Can't fix error 0x80004002
Please run the following command in an elevated PowerShell prompt and post the result in your next post.
Get-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\DoSvc"
Windows PowerShell
Copyright (C) Microsoft Corporation. Tutti i diritti riservati.
Installa la versione più recente di PowerShell per nuove funzionalità e miglioramenti. Migrating from Windows PowerShell 5.1 to PowerShell 7 - PowerShell
PS C:\WINDOWS\system32> Get-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\DoSvc"
DependOnService : {rpcss}
Description : @%systemroot%\system32\dosvc.dll,-101
DisplayName : @%systemroot%\system32\dosvc.dll,-100
ErrorControl : 1
FailureActions : {128, 81, 1, 0...}
ImagePath : C:\WINDOWS\System32\svchost.exe -k NetworkService -p
LaunchProtected : 2
ObjectName : NT Authority\NetworkService
ServiceDll : C:\WINDOWS\system32\dosvc.dll
ServiceDllUnloadOnStop : 1
ServiceSidType : 1
Start : 2
SvcMemHardLimitInMB : 39
SvcMemMidLimitInMB : 27
SvcMemSoftLimitInMB : 15
Type : 16
DelayedAutostart : 1
PSPath : Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\DoSvc
PSParentPath : Microsoft.PowerShell.Core\Registry::HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services
PSChildName : DoSvc
PSDrive : HKLM
PSProvider : Microsoft.PowerShell.Core\Registry
Please run the command in the Terminal (PowerShell) instead of CMD!
It should show:
PS C:\Users\Username> Get-ItemProperty -Path "HKLM:\SYSTEM\CurrentControlSet\Services\DoSvc"
ErrorControl           : 1
LaunchProtected        : 2
ServiceSidType         : 1
Start                  : 2
Type                   : 16
PSChildName            : DoSvc
PSDrive                : HKLM
This looks good, please export the state of all the services using the following command in CMD.
WMIC SERVICE GET caption, name, startmode, state > "%userprofile%\desktop\services.txt"
Please rename FRST64 to English
Start the
  • Right-click on English.exe and select "Run as administrator".
  • Press the Fix button.
Microsoft Windows [Versione 10.0.22631.4317]
(c) Microsoft Corporation. Tutti i diritti riservati.
C:\Windows\System32>DISM /online /cleanup-image /RestoreHealth
Strumento Gestione e manutenzione immagini distribuzione
Versione: 10.0.22621.2792
Versione immagine: 10.0.22631.4317
Errore: 0x80004002
Interfaccia non supportata.
Il file di registro di Gestione e manutenzione immagini
distribuzione (DISM) è disponibile in C:\WINDOWS\Logs\DISM\dism.log
the dism still does not work it looks
Hmm, please run also the following commands:
Dism /Online /Cleanup-Image /ScanHealth
Dism /Online /Cleanup-Image /CheckHealth
DISM /online /cleanup-image /AnalyzeComponentStore
C:\Windows\System32>Dism /Online /Cleanup-Image /ScanHealth
Errore: 0x80004002
C:\Windows\System32>Dism /Online /Cleanup-Image /CheckHealth
L'archivio dei componenti non è ripristinabile.
Operazione completata.
C:\Windows\System32>DISM /online /cleanup-image /AnalyzeComponentStore
i want to stress how much i'm grateful for the help you're giving me, really thank you
This is interesting, (CheckHealth) completed successfully, (ScanHealth / ResoreHealth) are actually the same commands but the first one will not perform any repairs. Is (AnalyzeComponentStore) still running because it did not shows an error?
looks like it did not starded and i didn't noticed, here's the results
Errore: 0x80004002
so just to be clear, this means "the component's archive is not restorable. operation complete"
Export CBS (Component Based Servicing) hive
  • Click on the Start button and type regedit
  • Name this file ComponentBasedServicing (with no file extension) and save it to your Desktop.
  • Right-click on the saved file and choose Send > Compressed (zipped) Folder.
Hmm, nothing special and this hive looks good. So please shutdown the system completely and run DISM again once the system has restarted.
ok, THIS IS REALLY STRANGE: it says access negated when i open the cmd as admin and run the dism
edit: i rebooted again and now it run the dism, still same stuff tho:
Errore: 0x80004002
Start the
  • Right-click on FRST64.exe and select "Run as administrator".
