Help: SURT total detected corruption count = 779
Are you able to upload the CBS.log and WindowsUpdate.log? I'll see if it still have information on why it failed.
Sure:
Dropbox - 16-8-23.zip
I had successfully installed 2 updates after the failure (the 1 of 18 updates done last night), so I re-did just the one failing update this morning to make sure it was in the log.
Thanks!
Alright so that's the current error we're facing.
2016-08-23 07:16:53, Error                 CSI    0000000e@2016/8/23:11:16:53.346 (F) d:\win7sp1_gdr\base\wcp\componentstore\csd_locking.cpp(324): Error STATUS_SXS_ASSEMBLY_MISSING originated in function CCSDirectTransaction::LockComponent expression: (null)
[gle=0x80004005]
2016-08-23 07:16:53, Error                 CSI    0000000f (F) STATUS_SXS_ASSEMBLY_MISSING #780288# from CCSDirectTransaction::OperateEnding at index 0 of 1 operations, disposition 2[gle=0xd015000c]
2016-08-23 07:16:53, Error                 CSI    00000010 (F) HRESULT_FROM_WIN32(ERROR_SXS_ASSEMBLY_MISSING) #780173# from Windows::ServicingAPI::CCSITransaction::ICSITransaction_InstallDeployment(Flags = 0, a = 818a12a9e763eddc7c0b1c9e3efe3d8d, Version = 6.1.7601.19018, pA = PROCESSOR_ARCHITECTURE_AMD64 (9), Culture neutral, VersionScope = 1 nonSxS, PublicKeyToken = {l:8 b:31bf3856ad364e35}, Type neutral, TypeName neutral, PublicKey neutral, cb = (null), s = (null), rid = [80]"Package_59_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3.3088195-148_neutral_GDR", rah = [1]"2", manpath = (null), catpath = (null), disp = 0)[gle=0x80073701]
2016-08-23 07:16:53, Info                  CBS    Failed to begin deployment installation for Update: 3088195-148_neutral_GDR [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-08-23 07:16:53, Info                  CBS    Failed to execute item[0] in Package: Package_59_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3, Update: 3088195-148_neutral_GDR [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-08-23 07:16:53, Info                  CBS    Failed to execute execution update. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-08-23 07:16:53, Info                  CBS    Failed to execute execution package: Package_59_for_KB3088195~31bf3856ad364e35~amd64~~6.1.1.3 [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-08-23 07:16:53, Info                  CBS    Failed to prepare execution. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
2016-08-23 07:16:53, Info                  CBS    Failed to process component watch list. [HRESULT = 0x80073701 - ERROR_SXS_ASSEMBLY_MISSING]
I'll put together a fix once I get home tonight since I need access to my VM for it.
SFCFix - Fix Time
  • On your Desktop, right-click and select New, then Text Document. Give it the name SFCFixScript (it should be a .txt) extension;
  • Open the SFCFixScript.txt file you just created, and copy/paste the following in it;
    [HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\818a12a9e76..c9e3efe3d8d_31bf3856ad364e35_6.1.7601.19018_0c4593b5e87afda1]
    "appid"=hex:38,31,38,61,31,32,61,39,65,37,36,33,65,64,64,63,37,63,30,62,31,63,\
      39,65,33,65,66,65,33,64,38,64,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,72,\
      61,6c,2c,20,56,65,72,73,69,6f,6e,3d,36,2e,31,2e,37,36,30,31,2e,31,39,30,31,\
      38,2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,33,31,62,66,33,38,35,\
      36,61,64,33,36,34,65,33,35,2c,20,50,72,6f,63,65,73,73,6f,72,41,72,63,68,69,\
      74,65,63,74,75,72,65,3d,61,6d,64,36,34,2c,20,76,65,72,73,69,6f,6e,53,63,6f,\
      70,65,3d,4e,6f,6e,53,78,53
    "CatalogThumbprint"="cd207dd190c713a1c2ca3ac1b2bebd0ca65f18a131521561a9bf33afd9306c6a"
    "p!CBS_package_59_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.308_4a0592276cc92e6d"=hex:50,\
      00,00,00,01,00,00,00,50,61,63,6b,61,67,65,5f,35,39,5f,66,6f,72,5f,4b,42,33,\
      30,38,38,31,39,35,7e,33,31,62,66,33,38,35,36,61,64,33,36,34,65,33,35,7e,61,\
      6d,64,36,34,7e,7e,36,2e,31,2e,31,2e,33,2e,33,30,38,38,31,39,35,2d,31,34,38,\
      5f,6e,65,75,74,72,61,6c,5f,47,44,52,32
    "i!CBS_package_59_for_kb3088195~31bf3856ad364e35~amd64~~6.1.1.3.308_4a0592276cc92e6d"=hex:50,\
  • Drag the SFCFixScript.txt file over the SFCFix.exe executable and release it;
SFCFix - Fix Time
Start time: 2016-08-23 22:38:53.002
Using .txt script file at C:\Users\x\Desktop\SFCFixScript.txt [0]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\818a12a9e76..c9e3efe3d8d_31bf3856ad364e35_6.1.7601.19018_0c4593b5e87afda1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments\818a12a9e76..c9e3efe3d8d_31bf3856ad364e35_6.1.7601.19018_0c4593b5e87afda1.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\CanonicalData\Deployments.
