Help: SURT total detected corruption count = 779
Alright, follow the instructions below please.
SFCFix - Fix Time
Start time: 2016-07-31 14:37:27.999
Using .txt script file at C:\Users\x\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components.
Currently storing 6 datablocks.
Finish time: 2016-07-31 14:37:28.695
Script hash: jgZ5XmSoIV2oP9RD/lTWXQdG4HFWX9Uc9Uf88yHlS6Y=
Alright, try to install the update again, and if it fails, upload the new CBS.log and WindowsUpdate.log for me please.
Said it didn't install, so I PM'd the link for the August 1st logs.
Thanks!!
New error. Do you have your Windows installation media by the way?
If you do, a Repair Install might be the fastest way to solve your issue, considering that we may have to go through a lot of fixes if everything continues that way.
I re-ran SFCFix and got the log below, showing 1 error (down from 779!). Is it a continual 1 error problem, or did we get it down to the last one?
Thanks!
Start time: 2016-08-04 21:59:24.628
SURT total detected corruption count: 1
Finish time: 2016-08-04 22:00:34.446
It could be 1 error from an old log, meaning that there's actually none left. Let's see.
System Update Readiness Tool (SURT) - Scan
Follow the instructions below to run a scan with the System Update Readiness Tool (SURT) and provide a log;
  • Download the right version of SURT for your system;
    • Your version of Windows is: Windows 7 SP1 x64
  • Once downloaded, execute the installer, and go throught the installation (this process can take around 15-20 minutes);
  • On completion, a log will be created in C:\Windows\Logs\CBS\CheckSUR.log;
  • Attach this log in your next reply;
Alternatively, if these instructions are unclear for you, you can follow the tutorial below.
Binary Version 6.1.7601.22471
Package Version 26.0
2016-08-08 17:20
Checking Package Watchlist
Checking Component Watchlist
Checking Packages
Checking Component Store
(f) CSI Catalog Missing 0x00000002 d500a9c53097f90db661b3cfc3354f45d34c9828a55ab0d9760ea7755faf6916.cat 885afb5bed2..3b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_33885207d59f7617 Missing catalog or invalid CatalogThumprint
(fix) CSI Catalog Missing CSI File Replaced Deleted CatalogThumbprint
(f) CSI Manifest Missing 0x00000002 amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.manifest amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617
Summary:
Seconds executed: 600
Found 2 errors
Fixed 1 errors
CSI Manifest Missing Total count: 1
CSI Catalog Missing Total count: 1
Fixed: CSI Catalog Missing. Total count: 1
Unavailable repair files:
winsxs\manifests\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.manifest
Alright, we'll replace that corrupt manifest file.
System Update Readiness Tool (SURT) - Fix
Follow the instructions below to fix the errors reported by the System Update Readiness Tool (SURT);
  • Download the attached archive file, Packs.zip and save it on your Desktop;
  • Once it's downloaded, right-click on it and select Extract All...;
  • Check the Show extracted files when complete checkbox, and click on Extract;
  • On completion, a folder will open with two folders inside it, Manifests and Packages;
    • Copy and paste the files of the Manifests folder (if there are any) inside C:\Windows\Temp\CheckSur\winsxs\Manifests
    • Copy and paste the files of the Packages folder (if there are any) inside C:\Windows\Temp\CheckSur\servicing\Packages
  • Run the System Update Readiness Tool (SURT) again;
  • On completion, attach the log located at C:\Windows\Logs\CBS\CheckSUR.log in your next reply;
Packs.zip
Now it replaced even more stuff that weren't even detected in the first SURT runs... Run SURT again please and provide me a new CheckSUR.log, I want to see if it'll come up with stuff it wasn't showing before again.
Okay good. Back to SFC.
System File Checker (SFC)
    Run as Administrator
  • On Windows 8.1 and Windows 10, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
Good, no corruption! Now, try to install the update again and if it fails, upload the new CBS.log and WindowsUpdate.log for me please.
Just wondering, did you ever consider upgrading your system to Windows 10?
Sorry for the delay; I was out of town.
I had, but I decided against the upgrade for the popular reasons (I never did an install/roll back). The decision to keep win7 (and be patched) led me to the failed install.
