[SOLVED] Not sure if I'm posting in the right section
Status
Not open for further replies.
Thanks for your patience.
I see you have multiple driver updater programs that aren't necessary. With a laptop, the main source of driver downloads is the vendor of your laptop, in this case ASUS, who provides you with drivers that should work fine. Speaking from experience as someone who does BSOD crash analysis, the latest drivers aren't necessarily the best drivers for a laptop or a desktop. That is why I recommend removing these programs when you are able to access normal mode again.
  • DriverFix
  • DriverEasy
  • Norton Driver Updater
I also need you to remove these programs when you're able to boot into safe mode as these looks to be illegally activated.
  • Topaz Sharpen AI 410 Crack.exe version 1.0
  • Adobe Lightroom Classic
Please remove or update Java 8 when you can, the installed version is outdated, and Java is known to be a security vulnerability. Unless you need it, it is strongly advised to remove the program.
After the FRST fix, please try to boot in normal mode and let me know how it goes.
Run FRST Fix
Warning: This script was created for this specific system. Attempting to use the fix on another system may cause damage to the system
  • Right-click FRST64.exe then click "Run as administrator".
  • Select the entire content of the code below including "Start::" and "End::", right click and select "Copy"
  • Click Fix button once and wait
  • When finished, it will produce a log called Fixlog.txt in the same directory the tool was run from.
  • Please copy and paste the log in your next reply.
Start::
CloseProcesses:
EmptyTemp:
cmd: netsh int ip reset C:\resettcpip.txt
HKLM\...\RunOnce: [DEL_ST_CPL] => CMD /C del "C:\Windows\TEMP\ST_CPL.pkg.XML" /F [4560 2023-12-04] () [File not signed] <==== ATTENTION
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Option => "OptionValue"="1"
S2 DCIService; C:\Program Files (x86)\Lavasoft\Web Companion\Service\x64\DCIService.exe [X] <==== ATTENTION
HKU\S-1-5-21-1876214748-2417306340-1488581364-1002\...\Winlogon: [Shell] explorer.exe, <==== ATTENTION
BootExecute:
Task: {0A04E7AE-7A2F-4462-AD18-353A06AC12ED} - \BlueStacksHelper -> No File <==== ATTENTION
Task: {1a244e45-906a-4e63-9003-71576417008f} - no filepath. <==== ATTENTION
Task: {2edc4496-8dc2-4d32-9801-771a6aca23bd} - no filepath. <==== ATTENTION
Task: {376cd3e9-4fd3-433c-bf69-88cd468521a1} - no filepath. <==== ATTENTION
Task: {6f79d294-cdcd-452b-83b7-47a4577b4a6f} - no filepath. <==== ATTENTION
Task: {86b60f0a-bbc9-42b8-8647-ed06ee0972e8} - no filepath. <==== ATTENTION
Task: {9ad0e8ab-7de2-432a-862a-ff8844f40706} - no filepath. <==== ATTENTION
Task: {9c34defe-4380-4758-b7bd-30ef3d959a1f} - no filepath. <==== ATTENTION
Task: {d5e5e80e-b1a0-4efd-9d33-e6f82a17a629} - no filepath. <==== ATTENTION
Task: {D72E48F5-9DF4-44C5-857D-D97C92A23146} - \klcp_update -> No File <==== ATTENTION
End::
In your next post
In your next post, please include the following. Make sure to copy and paste any requested logs unless asked to attach it.
  • Fixlog.txt
  • Are you able to boot into normal mode?
I booted into "safe" mode but I can't access the control panel to uninstall these programs. Should I just try to delete the folders in program files or wait until I can boot properly and uninstall from control panel?
I ran the fix in "safe" mode and it took several hours, kept saying windows was not responding, not sure if that's expected behavior or not. Here is what the log says:
Fix result of Farbar Recovery Scan Tool (x64) Version: 03-12-2023
Ran by Administrator (10-12-2023 18:21:49) Run:1
Running from E:\
Loaded Profiles: flipper26 & Administrator
Boot Mode: Safe Mode (minimal)
I cannot boot into normal mode. The laptop behaves as before, the screensaver comes up, it shows Administrator automatically logging in then the screen becomes black.
thank you
No sorry, a mistake on my part. Those programs can be removed when you can boot in normal mode. Do not manually delete folders from said programs, that can cause more harm.
