[SOLVED] IE 10 Will Not Install 9C59
2015-06-26 11:41:43, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-winsockautodialstub_31bf3856ad364e35_8.0.7601.22500_none_0d7cd54a4c27ad0f\url.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
Step#1 - SFCFix Script
Step#2 - Install IE10 Normally
Items for your next post
1. SFCFix.txt
2. CBS.log if needed
We're working through all the IE components. If this works I may be able to create a script to make this easier for others that need assistance with the same issue. Here's to hoping.
2015-06-29 08:49:35, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-vgx_31bf3856ad364e35_8.0.7601.22500_none_0a89156ed7184401\VGX.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 09:03:55, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-vgx_31bf3856ad364e35_8.0.7601.18305_none_0a04782fbdf625c3\VGX.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 09:10:35, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-jscriptdebugui_31bf3856ad364e35_8.0.7601.22500_none_d7be52e1bc02894e\jsdbgui.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 09:19:03, Info                  CBS    Failed to find file: x86_microsoft-windows-ieinstal_31bf3856ad364e35_8.0.7601.22500_none_05eddd227fffaa00\ieinstal.exe [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 09:49:26, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-ieshims_31bf3856ad364e35_8.0.7601.22500_none_64df33f988964f52\IEShims.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 10:01:17, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-ieproxy_31bf3856ad364e35_8.0.7601.22500_none_ad80e86338ede8e4\ieproxy.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 10:25:09, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-htmlrendering_31bf3856ad364e35_8.0.7601.22500_none_309516a01086c79b\mshtml.tlb [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 10:56:34, Info                  CBS    Failed to find file: x86_microsoft-windows-ie-htmlediting_31bf3856ad364e35_8.0.7601.22500_none_657aed6b31c21173\mshtmled.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
2015-06-29 11:20:36, Info                  CBS    Failed to find file: x86_microsoft-windows-ieframe_31bf3856ad364e35_8.0.7601.22500_none_81f470a39c7c55c8\ieframe.dll [HRESULT = 0x80070002 - ERROR_FILE_NOT_FOUND]
1. SFCFix.txt
