[SOLVED] [7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
Re: [W7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
Ran the command and got the following:
Investigating the error (have a day off) the only command I could find related to Cleanup is /Cleanup-Wim. I did not run it. ​Will wait to hear back from you. In case you wanted to see the dism log file, here it it:
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 DismApi.dll:                                            - DismInitializeInternal2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 DismApi.dll: <----- Starting DismApi.dll session -----> - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 DismApi.dll: Version 10.0.14393.0 - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 DismApi.dll: Parent process command line: C:\Windows\system32\CompatTelRunner.exe -m:appraiser.dll -f:DoScheduledTelemetryRun -cv:rzzwo7zHjUWbDvik.1 - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Enter DismInitializeInternal - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Input parameters: LogLevel: 2, LogFilePath: (null), ScratchDirectory: (null) - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   Try to initialize Panther logging 1 times, last error: 0x0
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Initialized GlobalConfig - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Initialized SessionTable - DismInitializeInternal
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Lookup in table by path failed for: DummyPath-2BA51B78-C7F7-4910-B99D-BB7345357CDC - CTransactionalImageTable::LookupImagePath
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=1580 Waiting for m_pInternalThread to start - CCommandThread::Start
2017-11-23 04:35:09, Info                  DISM   API: PID=3804 TID=9736 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=9736 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 CommandThread StartupEvent signaled - CCommandThread::WaitForStartup
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 m_pInternalThread started - CCommandThread::Start
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Created g_internalDismSession - DismInitializeInternal
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Leave DismInitializeInternal - DismInitializeInternal
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Enter DismOpenSessionInternal - DismOpenSessionInternal
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Input parameters: ImagePath: DISM_{53BFAE52-B167-4E2F-A258-0A37B57FF845}, WindowsDirectory: (null), SystemDrive: (null) - DismOpenSessionInternal
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Lookup in table by path failed for: DRIVE_C - CTransactionalImageTable::LookupImagePath
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Waiting for m_pInternalThread to start - CCommandThread::Start
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=5332 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=5332 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:10, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:10, Info                  DISM   PID=3804 TID=5332 Scratch directory set to 'C:\Windows\TEMP\'. - CDISMManager::put_ScratchDir
2017-11-23 04:35:10, Info                  DISM   PID=3804 TID=5332 DismCore.dll version: 10.0.14393.0 - CDISMManager::FinalConstruct
2017-11-23 04:35:10, Info                  DISM   Try to initialize Panther logging 1 times, last error: 0x0
2017-11-23 04:35:10, Info                  DISM   PID=3804 TID=5332 Successfully loaded the ImageSession at "C:\Windows\system32\compattel" - CDISMManager::LoadLocalImageSession
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Manager: PID=3804 TID=5332 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\WimProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:10, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\FfuProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Connecting to the provider located at C:\Windows\system32\compattel\FfuProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Loading Provider from location C:\Windows\system32\compattel\SiloedPackageProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:11, Warning               DISM   DISM Provider Store: PID=3804 TID=5332 Failed to Load the provider: C:\Windows\system32\compattel\SiloedPackageProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2017-11-23 04:35:11, Info                  DISM   DISM WIM Provider: PID=3804 TID=5332 [C:\] is not a WIM mount point. - CWimMountedImageInfo::Initialize
2017-11-23 04:35:11, Info                  DISM   DISM VHD Provider: PID=3804 TID=5332 [C:\] is not recognized by the DISM VHD provider. - CVhdImage::Initialize
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Getting Provider VHDManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Imaging Provider: PID=3804 TID=5332 The provider VHDManager does not support CreateDismImage on C:\ - CGenericImagingManager::CreateDismImage
2017-11-23 04:35:11, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Getting Provider WimManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:11, Info                  DISM   DISM Imaging Provider: PID=3804 TID=5332 The provider WimManager does not support CreateDismImage on C:\ - CGenericImagingManager::CreateDismImage
2017-11-23 04:35:11, Info                  DISM   DISM Imaging Provider: PID=3804 TID=5332 No imaging provider supported CreateDismImage for this path - CGenericImagingManager::CreateDismImage
2017-11-23 04:35:11, Info                  DISM   DISM Manager: PID=3804 TID=5332 physical location path: C:\ - CDISMManager::CreateImageSession
2017-11-23 04:35:11, Info                  DISM   DISM Manager: PID=3804 TID=5332 Event name for current DISM session is Global\{07376BEF-F446-470C-AC43-9E244F8502B4} - CDISMManager::CheckSessionAndLock
2017-11-23 04:35:11, Info                  DISM   DISM Manager: PID=3804 TID=5332 Create session event 0x918 for current DISM session and event name is Global\{07376BEF-F446-470C-AC43-9E244F8502B4}  - CDISMManager::CheckSessionAndLock
2017-11-23 04:35:11, Info                  DISM   DISM Manager: PID=3804 TID=5332 Copying DISM from "C:\Windows\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2017-11-23 04:35:13, Info                  DISM   DISM Manager: PID=3804 TID=5332 Successfully loaded the ImageSession at "C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39" - CDISMManager::LoadRemoteImageSession
2017-11-23 04:35:13, Info                  DISM   DISM Image Session: PID=8440 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Loading Provider from location C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Connecting to the provider located at C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:13, Info                  DISM   DISM OS Provider: PID=8440 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM OS Provider: PID=8440 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Loading Provider from location C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Connecting to the provider located at C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Loading Provider from location C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Warning               DISM   DISM Provider Store: PID=8440 Failed to Load the provider: C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Manager: PID=3804 TID=5332 Image session successfully loaded from the temporary location: C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39 - CDISMManager::CreateImageSession
