[SOLVED] High DPC latency and popping noises
:thud:
Re-try with these verifier custom settings:
  • all standard flags (you can click the flag type column to sort the flags)
  • these additional flags:
    • Power framework delay fuzzing.
    • DDI compliance checking (additional)
    • NDIS/WIFI verification
    • Kernel synchronization delay fuzzing
    • Code integrity checks
  • automatically select all drivers installed
To reset verifier settings in case something goes wrong, reboot to safe mode and type verifier /reset from an elevated command prompt.
Remember the precautions: system restore point, system image, windows cd at hand... In case the safe boot from the machine won't start.
I saw the latest bsod, but it points to a MS driver.
If the problem hasn't gone away (with verifier disabled), I'd run another verifier session: this time enable all verifier checks and select all drivers but Microsoft ones.
Uhm... When I told you to set bios default settings, I forgot you have to "underclock" your RAM speed...
What setting has been selected by your MB (for your RAM frequency)?
Your CPU specs "say" you should set it to DDR4-1866 or DDR4-2133.
I think so....
Write your reply...
