[SOLVED] [7SP1 x64] Monthly Quality Rollup failures - KB4041681, KB4054518, and KB4056894
Please create a new admin account to test. Use a simple name (no spaces or special characters).
Log onto it and attempt the update again. If it fails, please attach CBS.log
I set up the new Admin account and logged into the new account to update Windows. The update process failed exactly as it has in the past - at 98% during the reboot. I let the failure process complete, then logged into my normal account when the second reboot completed. I grabbed Dropbox - CBS.zip from my the account where I normally log in. Hopefully there is only one CBS.log which is shared among the user accounts.
Please let me know if I need to grab a different CBS file from the new Admin account rather than from my regular account.
I didn't know if CBS.log would change during subsequent computer activity, so I went through the same steps and had the update fail exactly as it did earlier. I grabbed the Dropbox - CBS.zip from the new admin account immediately after the failure.
FRST Fix
5. Try update again and attach CBS.log if it fails.
1. Click your start button and type cmd in the search box.
2. Right-click on cmd that comes up in the search results and select Run as administrator. Answer Yes to the UAC prompt if it appears.
3. Copy/Paste the following into the command-prompt window and hit enter.
reg query HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318} /s >1.txt && notepad 1.txt
4. Notepad will open showing some info. Can you copy and paste this into your next reply?
When the dust settled, Notepad contained the following:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}
    Characteristics    REG_DWORD    0x28
    InfPath    REG_SZ    netrass.inf
    InfSection    REG_SZ    Ndi-Steelhead
    LocDescription    REG_SZ    @netrass.inf,%steelhead-dispname%;Steelhead
    Description    REG_SZ    Steelhead
    ComponentId    REG_SZ    ms_steelhead
    InstallTimeStamp    REG_BINARY    D907070002000E00040031002D00D201
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}\Ndi
    ClsID    REG_SZ    {6e65cbc5-926d-11d0-8e27-00c04fc99dcf}
    ComponentDll    REG_SZ    rascfg.dll
    Service    REG_SZ    RemoteAccess
    CoServices    REG_MULTI_SZ    RemoteAccess
    ExcludeSetupStartServices    REG_MULTI_SZ    RemoteAccess
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}\Ndi\Interfaces
    UpperRange    REG_SZ    noupper
    LowerRange    REG_SZ    nolower
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}
    Characteristics    REG_DWORD    0x40000
    InfPath    REG_SZ    vpcnfltr.inf
    InfSection    REG_SZ    Install
    LocDescription    REG_SZ    @vpcnfltr.inf,%vpcnfltr_desc%;Virtual PC Network Filter Driver
    Description    REG_SZ    Virtual PC Network Filter Driver
    ComponentId    REG_SZ    vpcnfltr
    InstallTimeStamp    REG_BINARY    DA070600030002000D00300031007B00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}\Ndi
    Service    REG_SZ    Vpcnfltr
    CoServices    REG_MULTI_SZ    Vpcnfltr
    HelpText    REG_SZ    Provides networking support for Windows Virtual PC.
    FilterClass    REG_SZ    custom
    FilterType    REG_DWORD    0x2
    FilterRunType    REG_DWORD    0x2
    TimeStamp    REG_BINARY    DB07060000001A000600360008004D00
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}\Ndi\Interfaces
    FilterMediaTypes    REG_SZ    ethernet
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}
    InfPath    REG_SZ    netnb.inf
    InfSection    REG_SZ    NetBIOS.ndi
    LocDescription    REG_SZ    @netnb.inf,%netbios_desc%;NetBIOS Interface
    Description    REG_SZ    NetBIOS Interface
    ComponentId    REG_SZ    MS_NETBIOS
    InstallTimeStamp    REG_BINARY    D907070002000E00040035001E000101
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}\Ndi
    Service    REG_SZ    NetBIOS
    CoServices    REG_MULTI_SZ    NetBIOS
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}\Ndi\Interfaces
    UpperRange    REG_SZ    winnet5
    LowerRange    REG_SZ    netbios
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}
    Characteristics    REG_DWORD    0x40028
    InfPath    REG_SZ    netvwififlt.inf
    LocDescription    REG_SZ    @netvwififlt.inf,%vwififlt_desc%;Virtual WiFi Filter Driver
    Description    REG_SZ    Virtual WiFi Filter Driver
    ComponentId    REG_SZ    ms_vwifi
    InstallTimeStamp    REG_BINARY    DA070600030017000E00170013004700
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}\Ndi
    Service    REG_SZ    vwififlt
    CoServices    REG_MULTI_SZ    vwififlt
    HelpText    REG_SZ    Virtual WiFi Filter Driver