2017-11-23 04:35:13, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:13, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=5332 Target image information: OS Version=6.1.7601.23505, Image architecture=amd64 - CDismCore::LogImageSessionDetails
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=1580 Leave DismOpenSessionInternal - DismOpenSessionInternal
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=1580 Session id is: 2 - DismOpenSessionInternal
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem8.inf - DismGetDriverInfoInternal
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:13, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Loading Provider from location C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Connecting to the provider located at C:\Windows\TEMP\D6D052B9-D009-4535-8CB7-C21A2C1D3C39\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:13, Info                  DISM   DISM Provider Store: PID=8440 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2017-11-23 04:35:13, Info                  DISM   DISM OS Provider: PID=8440 Successfully loaded the hive. - CDISMOSServiceManager::DetermineBootDrive
2017-11-23 04:35:13, Info                  DISM   DISM Driver Manager: PID=8440 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2017-11-23 04:35:13, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem8.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:13, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:14, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.cat]
2017-11-23 04:35:14, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:14, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:14, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:14, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:14, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:14, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:14, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amdkmpfd.inf_amd64_neutral_e148d3dd3ab4b8d4\amdkmpfd.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem46.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem46.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:14, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amdhub30.inf_amd64_neutral_709a19a5b5db9957\amdhub30.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:14, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amdhub30.inf_amd64_neutral_709a19a5b5db9957\amdhub30.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amdhub30.inf_amd64_neutral_709a19a5b5db9957\amdhub30.cat]
2017-11-23 04:35:14, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amdhub30.inf_amd64_neutral_709a19a5b5db9957\amdhub30.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\amdhub30.inf_amd64_neutral_709a19a5b5db9957\amdhub30.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem48.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem48.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\atihdw76.inf_amd64_neutral_536a5da7c686e8e5\atihdw76.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem47.inf - DismGetDriverInfoInternal
2017-11-23 04:35:14, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem47.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:15, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:15, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:15, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:15, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\hdxcr.inf_amd64_neutral_a6418923aa470c08\hdxcr.inf - DismGetDriverInfoInternal
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:15, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:15, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem36.inf - DismGetDriverInfoInternal
2017-11-23 04:35:15, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem36.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\c7303291.inf_amd64_neutral_7d0988d949059d02\c7303291.inf - DismGetDriverInfoInternal
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:16, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:16, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:16, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem38.inf - DismGetDriverInfoInternal
2017-11-23 04:35:16, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem38.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:16, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:16, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.cat]
2017-11-23 04:35:16, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:16, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:16, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:16, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:17, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:17, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:17, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.cat]
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amd_sata.inf_amd64_neutral_0170ecb7700988c7\amd_sata.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem43.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem43.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amdehci.inf_amd64_neutral_06df889110801a5a\amdehci.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:17, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amdehci.inf_amd64_neutral_06df889110801a5a\amdehci.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amdehci.inf_amd64_neutral_06df889110801a5a\AmdEHCI.cat]
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amdehci.inf_amd64_neutral_06df889110801a5a\amdehci.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:17, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:17, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:17, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\amdehci.inf_amd64_neutral_06df889110801a5a\amdehci.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem31.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem31.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\smbusamd.inf_amd64_neutral_a1f6e32f30c39b3d\smbusamd.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:17, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\smbusamd.inf_amd64_neutral_a1f6e32f30c39b3d\smbusamd.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\smbusamd.inf_amd64_neutral_a1f6e32f30c39b3d\SMbusamd.cat]
2017-11-23 04:35:17, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\smbusamd.inf_amd64_neutral_a1f6e32f30c39b3d\smbusamd.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\smbusamd.inf_amd64_neutral_a1f6e32f30c39b3d\smbusamd.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem45.inf - DismGetDriverInfoInternal
2017-11-23 04:35:17, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem45.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:18, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\amdxhc.inf_amd64_neutral_58bf2b068a2ef992\amdxhc.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:18, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\amdxhc.inf_amd64_neutral_58bf2b068a2ef992\amdxhc.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\amdxhc.inf_amd64_neutral_58bf2b068a2ef992\amdxhc.cat]
2017-11-23 04:35:18, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\amdxhc.inf_amd64_neutral_58bf2b068a2ef992\amdxhc.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:18, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:18, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:18, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:18, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\amdxhc.inf_amd64_neutral_58bf2b068a2ef992\amdxhc.inf - DismGetDriverInfoInternal
