Do you have another SQL server running to check if the (PolyBase) services exist?
SQL Server Setup has encountered the following error:
Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
Error code 0x84B10001.
HKLM\SOFTWARE\Microsoft\Fusion\PublisherPolicy\Default\v4.0_policy.13.0.Microsoft.SqlServer.Chainer.Setup.resources_en_89845dcd8080cc91
HKLM\SOFTWARE\Microsoft\Fusion\PublisherPolicy\Default\policy.13.0.Microsoft.SqlServer.Chainer.Setup.resources_en_89845dcd8080cc91
reg export "HKLM\SOFTWARE\Microsoft\Fusion\PublisherPolicy\Default" "%userprofile%\desktop\regexp.txt"
reg export "HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall\Microsoft SQL Server SQLServer2016" "%userprofile%\desktop\regexp.txt"
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server
reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130" /v CollectorParameters /t REG_SZ /d " MSSQL13.MSSQLSERVER" /f
reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130"
C:\Windows\system32>reg add "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130" /v CollectorParameters /t REG_SZ /d " MSSQL13.MSSQLSERVER" /f
C:\Windows\system32>reg query "HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130"
CustomerFeedback REG_DWORD 0x1
EnableErrorReporting REG_DWORD 0x1
SharedCode REG_SZ C:\Program Files\Microsoft SQL Server\130\Shared\
VerSpecificRootDir REG_SZ C:\Program Files\Microsoft SQL Server\130\
ErrorReportingDir REG_SZ C:\Program Files\Microsoft SQL Server\130\Shared\ErrorDumps\
CollectorParameters REG_SZ MSSQL13.MSSQLSERVER
TimeOfReporting REG_DWORD 0xf0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\13.0
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\Bootstrap
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\ConfigurationState
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\Machines
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\Replication
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\SQLServer2016
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\SSIS
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\Tools
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Microsoft SQL Server\130\UpgradeIncompleteState
TITLE: SQL Server Setup failure.
For help, click: http://go.microsoft.com/fwlink?LinkID=20476&ProdName=Microsoft%20SQL%20Server&EvtSrc=setup.rll&EvtID=50000&EvtType=0xDBFE1571%25400x3FB6F251
BUTTONS:
OK
