Retrieve Components Hive
2. Please copy this file to your desktop. Note: If you receive an error that this file is in-use, simply reboot your computer and try again.
You should receive the message: The operation completed successfully.
Restart Windows to complete this operation. <---You may not get this line.
Do you want to restart the computer now (Y/N)? <---You may not get this line.
Go ahead and do so if prompted. Let me know what errors if any come up. If you do get errors, please zip/attach your CBS.log
Note: If you get an error that no packages that require processing were found, use the following command instead:
disaster... Installed 12 of 13 updates, I rebooted, took forever to shut down,
reboot started, started to install updates. Updates failed, said rolling back updates.
I took some pics.
Please find link to CBS.zip file.
Add Missing Package
1. Click the Start button and type cmd.exe in the search box.
2. Right-click on the cmd that comes up and select Run as administrator.
3. Once you are at the command prompt, copy/paste the following line and hit enter. pnputil -a C:\windows\WinSxS\amd64_machine.inf_31bf3856ad364e35_6.1.7601.24056_none_1899009dee8d03f0\machine.inf
Add Missing Package
3. Once you are at the command prompt, copy/paste the following line and hit enter. pnputil -a C:\windows\WinSxS\amd64_input.inf_31bf3856ad364e35_6.1.7601.24145_none_7eff7eb14ff2a230\input.inf
Let me know if it says successfully installed. If it does, please attempt the updates again.
