My machine is a 2019 ASUS ROG Strix laptop running Windows 10. Around Nov 22, I got a message on my screen that a file was infected with a virus and to shut down immediately. I was in a hurry and didn't verify the message first. When I rebooted, I got a message on the screen that said something like, "Hello, don't worry we got you...." It seemed suspect so I immediately shut down. Since then I've been unable to start up properly. Sometimes I get to the login screen, login and then I get the black/blue screen and Windows just grinds and grinds. If I continue to let it run, occasionally a message will pop up that itunes has an update, if I click on it it's back to the black screen. I've tried to run scannow and DISM but scannow says corrupt files have been found but Windows couldn't repair them. I've used Hitren on a USB to do a live boot and used the ESET Online anti-virus scanner. It claims to have found and cleaned a Trojan and subject scan shows up clean but I still have the same issues starting up however now instead of going into the login in screen it seems to immediately login as Administrator and then go to the blue/black screen and just grind (again if I let it run for hours occasionally a program pops up on the screen but I can't go any further).
I've looked at the CBS log file and searched for the word "corrupt" but I can't really find anything that seems like it's a big problem (I'm new at this so probably much more here than I realize). I'm attaching the CBS log file and hoping someone can help me.
I downloaded the BSOD collection app onto a USB drive and copied it to my laptop, Documents folder but it won't run on the laptop - "The application failed to start because it's side-by-side configuration is incorrect", which is why I have no BSOD data to attach.
I have a backup of my data but am trying to avoid re-installing all my programs, hence my desire to recover the machine to it's previous working state.
Thanks and apologies if I've not posted in the correct place.
