Can't fix error 0x80004002
I can only say never use fixes which are made for other systems because it may break your system badly. Also, I cannot guarantee that the system will be stable after removing some wrong fixes, so the best way is to perform a clean install.
So that's my bad, next team i'll learn to read better. Thank you so, so much for your help and time sir
If you think it's better not to try to remove the fixes i wrongfully tried (i can tell which one tried, it was the one in the link i posted at the start of the thread), only if you can suggest me the best way to clean install
The link in the first post refers to a Windows 10 system, not Server 2022 so you have used multiple fixes for different systems as it seems. However, I see you have some restore points, did you apply the fixes before or after 31-03-2025?
31-03-2025 22:04:49 Punto di controllo pianificato
03-04-2025 22:18:54 Windows Update
03-04-2025 22:18:58 Windows Update
The wrong fix i downloaded from here are from the 28\03. The other fixes may refer to the ISO i tried to install for updating manually, if so they're from the 31\03
Okay, then we cannot use this restore point! So then I would start to backup everything and reinstall the OS.
don't know maybe you had some kind of guide or tutorial message like the ones you used during this thread for doing the best and safest way possible