Finish time: 2016-08-23 22:38:53.075
Script hash: cNBYp6W6/jftVkdS9/ktrmUiuCKzSfc4xVWYRsZElM8=
Alright, please try to install the failing update again and if it fails, upload a new CBS.log and WindowsUpdate.log for me.
Alright follow the instructions below please.
SFCFix - Fix Time
    [HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617]
    "S256H"=hex:c9,9e,8b,99,03,de,97,14,39,02,ad,1f,64,73,79,d2,46,12,34,80,65,42,\
      10,d1,ba,77,66,40,2e,86,a1,fb
    "identity"=hex:38,38,35,61,66,62,35,62,65,64,32,31,32,66,34,62,30,37,33,35,36,\
      33,62,35,30,32,34,64,66,65,38,63,2c,20,43,75,6c,74,75,72,65,3d,6e,65,75,74,\
      72,61,6c,2c,20,56,65,72,73,69,6f,6e,3d,36,2e,31,2e,37,36,30,31,2e,31,39,30,\
      31,38,2c,20,50,75,62,6c,69,63,4b,65,79,54,6f,6b,65,6e,3d,33,31,62,66,33,38,\
      35,36,61,64,33,36,34,65,33,35,2c,20,50,72,6f,63,65,73,73,6f,72,41,72,63,68,\
      69,74,65,63,74,75,72,65,3d,61,6d,64,36,34,2c,20,76,65,72,73,69,6f,6e,53,63,\
      6f,70,65,3d,4e,6f,6e,53,78,53
    "ClosureFlags"=dword:00000003
    "c!885afb5bed2..3b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_33885207d59f7617"=hex:
SFCFix - Fix Time
Start time: 2016-08-25 18:17:29.994
Using .txt script file at C:\Users\x\Desktop\SFCFixScript.txt [1]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_885afb5bed212f4b073563b5024dfe8c_31bf3856ad364e35_6.1.7601.19018_none_33885207d59f7617.
Finish time: 2016-08-25 18:17:30.108
Script hash: jgZ5XmSoIV2oP9RD/lTWXQdG4HFWX9Uc9Uf88yHlS6Y=
Try to install the update again and it if fails, upload the new CBS.log and WindowsUpdate.log for me please.
Same error... Is that update the only one left you have to install?
Can you try to install an optional one (that isn't a driver)? I want to see if it'll go through. If it fails, upload the CBS.log and WindowsUpdate.log for me please.
Both installed fine (malicious definitions & update kb3161102).
Dropbox - 16-8-31.zip
ps - Windows update keeps auto updating that failing update on reboot... Do you know how to take it out of the queue so it doesn't try to install the update each time I shut down?
Thanks!
Okay so it's really an issue with that update. To cancel that task properly, you'll need your Windows installation media or a Recovery media.
Luckily, I was able to stop the attempts to auto install by deleting all the updates that had been downloaded by WU. I then hid the update. So for now, it still reads as no important updates left!.
Thanks for all your help, Aura!
So where are we with this? It's been a while, what's the current issue to be addressed?
I think it's all finished until some other problem arises for which I will make a new thread. As of now, I can install all but that one update and no important updates are pending. I was able to delete all the downloaded updates and that got rid of the auto install issue on shutdown.
Thanks!
Alright thanks for letting me know :) Is the update you can't install still KB3088195?