Let's take a different approach. Use the USB FRST is on and make sure it is connected.
FRST Fix
  • Open notepad
  • Copy and paste the entire content of the code below in notepad and save it as Fixlist.txt in the directory where FRST64.exe is located on your USB <--- important
    • make sure the name is Fixlist.txt and it is saved in the same directory, if the name is not right or Fixlist.txt is not located in the same directory as FRST, FRST will not be able to process the fix on your infected computer
  • Boot your laptop into the recovery environment again as you did before
  • Open FRST in the recovery environment and click Fix
  • After FRST is finished, reboot and see if you can enter normal mode.
  • Please post the content of the fixlog
BootExecute:
S3 BITS_bkp; C:\Windows\System32\qmgr.dll [1481216 2023-10-11] (Microsoft Windows -> Microsoft Corporation)
S3 dosvc_bkp; C:\Windows\system32\dosvc.dll [1536000 2023-10-11] (Microsoft Windows -> Microsoft Corporation)
S2 UsoSvc_bkp; C:\Windows\system32\usosvc.dll [570368 2023-10-11] (Microsoft Windows -> Microsoft Corporation)
S3 WaaSMedicSvc_bkp; C:\Windows\System32\WaaSMedicSvc.dll [427520 2023-10-11] (Microsoft Windows -> Microsoft Corporation)
S3 wuauserv_bkp; C:\Windows\system32\wuaueng.dll [3447296 2023-10-11] (Microsoft Windows -> Microsoft Corporation)
S3 bits; C:\windows\System32\svchost.exe [55456 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S3 bits; C:\windows\SysWOW64\svchost.exe [46632 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S3 dosvc; C:\windows\System32\svchost.exe [55456 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S3 dosvc; C:\windows\SysWOW64\svchost.exe [46632 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S2 UsoSvc; C:\windows\system32\svchost.exe [55456 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S2 UsoSvc; C:\windows\SysWOW64\svchost.exe [46632 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S3 wuauserv; C:\windows\system32\svchost.exe [55456 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
S3 wuauserv; C:\windows\SysWOW64\svchost.exe [46632 2023-10-11] (Microsoft Windows Publisher -> Microsoft Corporation) <==== ATTENTION (no ServiceDLL)
StartRegedit:
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BITS]
"DependOnService"=hex(7):52,00,70,00,63,00,53,00,73,00,00,00,00,00
"Description"="@%SystemRoot%\\system32\\qmgr.dll,-1001"
"DisplayName"="@%SystemRoot%\\system32\\qmgr.dll,-1000"
"ErrorControl"=dword:00000001
"FailureActions"=hex:80,51,01,00,00,00,00,00,00,00,00,00,03,00,00,00,14,00,00,\
00,01,00,00,00,60,ea,00,00,01,00,00,00,c0,d4,01,00,00,00,00,00,00,00,00,00
"ImagePath"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,00,\
74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,\
00,76,00,63,00,68,00,6f,00,73,00,74,00,2e,00,65,00,78,00,65,00,20,00,2d,00,\
6b,00,20,00,6e,00,65,00,74,00,73,00,76,00,63,00,73,00,20,00,2d,00,70,00,00,\
00
"ObjectName"="LocalSystem"
"RequiredPrivileges"=hex(7):53,00,65,00,43,00,72,00,65,00,61,00,74,00,65,00,47,\
00,6c,00,6f,00,62,00,61,00,6c,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,\
67,00,65,00,00,00,53,00,65,00,49,00,6d,00,70,00,65,00,72,00,73,00,6f,00,6e,\
00,61,00,74,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,\
00,00,53,00,65,00,54,00,63,00,62,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,\
00,67,00,65,00,00,00,53,00,65,00,41,00,73,00,73,00,69,00,67,00,6e,00,50,00,\
