[SOLVED] [Win7SP1Pro x64] Missing Packages Related to KB3123862 & KB3035583
Please do the following.
Step#1 - FRST Fix
Step#2 - SFCFix Script
Step#3 - System Update Readiness Tool (SUR)
Done. The SFCFix process errored out with permissions issues. As a result, re-running CheckSUR produces the same long as before.
FarBar Log
SFCFix Log
CheckSUR
I hope this will work.
Step#1 - SFCFix Script
Step#2 - System Update Readiness Tool (SUR) --ONLY DO IF PREVIOUS STEP IS SUCCESSFUL--
Well, hope received because it worked. No errors in the SFCFix log and the CheckSUR log came back clean. I think we finally did it.
Nope, I think we're good, just tried a couple more updates to be sure and they took without issue. Thanks so much for the help and patience. Really helped me out. Cheers.
