[SOLVED] CBS MUM Missing
FRST Registry Search
3. Select the Programs group.
4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog. Wait until this dialog populates with information. If this does not happen for some reason, please continue with the steps anyway.
Note: This loads your components hive which is what we want. Please keep this dialog open while you perform the remaining steps.
5. Please download Farbar Recovery Scan Tool and save it to your Desktop.
7. Copy and paste
KB4457144 into the Search box and click the Search Registry button.
8. When the scan is complete a notepad window will open with the results. Please attach this to your next reply. It is saved on your desktop named SearchReg.txt.
Step#1 - FRST Fix
Step#1 - FRST Fix
Step#1 - FRST Fix
the file
why about searching for all superseded installed payloads at the same time ? then fixing them all ? wouldn't it be faster ?
No, because we cannot do that reliably. I have to follow the logs and we will eventually succeed.
Step#1 - FRST Fix
