[SOLVED] [7SP1 x64] Monthly Quality Rollup failures - KB4041681, KB4054518, and KB4056894
Salut -
I've attached poqexec.zip for your review.
Remote Access Connection Manager has a startup type of Manual. Its Property window shows it is stopped.
Routing and Remote Access has a startup type of Automatic. Its Property window shows it is stopped.
I didn't stop either of these services - this is how I found them when checking services.msc.
I don't know if those services are related to Remote Desktop Connection, but please note that I use RDC to view the desktop of the XP system in the HP 5710 thinclient (for VoIP) from time to time - I don't have enough room on my desk for another monitor, keyboard, and mouse. I've been using RDC to access the thinclient this way for years.
1. Click your start button and type cmd in the search box.
2. Right-click on cmd that comes up in the search results and select Run as administrator. Answer Yes to the UAC prompt if it appears.
3. Copy/Paste the following into the command-prompt window and hit enter.
reg query HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318} /s >1.txt && notepad 1.txt
4. Notepad will open showing some info. Can you copy and paste this into your next reply?
I copied and pasted the command into the elevated command dialog. CMD opened in C:\Windows\system32>, but when I ran the command I only got the following message: "ERROR: The system was unable to find the specified registry key or value." I tried backing out to the root directory (C:\), but got the same message.
For grins and giggles, I went into the registry and looked for that entry, but only got as far as HKEY_LOCAL_MACHINE\SYSTEM\ - the subdirectories below that didn't include ControlSet. The closest I could find was CurrentControlSet, which *does* have an entry in it for \Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}. Should I change the command to "reg query HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318} /s >1.txt && notepad 1.txt" and re-run it in the elevated command dialog box?
I'm a bit leery of mucking about in the registry, so I bailed while waiting for further direction.
You can export the key or entry as you call it you found directly from the registry without modifying anything by right-clicking it and selecting export.
It turns out the system doesn't like .reg files uploaded. Who knew?
Attached is the zip file containing the export.
FRST Fix
... not an encouraging output - but perhaps informative(?)
Fix result of Farbar Recovery Scan Tool (x64) Version: 27.01.2018
Ran by Dennis (06-02-2018 22:39:11) Run:2
Running from C:\Users\Dennis\Desktop
Loaded Profiles: Dennis (Available Profiles: Dennis & Administrator)
Boot Mode: Normal
fixlist content:
cmd: netcfg.exe -e -u MS_RasSrv
cmd: netcfg.exe -e -c s -i MS_RasSrv
========= netcfg.exe -e -u MS_RasSrv =========
Trying to uninstall MS_RasSrv ...
..failed. Error code: 0x80070057.
========= netcfg.exe -e -c s -i MS_RasSrv =========
Trying to install MS_RasSrv ...
==== End of Fixlog 22:39:12 ====
2. Run the attached fix.
3. Stop Process Monitor as soon as the error pops up. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
FRST Fix
Apologies for the delay - I started backing up the C: and D: drives, and it's taking f o r e v e r.
I'll be back as soon as it wraps up.
My backup insists on disconnecting from the network before the backup completes. Arrrgg! Different problem - for a different day.
The Fixlog.txt follows. Here are links for Dropbox - CBS.zip and Dropbox - Logfile.zip
Please note there was no error code generated - I just shut off procmon.exe after Fixlog.txt was generated. There was no restart required.
Fix result of Farbar Recovery Scan Tool (x64) Version: 10.02.2018 02
Ran by Dennis (10-02-2018 17:35:31) Run:3
Boot Mode: Normal
fixlist content:
==== End of Fixlog 17:35:32 ====
Please do the following:
Open CMD as admin and enter the following:
"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regiis.exe" -iru
Let me know if you receive anything other than the following.
Microsoft (R) ASP.NET RegIIS version 4.0.30319.36415
Administration utility to install and uninstall ASP.NET on the local machine.
Copyright (C) Microsoft Corporation.  All rights reserved.
Start installing ASP.NET (4.0.30319.36415).
Finished installing ASP.NET (4.0.30319.36415).
The version numbers of the RegIIS version were different; your example above showed 4.0.30319.36415, and when I opened CMD as admin it returned 4.0.30319.0, as shown below.
C:\Windows\system32>"C:\Windows\Microsoft.NET\Framework64\v4.0.30319\aspnet_regi
is.exe" -iru
Microsoft (R) ASP.NET RegIIS version 4.0.30319.0
Start installing ASP.NET (4.0.30319.0).
Finished installing ASP.NET (4.0.30319.0).
Yesterday I knew how to paste text into the command prompt window, and now I know how to copy text from it. This thread has been a series of interesting factoids I've learned. Amazing.
I'm afraid we're bumping into the ceiling of my knowledge again.
I found several web sites like Download ASP.NET | The ASP.NET Site and https://support.microsoft.com/en-us...ng-pack-for-the-microsoft-net-framework-4-0-3 that looked like hopeful candidates, but I wasn't able to find a download link for ASP.NET 4.0.30319.36415, let alone sort things clearly enough to know I wouldn't shoot myself in the foot when installing it.
I did not see an "Update" option for the entry that looks like it might be ASP.NET in Control Panel (Microsoft .NET framework 4 Multi-Targeting Pack, with a version number of 4.0.30319). The next closest candidate was Microsoft .NET Framework 4.7 - but it's got a version number of 4.7.02053.
Sooo... could you point me to a page with an available download and update procedure?
Greetings -
I ran Windows Update from the control panel, and it indicated there were 3 important updates, but only 2 were pre-checked for downloading & installation. The installation initially indicated success, then failed and reverted after rebooting. Windows update indicates the following:
2-21-18 2018-02 Security Monthly Quality Rollup for Windows 7 for x64-based Systems (KB4074598) Installation status: Failed Error details: Code 80004005
2-21-18 Definition Update for Windows Defender - KB915597 (Definition 1.261.1370.0) Installation status: Successful
Let me know if you need any update history prior to tonight's attempt.
Dennis
