Bootloop after trying Installing KB4493473
I Think now is the 10x reboot. Should i Stop it? One Question, does a Virtuall machine on a HyperV needs more Reboots?
I asked me one Question, why do we install
2019-05 Servicing Stack Update für Windows Server 2016 für x64-basierte Systeme (KB4498947) instead of
2019-04 Kumulatives Update für Windows Server 2016 für x64-basierte Systeme (KB4493473) which was before and does not work.
Ok, I let it running this Night and report tomorrow morning. Again thank you for your gorgeous help so far.
Good night
Good moring,
the System was still in Update modus und restarts the hole night.
SFC scannow : After Sfc /scannow, I get the Error: There is a system repair pending which requires reboot to complete. Restart Windows and run SFC scan again. Reboot does not cause anything.
attached the new cbs.txt
Version: 10.0.14393.0
Abbildversion: 10.0.14393.0
[==========================100.0%==========================] Der Wiederherstellungsvorgang wurde erfolgreich abgeschlossen.
Der Vorgang wurde erfolgreich beendet.
Now I am at that point again.
I try Sfc scannow again an get
In German: "Es steht eine Systemreparatur aus, deren Abschluss einen Neustart erfordert"
Attached new cbs.zip
Windows Repair tool and sfc scannow done with Result:
Windows Resource Protection did not find any integrity violations." / "Der Windows-Ressourcenschutz hat keine Integritätsverletzungen gefunden. "
Should I start Dism /Online /Cleanup-Image /RestoreHealth again?
The Thing is, we have 4 VM on the Hyper V. This one is the only VM who was problems.
After the Reboot the Windows Updates wants to Install
2019-11 Servicing Stack Update für Windows Server 2016 für x64-basierte Systeme (KB4520724)
and
why does the Updates doesn't want to install KB4498947
About for Question above:
"Is it an option to temporarily disable Hyper-V while we troubleshoot this? I've had a similar issue recently and it was the root cause. "
this is possible.
After auto-Download from the Windows-Update without Installation, the SFC scannow, says again Error: There is a system repair pending which requires reboot to complete. Restart Windows and run SFC scan again.
Please remove hyper V and then try installing only the update I linked, so the Servicing Stack 2019-04 and then reboot and retry updates.
Do not restore Hyper-V until you hear back from me.
I am off to bed now.
Good night.
Do not understand, how can I Access a virtuelle Hyper-V-Maschine, when I remove Hyper-V-Server?
Good Night
Hello again and happy new year,
Just that you understand me: We have 1 physically Server-Hardware Windows 2016 Server which works as Hyper-V-Server.
One the Hyper-V-Server we installed 4 Virtuelle Windows 2016 Server: 2 DC, 1 Terminalsever and 1 Fileserver.
The Fileserver has the problems with the Rebootloops, like i showed in the Video before.
I Try what unrecommend above, but I get the same Problem. The SFc-Scan before installation was OK.
Attached the file.
