[SOLVED] Error Code 0x80073712
Hi!
Afterwards, run DISM again and attach CBS.log if it fails.
Start time: 2020-01-29 10:58:01.558
Microsoft Windows Server 2012  - amd64
Using .zip script file at D:\Profilo\Administrator\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\x86_netfx4-clrjit_dll_b03f5f7f11d50a3a_4.0.9296.16601_none_7fc481119c558a85\clrjit.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\msil_system.xaml_b77a5c561934e089_4.0.9296.16627_none_49b98219c75fdfa4\System.Xaml.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_netfx4-mscordacwks_dll_b03f5f7f11d50a3a_4.0.9296.16830_none_f9832e35073e35f4\mscordacwks.dll
Successfully took permissions for file or folder C:\Windows\WinSxS\Manifests\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.4.9600.19572_none_de8c6dad9da71a5e.manifest
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\x86_netfx4-clrjit_dll_b03f5f7f11d50a3a_4.0.9296.16601_none_7fc481119c558a85\clrjit.dll to C:\Windows\WinSxS\x86_netfx4-clrjit_dll_b03f5f7f11d50a3a_4.0.9296.16601_none_7fc481119c558a85\clrjit.dll.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\msil_system.xaml_b77a5c561934e089_4.0.9296.16627_none_49b98219c75fdfa4\System.Xaml.dll to C:\Windows\WinSxS\msil_system.xaml_b77a5c561934e089_4.0.9296.16627_none_49b98219c75fdfa4\System.Xaml.dll.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_netfx4-mscordacwks_dll_b03f5f7f11d50a3a_4.0.9296.16830_none_f9832e35073e35f4\mscordacwks.dll to C:\Windows\WinSxS\amd64_netfx4-mscordacwks_dll_b03f5f7f11d50a3a_4.0.9296.16830_none_f9832e35073e35f4\mscordacwks.dll.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\Manifests\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.4.9600.19572_none_de8c6dad9da71a5e.manifest to C:\Windows\WinSxS\Manifests\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.4.9600.19572_none_de8c6dad9da71a5e.manifest.
Successfully restored ownership for C:\Windows\WinSxS\x86_netfx4-clrjit_dll_b03f5f7f11d50a3a_4.0.9296.16601_none_7fc481119c558a85\clrjit.dll
Successfully restored permissions on C:\Windows\WinSxS\x86_netfx4-clrjit_dll_b03f5f7f11d50a3a_4.0.9296.16601_none_7fc481119c558a85\clrjit.dll
Successfully restored ownership for C:\Windows\WinSxS\msil_system.xaml_b77a5c561934e089_4.0.9296.16627_none_49b98219c75fdfa4\System.Xaml.dll
Successfully restored permissions on C:\Windows\WinSxS\msil_system.xaml_b77a5c561934e089_4.0.9296.16627_none_49b98219c75fdfa4\System.Xaml.dll
Successfully restored ownership for C:\Windows\WinSxS\amd64_netfx4-mscordacwks_dll_b03f5f7f11d50a3a_4.0.9296.16830_none_f9832e35073e35f4\mscordacwks.dll
Successfully restored permissions on C:\Windows\WinSxS\amd64_netfx4-mscordacwks_dll_b03f5f7f11d50a3a_4.0.9296.16830_none_f9832e35073e35f4\mscordacwks.dll
Successfully restored ownership for C:\Windows\WinSxS\Manifests\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.4.9600.19572_none_de8c6dad9da71a5e.manifest
Successfully restored permissions on C:\Windows\WinSxS\Manifests\wow64_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_11.4.9600.19572_none_de8c6dad9da71a5e.manifest
Currently storing 26 datablocks.
Finish time: 2020-01-29 10:58:11.023
Script hash: BVjMr7QUrNdx9+6hozhQCSkc/zj3W8uV3Ae38cAiCGc=
C:\Windows\system32>Dism /Online /Cleanup-Image /RestoreHealth
Version: 6.2.9200.22807
Image Version: 6.2.9200.22807
Error: 87
An error occurred while processing the command.
Ensure that the command-line arguments are valid. For more information, review t
he log file.
2. Try running DISM just like you have in the past.
FRST Registry Search
6. Copy and paste 11.4.9600.19463 into the Search box and click the Search Registry button.
After uninstalling, this is result:
- KB4537767 error 80070490
- KB3205972 error 8004FF04
- KB4537807 error 80070490
- KB4538157 error 80070490
- KB4537814 error 80070490
- KB4538123 error 80070490
excuse me in the delay for the answer, but it's a difficult time. I attach the file as you requested and of course now updates are accumulating as they are published.
