[SOLVED] Corrept System files, Can't repair them. Won't update. Please HELP
ok did this one ok.
Jim
rebooted
looks like it took that one.
Jim
Please try the following:
Step#1 - FRST Fix
Thank you.
Add Missing Package
1. Click the Start button and type cmd.exe in the search box.
2. Right-click on the cmd that comes up and select Run as administrator.
3. Once you are at the command prompt, copy/paste the following line and hit enter.
pnputil -a C:\windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.1.7601.24291_none_bba030ab1f623588\cpu.inf
Let me know if it says successfully installed. If it does, please retry the updates and attach the logs if any fail.
