Help: SURT total detected corruption count = 779
Alright let's go with a 4th fix then.
Follow the instructions below to fix the errors reported by the System Update Readiness Tool (SURT);
  • Download the attached archive file, Packs.zip and save it on your Desktop;
  • Once it's downloaded, right-click on it and select Extract All...;
  • Check the Show extracted files when complete checkbox, and click on Extract;
  • On completion, a folder will open with two folders inside it, Manifests and Packages;
    • Copy and paste the files of the Manifests folder (if there are any) inside C:\Windows\Temp\CheckSur\winsxs\Manifests
    • Copy and paste the files of the Packages folder (if there are any) inside C:\Windows\Temp\CheckSur\servicing\Packages
  • Run the System Update Readiness Tool (SURT) again;
  • On completion, attach the log located at C:\Windows\Logs\CBS\CheckSUR.log in your next reply;
Packs.zip
Thanks!
Alright, so one of my teacher managed to source the needed files for the KB2952664. Follow the instructions below please.
System Update Readiness Tool (SURT) - Fix
View attachment Packs.zip
Thanks!
Now there's only 2 packages needed for the KB3035583. I doubt I'll be able to source them, but I'll take a more in-depth look tonight.
Meanwhile, are you able to download and install the KB from your first post? If it fails, upload the two logs below for me to review.
C:\Windows\WindowsUpdate.log
C:\Windows\Logs\CBS\CBS.log
Thanks. I assume WU is still broken as it's been saying for an hour that it's downloading a <30 mb update. I have to turn off my computer now, so I will try again tomorrow and report back & post the logs.
Sometimes, it can take Windows a while to download and install updates. When it's too long, the best thing to do is to leave it overnight and check in the morning if there was any progress.
It failed with error code 80073701.
The WindowsUpdate.log is 1.18 mb and the website says it is too big for that type of file to attach.
The CBS.log is over 100 megabytes and locks up Notepad when trying to open it. I've attached WindowsUpdate.log
I compressed them into a 17.8 mb file via dropbox and sent the link to you via PM.
Thanks!
Alright I'll need to take a look at your Components hive. Follow the instructions below please.
Retrieving the COMPONENTS Hive
Follow the instructions below to retrieve your COMPONENTS Hive and send me it.
  • Open your Windows Explorer, and navigate to the C:\Windows\System32\Config folder;
  • In this folder, find the COMPONENTS file (there's no extension), and copy it to your Desktop;
    Note: If you receive an error message saying that the COMPONENTS file is in use, restart your computer and try again. If the error message persist, let me know.
  • Right-click on it, and select Send to... and choose Compressed (zipped) folder;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL for it here;
Done. I've sent the link via PM. Thanks!
In that case, follow the instructions below please.
Uninstall a Windows Update - Command Prompt
Follow the instructions below to uninstall a Windows Update manually via the command prompt.
  • On Windows Vista & 7, click on the Windows Start Menu, then enter cmd in the search box, right-click on the cmd icon and select Run as Administrator
  • Enter the command below (you can copy/paste it, to paste in the command prompt, right-click inside it and select Paste):
    wusa /uninstall /KB:3088195
  • Let me know the outcome of the command: either it uninstall the update or either it says that the update isn't installed on the system;
Error 0x80070490, Element not found.
Thanks!
Sorry for the delay Confoosed. I've been taken up in my move to my appartment, and also catching back on a class I'm taking (because of the time I lost in that move).
Can you list me the updates (KB) you are trying to install?
No problem, life happens :thumbsup2:
The chronic failure is 3126587. Thanks
Let's see if this does the trick. Also, you can post the Dropbox link to the CBS.log and WindowsUpdate.log directly in your thread, no need to PM me it :)
SFCFix - Fix Time
SFCFix.zip
SFCFix - Fix Time
[snip]
SFCFix.zip
Start time: 2016-07-10 22:26:14.619
Using .zip script file at C:\Users\x\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
Successfully copied file C:\Users\x\AppData\Local\niemiro\Archive\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat.
Successfully copied file C:\Users\x\AppData\Local\niemiro\Archive\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully restored ownership for C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored permissions on C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored ownership for C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
Successfully restored permissions on C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
Finish time: 2016-07-10 22:26:15.169
Script hash: cTbolQF/4s5qKgA3oALzB++275oC21eWjc2cdWdey3c=
