[SOLVED] [Win7SP1Pro x64] Missing Packages Related to KB3123862 & KB3035583
Done. Looks like it wants the manifest for that component as well now.
EDIT: I forgot to attach the SFCFix log, however it shows everything completed successfully.
Please do the following.
Step#1 - SFCFix Script
Step#2 - System Update Readiness Tool (SUR)
Donedy. Here's the logs. Re-running CheckSUR one more time and will attempt to install update afterwards. I'll update on that progress once completed.
SFCFix
CheckSUR
Still no go Joe. Here's the latest CBS. Same drill, different file again.
2017-03-16 17:05:54, Error                 CSI    000001c3@2017/3/16:22:05:54.022 (F) d:\win7sp1_gdr\base\wcp\componentstore\storelayout.cpp(11690): Store corruption detected in function ComponentStore::CRawStoreLayout::CheckFamilyIndexForDeadWinnerComponent expression: (null)
  MissingWinningComponentKey on resource [97]"x86_microsoft-windows-authentication-authui_31bf3856ad364e35_6.1.7601.19135_none_0de6124c53b98ae1"[gle=0x80004005]
Just out of curiousity, how do you go about finding the registry values you've been giving me? I'm not finding any way to cross reference it, at least not the CanonicalData portions. Curious as to the method for getting those entries.
It's not easy at all. If I don't have the key in one of my own VMs, I need to identify the update that this component is in and then install it on one of my VMs to create they keys. Tedious. Let's take a different approach. Please do the following.
Install Update with DISM
  1. Download this update and save to your desktop. The file name will be Windows6.1-KB3123862-x64.cab.zip.
  2. Right-click on this file and select Extract All... Keep the defaults and click the Extract button. You can close the folder window that opens.
  3. Right-click your Start button and select Command Prompt (Admin). If a user account control prompt comes up, please allow.
  4. Copy and paste the following command into the command prompt window and press enter.
    dism /online /add-package /packagepath:%userprofile%\desktop\Windows6.1-KB3123862-x64.cab\Windows6.1-KB3123862-x64.cab
  5. You should receive the message:
    Restart Windows to complete this operation. <---You may not get this line.
    Do you want to restart the computer now (Y/N)? <---You may not get this line.
Go ahead and do so if prompted. Let me know what errors if any come up.
Well, from one tech to another, I know exactly what you mean and I appreciate it.
That said, I went through the manual install above and still got an error. I've attached the dism/cbs logs, it appears it has something to do with one of the packages of the update.
OK, do the following then.
Uninstall Update with DISM
  1. Download this update and save to your desktop. The file name will be Windows6.1-KB3123862-x64.cab.zip. Note: You can use the previous one you downloaded if you still have it.
    dism /online /remove-package /packagepath:%userprofile%\desktop\Windows6.1-KB3123862-x64.cab\Windows6.1-KB3123862-x64.cab
OK, attempt to install the Windows Update that you were originally trying to do. Just let me know what the KB number is that you are trying to install.
Provide the CBS.log when it fails.
OK, let's go a little further. Please do the following.
Step#3 - Attempt update
1. Attempt install of KB4012215 and provide the CBS.log if it fails.
Finished off step 1. Here's the SFCFix log. It errored on one of the file copy operations.
Just finished doing so. Believe it or not the update finally took (yay!). CheckSUR still has a couple of errors though so here's the latest logfiles.
Yep, here's the post-update log.