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:18, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:18, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem49.inf - DismGetDriverInfoInternal
2017-11-23 04:35:18, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem49.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:19, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:19, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:19, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:19, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\rt64win7.inf_amd64_neutral_fec6b33bc69ab753\rt64win7.inf - DismGetDriverInfoInternal
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:34, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:34, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:34, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem18.inf - DismGetDriverInfoInternal
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:51, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:51, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:51, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem18.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:51, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:51, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:51, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:51, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\mp620sc.inf_amd64_neutral_c417519f60ee38f3\mp620sc.inf - DismGetDriverInfoInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem33.inf - DismGetDriverInfoInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:52, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:52, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:52, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem33.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:52, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:52, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:52, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\vpnva-6.inf_amd64_neutral_f4ee011be27e2804\vpnva-6.inf - DismGetDriverInfoInternal
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem19.inf - DismGetDriverInfoInternal
2017-11-23 04:35:52, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem19.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:52, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_25db870ab7cd867d\unifhid.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:52, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_25db870ab7cd867d\unifhid.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_25db870ab7cd867d\unifhidx64.cat]
2017-11-23 04:35:52, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_25db870ab7cd867d\unifhid.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:52, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\unifhid.inf_amd64_neutral_25db870ab7cd867d\unifhid.inf - DismGetDriverInfoInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem24.inf - DismGetDriverInfoInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:53, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:53, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:53, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem24.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:53, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\lfeqdusb.inf_amd64_neutral_174f1cc10979ac99\lfeqdusb.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:53, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\lfeqdusb.inf_amd64_neutral_174f1cc10979ac99\lfeqdusb.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\lfeqdusb.inf_amd64_neutral_174f1cc10979ac99\LfEqdUsb.cat]
2017-11-23 04:35:53, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\lfeqdusb.inf_amd64_neutral_174f1cc10979ac99\lfeqdusb.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:53, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:53, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:53, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\lfeqdusb.inf_amd64_neutral_174f1cc10979ac99\lfeqdusb.inf - DismGetDriverInfoInternal
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem25.inf - DismGetDriverInfoInternal
2017-11-23 04:35:53, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem25.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:53, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\lfhideqd.inf_amd64_neutral_0416c38d86dc340d\lfhideqd.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:53, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\lfhideqd.inf_amd64_neutral_0416c38d86dc340d\lfhideqd.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\lfhideqd.inf_amd64_neutral_0416c38d86dc340d\LfHidEqd.cat]
2017-11-23 04:35:53, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\lfhideqd.inf_amd64_neutral_0416c38d86dc340d\lfhideqd.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:53, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\lfhideqd.inf_amd64_neutral_0416c38d86dc340d\lfhideqd.inf - DismGetDriverInfoInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem28.inf - DismGetDriverInfoInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:54, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:54, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:54, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem28.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:54, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\lfkbdhid.inf_amd64_neutral_8c0c81ffd4855035\lfkbdhid.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:54, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\lfkbdhid.inf_amd64_neutral_8c0c81ffd4855035\lfkbdhid.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\lfkbdhid.inf_amd64_neutral_8c0c81ffd4855035\LfKbdHid.cat]
2017-11-23 04:35:54, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\lfkbdhid.inf_amd64_neutral_8c0c81ffd4855035\lfkbdhid.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:54, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:54, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:54, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:54, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\lfkbdhid.inf_amd64_neutral_8c0c81ffd4855035\lfkbdhid.inf - DismGetDriverInfoInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem27.inf - DismGetDriverInfoInternal
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:55, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:55, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:55, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem27.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:55, Info                  DISM   DISM Driver Manager: PID=8440 Driver C:\Windows\System32\DriverStore\FileRepository\lfhidhid.inf_amd64_neutral_d7844699e9bae46e\lfhidhid.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-23 04:35:55, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\lfhidhid.inf_amd64_neutral_d7844699e9bae46e\lfhidhid.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\lfhidhid.inf_amd64_neutral_d7844699e9bae46e\LfHidHid.cat]