72,00,69,00,6d,00,61,00,72,00,79,00,54,00,6f,00,6b,00,65,00,6e,00,50,00,72,\
00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,49,00,6e,00,\
63,00,72,00,65,00,61,00,73,00,65,00,51,00,75,00,6f,00,74,00,61,00,50,00,72,\
00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,44,00,65,00,\
62,00,75,00,67,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,\
00,00,00
"ServiceSidType"=dword:00000001
"Start"=dword:00000003
"Type"=dword:00000020
"DelayedAutostart"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BITS\Parameters]
"ServiceDll"=hex(2):25,00,53,00,79,00,73,00,74,00,65,00,6d,00,52,00,6f,00,6f,\
00,74,00,25,00,5c,00,53,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,\
71,00,6d,00,67,00,72,00,2e,00,64,00,6c,00,6c,00,00,00
"ServiceDllUnloadOnStop"=dword:00000001
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BITS\Performance]
"Close"="PerfMon_Close"
"Collect"="PerfMon_Collect"
"Library"="C:\\Windows\\System32\\bitsperf.dll"
"Open"="PerfMon_Open"
"InstallType"=dword:00000001
"PerfIniFile"="bitsctrs.ini"
"First Counter"=dword:000022ac
"Last Counter"=dword:000022bc
"First Help"=dword:000022ad
"Last Help"=dword:000022bd
"Object List"="8876"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\BITS\Security]
"Security"=hex:01,00,14,80,90,00,00,00,a0,00,00,00,14,00,00,00,34,00,00,00,02,\
00,20,00,01,00,00,00,02,c0,18,00,00,00,0c,00,01,02,00,00,00,00,00,05,20,00,\
00,00,20,02,00,00,02,00,5c,00,04,00,00,00,00,02,14,00,ff,01,0f,00,01,01,00,\
00,00,00,00,05,12,00,00,00,00,00,18,00,ff,01,0f,00,01,02,00,00,00,00,00,05,\
20,00,00,00,20,02,00,00,00,00,14,00,8d,01,02,00,01,01,00,00,00,00,00,05,04,\
00,00,00,00,00,14,00,8d,01,02,00,01,01,00,00,00,00,00,05,06,00,00,00,01,02,\
00,00,00,00,00,05,20,00,00,00,20,02,00,00,01,02,00,00,00,00,00,05,20,00,00,\
00,20,02,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\DoSvc]
"DependOnService"=hex(7):72,00,70,00,63,00,73,00,73,00,00,00,00,00
"Description"="@%systemroot%\\system32\\dosvc.dll,-101"
"DisplayName"="@%systemroot%\\system32\\dosvc.dll,-100"
00,01,00,00,00,60,ea,00,00,01,00,00,00,60,ea,00,00,00,00,00,00,00,00,00,00
6b,00,20,00,4e,00,65,00,74,00,77,00,6f,00,72,00,6b,00,53,00,65,00,72,00,76,\
00,69,00,63,00,65,00,20,00,2d,00,70,00,00,00
"LaunchProtected"=dword:00000002
"ObjectName"="NT Authority\\NetworkService"
00,74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,\
64,00,6f,00,73,00,76,00,63,00,2e,00,64,00,6c,00,6c,00,00,00
"Start"=dword:00000002
"SvcMemHardLimitInMB"=dword:00000027
"SvcMemMidLimitInMB"=dword:0000001b
"SvcMemSoftLimitInMB"=dword:0000000f
"Type"=dword:00000010
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\DoSvc\Security]
"Security"=hex:01,00,14,80,a0,00,00,00,ac,00,00,00,14,00,00,00,30,00,00,00,02,\
00,1c,00,01,00,00,00,02,80,14,00,ff,01,0f,00,01,01,00,00,00,00,00,01,00,00,\
00,00,02,00,70,00,04,00,00,00,00,00,14,00,9d,00,02,00,01,01,00,00,00,00,00,\
05,0b,00,00,00,00,00,18,00,ff,01,0f,00,01,02,00,00,00,00,00,05,20,00,00,00,\
20,02,00,00,00,00,14,00,ff,01,0f,00,01,01,00,00,00,00,00,05,12,00,00,00,00,\
00,28,00,22,00,02,00,01,06,00,00,00,00,00,05,50,00,00,00,4d,f8,19,b6,b3,a7,\
7f,e3,93,9a,10,ee,20,5d,51,ab,9b,39,b9,82,01,01,00,00,00,00,00,05,12,00,00,\
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\DoSvc\TriggerInfo]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\DoSvc\TriggerInfo\0]
"Action"=dword:00000001
"Data0"=hex:75,10,bc,a3,29,01,c6,41
"DataType0"=dword:00000001
