Alright thanks for letting me know :) Is the update you can't install still KB3088195?
3126587
Dropbox - 16-925.zipAlright let's try it. Download and install it manually, if it fails, upload the CBS.log and WindowsUpdate.log for me.
Download Security Update for Windows 7 for x64-based Systems (KB3126587) from Official Microsoft Download Center
wusa /uninstall /KB:3088195
It's funny because it's the KB3088195 that is getting in the way... Here, try this.
Uninstall a Windows Update - Command Prompt![]()
Follow the instructions below to uninstall a Windows Update manually via the command prompt.
- On Windows Vista & 7, click on the Windows Start Menu, then enter cmd in the search box, right-click on the cmd icon and select Run as Administrator
- On Windows 8, drag your cursor in the bottom-left corner, and right-click on the metro menu preview, then select Command Prompt (Admin);
- On Windows 8.1 and Windows 10, right click on the Windows logo in the bottom-left corner and select Command Prompt (Admin);
- Enter the command below (you can copy/paste it, to paste in the command prompt, right-click inside it and select Paste):
Code:wusa /uninstall /KB:3088195
- Let me know the outcome of the command: either it uninstall the update or either it says that the update isn't installed on the system;
[HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\818a12a9e76..c9e3efe3d8d_31bf3856ad364e35_6.1.7601.19018_0c4593b5e87afda1]
"appid"=hex:38,31,38,61,31,32,61,39,65,37,36,33,65,64,64,63,37,63,30,62,31,63,\
39,65,33,65,66,65,33,64,38,64,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,\
61,6c,2c,20,56,65,72,73,69,6f,6e,3d,36,2e,31,2e,37,36,30,31,2e,31,39,30,31,\
38,2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,33,31,62,66,33,38,35,\
36,61,64,33,36,34,65,33,35,2c,20,50,72,6f,63,65,73,73,6f,72,41,72,63,68,69,\
74,65,63,74,75,72,65,3d,61,6d,64,36,34,2c,20,76,65,72,73,69,6f,6e,53,63,6f,\
70,65,3d,4e,6f,6e,53,78,53
"CatalogThumbprint"="cd207dd190c713a1c2ca3ac1b2bebd0ca65f18a131521561a9bf33afd9306c6a"
"p!CBS_package_59_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.308_4a0592276cc92e6d"=hex:50,\
00,00,00,01,00,00,00,50,61,63,6b,61,67,65,5f,35,39,5f,66,6f,72,5f,4b,42,33,\
30,38,38,31,39,35,7e,33,31,62,66,33,38,35,36,61,64,33,36,34,65,33,35,7e,61,\
6d,64,36,34,7e,7e,36,2e,31,2e,31,2e,33,2e,33,30,38,38,31,39,35,2d,31,34,38,\
5f,6e,65,75,74,72,61,6c,5f,47,44,52,32
"i!CBS_package_59_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.308_4a0592276cc92e6d"=hex:50,\
Alright follow the instructions below please.
SFCFix - Fix Time![]()
- Open the file, then copy and paste its content in your next reply;
Set your Windows Update settings to "Never check for updates", restart your computer and try to install the update again.
Trace::
amd64_818a12a9e763eddc7c0b1c9e3efe3d8d_31bf3856ad364e35_6.1.7601.19018_none_0c4593b5e87afda1
Follow the instructions below.
[HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\x86_microsoft-windows-win32k_31bf3856ad364e35_6.1.7601.23528_none_bb7d823711eb39fd]
"identity"=hex:4d,69,63,72,6f,73,6f,66,74,2d,57,69,6e,64,6f,77,73,2d,57,69,6e,\
33,32,6b,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,61,6c,2c,20,56,65,72,\
73,69,6f,6e,3d,36,2e,31,2e,37,36,30,31,2e,32,33,35,32,38,2c,20,50,75,62,6c,\
69,63,4b,65,79,54,6f,6b,65,6e,3d,33,31,62,66,33,38,35,36,61,64,33,36,34,65,\
33,35,2c,20,50,72,6f,63,65,73,73,6f,72,41,72,63,68,69,74,65,63,74,75,72,65,\
3d,78,38,36,2c,20,76,65,72,73,69,6f,6e,53,63,6f,70,65,3d,4e,6f,6e,53,78,53
"S256H"=hex:ee,62,95,d6,8b,3c,63,7b,f1,38,01,47,aa,fa,fc,f3,e2,5d,ce,3d,c7,2b,\
43,09,ee,ee,5a,c8,21,7f,6a,de
"c!7cb937edb38..c76f74993d6_31bf3856ad364e35_6.1.7601.23528_5f9a5ef469429fcd"=hex:
"f!win32k.sys"=hex:77,00,69,00,6e,00,33,00,32,00,6b,00,2e,00,73,00,79,00,73,00
Alright follow the instructions below.
Good. Try to install the update again if it fails, upload the CBS.log and WindowsUpdate.log for me please.
It was searching for updates this entire time?