2017-11-23 04:35:55, Info                  DISM   DISM Driver Manager: PID=8440 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\lfhidhid.inf_amd64_neutral_d7844699e9bae46e\lfhidhid.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-23 04:35:55, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:55, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:55, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:55, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\lfhidhid.inf_amd64_neutral_d7844699e9bae46e\lfhidhid.inf - DismGetDriverInfoInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem29.inf - DismGetDriverInfoInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:56, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-23 04:35:56, Info                  DISM   DISM Provider Store: PID=8440 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-23 04:35:56, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem29.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:56, Info                  DISM   DISM Provider Store: PID=8440 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-23 04:35:56, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-23 04:35:56, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\lfunkraw.inf_amd64_neutral_f80e6194bbf7739f\lfunkraw.inf - DismGetDriverInfoInternal
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: oem15.inf - DismGetDriverInfoInternal
2017-11-23 04:35:56, Error                 DISM   DISM Driver Manager: PID=8440 Error, file not found 'oem15.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-23 04:35:56, Info                  DISM   API: PID=3804 TID=1580 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\brohlb0a.inf_amd64_neutral_4bd6553963351516\brohlb0a.inf - DismGetDriverInfoInternal
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=1580 Enter DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=1580 Leave DismDeleteInternal - DismDeleteInternal
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=7604 Enter DismCloseSessionInternal - DismCloseSessionInternal
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=7604 Input parameters: Session: 2 - DismCloseSessionInternal
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=7604 GetReferenceCount hr: 0x0 - CSessionTable::RemoveSession
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=7604 Refcount for DismSession= 2s 0 - CSessionTable::RemoveSession
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=7604 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=5332 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=5332 ExecuteLoop: Cancel signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:57, Info                  DISM   API: PID=3804 TID=5332 Leave CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-23 04:35:57, Info                  DISM   DISM Image Session: PID=8440 Disconnecting the provider store - CDISMImageSession::Final_OnDisconnect
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:57, Info                  DISM   DISM Provider Store: PID=8440 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Manager: PID=3804 TID=5332 Closing session event handle 0x918 - CDISMManager::CloseImageSession
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: Compatibility Manager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Disconnecting Provider: FfuManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:58, Info                  DISM   DISM Provider Store: PID=3804 TID=5332 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=5332 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 Leave DismCloseSessionInternal - DismCloseSessionInternal
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 Enter DismShutdownInternal - DismShutdownInternal
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 GetReferenceCount hr: 0x0 - CSessionTable::RemoveSession
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 Refcount for DismSession= 1s 0 - CSessionTable::RemoveSession
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=9736 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=9736 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=9736 ExecuteLoop: Cancel signaled - CCommandThread::ExecuteLoop
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=9736 Leave CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-23 04:35:59, Info                  DISM   PID=3804 TID=9736 Temporarily setting the scratch directory. This may be overridden by user later. - CDISMManager::FinalConstruct
2017-11-23 04:35:59, Info                  DISM   PID=3804 TID=9736 Scratch directory set to 'C:\Windows\TEMP\'. - CDISMManager::put_ScratchDir
2017-11-23 04:35:59, Info                  DISM   PID=3804 TID=9736 DismCore.dll version: 10.0.14393.0 - CDISMManager::FinalConstruct
2017-11-23 04:35:59, Info                  DISM   Try to initialize Panther logging 1 times, last error: 0x0
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=9736 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-23 04:35:59, Info                  DISM   API: PID=3804 TID=7604 Deleted g_internalDismSession - DismShutdownInternal
2017-11-23 04:36:00, Info                  DISM   API: PID=3804 TID=7604 Shutdown SessionTable - DismShutdownInternal
2017-11-23 04:36:00, Info                  DISM   API: PID=3804 TID=7604 Leave DismShutdownInternal - DismShutdownInternal
2017-11-23 04:36:00, Info                  DISM   API: PID=3804 TID=7604 DismApi.dll:                                          - DismShutdownInternal
2017-11-23 04:36:00, Info                  DISM   API: PID=3804 TID=7604 DismApi.dll: <----- Ending DismApi.dll session -----> - DismShutdownInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 DismApi.dll:                                            - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 DismApi.dll: <----- Starting DismApi.dll session -----> - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 DismApi.dll: Version 10.0.14393.0 - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 DismApi.dll: Parent process command line: C:\Windows\system32\CompatTelRunner.exe -m:appraiser.dll -f:DoScheduledTelemetryRun -cv:ium40YhKtkinXrR7.1 - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Enter DismInitializeInternal - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Input parameters: LogLevel: 2, LogFilePath: (null), ScratchDirectory: (null) - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   Try to initialize Panther logging 1 times, last error: 0x0
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Initialized GlobalConfig - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Initialized SessionTable - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Lookup in table by path failed for: DummyPath-2BA51B78-C7F7-4910-B99D-BB7345357CDC - CTransactionalImageTable::LookupImagePath
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Waiting for m_pInternalThread to start - CCommandThread::Start
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4104 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4104 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 CommandThread StartupEvent signaled - CCommandThread::WaitForStartup
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 m_pInternalThread started - CCommandThread::Start
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Created g_internalDismSession - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Leave DismInitializeInternal - DismInitializeInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Enter DismOpenSessionInternal - DismOpenSessionInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Input parameters: ImagePath: DISM_{53BFAE52-B167-4E2F-A258-0A37B57FF845}, WindowsDirectory: (null), SystemDrive: (null) - DismOpenSessionInternal
