[SOLVED] [7SP1 x64] KB4074598 Fails with Error 0x80004005
Re: Windows 7 SP1 (KB4074598) Fails with Error 0x80004005
Summary:
Seconds executed: 146
Found 10 errors
CSI C Mark Deployment Missing Total count: 3
CBS MUM Corrupt Total count: 2
CBS Catalog Corrupt Total count: 2
CSI Missing Winning Component Key Total count: 3
Unavailable repair files:
servicing\packages\Package_79_for_KB3172605~31bf3856ad364e35~amd64~~6.1.1.2.mum
servicing\packages\Package_80_for_KB3172605~31bf3856ad364e35~amd64~~6.1.1.2.mum
servicing\packages\Package_79_for_KB3172605~31bf3856ad364e35~amd64~~6.1.1.2.cat
servicing\packages\Package_80_for_KB3172605~31bf3856ad364e35~amd64~~6.1.1.2.cat
I keep getting this; windowsupdate.log; is there another log on the computer that goes into more detail about the errors?
2018-03-02 01:44:12:651 344 1140 Handler Post-reboot status for package Package_for_RollupFix~31bf3856ad364e35~amd64~~7601.24055.1.3: 0x80004005.
2018-03-02 01:44:12:651 344 1140 Handler WARNING: Got extended error: "Generic Command ErrorCode 80004005 Executable netsh.exe ExitCode 1 Phase 24 Mode Uninstall (upgrade) Component Microsoft-Windows-PeerDist, Culture=neutral, PublicKeyToken=31bf3856ad364e35, ProcessorArchitecture=amd64, versionScope=NonSxS"
what does this mean? "ErrorCode 80004005 Executable netsh.exe ExitCode 1 Phase 24"
and "Mode Uninstall (upgrade) Component Microsoft-Windows-PeerDist, Culture=neutral, PublicKeyToken=31bf3856ad364e35, ProcessorArchitecture=amd64, versionScope=NonSxS"?
is it microsoft-wnidows-peerdist that is the culprit here? or netsh?
Yup, this component is the root cause, but this is a very rare error I have not seen before.
Let's do some more scans:
Open CMD as admin and enter the following:
Dism /Online /Cleanup-Image /ScanHealth
Let me know the result and attach CBS.log and dism.log.
By the way, are you interested in upgrading to Windows 10?
is there any way for me to get independent updates rather than doing all of them, so i can skip the one update giving me problems? I'm not a big fan of windows 10 for the huge push Microsoft used upon their users against their will; the built in telemetry and the terrible mobile like interface they plastered over top of all the panels and settings everywhere; if there is a way to disable that, i might consider migrating in the future. i think its been around long enough now that many issues with it have been ironed out. I know how to disable the telemetry and crap; there are a few great programs out there like o&o's shutup 10, blackbird, and a hand full of others that do a good job tightening it up; here they are.
I notice its giving the same code as the windows update error "0x80004005" is this related?
2018-03-02 02:43:54, Info CBS Starting the TrustedInstaller main loop.
2018-03-02 02:43:54, Info CBS TrustedInstaller service starts successfully.
2018-03-02 02:43:54, Info CBS SQM: Initializing online with Windows opt-in: False
2018-03-02 02:43:54, Info CBS SQM: Cleaning up report files older than 10 days.
2018-03-02 02:43:54, Info CBS SQM: Requesting upload of all unsent reports.
2018-03-02 02:43:54, Info CBS SQM: Failed to start upload with file pattern: C:\Windows\servicing\sqm\*_std.sqm, flags: 0x2 [HRESULT = 0x80004005 - E_FAIL]
2018-03-02 02:43:54, Info CBS SQM: Failed to start standard sample upload. [HRESULT = 0x80004005 - E_FAIL]
2018-03-02 02:43:54, Info CBS SQM: Queued 0 file(s) for upload with pattern: C:\Windows\servicing\sqm\*_all.sqm, flags: 0x6
2018-03-02 02:43:54, Info CBS SQM: Warning: Failed to upload all unsent reports. [HRESULT = 0x80004005 - E_FAIL]
2018-03-02 02:43:54, Info CBS No startup processing required, TrustedInstaller service was not set as autostart, or else a reboot is still pending.
2018-03-02 02:43:54, Info CBS NonStart: Checking to ensure startup processing was not required.
I;'m thinking ill force trusted installer to force start via the registry after installing the update, just prior to reboot; setting it to automatic or system, or boot.... this way it will load with the kernel during the boot process.
Forcing trusted installer to 0 (boot) and 1 (system) doesn't allow the updates to configure; Some sources suggest it could be "The TrustedInstaller service was set to manual using Group Policy (GPO), which prevented him to start to complete pending operations.
The TrustedInstaller service changes the default service startup type of Manual (3) to Automatic (2), when it encounters an update that has to process a transaction after a restart. When the value is set back to Manual before the restart the transaction that has to be applied after restart cannot be applied. This transaction will be pended. It will block all other update installations that might come....etc"
Well i was playing around with group policy and changing its settings quite vigorously so ill see if i can find that setting.
I ran the windows update trouble shooter: https://support.microsoft.com/en-us/help/10164/fix-windows-update-errors
Results:
Service Registration is missing or corrupt: Fixed
Windows Update Error 0x80070005(2018-03-02-T-03_52_02A) (FIXED)
Repaired: Problems installing recent updates: fixed
Repaired windows update services and dependencies
Resetting Windows Update data store completed: DataStoreAndWULogFiles.zip
Potential issues that were checked Installing Recent updates FIXED: CheckSURLog.cab
Will attempt update
Files attached:
What I don't understand is why trusted installer is trying to upload "unsent reports" during the configuration stage of the update; it fails to start an upload so it shuts down.
2018-03-02 02:43:54, Info CBS Ending TrustedInstaller initialization.
2018-03-02 02:43:54, Info CSI 00000004 IAdvancedInstallerAwareStore_ResolvePendingTransactions (call 1) (flags = 00000004, progress = NULL, phase = 0, pdwDisposition = @0x111f6b0
2018-03-02 02:43:54, Info CSI 00000005 Creating NT transaction (seq 1), objectname [6]"(null)"
2018-03-02 02:43:54, Info CSI 00000006 Created NT transaction (seq 1) result 0x00000000, handle @0x200
2018-03-02 02:43:54, Info CSI 00000007@2018/3/2:09:43:54.041 CSI perf trace:
CSIPERF:TXCOMMIT;200
2018-03-02 02:43:54, Info CBS NonStart: Success, startup processing not required as expected.
2018-03-02 02:43:54, Info CBS Startup processing thread terminated normally
2018-03-02 02:43:54, Info CSI 00000008 CSI Store 5485296 (0x000000000053b2f0) initialized
2018-03-02 02:43:54, Info CBS Session: 30650890_4197273720 initialized by client DISM Package Manager Provider.
2018-03-02 02:44:14, Info CBS Archived backup log: C:\Windows\Logs\CBS\CbsPersist_20180302094353.cab.
Intel raid drivers have been installed on this computer, even though its not running raid; i removed them and will switch on from IDE to AHCI and see if that has any effect.