    FilterClass    REG_SZ    ms_medium_converter_128
    TimeStamp    REG_BINARY    DA070600030017000E00170013003200
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}\Ndi\Interfaces
    FilterMediaTypes    REG_SZ    vwifi
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}
    Characteristics    REG_DWORD    0x0
    InfPath    REG_SZ    netserv.inf
    InfSection    REG_SZ    Install.ndi
    LocDescription    REG_SZ    @netserv.inf,%msserver_desc%;File and Printer Sharing for Microsoft Networks
    Description    REG_SZ    File and Printer Sharing for Microsoft Networks
    ComponentId    REG_SZ    ms_server
    InstallTimeStamp    REG_BINARY    D907070002000E00040035002000E801
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}\Ndi
    ClsID    REG_SZ    {7F368827-9516-11d0-83D9-00A0C911E5DF}
    Service    REG_SZ    LanmanServer
    CoServices    REG_MULTI_SZ    LanmanServer
    ExcludeSetupStartServices    REG_MULTI_SZ    LanmanServer
    HelpText    REG_SZ    @netcfgx.dll,-50003
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}\Ndi\Interfaces
    LowerRange    REG_SZ    tdi,netbios,ipx,netbios_smb
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}
    Characteristics    REG_DWORD    0x4410
    InfPath    REG_SZ    oem37.inf
    InfSection    REG_SZ    appliand.ndi
    LocDescription    REG_SZ    @oem37.inf,%appliand_desc%;Applian Network Driver
    Description    REG_SZ    Applian Network Driver
    ComponentId    REG_SZ    nt_appliand
    InstallTimeStamp    REG_BINARY    DB07080000001C0005000C0026002902
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Ndi
    HelpText    REG_SZ    Applian Network Driver
    FilterClass    REG_SZ    failover
    FilterDeviceInfId    REG_SZ    nt_appliandmp
    Service    REG_SZ    appliand
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Ndi\Interfaces
    FilterMediaTypes    REG_SZ    ethernet, wan
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Parameters
    Param1    REG_SZ    4
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}
    InfPath    REG_SZ    netpacer.inf
    LocDescription    REG_SZ    @netpacer.inf,%psched_desc%;QoS Packet Scheduler
    Description    REG_SZ    QoS Packet Scheduler
    ComponentId    REG_SZ    ms_pacer
    InstallTimeStamp    REG_BINARY    D907070002000E000400350039009A02
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}\Ndi
    Service    REG_SZ    Psched
    CoServices    REG_MULTI_SZ    Psched
    HelpText    REG_SZ    @%SystemRoot%\System32\drivers\pacer.sys,-100
    FilterClass    REG_SZ    scheduler
    TimeStamp    REG_BINARY    DB07060000001A00060035003B00E403
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}
    InfPath    REG_SZ    wfplwf.inf
    LocDescription    REG_SZ    @wfplwf.inf,%wfplwf_desc%;WFP Lightweight Filter
    Description    REG_SZ    WFP Lightweight Filter
    ComponentId    REG_SZ    MS_WfpLwf
    InstallTimeStamp    REG_BINARY    D907070002000E000400310030004700
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}\Ndi
    Service    REG_SZ    WfpLwf
    CoServices    REG_MULTI_SZ    WfpLwf
    HelpText    REG_SZ    WFP Lightweight Filter
    FilterClass    REG_SZ    ms_firewall_upper
    FilterRunType    REG_DWORD    0x1
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}
    Characteristics    REG_DWORD    0x38
    InfSection    REG_SZ    Ndi-RasSrv
    LocDescription    REG_SZ    @netrass.inf,%rassrv-dispname%;Dial-Up Server
    Description    REG_SZ    Dial-Up Server
    ComponentId    REG_SZ    ms_rassrv
    InstallTimeStamp    REG_BINARY    D907070002000E00040031002D008401
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi
    ClsID    REG_SZ    {6e65cbc1-926d-11d0-8e27-00c04fc99dcf}
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi\Interfaces
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}
    InfPath    REG_SZ    netnwifi.inf
    InfSection    REG_SZ    MS_NWIFI.Install
    LocDescription    REG_SZ    @netnwifi.inf,%ms_nwifi.displayname%;NativeWiFi Filter
    Description    REG_SZ    NativeWiFi Filter
    ComponentId    REG_SZ    MS_NativeWifiP
    InstallTimeStamp    REG_BINARY    D907070002000E000400370002005801
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}\Ndi
    Service    REG_SZ    NativeWifiP
    CoServices    REG_MULTI_SZ    NativeWifiP
    HelpText    REG_SZ
    FilterClass    REG_SZ    ms_medium_converter_top
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}\Ndi\Interfaces
    FilterMediaTypes    REG_SZ    wlan
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}
    Characteristics    REG_DWORD    0x40038
    InfPath    REG_SZ    ndiscap.inf