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Lookup in table by path failed for: DRIVE_C - CTransactionalImageTable::LookupImagePath
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=2148 Enter CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=2148 Enter CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=2148 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=4496 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-24 03:41:57, Info                  DISM   API: PID=4372 TID=2148 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-24 03:41:57, Info                  DISM   PID=4372 TID=2148 Scratch directory set to 'C:\Windows\TEMP\'. - CDISMManager::put_ScratchDir
2017-11-24 03:41:57, Info                  DISM   PID=4372 TID=2148 DismCore.dll version: 10.0.14393.0 - CDISMManager::FinalConstruct
2017-11-24 03:41:57, Info                  DISM   PID=4372 TID=2148 Successfully loaded the ImageSession at "C:\Windows\system32\compattel" - CDISMManager::LoadLocalImageSession
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:57, Info                  DISM   DISM Manager: PID=4372 TID=2148 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Getting the collection of providers from a local provider store type. - CDISMProviderStore::GetProviderCollection
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:57, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\WimProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\WimProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\VHDProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\VHDProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\ImagingProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\ImagingProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\CompatProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\CompatProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\FfuProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Connecting to the provider located at C:\Windows\system32\compattel\FfuProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Loading Provider from location C:\Windows\system32\compattel\SiloedPackageProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Warning               DISM   DISM Provider Store: PID=4372 TID=2148 Failed to Load the provider: C:\Windows\system32\compattel\SiloedPackageProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2017-11-24 03:41:58, Info                  DISM   DISM WIM Provider: PID=4372 TID=2148 [C:\] is not a WIM mount point. - CWimMountedImageInfo::Initialize
2017-11-24 03:41:58, Info                  DISM   DISM VHD Provider: PID=4372 TID=2148 [C:\] is not recognized by the DISM VHD provider. - CVhdImage::Initialize
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Getting Provider VHDManager - CDISMProviderStore::GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Imaging Provider: PID=4372 TID=2148 The provider VHDManager does not support CreateDismImage on C:\ - CGenericImagingManager::CreateDismImage
2017-11-24 03:41:58, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Getting Provider WimManager - CDISMProviderStore::GetProvider
2017-11-24 03:41:58, Info                  DISM   DISM Imaging Provider: PID=4372 TID=2148 The provider WimManager does not support CreateDismImage on C:\ - CGenericImagingManager::CreateDismImage
2017-11-24 03:41:58, Info                  DISM   DISM Imaging Provider: PID=4372 TID=2148 No imaging provider supported CreateDismImage for this path - CGenericImagingManager::CreateDismImage
2017-11-24 03:41:58, Info                  DISM   DISM Manager: PID=4372 TID=2148 physical location path: C:\ - CDISMManager::CreateImageSession
2017-11-24 03:41:58, Info                  DISM   DISM Manager: PID=4372 TID=2148 Event name for current DISM session is Global\{9818CE58-8EC1-4814-B7E6-166BB3917E49} - CDISMManager::CheckSessionAndLock
2017-11-24 03:41:58, Info                  DISM   DISM Manager: PID=4372 TID=2148 Create session event 0x654 for current DISM session and event name is Global\{9818CE58-8EC1-4814-B7E6-166BB3917E49}  - CDISMManager::CheckSessionAndLock
2017-11-24 03:41:58, Info                  DISM   DISM Manager: PID=4372 TID=2148 Copying DISM from "C:\Windows\System32\Dism" - CDISMManager::CreateImageSessionFromLocation
2017-11-24 03:42:01, Info                  DISM   DISM Manager: PID=4372 TID=2148 Successfully loaded the ImageSession at "C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17" - CDISMManager::LoadRemoteImageSession
2017-11-24 03:42:01, Info                  DISM   DISM Image Session: PID=4444 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Loading Provider from location C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Connecting to the provider located at C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:42:01, Info                  DISM   DISM OS Provider: PID=4444 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM OS Provider: PID=4444 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Loading Provider from location C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Connecting to the provider located at C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Loading Provider from location C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Warning               DISM   DISM Provider Store: PID=4444 Failed to Load the provider: C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Manager: PID=4372 TID=2148 Image session successfully loaded from the temporary location: C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17 - CDISMManager::CreateImageSession
2017-11-24 03:42:01, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-24 03:42:01, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 Target image information: OS Version=6.1.7601.23505, Image architecture=amd64 - CDismCore::LogImageSessionDetails
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Leave DismOpenSessionInternal - DismOpenSessionInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Session id is: 2 - DismOpenSessionInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Enter DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Input parameters: Session: 2, DriverPath: oem50.inf - DismGetDriverInfoInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Getting Provider DriverManager - CDISMProviderStore::GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Loading Provider from location C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Connecting to the provider located at C:\Windows\TEMP\F19329ED-7BDE-4627-972E-078312AF9E17\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2017-11-24 03:42:01, Info                  DISM   DISM OS Provider: PID=4444 Successfully loaded the hive. - CDISMOSServiceManager::DetermineBootDrive
2017-11-24 03:42:01, Info                  DISM   DISM Driver Manager: PID=4444 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2017-11-24 03:42:01, Error                 DISM   DISM Driver Manager: PID=4444 Error, file not found 'oem50.inf'. - CDriverManager::OpenPackageByFile(hr:0x80070002)
2017-11-24 03:42:01, Info                  DISM   DISM Driver Manager: PID=4444 Driver C:\Windows\System32\DriverStore\FileRepository\xtuacpidriver.inf_amd64_neutral_bd1bc401eb7a9d7a\xtuacpidriver.inf is boot-critical. - CDriverPackage::FillInPackageDetails
2017-11-24 03:42:01, Info                         IsDriverPackageSigned: File [C:\Windows\System32\DriverStore\FileRepository\xtuacpidriver.inf_amd64_neutral_bd1bc401eb7a9d7a\xtuacpidriver.inf] is signed by a catalog [C:\Windows\System32\DriverStore\FileRepository\xtuacpidriver.inf_amd64_neutral_bd1bc401eb7a9d7a\XtuAcpiDriver.cat]
