[SOLVED] High DPC latency and popping noises
I found runtimebroker.exe is using Wpc.dll and FamilySafetyExt.dll (they should be the parental control on windows 10...), right during the second hard fault.
During the first one instead I found MsMpEng.exe (Windows defender), hence you could try to exclude this folder in WinDefender: C:\Program Files (x86)\Steam\steamapps\Common\Counter-Strike Global Offensive.
Only if you are sure you (or the program) won't download and run anything inside that folder, obviously.
After weeks I finally found the problem, It is the MEI Chipset driver, I resinstalled windows 10 again and found out the os itself installs the PCI simple communications controller. (perhaps the driver windows 10 installs is incompatible). So i roll backed to windows 8 again the DPC problem went away after I installed the latest Chipset driver from asus support.
Oh I really wish to have a happy ending like Cheah :( i have a made a whole post about my GPU causing stutters or audio cracks, and i'm running a ryzen computer i made a post in EVGA to not copy post here
If you can help me xilolee this time plz, i know you close one of my thread like 10'15 days ago but plz :(
Check this thread that i made in EVGA I tested 3 gpu...
[FONT=&quot]https://forums.evga.com/Im-started-to-get-worried-about-my-GTX-1060-m2746843.aspx#2746843[/FONT]
I Have the SAME problem, can you tell me if i can fix it while using windows 10 ?
New bios: Version 3805 2018/05/25
I just followed this thread after a long night of troubleshooting my desyncing audio problem. With your troubleshooting, I have finally solved it by updating my bios. Thank you for doing amazing work and making it public so that lost troubleshooters like me can find salvation. You saved me a hell of a lot of trouble and I appreciate it.
Write your reply...
