Sysnative Windows Update
Inactive
- Oct 9, 2014
- 741
Hi!
Happy New Year!
We have resolved all the corruption, SFC and DISM are not going to show anything new.
Are all the VMs fully up to date and the same in terms of software?
Does the issue occur with every update you try to install on the FileServer?
Please do the following:
Step#1 - FRST Scan
2. Right-click FRST64.exe and click Run as Administrator to run it as administrator. When the tool opens, click Yes to disclaimer.
3. Please ensure you place a check mark in the Addition.txt check box at the bottom of the form before running (if not already checked).
4. Press Scan button.
6. Please attach the log back here.
7. Another log (Addition.txt - also located in the same directory as FRST64.exe) will be generated Please also attach that along with the FRST.txt in your reply.
Happy New Year!
Step#1 - FRST Scan