2017-11-24 03:42:01, Info                  DISM   DISM Driver Manager: PID=4444 Signature status of driver C:\Windows\System32\DriverStore\FileRepository\xtuacpidriver.inf_amd64_neutral_bd1bc401eb7a9d7a\xtuacpidriver.inf is: SIGNED - CDriverPackage::InitSignatureStatus
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Leave DismGetDriverInfoInternal - DismGetDriverInfoInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Input parameters: Session: 2, DriverPath: C:\Windows\System32\DriverStore\FileRepository\xtuacpidriver.inf_amd64_neutral_bd1bc401eb7a9d7a\xtuacpidriver.inf - DismGetDriverInfoInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Enter DismDeleteInternal - DismDeleteInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4496 Leave DismDeleteInternal - DismDeleteInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Enter DismCloseSessionInternal - DismCloseSessionInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Input parameters: Session: 2 - DismCloseSessionInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 GetReferenceCount hr: 0x0 - CSessionTable::RemoveSession
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Refcount for DismSession= 2s 0 - CSessionTable::RemoveSession
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Successfully enqueued command object - CCommandThread::EnqueueCommandObject
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 ExecuteLoop: Cancel signaled - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 Leave CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   DISM Image Session: PID=4444 Disconnecting the provider store - CDISMImageSession::Final_OnDisconnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4444 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Manager: PID=4372 TID=2148 Closing session event handle 0x654 - CDISMManager::CloseImageSession
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: WimManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: VHDManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: GenericImagingManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: Compatibility Manager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Disconnecting Provider: FfuManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   DISM Provider Store: PID=4372 TID=2148 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2148 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Leave DismCloseSessionInternal - DismCloseSessionInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Enter DismShutdownInternal - DismShutdownInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Refcount for DismSession= 1s 0 - CSessionTable::RemoveSession
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4104 ExecuteLoop: CommandQueue signaled - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4104 Successfully dequeued command object - CCommandThread::DequeueCommandObject
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4104 ExecuteLoop: Cancel signaled - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4104 Leave CCommandThread::ExecuteLoop - CCommandThread::ExecuteLoop
2017-11-24 03:42:01, Info                  DISM   PID=4372 TID=4104 Temporarily setting the scratch directory. This may be overridden by user later. - CDISMManager::FinalConstruct
2017-11-24 03:42:01, Info                  DISM   PID=4372 TID=4104 Scratch directory set to 'C:\Windows\TEMP\'. - CDISMManager::put_ScratchDir
2017-11-24 03:42:01, Info                  DISM   PID=4372 TID=4104 DismCore.dll version: 10.0.14393.0 - CDISMManager::FinalConstruct
2017-11-24 03:42:01, Info                  DISM   Try to initialize Panther logging 1 times, last error: 0x0
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=4104 Leave CCommandThread::CommandThreadProcedureStub - CCommandThread::CommandThreadProcedureStub
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Deleted g_internalDismSession - DismShutdownInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Shutdown SessionTable - DismShutdownInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 Leave DismShutdownInternal - DismShutdownInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 DismApi.dll:                                          - DismShutdownInternal
2017-11-24 03:42:01, Info                  DISM   API: PID=4372 TID=2752 DismApi.dll: <----- Ending DismApi.dll session -----> - DismShutdownInternal
2017-11-29 08:58:46, Info                  DISM   PID=5344 Scratch directory set to 'C:\Users\MarkAZ\AppData\Local\Temp\'. - CDISMManager::put_ScratchDir
2017-11-29 08:58:46, Info                  DISM   PID=5344 Successfully loaded the ImageSession at "C:\Windows\System32\Dism" - CDISMManager::LoadImageSession
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Manager: PID=5344 Successfully created the local image session and provider store. - CDISMManager::CreateLocalImageSession
2017-11-29 08:58:46, Info                  DISM   DISM.EXE:
2017-11-29 08:58:46, Info                  DISM   DISM.EXE: <----- Starting Dism.exe session ----->
2017-11-29 08:58:46, Info                  DISM   DISM.EXE: Host machine information: OS Version=6.1.7601, Running architecture=amd64, Number of processors=2
2017-11-29 08:58:46, Info                  DISM   DISM.EXE: Executing command line: DISM  /Online /Cleanuo-Image /Scanhealth
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Getting Provider FolderManager - CDISMProviderStore::GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Loading Provider from location C:\Windows\System32\Dism\FolderProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=5344 Connecting to the provider located at C:\Windows\System32\Dism\FolderProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:46, Info                  DISM   DISM Manager: PID=5344 Successfully loaded the ImageSession at "C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC" - CDISMManager::LoadImageSession
2017-11-29 08:58:46, Info                  DISM   DISM Image Session: PID=7556 Instantiating the Provider Store. - CDISMImageSession::get_ProviderStore
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Initializing a provider store for the IMAGE session type. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\OSProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\OSProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:46, Info                  DISM   DISM OS Provider: PID=7556 Defaulting SystemPath to C:\ - CDISMOSServiceManager::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM OS Provider: PID=7556 Defaulting Windows folder to C:\Windows - CDISMOSServiceManager::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Attempting to initialize the logger from the Image Session. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\LogProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\LogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Getting Provider OSServices - CDISMProviderStore::GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Found and Initialized the DISM Logger. - CDISMProviderStore::Internal_InitializeLogger
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\PEProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Warning               DISM   DISM Provider Store: PID=7556 Failed to Load the provider: C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\PEProvider.dll. - CDISMProviderStore::Internal_GetProvider(hr:0x8007007e)