"GUID"=hex:16,28,7a,2d,5e,0c,fc,45,9c,e7,57,0e,5e,cd,e9,c9
"Type"=dword:00000007
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\DoSvc\TriggerInfo\1]
"GUID"=hex:e6,ca,9f,65,db,5b,a9,4d,b1,ff,ca,2a,17,8d,46,e0
"Type"=dword:00000005
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\UsoSvc]
"DelayedAutoStart"=dword:00000001
"Description"="@%systemroot%\\system32\\usosvc.dll,-102"
"DisplayName"="@%systemroot%\\system32\\usosvc.dll,-101"
00,01,00,00,00,c0,d4,01,00,01,00,00,00,e0,93,04,00,00,00,00,00,00,00,00,00
"ImagePath"=hex(2):25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,6f,00,\
74,00,25,00,5c,00,73,00,79,00,73,00,74,00,65,00,6d,00,33,00,32,00,5c,00,73,\
00
"PreshutdownTimeout"=dword:0036ee80
"RequiredPrivileges"=hex(7):53,00,65,00,41,00,75,00,64,00,69,00,74,00,50,00,72,\
00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,43,00,72,00,\
65,00,61,00,74,00,65,00,47,00,6c,00,6f,00,62,00,61,00,6c,00,50,00,72,00,69,\
00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,43,00,72,00,65,00,\
61,00,74,00,65,00,50,00,61,00,67,00,65,00,46,00,69,00,6c,00,65,00,50,00,72,\
00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,54,00,63,00,\
62,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,\
00,41,00,73,00,73,00,69,00,67,00,6e,00,50,00,72,00,69,00,6d,00,61,00,72,00,\
79,00,54,00,6f,00,6b,00,65,00,6e,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,\
00,67,00,65,00,00,00,53,00,65,00,49,00,6d,00,70,00,65,00,72,00,73,00,6f,00,\
6e,00,61,00,74,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,\
00,00,00,53,00,65,00,49,00,6e,00,63,00,72,00,65,00,61,00,73,00,65,00,51,00,\
75,00,6f,00,74,00,61,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,\
00,00,00,53,00,65,00,53,00,68,00,75,00,74,00,64,00,6f,00,77,00,6e,00,50,00,\
72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,44,00,65,\
00,62,00,75,00,67,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,\
00,00,53,00,65,00,42,00,61,00,63,00,6b,00,75,00,70,00,50,00,72,00,69,00,76,\
00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,52,00,65,00,73,00,74,00,\
6f,00,72,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,\
00,53,00,65,00,53,00,65,00,63,00,75,00,72,00,69,00,74,00,79,00,50,00,72,00,\
69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,54,00,61,00,6b,\
00,65,00,4f,00,77,00,6e,00,65,00,72,00,73,00,68,00,69,00,70,00,50,00,72,00,\
69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,4c,00,6f,00,61,\
00,64,00,44,00,72,00,69,00,76,00,65,00,72,00,50,00,72,00,69,00,76,00,69,00,\
6c,00,65,00,67,00,65,00,00,00,53,00,65,00,4d,00,61,00,6e,00,61,00,67,00,65,\
00,56,00,6f,00,6c,00,75,00,6d,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,00,\
65,00,67,00,65,00,00,00,53,00,65,00,53,00,79,00,73,00,74,00,65,00,6d,00,45,\
00,6e,00,76,00,69,00,72,00,6f,00,6e,00,6d,00,65,00,6e,00,74,00,50,00,72,00,\
69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,43,00,72,00,65,\
00,61,00,74,00,65,00,53,00,79,00,6d,00,62,00,6f,00,6c,00,69,00,63,00,4c,00,\
69,00,6e,00,6b,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,\
00,53,00,65,00,49,00,6e,00,63,00,72,00,65,00,61,00,73,00,65,00,42,00,61,00,\
73,00,65,00,50,00,72,00,69,00,6f,00,72,00,69,00,74,00,79,00,50,00,72,00,69,\
00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\UsoSvc\Parameters]
"ServiceDll"=hex(2):25,00,73,00,79,00,73,00,74,00,65,00,6d,00,72,00,6f,00,6f,\
75,00,73,00,6f,00,73,00,76,00,63,00,2e,00,64,00,6c,00,6c,00,00,00
