[SOLVED] IE 10 Will Not Install 9C59
2015-06-25 08:09:49, Info                  CBS    Failed to find file: x86_microsoft-windows-scripting-jscript_31bf3856ad364e35_8.0.7601.21663_none_9ff4269ee5af7abd\jscript.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
Step#1 - SFCFix Script
Step#2 - Install IE10 Normally
Items for your next post
1. SFCFix.txt
2. CBS.log if needed
Did not install. Is it missing a bunch of files?
It's interesting. Your machine appears to have most if not all the files but your registry is saying that the files aren't there. So basically I'm telling your registry that they are there and to use them. I'm hoping we are almost there.
You actually attached the same SFCFix.txt log twice. I need the CBS log as well. Thanks.
2015-06-26 09:56:38, Info                  CBS    Failed to find file: x86_microsoft-windows-scripting-jscript_31bf3856ad364e35_8.0.7601.17562_none_9f698989cc92c19c\jscript.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-26 10:07:38, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_8.0.7601.22500_none_64f5ae5d7ae17cc2\sqmapi.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-26 10:21:23, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_8.0.7601.22500_none_64f5ae5d7ae17cc2\sqmapi.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-26 11:01:24, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-runtimeutilities_31bf3856ad364e35_8.0.7601.18305_none_6471111e61bf5e84\sqmapi.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-26 11:16:11, Info                  CBS    Failed to find file: x86_microsoft-windows-i..ersandsecurityzones_31bf3856ad364e35_8.0.7601.22500_none_d2351bdfc52737d2\urlmon.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-26 11:29:12, Info                  CBS    Failed to find file: x86_microsoft-windows-i..tocolimplementation_31bf3856ad364e35_8.0.7601.22500_none_1f3af78190305e65\jsproxy.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