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Failed to get and initialize the PE Provider.  Continuing by assuming that it is not a WinPE image. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Finished initializing the Provider Map. - CDISMProviderStore::Final_OnConnect
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Getting Provider DISMLogger - CDISMProviderStore::GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Manager: PID=5344 Image session successfully loaded from the temporary location: C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC - CDISMManager::CreateImageSession
2017-11-29 08:58:46, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-29 08:58:46, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-29 08:58:46, Info                  DISM   DISM.EXE: Target image information: OS Version=6.1.7601.23505, Image architecture=amd64
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Getting the collection of providers from an image provider store type. - CDISMProviderStore::GetProviderCollection
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\CbsProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\CbsProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:46, Info                  DISM   DISM Provider Store: PID=7556 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:46, Info                  DISM   DISM Package Manager: PID=7556 Finished initializing the CbsConUI Handler. - CCbsConUIHandler::Initialize
2017-11-29 08:58:46, Info                  DISM   DISM Package Manager: PID=7556 CBS is being initialized for online use. More information about CBS actions can be located at: %windir%\logs\cbs\cbs.log - CDISMPackageManager::Initialize
2017-11-29 08:58:47, Info                  DISM   DISM Package Manager: PID=7556 Loaded servicing stack for online use only. - CDISMPackageManager::RefreshInstanceAndLock
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Provider has not previously been encountered.  Attempting to initialize the provider. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\MsiProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\MsiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Encountered a servicing provider, performing additional servicing initializations. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\IntlProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\IntlProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\DmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\DmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  CSI    00000001 Shim considered [l:256{128}]"\??\C:\Windows\Servicing\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_OBJECT_PATH_NOT_FOUND
2017-11-29 08:58:47, Info                  CSI    00000002 Shim considered [l:250{125}]"\??\C:\Windows\WinSxS\amd64_microsoft-windows-servicingstack_31bf3856ad364e35_6.1.7601.23505_none_681aa442f6fed7f0\pkgmgr.exe" : got STATUS_SUCCESS
2017-11-29 08:58:47, Info                  DISM   DISM OS Provider: PID=7556 Successfully loaded the hive. - CDISMOSServiceManager::DetermineBootDrive
2017-11-29 08:58:47, Info                  DISM   DISM Driver Manager: PID=7556 Further logs for driver related operations can be found in the target operating system at %WINDIR%\inf\setupapi.offline.log - CDriverManager::Initialize
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\UnattendProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\UnattendProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\SmiProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\SmiProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Loading Provider from location C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\TransmogProvider.dll - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Connecting to the provider located at C:\Users\MarkAZ\AppData\Local\Temp\1A5C3070-7BD2-4DDD-8D4F-47D4318B8EDC\TransmogProvider.dll. - CDISMProviderStore::Internal_LoadProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Getting Provider DISM Package Manager - CDISMProviderStore::GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Provider has previously been initialized.  Returning the existing instance. - CDISMProviderStore::Internal_GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Getting Provider DISM Unattend Manager - CDISMProviderStore::GetProvider
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Got the collection of providers. Now enumerating them to build the command table.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Package Manager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Package Manager.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: OSServices
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: MsiManager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: MsiManager.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: IntlManager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: IntlManager.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DriverManager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DriverManager.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Unattend Manager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: DISM Unattend Manager.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: DISM Log Provider
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: SmiManager
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Attempting to add the commands from provider: Edition Manager
2017-11-29 08:58:47, Info                  DISM   DISM Transmog Provider: PID=7556 Current image session is [ONLINE] - CTransmogManager::GetMode
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Succesfully registered commands for the provider: Edition Manager.
2017-11-29 08:58:47, Error                 DISM   DISM.EXE: No providers were found that support the command(cleanuo-image). HRESULT=0
2017-11-29 08:58:47, Info                  DISM   DISM Image Session: PID=7556 Disconnecting the provider store - CDISMImageSession::Final_OnDisconnect
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(DISM Package Manager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Package Manager: PID=7556 Finalizing CBS core. - CDISMPackageManager::Finalize
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: DISM Package Manager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(MsiManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: MsiManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(IntlManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: IntlManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Found the PE Provider.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(DriverManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: DriverManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(DISM Unattend Manager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: DISM Unattend Manager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(SmiManager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: SmiManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Finalizing the servicing provider(Edition Manager) - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: Edition Manager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Releasing the local reference to OSServices. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Disconnecting Provider: OSServices - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=7556 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: Image session has been closed. Reboot required=no.
