TITLE: SQL Server Setup failure.
SQL Server Setup has encountered the following error:
Index (zero based) must be greater than or equal to zero and less than the size of the argument list.
Error code 0x84B10001.
For help, click: http://go.microsoft.com/fwlink?LinkID=20476&ProdName=Microsoft%20SQL%20Server&EvtSrc=setup.rll&EvtID=50000&EvtType=0xDBFE1571%25400x3FB6F251
BUTTONS:
OK
SQL Full-text Filter Daemon Launcher (MSSQLSERVER) MSSQLFDLauncher Manual Running
SQL Server (MSSQLSERVER) MSSQLSERVER Auto Running
SQL Server Agent (MSSQLSERVER) SQLSERVERAGENT Auto Running
SQL Server VSS Writer SQLWriter Auto Running
TSM Scheduler MSSQLSERVER TSM Scheduler MSSQLSERVER Auto Running
BUTTONS:
OK
cscript FindSQLInstalls.vbs "%userprofile%\Desktop\SQLLog.txt"
!!!! sql_engine_core_shared.msi DOES NOT exist on the path in the path 1;H:\x64\setup\sql_engine_core_shared_msi\ !!!!
Action needed, re-establish the path to 1;H:\x64\setup\sql_engine_core_shared_msi\
Copy "1;H:\x64\setup\sql_engine_core_shared_msi\sql_engine_core_shared.msi" C:\Windows\Installer\48868ba6.msi
!!!! sql_engine_core_shared_loc.msi DOES NOT exist on the path in the path 1;H:\1033_ENU_LP\x64\setup\sql_engine_core_shared_loc_msi\ !!!!
Action needed, re-establish the path to 1;H:\1033_ENU_LP\x64\setup\sql_engine_core_shared_loc_msi\
Copy "1;H:\1033_ENU_LP\x64\setup\sql_engine_core_shared_loc_msi\sql_engine_core_shared_loc.msi" C:\Windows\Installer\48868bc1.msi
!!!! sql_engine_core_inst_loc.msi DOES NOT exist on the path in the path 1;H:\1033_ENU_LP\x64\setup\sql_engine_core_inst_loc_msi\ !!!!
Action needed, re-establish the path to 1;H:\1033_ENU_LP\x64\setup\sql_engine_core_inst_loc_msi\
Copy "1;H:\1033_ENU_LP\x64\setup\sql_engine_core_inst_loc_msi\sql_engine_core_inst_loc.msi" C:\Windows\Installer\48868bca.msi
!!!! sqlsupport.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sql2008support\ !!!!
Action needed, re-establish the path to C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sql2008support\
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sql2008support\sqlsupport.msi" C:\Windows\Installer\48868b7e.msi
!!!! SqlWriter.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x64\ !!!!
Action needed, re-establish the path to C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x64\
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x64\SqlWriter.msi" C:\Windows\Installer\48868b64.msi
!!!! sql_fulltext.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Action needed, re-establish the path to C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sql_fulltext.msi" C:\Windows\Installer\48868bb8.msi
!!!! sqlbrowser.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sqlbrowser.msi" C:\Windows\Installer\48868b6d.msi
!!!! sql_dmf.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sql_dmf.msi" C:\Windows\Installer\48868b2b.msi
!!!! sql_tools_extensions.msi DOES NOT exist on the path in the path H:\x64\setup\ !!!!
Action needed, re-establish the path to H:\x64\setup\
Copy "H:\x64\setup\sql_tools_extensions.msi" C:\Windows\Installer\13eb4730.msi
!!!! SQLSUPPORT.MSI DOES NOT exist on the path in the path F:\67059f7b17b65789e0e077da3cd4caf5\1033_ENU_LP\x64\setup\sqlsupport_msi\ !!!!
Action needed, re-establish the path to F:\67059f7b17b65789e0e077da3cd4caf5\1033_ENU_LP\x64\setup\sqlsupport_msi\
Copy "F:\67059f7b17b65789e0e077da3cd4caf5\1033_ENU_LP\x64\setup\sqlsupport_msi\SQLSUPPORT.MSI" C:\Windows\Installer\b400aeb8.msi
!!!! IBM Spectrum Protect for Databases - MS SQL.msi DOES NOT exist on the path in the path C:\Windows\ccmcache\5ba\ !!!!