"ServiceMain"="ServiceMain"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\UsoSvc\Security]
"Security"=hex:01,00,14,80,78,00,00,00,84,00,00,00,14,00,00,00,30,00,00,00,02,\
00,1c,00,01,00,00,00,02,80,14,00,ff,00,0f,00,01,01,00,00,00,00,00,01,00,00,\
00,00,02,00,48,00,03,00,00,00,00,00,14,00,9d,00,02,00,01,01,00,00,00,00,00,\
20,02,00,00,00,00,14,00,ff,01,0f,00,01,01,00,00,00,00,00,05,12,00,00,00,01,\
01,00,00,00,00,00,05,12,00,00,00,01,01,00,00,00,00,00,05,12,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WaaSMedicSvc]
"Description"="@WaaSMedicSvcImpl.dll,-101"
"DisplayName"="@WaaSMedicSvcImpl.dll,-100"
"FailureActions"=hex:84,03,00,00,00,00,00,00,00,00,00,00,03,00,00,00,14,00,00,\
6b,00,20,00,77,00,75,00,73,00,76,00,63,00,73,00,20,00,2d,00,70,00,00,00
"RequiredPrivileges"=hex(7):53,00,65,00,54,00,63,00,62,00,50,00,72,00,69,00,76,\
00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,43,00,68,00,61,00,6e,00,\
67,00,65,00,4e,00,6f,00,74,00,69,00,66,00,79,00,50,00,72,00,69,00,76,00,69,\
00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,49,00,6d,00,70,00,65,00,72,00,\
73,00,6f,00,6e,00,61,00,74,00,65,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,\
00,67,00,65,00,00,00,53,00,65,00,54,00,61,00,6b,00,65,00,4f,00,77,00,6e,00,\
65,00,72,00,73,00,68,00,69,00,70,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,\
00,67,00,65,00,00,00,53,00,65,00,53,00,65,00,63,00,75,00,72,00,69,00,74,00,\
79,00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,\
00,42,00,61,00,63,00,6b,00,75,00,70,00,50,00,72,00,69,00,76,00,69,00,6c,00,\
65,00,67,00,65,00,00,00,53,00,65,00,52,00,65,00,73,00,74,00,6f,00,72,00,65,\
00,50,00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,53,00,65,00,\
4d,00,61,00,6e,00,61,00,67,00,65,00,56,00,6f,00,6c,00,75,00,6d,00,65,00,50,\
00,72,00,69,00,76,00,69,00,6c,00,65,00,67,00,65,00,00,00,00,00
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WaaSMedicSvc\Parameters]
57,00,61,00,61,00,53,00,4d,00,65,00,64,00,69,00,63,00,53,00,76,00,63,00,2e,\
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\WaaSMedicSvc\Security]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv]
"Description"="@%systemroot%\\system32\\wuaueng.dll,-106"
"DisplayName"="@%systemroot%\\system32\\wuaueng.dll,-105"
00,01,00,00,00,60,ea,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00,00
00
"SvcMemHardLimitInMB"=dword:000000f6
"SvcMemMidLimitInMB"=dword:000000a7
"SvcMemSoftLimitInMB"=dword:00000058
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv\Parameters]
77,00,75,00,61,00,75,00,65,00,6e,00,67,00,2e,00,64,00,6c,00,6c,00,00,00
"ServiceMain"="WUServiceMain"
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv\Security]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv\TriggerInfo]
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv\TriggerInfo\0]
"Guid"=hex:e6,ca,9f,65,db,5b,a9,4d,b1,ff,ca,2a,17,8d,46,e0
[HKEY_LOCAL_MACHINE\SYSTEM\ControlSet001\Services\wuauserv\TriggerInfo\1]
"Guid"=hex:c8,46,fb,54,89,f0,4c,46,b1,fd,59,d1,b6,2c,3b,50
End Regedit
I used the F8 key on the laptop to boot into "safe" mode and from there I ran the FixList.txt Here is the content of the log file:
Ran by Administrator (11-12-2023 14:50:47) Run:2
Running from E:\
fixlist content:
BootExecute:
StartRegedit:
00
00,00,00
00,20,02,00,00
00
00
End Regedit
"HKLM\Software\Microsoft\Windows\CurrentVersion\RunOnce\\DEL_ST_CPL" => not found
DCIService => service not found.