2017-11-29 08:58:47, Info                  DISM   DISM.EXE: <----- Ending Dism.exe session ----->
2017-11-29 08:58:47, Info                  DISM   DISM Image Session: PID=5344 Disconnecting the provider store - CDISMImageSession::Final_OnDisconnect
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=5344 Disconnecting Provider: FolderManager - CDISMProviderStore::Internal_DisconnectProvider
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=5344 Found the OSServices.  Waiting to finalize it until all other providers are unloaded. - CDISMProviderStore::Final_OnDisconnect
2017-11-29 08:58:47, Info                  DISM   DISM Provider Store: PID=5344 Releasing the local reference to DISMLogger.  Stop logging. - CDISMProviderStore::Internal_DisconnectProvider
Re: [W7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
Sorry. Didn't include it because of the error when attempting to run the command. CheckSUR.log is attached.
I reported that update as successfully installing in this post. To double check I downloaded and attempted to install. I got the message that it was already on the computer. KB4048957 will still not install.
Install Update with DISM
  1. Download the update MSU here: http://download.windowsupdate.com/d..._83688ecf3a901fc494ee67b5c57e35f0a09dc455.msu
    cd C:\temp
    expand Windows6.1-kb4048957-x64_83688ecf3a901fc494ee67b5c57e35f0a09dc455.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB4048957-x64.cab
  9. Paste (Ctrl+V) it into your next post.
  10. Zip and attach C:\Windows\Logs\CBS\CBS.log
Microsoft Windows [Version 6.1.7601]
Copyright (c) 2009 Microsoft Corporation. All rights reserved.
C:\Users\MarkAZ>cd C:\temp
C:\temp>expand Windows6.1-kb4048957-x64_83688ecf3a901fc494ee67b5c57e35f0a09dc455
.msu -f:* C:\temp
Microsoft (R) File Expansion Utility Version 6.1.7600.16385
Adding C:\temp\WSUSSCAN.cab to Extraction Queue
Adding C:\temp\Windows6.1-KB4048957-x64.cab to Extraction Queue
Adding C:\temp\Windows6.1-KB4048957-x64-pkgProperties.txt to Extraction Queue
Adding C:\temp\Windows6.1-KB4048957-x64.xml to Extraction Queue
Expanding Files ....
Expanding Files Complete ...
4 files total.
C:\temp>DISM.exe /Online /Add-Package /PackagePath:C:\temp\Windows6.1-KB4048957-
x64.cab
Version: 6.1.7600.16385
Image Version: 6.1.7601.18489
Processing 1 of 1 - Adding package Package_for_RollupFix~31bf3856ad364e35~amd64~
~7601.23934.1.2
[=== 6.0% ]
An error occurred - Package_for_RollupFix Error: 0x80073701
Error: 14081
The referenced assembly could not be found.
C:\temp>
Great! This is very helpful.
Remove Update Manually
wusa /uninstall /KB:4025341
Search with Farbar Recovery Scan Tool (FRST)
  • Download FRST64 and save it to the Desktop.
  • Open the Command Prompt as Administrator (Tutorial)
  • Type or copy/paste the following command:
dism /online /Get-FeatureInfo /FeatureName:TFTP|find "completed"
  • Wait for the command to finish with "The operation completed successfully"
  • Close the window "Administrator: Command Prompt"
  • Execute FRST/FRST64 right click on the icon
    and choose Run as Administrator. Make sure all other windows are closed.
    (When the tool opens for the first time, you must click Yes on the disclaimer.)
  • On the Search box (1) type or copy and paste the following text:
    KB4025341
  • Press the Search Registry button.
  • Wait for the search to finish FRST will produce a log called (SearchReg.txt) in the same directory the Tool is run from.
  • Please attach the log to your post.
Command Prompt run as Adminstrator
Command dism /online /Get-FeatureInfo /FeatureName:TFTP|find "completed" entered with no add'l spaces
No result is displayed or notification that the operation even ran. Just reverts back to the user's command prompt.
Step#1 - FRST Fix
This has been running for over two hours and I have to leave. Is this normal for the FRST to take this long?
No, please reboot your computer, disable your antivirus software and try again.
FYI - I ran FRST in Safe Mode and it still took 2 hours.
Got the following message when attempting to upload Fixlog.txt:
Please click here to view the log file: Fixlog.txt - Google Drive
I don't think that worked. Please try updates again and attach CBS.log if any fail.
I get home in about 4 hours and I'll update then. Question(s) in the meantime........1) Would an upgrade to Windows 10 take care of this and any other issues? 2) What's your take on Win 10?
I can't thank you enough for being so diligent.
I like it very much and I'd recommend it because it's newer and safer. We can try it if you'd like. And not to worry even if there are problems while upgrading, we can trroubleshoot these as well.
