[SOLVED] CBS MUM Missing
If I had searchReg.txt to FixList.txt "convertor" I could delete all superseded on my own... but not sure I have the good procedure :grin1:
Good job anyway !
Step#1 - FRST Fix
Start time: 2018-11-24 10:10:15.765
Using .txt script file at C:\Users\jp\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23539_none_996c1f75ac7e2a84.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23539_none_605e8e6c6907b428.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23539_none_d11946ba3b790a7f.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23539_none_6eb09a7b2b8eb7ed.
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.23539_none_e5c88a84fded5e35.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23539_none_996c1f75ac7e2a84.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23539_none_605e8e6c6907b428.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23539_none_d11946ba3b790a7f.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23539_none_6eb09a7b2b8eb7ed.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.23539_none_e5c88a84fded5e35.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_microsoft-windows-security-digest_31bf3856ad364e35_6.1.7601.23539_none_996c1f75ac7e2a84.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-ncrypt-dll_31bf3856ad364e35_6.1.7601.23539_none_605e8e6c6907b428.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\wow64_microsoft-windows-wow64_31bf3856ad364e35_6.1.7601.23539_none_d11946ba3b790a7f.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-os-kernel_31bf3856ad364e35_6.1.7601.23539_none_6eb09a7b2b8eb7ed.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-advapi32_31bf3856ad364e35_6.1.7601.23539_none_e5c88a84fded5e35.
Finish time: 2018-11-24 10:10:16.482
Script hash: yaBMRAK8M/yTTkRPkRBdG7p5/CHqrWY5LsSegVbVtjk=
Binary Version 6.1.7601.23471
2018-11-24 15:46
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.6.7601.18917_fr-fr_898a72bb075034fb
(f) CSI Missing Winning Component Key 0x00000000 wow64_microsoft-windows-w..lient-aux.resources_31bf3856ad364e35_7.6.7601.18917_fr-fr_93df1d0d3bb0f6f6
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-winsetupui_31bf3856ad364e35_6.1.7601.18917_none_bd352493dc47b3aa
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..ent-internalupgrade_31bf3856ad364e35_7.6.7601.18917_none_2b9ef68688675bec
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-windowsupdate-adm_31bf3856ad364e35_7.6.7601.18917_none_a3f78987ce3af290
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-s..-downlevel.binaries_31bf3856ad364e35_6.3.9600.17691_none_5f5cc410ff7c8bf5
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..client-ui.resources_31bf3856ad364e35_7.6.7601.18917_fr-fr_f0b51a171a567377
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-windowsupdateclient-ui_31bf3856ad364e35_7.6.7601.18917_none_6512f64d051a06d9
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..owsupdateclient-aux_31bf3856ad364e35_7.6.7601.18917_none_cd770cee78d61d2b
(f) CSI Missing Winning Component Key 0x00000000 wow64_microsoft-windows-w..owsupdateclient-aux_31bf3856ad364e35_7.6.7601.18917_none_d7cbb740ad36df26
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..ient-core.resources_31bf3856ad364e35_7.6.7601.18917_fr-fr_df5d130c8ca87bf6
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..pdate-adm.resources_31bf3856ad364e35_7.6.7601.18917_fr-fr_391443947137425c
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..pdateclient-activex_31bf3856ad364e35_7.6.7601.18917_none_7781cd2f1e8d4f27
(f) CSI Missing Winning Component Key 0x00000000 wow64_microsoft-windows-w..pdateclient-activex_31bf3856ad364e35_7.6.7601.18917_none_81d6778152ee1122
(f) CSI Missing Winning Component Key 0x00000000 amd64_microsoft-windows-w..wsupdateclient-core_31bf3856ad364e35_7.6.7601.18917_none_e765d2a26515c428
Summary:
Seconds executed: 219
Found 15 errors
CSI Missing Winning Component Key Total count: 15
It's a French system installed from French DVD, no additional language pack.
Retrieve Components Hive
4. The file will likely be too large to upload here so please upload to a file sharing service and just provide the link here.
