysinfo-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-sysinfo-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-sysinfo-l1-2-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-threadpool-l1-2-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-l1-2-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-threadpool-legacy-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-legacy-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-threadpool-private-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-private-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-timezone-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-timezone-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-url-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-url-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-util-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-util-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-version-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-version-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-wow64-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-wow64-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-core-xstate-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-core-xstate-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-core-xstate-l2-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-core-xstate-l2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-conio-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-conio-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-convert-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-convert-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-environment-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-environment-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-filesystem-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-filesystem-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-heap-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-heap-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-locale-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-locale-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-math-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-math-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-multibyte-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-multibyte-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-private-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-private-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-process-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-process-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-runtime-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-runtime-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-stdio-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-stdio-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-string-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-string-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-time-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-time-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-crt-utility-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-crt-utility-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-devices-config-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-devices-config-L1-1-1.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Eventing-ClassicProvider-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-ClassicProvider-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-eventing-consumer-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-eventing-consumer-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Eventing-Controller-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Controller-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Eventing-Legacy-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Legacy-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Eventing-Provider-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Provider-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-EventLog-Legacy-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-EventLog-Legacy-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-security-base-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-security-base-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-security-cryptoapi-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-security-cryptoapi-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Security-Lsalookup-L2-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-Security-Lsalookup-L2-1-1.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-security-lsapolicy-l1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-security-lsapolicy-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\API-MS-Win-security-provider-L1-1-0.dll to C:\WINDOWS\system32\downlevel\API-MS-Win-security-provider-L1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-security-sddl-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-security-sddl-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-core-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-core-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-management-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-management-l2-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l2-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-private-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-private-l1-1-1.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-1.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-service-winsvc-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-service-winsvc-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\api-ms-win-shcore-stream-l1-1-0.dll to C:\WINDOWS\system32\downlevel\api-ms-win-shcore-stream-l1-1-0.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\downlevel\ucrtbase.dll to C:\WINDOWS\system32\downlevel\ucrtbase.dll.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-base-util-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-com-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-comm-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-console-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-datetime-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-debug-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-delayload-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-errorhandling-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-fibers-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-file-l1-2-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-file-l2-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-handle-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-heap-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Heap-Obsolete-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-interlocked-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-io-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-kernel32-legacy-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Core-Kernel32-Private-L1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-libraryloader-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-localization-l1-2-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-localization-obsolete-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-memory-l1-1-2.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-namedpipe-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-privateprofile-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processenvironment-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processthreads-l1-1-2.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-processtopology-obsolete-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-profile-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-realtime-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-registry-l2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-rtlsupport-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-legacy-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shlwapi-obsolete-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-shutdown-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-string-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-l2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-string-obsolete-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-stringansi-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-stringloader-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-synch-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-sysinfo-l1-2-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-l1-2-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-legacy-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-threadpool-private-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-timezone-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-url-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-util-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-version-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-wow64-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-core-xstate-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-core-xstate-l2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-conio-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-convert-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-environment-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-filesystem-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-heap-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-locale-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-math-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-multibyte-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-private-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-process-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-runtime-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-stdio-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-string-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-time-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-crt-utility-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-devices-config-L1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-ClassicProvider-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-eventing-consumer-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Controller-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Legacy-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Eventing-Provider-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-EventLog-Legacy-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-base-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-cryptoapi-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-Security-Lsalookup-L2-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-security-lsapolicy-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\API-MS-Win-security-provider-L1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-security-sddl-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-core-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-management-l2-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-private-l1-1-1.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-service-winsvc-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\api-ms-win-shcore-stream-l1-1-0.dll. Error code ERROR_ACCESS_DENIED.
Failure code returned from icacls process in RestoreFromDataBlock function for file or folder C:\WINDOWS\system32\downlevel\ucrtbase.dll. Error code ERROR_ACCESS_DENIED.
PowerCopy:: directive failed to complete successfully.
Currently storing 205 datablocks.
Finish time: 2018-08-15 22:12:01.754
Script hash: 0jc74Bzfg12kmK4rBPNH4Z3nAtOEUGwT0jOpLvlRjDk=
Here is the cbs.log
Dism /Online /Get-Drivers : gives error code 193.
