[SOLVED] Win10 update problems / Start menu and Right click not working / SFC and DISM fail
Can you please create a new user account, name it Test, give it Admin privileges and log onto the account and try running DISM again? Let me know if the error 193 comes up.
Hello !
here it is
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-16 22:46:51.903
Microsoft Windows 10 Build 17134 - amd64
Using .zip script file at C:\Users\Eric\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\FileHistory.exe.mui
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\FileHistory.exe.mui to C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\FileHistory.exe.mui.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\fhuxpresentation.Resources.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\FileHistory.exe.mui
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-f..istory-ui.resources_31bf3856ad364e35_10.0.17134.1_fr-fr_900af99666310aaf\FileHistory.exe.mui
Currently storing 207 datablocks.
Finish time: 2018-08-16 22:46:57.544
Script hash: 5zdbdoKcpFiUctvHuGzna0JoYs8ixXPdq16NgV5Rz1E=
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-17 10:24:28.307
Using .zip script file at C:\Users\Eric\Desktop\SFCFix (1).zip [0]
Successfully created directory tree \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.16299.15_none_543a6e9aaf8e3b44.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.16299.15_none_543a6e9aaf8e3b44\ebrimabd.ttf to C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.16299.15_none_543a6e9aaf8e3b44\ebrimabd.ttf.
Currently storing 208 datablocks.
Finish time: 2018-08-17 10:24:36.885
Script hash: NRxeBgSi9BVZfzUQ3/9WzSCKQ+2z/6AJYkBQACVuSQg=
Step#1 - FRST Fix
Done with FRST. Here is the log.
Résultats de correction de Farbar Recovery Scan Tool (x64) Version: 02.08.2018Exécuté par Eric (17-08-2018 23:59:16) Run:1
Exécuté depuis C:\Users\Eric\Desktop
Profils chargés: Eric (Profils disponibles: Eric & Test & MSSQL$SQLEXPRESS & DefaultAppPool)
Mode d'amorçage: Normal
fixlist contenu:
CreateRestorePoint:
Le Point de restauration a été créé avec succès.
"C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.16299.15_none_543a6e9aaf8e3b44" => non trouvé(e)
==== Fin de Fixlog 00:01:20 ====
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-18 00:22:15.929
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf to C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-f..truetype-ebrimabold_31bf3856ad364e35_10.0.17134.1_none_16ceceffa7942e04\ebrimabd.ttf
Currently storing 210 datablocks.
Finish time: 2018-08-18 00:30:18.510
Script hash: 2myJQHjbytt/OnAdMIPlkhQd+KQqbyG3tZLeBHHcPD4=
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-18 00:54:41.128
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmlib.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\dciman32.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontdrvhost.exe
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontsub.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\lpk.dll
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmlib.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmlib.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\dciman32.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\dciman32.dll.
The file \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontdrvhost.exe is in use and must be replaced over a reboot.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontsub.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontsub.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\lpk.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\lpk.dll.
Successfully pended file for replace over reboot: \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontdrvhost.exe
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmfd.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmlib.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\atmlib.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\dciman32.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\dciman32.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontsub.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontsub.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\lpk.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\lpk.dll
Reboot:: directive completed successfully.
PostRebootCorruptionDetection::
No hash verification failures detected.
PostRebootCorruptionDetection:: directive completed successfully.
PostRebootRestorePermissions::
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontdrvhost.exe
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-gdi_31bf3856ad364e35_10.0.17134.1_none_8f53a4cfc3b0c336\fontdrvhost.exe
PostRebootRestorePermissions:: directive completed successfully.
Currently storing 216 datablocks.
Finish time: 2018-08-18 01:01:37.806
scan ends at 29%
Hello !