    LocDescription    REG_SZ    @ndiscap.inf,%ndiscap_desc%;NDIS Capture LightWeight Filter
    Description    REG_SZ    NDIS Capture LightWeight Filter
    ComponentId    REG_SZ    MS_NDISCAP
    InstallTimeStamp    REG_BINARY    D907070002000E00040036002600F200
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}\Ndi
    Service    REG_SZ    NdisCap
    CoServices    REG_MULTI_SZ    NdisCap
    HelpText    REG_SZ    Packet Capture Filter Driver
    FilterType    REG_DWORD    0x1
    ClsID    REG_SZ    {D212B88E-8365-4CA9-BC4E-CFA4251F6B5F}
    ComponentDll    REG_SZ    ndiscapCfg.dll
    TimeStamp    REG_BINARY    D907070002000E00040036002600D300
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}\Ndi\Interfaces
    FilterMediaTypes    REG_SZ    ethernet, wlan, ppip
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}
    InfSection    REG_SZ    Ndi-RasMan
    LocDescription    REG_SZ    @netrass.inf,%rasman-dispname%;Remote Access Connection Manager
    Description    REG_SZ    Remote Access Connection Manager
    ComponentId    REG_SZ    ms_rasman
    InstallTimeStamp    REG_BINARY    D907070002000E00040031001E00F302
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}\Ndi
    Service    REG_SZ    RasMan
    CoServices    REG_MULTI_SZ    RasAcd\0RasAuto
    ExcludeSetupStartServices    REG_MULTI_SZ    RasAcd\0RasAuto
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}\Ndi\Interfaces
FRST Fix
A little light reading follows...
Start time: 2018-02-27 18:52:53.775
Using .txt script file at C:\Users\Dennis\Desktop\SFCFixScript.txt [0]
RegistryTakePermissions::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{0EFE03B2-EA87-44C1-B825-9BBEA54F37B4}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{4C4F8B37-E1E2-4357-9473-7C77F4D580DC}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{56494156-6C00-4B77-90D7-A4A435088232}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{5CBF81BF-5055-47CD-9055-A76B2B4E3698}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{6B7E8FF8-E9A2-46EB-A4EA-42CCA2D43C96}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{9BB94186-292A-4E9B-A719-6115CDF90DA1}\Parameters.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B5F4D659-7DAA-4565-8E41-BE220ED60542}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{B70D6460-3635-4D42-B866-B8AB1A24454C}\Ndi\Interfaces.
Failed to open registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F} with error code ERROR_FILE_NOT_FOUND.
Failed to open registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi with error code ERROR_FILE_NOT_FOUND.
Failed to open registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi\Interfaces with error code ERROR_FILE_NOT_FOUND.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{E475CF9A-60CD-4439-A75F-0079CE0E18A1}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{EA24CD6C-D17A-4348-9190-09F0D5BE83DD}\Ndi\Interfaces.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}\Ndi.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{F5658C39-CD0D-45B5-A342-E2C037714CE4}\Ndi\Interfaces.
RegistryTakePermissions:: directive failed to complete successfully.
Currently storing 35 datablocks.
Finish time: 2018-02-27 18:52:54.034
Script hash: 1rA89FDeaWX9vRipWkj55Aeja/BMVnTkJDS5t06s5cU=
Sorry for a slight delay! This is indeed a very interesting issue.
FRST Fix
I grabbed the fixlixt.txt after a reboot. Please see the attached.
Fix result of Farbar Recovery Scan Tool (x64) Version: 28.02.2018
Ran by Dennis (03-03-2018 18:54:37) Run:6
Running from C:\Users\Dennis\Desktop
Loaded Profiles: Dennis (Available Profiles: Dennis & testact1 & Administrator)
Boot Mode: Normal
fixlist content:
StartRegEdit:
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}]
"Characteristics"=dword:00000038
"InfPath"="netrass.inf"
"InfSection"="Ndi-RasSrv"
"LocDescription"="@netrass.inf,%rassrv-dispname%;Dial-Up Server"
"Description"="Dial-Up Server"
"ComponentId"="ms_rassrv"
"InstallTimeStamp"=hex:d9,07,07,00,02,00,0e,00,04,00,31,00,2d,00,84,01
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi]
"ClsID"="{6e65cbc1-926d-11d0-8e27-00c04fc99dcf}"
"ComponentDll"="rascfg.dll"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet\Control\Network\{4d36e974-e325-11ce-bfc1-08002be10318}\{C9548B78-5743-4E64-9BA1-CD4D974A329F}\Ndi\Interfaces]
"UpperRange"="noupper"
"LowerRange"="nolower"
EndRegEdit:
DeleteValue:HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network|Config
Reboot:
====> Registry
"HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Network\\Config" => removed successfully
The system needed a reboot.
==== End of Fixlog 18:54:38 ====
