[SOLVED] Cant run SFCfix cause of side by side configuration is incorrect
The tool FRST64.exe is on your desktop now. Keep it there.
Do you have a folder called Manifests on your desktop ?
Open that folder. Does it contain a folder called Manifests also ?
I don't think it does, but i can't verify it right now cause I'm about to sleep
But the last time i opened it, which is a few hours ago.I didn't remember seeing a folder called manifests
Ok. No problem.
Open the folder Manifests which is on your desktop.
Provide a screenshot of what it contains.
Okay. All clear now.
  3. Press the Fix button.
The source location is correct now but it did not copy the files. Probably due to access permissions.
Perform the next fix.
So for some reason my pc kinda died after yesterday
So when i boot it up the screen is on but it's blank
And after some time i took of the battery off and turn it on again
The PC(laptop) went into this mode (look at the pic)
And I'm considering just refreshing the PC cause I think that would fix most of my problems and i would still have most of my files, the only downside and reason i didn't do this from the start is because I didn't want to reinstall everything
So what's your opinion about this and what do you think i should do?
I'm gonna turn my pc off for now and I'm not gonna do anything to it
Before you ran my latest fix or after that ?
Select Troubleshoot in your screenshot then provide a new image what is displayed next.
I tried running it but it took too long ( it was late at night i had to sleep) so i closed everything and shut down the PC but i noticed that the indicator lights weren't turning of and the fan is still on(the PC is not shutting down) so i held down the power button and the indicator lights turn off.
The next day i wanted to try doing the fix again so i started up the PC and that happened
I don't see a problem in the FRST fix.
I don't think it's because of the FRST FIX
In the third screenshot, select Refresh your PC.
If that doesn't help, select Startup Repair in the fourth screenshot.
So to refresh the PC i need the password and the person who gave me the PC forgot want the password is
Usually when i boot up the PC it doesn't ask for the password so i never needed to know or change it
So is there a way to get the password or bypass it?
So to refresh the PC i need the password and the person who gave me the PC forgot want the password is.
Clearing the password inputbox, the name of this person, 'admin', a single space character or one of these common passwords doesn't allow you to proceed ?
If not, provide a screenshot.
So after contacting the previous owner i have aquired the password so i have refreshed the PC and for now everything seems to work well
Thank you very much for helping me
