Not Received Help?
Status
Not open for further replies.
Good day gentlemen!, I would appreciate if anyone can take a look at this thread that I created 3 days ago: https://www.sysnative.com/forums/windows-update/21604-cant-update-w7-x64-ultimate-w7-sp1-components-missing.html
Thanks!
MoonWalker, zlippy and derezzed, I picked up your threads.
Hello again,
I posted a problem thread a few days ago and here is the link:-
https://www.sysnative.com/forums/wi...e-error-8024402f-cnbj2530-dpb-corruption.html
Since that time, I have run DISM three times with /ScanHealth, then /Checkhealth and finally /Restorehealth switches. The first two times I was told that the compnent store is 100% repairable but with the RestoreHealth switch DISM hangs (after about 90 minutes) at 40% complete. As the windows update appears broken it is perhaps not surprising DISM doesn't work to "restore health". But I am begnning to run out of my depth here suffice to say that I need to point to a clean image or clean windows files to fix my problem? I do have recovery USB that I created quickly after I bought my computer but will that do ? It is not a single ISO file that I have been reading about elsewhere. Please help.
Thanks a lot!
Slav Paleolog
Greetings :)
I'm considering making a fresh system install, I know you guys are busy but I'd appreciate if you could just look for a second into my thread and only say if you are able to help me fix it. If yes, I'll wait for your help but if you recommend me to do fresh system install, I'll not take your time and try that maybe it fix itself after system format. But would be much better to avoid it cuz I can't copy everything. Thank you :)
https://www.sysnative.com/forums/wi...service-pack-1-windows-update.html#post169596
Posted this a few days ago and haven't received anything - the problem is having a knock on affect and wont let me install USB drivers so I can't access my HDD which contains all my teaching resources and lessons (maths teacher), I need these for teaching in the coming weeks and so would appreciate any h
windows asking to update over and over again
hello sorry for disturbing you guys but if you have time could it be possible to help me with my problem ?
Thank you in advanced :)
https://www.sysnative.com/forums/windows-update/21680-windows-10-update-1607-fails-88-a.html
Status