Action needed, re-establish the path to C:\Windows\ccmcache\5ba\
Copy "C:\Windows\ccmcache\5ba\IBM Spectrum Protect for Databases - MS SQL.msi" C:\Windows\Installer\4ec076f5.msi
!!!! sql_common_core.msi DOES NOT exist on the path in the path 1;H:\x64\setup\sql_common_core_msi\ !!!!
Action needed, re-establish the path to 1;H:\x64\setup\sql_common_core_msi\
Copy "1;H:\x64\setup\sql_common_core_msi\sql_common_core.msi" C:\Windows\Installer\48868b86.msi
!!!! sqlsqm.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sqlsqm.msi" C:\Windows\Installer\48868b76.msi
!!!! IBM Spectrum Protect for Databases - MS SQL - Management Console.msi DOES NOT exist on the path in the path C:\Windows\ccmcache\5b9\ !!!!
Action needed, re-establish the path to C:\Windows\ccmcache\5b9\
Copy "C:\Windows\ccmcache\5b9\IBM Spectrum Protect for Databases - MS SQL - Management Console.msi" C:\Windows\Installer\4ec076b6.msi
!!!! DACFramework.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x86\ !!!!
Action needed, re-establish the path to C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x86\
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\x86\DACFramework.msi" C:\Windows\Installer\487aa9f0.msi
!!!! smo_extensions_loc.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\smo_extensions_loc.msi" C:\Windows\Installer\48868b55.msi
!!!! sql_batchparser.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sql_batchparser.msi" C:\Windows\Installer\48868b1d.msi
!!!! smo_extensions.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\smo_extensions.msi" C:\Windows\Installer\48868b40.msi
!!!! sql_engine_core_inst.msi DOES NOT exist on the path in the path 1;H:\x64\setup\sql_engine_core_inst_msi\ !!!!
Action needed, re-establish the path to 1;H:\x64\setup\sql_engine_core_inst_msi\
Copy "1;H:\x64\setup\sql_engine_core_inst_msi\sql_engine_core_inst.msi" C:\Windows\Installer\48868baf.msi
!!!! sql_diag.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sql_diag.msi" C:\Windows\Installer\48868b24.msi
!!!! sql_xevent.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\x64\setup\sql_xevent.msi" C:\Windows\Installer\48868b39.msi
!!!! sql_dmf_loc.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sql_dmf_loc.msi" C:\Windows\Installer\48868b32.msi
!!!! sql_tools_extensions_loc.msi DOES NOT exist on the path in the path H:\1033_ENU_LP\x64\setup\ !!!!
Action needed, re-establish the path to H:\1033_ENU_LP\x64\setup\
Copy "H:\1033_ENU_LP\x64\setup\sql_tools_extensions_loc.msi" C:\Windows\Installer\13eb4739.msi
!!!! sql_common_core_loc.msi DOES NOT exist on the path in the path 1;H:\1033_ENU_LP\x64\setup\sql_common_core_loc_msi\ !!!!
Action needed, re-establish the path to 1;H:\1033_ENU_LP\x64\setup\sql_common_core_loc_msi\
Copy "1;H:\1033_ENU_LP\x64\setup\sql_common_core_loc_msi\sql_common_core_loc.msi" C:\Windows\Installer\48868b8f.msi
!!!! sql_xevent_loc.msi DOES NOT exist on the path in the path C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\ !!!!
Copy "C:\Users\wwiadmin\Desktop\SQL 2016 Standard with SP1\1033_ENU_LP\x64\setup\sql_xevent_loc.msi" C:\Windows\Installer\48868b4e.msi
PRODUCT NAME : SQL Server 2016 Database Engine Shared
Product Code: {686A81C0-C8E4-46F6-952F-B19A28E8C430}
Version : 13.2.5026.0
Most Current Install Date: 20191029
Target Install Location:
Registry Path:
HKEY_CLASSES_ROOT\Installer\Products\0C18A6864E8C6F6459F21BA9828E4C03\SourceList
Package : sql_engine_core_shared.msi
Install Source: \x64\setup\sql_engine_core_shared_msi\
LastUsedSource: m;101;H:\x64\setup\sql_engine_core_shared_msi\