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-21 21:27:40.641
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1250.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1251.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1253.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1254.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1255.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1256.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1257.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1258.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20000.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20001.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20002.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20003.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20004.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20005.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20127.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20261.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20866.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20932.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20936.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20949.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_21866.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28591.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28592.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28593.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28594.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28595.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28596.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28597.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28598.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28599.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_28603.nls
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28605.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_65001.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_708.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_720.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_737.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_775.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_850.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_852.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_855.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_857.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_858.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_860.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_861.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_862.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_863.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_864.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_865.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_866.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_869.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_874.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_932.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_936.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_949.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_950.NLS
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_G18030.DLL
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_GSM7.DLL
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_IS2022.DLL
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1250.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1250.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1251.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1251.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1253.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1253.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1254.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1254.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1255.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1255.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1256.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1256.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1257.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1257.NLS with error code 0x4C8.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1258.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1258.NLS.
Failed to backup file C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS with error code 0x1160.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20000.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20000.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20001.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20001.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20002.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20002.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20003.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20003.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20004.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20004.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20005.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20005.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20127.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20127.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20261.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20261.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20866.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20866.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20932.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20932.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20936.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20936.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20949.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20949.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_21866.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_21866.NLS.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28591.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28591.NLS with error code 0x4C8.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28592.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28592.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28593.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28593.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28594.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28594.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28595.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28595.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28596.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28596.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28597.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28597.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28598.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28598.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28599.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28599.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_28603.nls to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_28603.nls.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28605.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28605.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_65001.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_65001.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_708.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_708.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_720.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_720.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_737.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_737.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_775.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_775.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_850.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_850.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_852.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_852.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_855.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_855.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_857.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_857.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_858.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_858.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_860.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_860.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_861.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_861.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_862.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_862.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_863.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_863.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_864.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_864.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_865.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_865.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_866.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_866.NLS.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_869.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_869.NLS.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_874.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_874.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_932.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_932.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_936.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_936.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_949.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_949.NLS with error code 0x4C8.
Failed to copy file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_950.NLS to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_950.NLS with error code 0x4C8.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_G18030.DLL to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_G18030.DLL.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_GSM7.DLL to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_GSM7.DLL.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_IS2022.DLL to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_IS2022.DLL.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1250.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1250.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1251.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1251.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1253.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1253.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1254.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1254.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1255.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1255.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1256.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1256.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1257.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1257.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1258.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1258.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_1361.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20000.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20000.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20001.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20001.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20002.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20002.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20003.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20003.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20004.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20004.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20005.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20005.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20127.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20127.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20261.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20261.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20866.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20866.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20932.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20932.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20936.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20936.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20949.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_20949.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_21866.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_21866.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28591.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28591.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28592.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28592.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28593.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28593.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28594.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28594.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28595.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28595.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28596.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28596.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28597.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28597.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28598.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28598.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28599.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28599.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_28603.nls
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_28603.nls
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28605.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_28605.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_65001.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_65001.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_708.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_708.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_720.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_720.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_737.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_737.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_775.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_775.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_850.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_850.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_852.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_852.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_855.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_855.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_857.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_857.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_858.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_858.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_860.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_860.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_861.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_861.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_862.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_862.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_863.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_863.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_864.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_864.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_865.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_865.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_866.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_866.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_869.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_869.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_874.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_874.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_932.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_932.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_936.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_936.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_949.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_949.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_950.NLS
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_950.NLS
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_G18030.DLL
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_G18030.DLL
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_GSM7.DLL
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\c_GSM7.DLL
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_IS2022.DLL
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ional-codepage-core_31bf3856ad364e35_10.0.17134.1_none_1c55515b6650ea1f\C_IS2022.DLL
PowerCopy:: directive failed to complete successfully.
Currently storing 275 datablocks.
