[SOLVED] Corrept System files, Can't repair them. Won't update. Please HELP
ok says only one is failing.
Jim
Please do the following:
FRST Registry Search
6. Copy and paste KB3146706 into the Search box and click the Search Registry button.
When able, do the following:
Install Update with DISM
  1. Download this update and save to your desktop. The file name will be Windows6.1-KB3146706-x64.cab.zip.
  2. Right-click on this file and select Extract All... Click the Extract button. You can close the folder window that opens
  4. When you see Command Prompt on the list, right-click on it and select Run as administrator. Go ahead and allow if you receive the UAC prompt.
  5. Copy and paste the following command into the command prompt window and press enter.
    dism /online /add-package /packagepath:%userprofile%\desktop\Windows6.1-KB3146706-x64.cab
    Restart Windows to complete this operation. <---You may not get this line.
    Do you want to restart the computer now (Y/N)? <---You may not get this line.
Go ahead and do so if prompted. Let me know what errors if any come up. If you do get errors, please zip/attach your CBS.log
Note: If you get an error about the packages not being found, please use the following command instead:
dism /online /add-package /packagepath:%userprofile%\desktop\Windows6.1-KB3146706-x64.cab\Windows6.1-KB3146706-x64.cab
