[SOLVED] [7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
Re: [W7SP1Pro x64] Updates KB2952664 and KB4048957: Error code 80073701
Ran the Update. There are now NO critical update errors. KB4048957 was resolved during the last run of FRST. That said, there were three (3) optional updates and when I tried installing them there were 2 errors. As I said, I don't care about the IE error as I have disables IE services. I would attach the CBSLog file except that it is 398MB!! That is unreal. Can it be deleted and the Update attempted again?
Yes, CBS.log files can get big. But if you don't care about these optional IE updates, you don't have to worry. If you'd like I can help you with that as well, but then I'm gonna need CBS.log :)
Excellent! Please do the following:
Remove Update Manually
wusa /uninstall /KB:3124275
Search with Farbar Recovery Scan Tool (FRST)
  • Download FRST or FRST64 and save it to the Desktop.
    (Please pick the version that matches your operating system's bit type. If you don't know which version matches your system, try FRST if it says that is not compatible with your OS you have to use FRST64)
  • Open the Command Prompt as Administrator (Tutorial)
  • Type or copy/paste the following command:
               dism /online /Get-FeatureInfo /FeatureName:TFTP|find "completed"
  • Wait for the command to finish with "The operation completed successfully"
  • Close the window "Administrator: Command Prompt"
  • Execute FRST/FRST64 right click on the icon
    and choose Run as Administrator. Make sure all other windows are closed.
    (When the tool opens for the first time, you must click Yes on the disclaimer.)
  • On the Search box (1) type or copy and paste the following text:
    KB3124275
  • Press the Search Registry button.
  • Wait for the search to finish FRST will produce a log called (SearchReg.txt) in the same directory the Tool is run from.
  • Please copy and paste the log to your post.
Step#1 - FRST Fix
Afterwards, try updates and if any fail, attach CBS.log.
Actually one ot them did install, so we've made progress!
wusa /uninstall /KB:3076949
Step#1 - FRST Fix
Fixlog:
Fix result of Farbar Recovery Scan Tool (x64) Version: 30-11-2017Ran by MarkAZ (05-12-2017 11:38:09) Run:8
Running from C:\Users\MarkAZ\Desktop
Loaded Profiles: MarkAZ (Available Profiles: MarkAZ)
Boot Mode: Normal
fixlist content:
CreateRestorePoint:
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0]
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-1_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-2_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-3_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-4_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-5_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-6_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-4_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-5_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-6_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-1_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-2_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-3_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-7_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-8_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-9_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-7_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-8_neutral_LDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-9_neutral_GDR
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0|Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0|Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-FS-RemoteClient~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-FS-RemoteClient~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Remote-Cli-Core~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Remote-Cli-Core~31bf3856ad364e35~amd64~~0.0.0.0|Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0
DeleteValue:HKEY_USERS\S-1-5-21-2609069616-2479026874-2953070309-1000\Software\Microsoft\Windows\CurrentVersion\Applets\Regedit|LastKey
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0]
[-HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0]
DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0\\DeleteValue:HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ApplicabilityEvaluationCache\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0] => value not found.
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-1_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-2_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-3_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_573d36d2f640b7cf\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-4_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-5_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-6_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_13c5fa7052c6e7f0\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_05ff6291baf854a9\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-4_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-5_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-6_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\amd64_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_d51e5aedb43950ed\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-1_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-2_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-3_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-clientonly_31bf3856ad364e35_0.0.0.0_none_6191e1252aa179ca\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\wow64_microsoft-windows-webdavredir-serveronly_31bf3856ad364e35_0.0.0.0_none_10540ce3ef5916a4\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-7_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-8_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-davclient_31bf3856ad364e35_0.0.0.0_none_b7a75eec9a6976ba\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-9_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.Trigger_1 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-7_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-8_neutral_LDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\ComponentDetect\x86_microsoft-windows-webdavredir-webclient_31bf3856ad364e35_0.0.0.0_none_78ffbf69fbdbdfb7\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0.3076949-9_neutral_GDR => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-Printing-Server-Role-Package~31bf3856ad364e35~amd64~~0.0.0.0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0\\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\Microsoft-Windows-ServerDesktopExperience~31bf3856ad364e35~amd64~~0.0.0.0\\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-FS-RemoteClient~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-FS-RemoteClient~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Remote-Cli-Core~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageDetect\WinEmb-Remote-Cli-Core~31bf3856ad364e35~amd64~~0.0.0.0\\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => value removed successfully
HKEY_USERS\S-1-5-21-2609069616-2479026874-2953070309-1000\Software\Microsoft\Windows\CurrentVersion\Applets\Regedit\\LastKey => value removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~0.0.0.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~0.0.0.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\PackageIndex\Package_for_KB3076949~31bf3856ad364e35~amd64~~0.0.0.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_1_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_2_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_3_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949_SP1~31bf3856ad364e35~amd64~~6.1.1.0 => key not found
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key removed successfully
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_for_KB3076949~31bf3856ad364e35~amd64~~6.1.1.0 => key not found
==== End of Fixlog 11:40:09 ====
Path to zipped CBS log file: CBS.zip - Google Drive
wusa /uninstall /KB:4015549
"4. Let me know if it says it was successful or if there are any errors."
