[SOLVED] [Win7SP1Ult X64] WU ERROR_NOT_FOUND (0X80070490) (Element not found)
Though I have tried this earlier and was unsuccessful with SP1, as you've suggested let me try once again. I will keep you posted.
Hi, the size came up to 16mb, after zipping and couldn't upload as an attachment. Any alternate way to share here? Please advise.
2017-06-06 22:56:46, Error                 CBS    Failed to resolve package 'Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.1.0' [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
Please do the following.
Remove Update Manually
wusa /uninstall /KB:977165
Just to confirm you got a message similar to the following and answered Yes to uninstall?
13005d1433597754-failed-install-kb3061904-kb3049563-wusa-jpg
Good. OK, please boot your computer into a Clean Boot state using the instructions in the following article. (You may still be in a clean boot state which is great and if that's the case you don't have to do it again)
https://support.microsoft.com/en-us/...oot-in-windows
Once in a clean boot, go ahead and attempt the SP1 upgrade again. If it fails, please zip up and attach the following two files.
c:\windows\logs\cbs <---entire folder
C:\WINDOWS\INF\setupapi.dev.log
Well, when we attempted to install this security update, it prompted with the message "The update is not applicable to your computer" and not an option to proceed.
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
KB977165 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please copy and paste the contents in your next reply. If for some reason notepad doesn't open the file should be
saved on your desktop named Search.txt.
Hi, ran the 32 bit version, since mine is a 32-Bit and here is the log. Please let me know with your findings.
Thanks.
Farbar Recovery Scan Tool (x86) Version: 12-06-2017
Ran by DR (13-06-2017 14:18:39)
Running from C:\Users\xxxx\Downloads
Boot Mode: Normal
================== Search Registry: "KB977165" ===========
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\186a3b50cab..898164d7eb2_31bf3856ad364e35_6.1.7600.16481_ff1c4ae7b5a097cf]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_b216274fe702de73"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D385F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_b216274fe702de73"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D385F6E65757472616C5F47445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_93d87a7aeb0da362"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D385F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_93d87a7aeb0da362"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D385F6E65757472616C5F47445232"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\1922733cda7..1a48609921b_31bf3856ad364e35_6.1.7600.20591_7aab541493daaae4]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_0606716f691a6e5f"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D395F6E65757472616C5F4C445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_e7c8c49a6d25334e"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D395F6E65757472616C5F4C445232"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\344c8bf5634..01edcc8f759_31bf3856ad364e35_6.1.7600.20591_6dfbdaffa17e5a54]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_b645464060bc2dfb"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D355F6E65757472616C5F4C445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_9807996b64c6f2ea"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D355F6E65757472616C5F4C445232"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\3b62895240e..953a1c747fb_31bf3856ad364e35_6.1.7600.16481_4cc1e1bae09e3a35]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_0a359324e2d3be41"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D365F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_0a359324e2d3be41"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D365F6E65757472616C5F47445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_ebf7e64fe6de8330"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D365F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_ebf7e64fe6de8330"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D365F6E65757472616C5F47445232"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\a53281fb1b9..c6624262557_31bf3856ad364e35_6.1.7600.20591_7e385fb5040d8bd8]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_5e25dd4464eb4e2d"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D375F6E65757472616C5F4C445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_3fe8306f68f6131c"="0x49000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D375F6E65757472616C5F4C445232"
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\f7beb164ed6..dad66ce62d9_31bf3856ad364e35_6.1.7600.16481_0f2b2670ed3e4cf4]
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_096376fa481c681e"="0x4A000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D31305F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.1.0.977165-_096376fa481c681e"="0x4A000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E312E302E3937373136352D31305F6E65757472616C5F47445232"
"p!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_eb59ed1a0bb1deef"="0x4A000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D31305F6E65757472616C5F47445232"
"i!CBS_package_2_for_kb977165~31bf3856ad364e35~x86~~6.1.2.0.977165-_eb59ed1a0bb1deef"="0x4A000000010000005061636B6167655F325F666F725F4B423937373136357E333162663338353661643336346533357E7838367E7E362E312E322E302E3937373136352D31305F6E65757472616C5F47445232"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB977165~31bf3856ad364e35~x86~~6.1.1.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-a..ence-infrastructure_31bf3856ad364e35_0.0.0.0_none_f8eaf96b94e412f9]
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-9_neutral_LDR"="6.1.7600.20591@2"
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-10_neutral_GDR"="6.1.7600.16481@2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-kernel32_31bf3856ad364e35_0.0.0.0_none_b797daee9e75c4e4]
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-7_neutral_LDR"="6.1.7600.20591@2"
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-8_neutral_GDR"="6.1.7600.16481@2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-os-kernel_31bf3856ad364e35_0.0.0.0_none_900a574dfc4d4e9e]
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-5_neutral_LDR"="6.1.7600.20591@2"
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.977165-6_neutral_GDR"="6.1.7600.16481@2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Foundation-Package~31bf3856ad364e35~x86~~0.0.0.0]
"Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="2"
"Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0"="2"
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="2"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-WinPE-Package~31bf3856ad364e35~x86~~0.0.0.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_2_for_KB977165~31bf3856ad364e35~x86~~0.0.0.0]
"Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB977165_RTM~31bf3856ad364e35~x86~~0.0.0.0]
"Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0"="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB977165~31bf3856ad364e35~x86~~0.0.0.0]
"Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="0"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0]
"InstallName"="Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0.mum"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_2_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0\Owners]
"Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0"="196720"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0]
"InstallName"="Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0.mum"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB977165_RTM~31bf3856ad364e35~x86~~6.1.2.0\Owners]
"Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="196720"
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0]
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0\Owners]
"Package_for_KB977165~31bf3856ad364e35~x86~~6.1.2.0"="131184"
====== End of Search ======
