[SOLVED] Error Code 0x80073712
Hi!
No worries.
Add Missing Package
1. Click the Start button and type cmd.exe in the search box.
2. Right-click on the cmd that comes up and select Run as administrator.
3. Once you are at the command prompt, copy/paste the following line and hit enter.
pnputil -a C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf
Let me know if it says successfully installed. If it does, try installing the update again. If it fails, attach the setupapi.dev.log again.
This is result:
C:\Windows\system32>pnputil -a C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_
Microsoft PnP Utility
Processing inf : cpu.inf
Adding the driver package failed : The third-party INF does not contain digital
signature information.
Total attempted: 1
Number successfully imported: 0
Okay.
Please do the following:
FRST Registry Search
6. Copy and paste 6.2.9200.22904 into the Search box and click the Search Registry button.
Afterwards, retry adding the missing driver package as you've done previously.
Start time: 2020-04-08 10:53:22.335
Microsoft Windows Server 2012  - amd64
Using .zip script file at D:\Profilo\Administrator\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdk8.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdppm.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\fxppm.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\intelppm.sys
Successfully took permissions for file or folder C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\processr.sys
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdk8.sys to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdk8.sys.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdppm.sys to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdppm.sys.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\fxppm.sys to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\fxppm.sys.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\intelppm.sys to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\intelppm.sys.
Successfully copied file C:\Users\Administrator\AppData\Local\niemiro\Archive\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\processr.sys to C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\processr.sys.
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdk8.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdk8.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdppm.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\amdppm.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\cpu.inf
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\fxppm.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\fxppm.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\intelppm.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\intelppm.sys
Successfully restored ownership for C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\processr.sys
Successfully restored permissions on C:\Windows\WinSxS\amd64_cpu.inf_31bf3856ad364e35_6.2.9200.22904_none_b6f3fa1c92023af1\processr.sys
Currently storing 32 datablocks.
Finish time: 2020-04-08 10:53:31.319
Script hash: sKmj0EYGqlcnpvbBWtxH3bZU+MvuUgsYBKwO7VM6TiM=
The result:
Microsoft Windows [Version 6.2.9200]
(c) 2012 Microsoft Corporation. All rights reserved.
Total attempted: 1
I disabled Digital Signature with this command: BCDEDIT /Set LoadOptions DISABLE_INTEGRITY_CHECKS
After restart, this is result:
Total attempted: 1
I disabled Digital Signature and now only KB4541332 fails.
I attached CBS.log
Thanks.
2. Try updating the system just like you have in the past.
Sorry, after a reboot seems to be back all right. The update is installed correctly. I hope that the problems will not reoccurring with future updates.
Thanks for everything.