Finish time: 2018-08-21 21:28:34.225
Script hash: vATsqv7i0XX8GVmy7l5v31aADNOHEqIXDHQe8h7G5bw=
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-22 22:40:35.287
Microsoft Windows 10 Build 17134 - amd64
Using .zip script file at C:\Users\Eric\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ahadmin.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.exe
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.xml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\applicationHost.config
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appobj.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ASPNET_schema.xml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\cngkeyhelper.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\FX_schema.xml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisres.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisRtl.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissetup.exe
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissyspr.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisutil.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\IIS_schema.xml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\nativerd.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\redirection.config
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rsca.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.dll
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.xml
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\w3ctrlps.dll
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ahadmin.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ahadmin.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.exe.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.xml.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\applicationHost.config to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\applicationHost.config.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appobj.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appobj.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ASPNET_schema.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ASPNET_schema.xml.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\cngkeyhelper.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\cngkeyhelper.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\FX_schema.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\FX_schema.xml.
The file \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisres.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisRtl.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisRtl.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissetup.exe to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissetup.exe.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissyspr.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissyspr.dll.
The file \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisutil.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\IIS_schema.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\IIS_schema.xml.
The file \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\nativerd.dll is in use and must be replaced over a reboot.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\redirection.config to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\redirection.config.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rsca.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rsca.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.dll.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.xml to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.xml.
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\w3ctrlps.dll to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\w3ctrlps.dll.
Successfully pended file for replace over reboot: \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisres.dll
Successfully pended file for replace over reboot: \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisutil.dll
Successfully pended file for replace over reboot: \\?\C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\nativerd.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ahadmin.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ahadmin.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.exe
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.exe
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.xml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appcmd.xml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\applicationHost.config
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\applicationHost.config
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appobj.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\appobj.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ASPNET_schema.xml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\ASPNET_schema.xml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\cngkeyhelper.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\cngkeyhelper.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\FX_schema.xml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\FX_schema.xml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisRtl.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisRtl.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissetup.exe
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissetup.exe
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissyspr.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iissyspr.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\IIS_schema.xml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\IIS_schema.xml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\redirection.config
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\redirection.config
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rsca.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rsca.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.xml
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\rscaext.xml
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\w3ctrlps.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\w3ctrlps.dll
Reboot:: directive completed successfully.
PostRebootCorruptionDetection::
No hash verification failures detected.
PostRebootCorruptionDetection:: directive completed successfully.
PostRebootRestorePermissions::
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisres.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisres.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisutil.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\iisutil.dll
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\nativerd.dll
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..raries-servercommon_31bf3856ad364e35_10.0.17134.1_none_8f0c17e6d938fd6f\nativerd.dll
PostRebootRestorePermissions:: directive completed successfully.
Currently storing 295 datablocks.
Finish time: 2018-08-22 23:17:10.035
SFCFix version 3.0.0.0 by niemiro.Start time: 2018-08-22 23:55:36.955
Successfully took permissions for file or folder C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ntrolpanel.appxmain_31bf3856ad364e35_10.0.17134.112_none_fc85c821ed04e36b\MemMDL2.2.2.ttf
Successfully copied file C:\Users\Eric\AppData\Local\niemiro\Archive\winsxs\amd64_microsoft-windows-i..ntrolpanel.appxmain_31bf3856ad364e35_10.0.17134.112_none_fc85c821ed04e36b\MemMDL2.2.2.ttf to C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ntrolpanel.appxmain_31bf3856ad364e35_10.0.17134.112_none_fc85c821ed04e36b\MemMDL2.2.2.ttf.
Successfully restored ownership for C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ntrolpanel.appxmain_31bf3856ad364e35_10.0.17134.112_none_fc85c821ed04e36b\MemMDL2.2.2.ttf
Successfully restored permissions on C:\WINDOWS\winsxs\amd64_microsoft-windows-i..ntrolpanel.appxmain_31bf3856ad364e35_10.0.17134.112_none_fc85c821ed04e36b\MemMDL2.2.2.ttf
Currently storing 296 datablocks.
Finish time: 2018-08-22 23:55:38.353
Script hash: ZiQXmHmQn+fTBwWZPXCz7k9gXzXv2YNuwlG7XdzszLM=
