Help: SURT total detected corruption count = 779
So it seems like we won't be able to move on unless we replace the corrupt packages for that KB3035583. I'll ask my colleagues once more if one of them have it.
2016-07-12 06:51:16, Error                 CBS    Failed to parse package manifest: \\?\C:\Windows\Servicing\Packages\Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.mum [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2016-07-12 06:51:16, Error                 CBS    Failed to resolve package 'Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13' [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Info                  CBS    Failed to resolve package [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Info                  CBS    Failed to populate children. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Info                  CBS    Failed to initialize internal package for package: Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~6.1.7601.17514 [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Info                  CBS    Delay load failed for package: Package_for_KB976932~31bf3856ad364e35~amd64~~6.1.1.17514 [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Error                 CBS    Delay Initialization Failed [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:16, Info                  CBS    Session: 30530603_1351035159 initialized by client WindowsUpdateAgent.
2016-07-12 06:51:17, Info                  CBS    Failed to open package file: \\?\C:\Windows\Servicing\Packages\Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.mum [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2016-07-12 06:51:17, Info                  CBS    Failed to read in xml content [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2016-07-12 06:51:17, Error                 CBS    Failed to parse package manifest: \\?\C:\Windows\Servicing\Packages\Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.mum [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
2016-07-12 06:51:17, Error                 CBS    Failed to resolve package 'Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13' [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:17, Info                  CBS    Failed to resolve package [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:17, Info                  CBS    Failed to populate children. [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:17, Info                  CBS    Failed to initialize internal package for package: Microsoft-Windows-Client-Features-Package~31bf3856ad364e35~amd64~~6.1.7601.17514 [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:17, Info                  CBS    Delay load failed for package: Package_for_KB976932~31bf3856ad364e35~amd64~~6.1.1.17514 [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
2016-07-12 06:51:17, Error                 CBS    Delay Initialization Failed [HRESULT = 0x80070490 - ERROR_NOT_FOUND]
Alright, CKind managed to source the files needed :) Here goes!
System Update Readiness Tool (SURT) - Fix
Follow the instructions below to fix the errors reported by the System Update Readiness Tool (SURT);
  • Download the attached archive file, Packs.zip and save it on your Desktop;
  • Once it's downloaded, right-click on it and select Extract All...;
  • Check the Show extracted files when complete checkbox, and click on Extract;
  • On completion, a folder will open with two folders inside it, Manifests and Packages;
    • Copy and paste the files of the Manifests folder (if there are any) inside C:\Windows\Temp\CheckSur\winsxs\Manifests
    • Copy and paste the files of the Packages folder (if there are any) inside C:\Windows\Temp\CheckSur\servicing\Packages
  • Run the System Update Readiness Tool (SURT) again;
  • On completion, attach the log located at C:\Windows\Logs\CBS\CheckSUR.log in your next reply;
Packs.zip
Packs.zip
Binary Version 6.1.7601.22471
Package Version 26.0
2016-07-13 21:21
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
(f) CBS MUM Missing 0x00000002 servicing\Packages\Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.mum
(fix) CBS MUM Missing CBS File Replaced Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.mum from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
(fix) CBS Paired File CBS File also Replaced Package_1_for_KB3035583~31bf3856ad364e35~amd64~~6.1.2.13.cat from Cabinet: C:\Windows\CheckSur\v1.0\windows6.1-7601-x64-clientcab4.cab.
Checking Component Store
Summary:
Seconds executed: 618
Found 1 errors
Fixed 1 errors
CBS MUM Missing Total count: 1
Fixed: CBS MUM Missing. Total count: 1
Fixed: CBS Paired File. Total count: 1
Awesome :) Please try to install the update. If it fails, upload the WindowsUpdate.log and CBS.log again for me.
Start time: 2016-07-19 07:45:53.721
Using .zip script file at C:\Users\x\Desktop\SFCFix.zip [1]
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully took permissions for file or folder C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
WARNING: File C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat was not backed up as that would replace the current backup.
Successfully copied file C:\Users\x\AppData\Local\niemiro\Archive\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat to C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat.
WARNING: File C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum was not backed up as that would replace the current backup.
Successfully copied file C:\Users\x\AppData\Local\niemiro\Archive\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum to C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum.
Successfully restored ownership for C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored permissions on C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.cat
Successfully restored ownership for C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
Successfully restored permissions on C:\Windows\servicing\Packages\package_58_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.mum
Finish time: 2016-07-19 07:45:54.127
Script hash: cTbolQF/4s5qKgA3oALzB++275oC21eWjc2cdWdey3c=
Alright. Please try to install the update again, and if it fails, upload the CBS.log and WindowsUpdate.log for me please.
Same error.
2016-07-20 17:33:27, Error                 CSI    0000000e@2016/7/20:21:33:27.246 (F) d:\win7sp1_gdr\base\wcp\componentstore\csd_locking.cpp(324): Error STATUS_SXS_ASSEMBLY_MISSING originated in function CCSDirectTransaction::LockComponent expression: (null)
[gle=0x80004005]
2016-07-20 17:33:27, Error                 CSI    0000000f (F) STATUS_SXS_ASSEMBLY_MISSING #630587# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 2[gle=0xd015000c]
2016-07-20 17:33:27, Error                 CSI    00000010 (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #630472# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_InstallDeployment(Flags = 0, a = 885afb5bed212f4b073563b5024dfe8c, Version = 6.1.7601.19018, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, cb = (null), s = (null), rid = [80]"Package_58_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3.3088195-145_neutral_GDR", rah = [2]"17", manpath = (null), catpath = (null), disp = 0)[gle=0x80073701]
2016-07-20 17:33:27, Info                  CBS    Failed to begin deployment installation for Update: 3088195-145_neutral_GDR [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    Failed to execute item[0] in Package: Package_58_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3, Update: 3088195-145_neutral_GDR [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    Failed to execute execution update. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    Failed to execute execution package: Package_58_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    Failed to prepare execution. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    Failed to process component watch list. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CSI    00000011@2016/7/20:21:33:27.340 CSI Transaction @0xdcac00 destroyed
2016-07-20 17:33:27, Info                  CBS    Perf: InstallUninstallChain complete.
2016-07-20 17:33:27, Info                  CBS    Failed to execute execution chain. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Error                 CBS    Failed to process single phase execution. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-07-20 17:33:27, Info                  CBS    WER: Generating failure report for package: Package_for_KB3126587~31bf3856ad364e35~amd64~~6.1.1.1, status: 0x80073701, failure source: Execute, start state: Staged, target state: Installed, client id: WindowsUpdateAgent
Let's take a look at the CBS key.
Exporting the CBS Registry Key
Follow the instructions below to export the CBS Key from the Registry and upload it.
  • Press on the Windows + R keys, enter regedit and press on Enter;
  • In Regedit, in the left-pane, navigate to the Registry key below and select it by clicking on it:
    • HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing
  • Once the key is selected, click on the File menu and select Export...;
  • From there Save menu, change the Save as type: to Registry Hive Files (*.*);
  • Name the file CBS (without any file extension) and save it on your Desktop;
  • Upload the file on Dropbox, Google Drive or OneDrive and post the download URL here;
Same error.
[gle=0x80004005]
Done:
Dropbox - CBS hive.zip
I might have pinned down the issue. I'll have to check tonight since I think I'll have to install that update on one of my VM. Looks like a missing deployment key.
Seems like my Windows 7 x64 VM is affected by the slow update issue from June. I'll have to work on it tomorrow evening since I got another one that crashed while I was working on it. Sorry about that.
No problem, & thanks for the help!
Alright, follow the instructions below please.
SFCFix - Fix Time
  • Download the attached SFCFixScript.txt and move the file to your Desktop;
    Note: Make sure that the file is named SFCFixScript.txt, do not rename it.
  • Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it;
SFCFixScript.txt
SFCFix - Fix Time
Start time: 2016-07-24 11:41:46.972
Using .txt script file at C:\Users\x\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\885afb5bed2..3b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_33885207d59f7617.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\885afb5bed2..3b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_33885207d59f7617.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Finish time: 2016-07-24 11:41:47.628
Script hash: LXhMwSFlvNEbWShhg6gI3inw5voC7SKIk6nUk92ANgs=
Good :) Try to install the update again. If it fails, upload the CBS.log and WindowsUpdate.log for me please.
SFCFix - Fix Time
SFCFixScript.txt