"HKU\S-1-5-21-1876214748-2417306340-1488581364-1002\Software\Microsoft\Windows NT\CurrentVersion\Winlogon\\Shell" => not found
HKLM\System\CurrentControlSet\Control\Session Manager\\"BootExecute"="autocheck autochk *" => value restored successfully
"HKLM\System\CurrentControlSet\Services\BITS_bkp" => removed successfully
BITS_bkp => service removed successfully
HKLM\System\CurrentControlSet\Services\dosvc_bkp => removed successfully
dosvc_bkp => service removed successfully
HKLM\System\CurrentControlSet\Services\UsoSvc_bkp => removed successfully
UsoSvc_bkp => service removed successfully
HKLM\System\CurrentControlSet\Services\WaaSMedicSvc_bkp => removed successfully
WaaSMedicSvc_bkp => service removed successfully
HKLM\System\CurrentControlSet\Services\wuauserv_bkp => removed successfully
wuauserv_bkp => service removed successfully
HKLM\System\CurrentControlSet\Services\bits => removed successfully
bits => service removed successfully
bits => service not found.
HKLM\System\CurrentControlSet\Services\dosvc => removed successfully
dosvc => service removed successfully
dosvc => service not found.
HKLM\System\CurrentControlSet\Services\UsoSvc => removed successfully
UsoSvc => service removed successfully
UsoSvc => service not found.
HKLM\System\CurrentControlSet\Services\wuauserv => removed successfully
wuauserv => service removed successfully
wuauserv => service not found.
Registry ====> The operation completed successfully.
==== End of Fixlog 14:50:48 ====
I cannot boot normally. It's the same as before, goes from screensaver right to logging in as Administrator then immediately to the "safe" mode screen.
Could you post new FRST logs please.
So I should run a FRST scan again? When running the Fix, only a Fix log was generated, not a new FRST or Additon log.
Please do the following, this should create a new profile called OWNER. Try and login from this account.
Afterwards, please run a new scan with FRST and post both FRST and Addition logs.
FRST Fix
  • Open notepad
EmptyTemp:
cmd: net user administrator
cmd: net user flipper26
cmd: net user OWNER /add
cmd: net localgroup administrators OWNER /add
cmd: netsh advfirewall reset
DeleteKey: HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Option
StartRegedit:
00
00,00,00
00,20,02,00,00
00
00
End Regedit
After running the Fix, I rebooted and the laptop automatically logged on to the Administrator account, welcome spinning circles and black screen. I brought up the task manager and hit "Switch User" where I could see the OWNER profile and logged in. I then got the message, "Hi, we're getting everything ready for you......". It was stuck on "this is taking longer than expected but we'll get there as fast as we can". I let this keep running for quite awhile and when I came back there was just a black screen again. I tried to boot into "safe" mode using the OWNER profile but it just goes to a black screen. I can boot into "safe" mode using the Administrator profile. Here are the contents of the fixlog:
Ran by Administrator (13-12-2023 14:59:32) Run:3
Running from E:\
fixlist content:
EmptyTemp:
StartRegedit:
00
00,00,00
00,20,02,00,00
00
00
End Regedit
========= net user administrator =========
User name Administrator
Full Name
Comment Built-in account for administering the computer/domain
User's comment
Country/region code 000 (System Default)
Account active Yes
Account expires Never
Password last set 2023-04-19 8:51:12 PM
Password expires Never
Password changeable 2023-04-19 8:51:12 PM
Password required Yes
User may change password Yes
Workstations allowed All
Logon script
User profile
Home directory
Last logon 2023-12-12 7:47:28 AM
Logon hours allowed All
Local Group Memberships *Administrators
Global Group memberships *None
The command completed successfully.
========= net user flipper26 =========
User name flipper26
Full Name chris warner
Comment
User's comment
Account active Yes
Password last set 2021-05-03 9:11:44 AM
Password changeable 2021-05-03 9:11:44 AM
Password required No
Logon script
User profile
Home directory
Last logon 2021-05-03 9:11:40 AM
========= net user OWNER /add =========
========= net localgroup administrators OWNER /add =========
========= netsh advfirewall reset =========
An error occurred while attempting to contact the Windows Defender Firewall service. Make sure that the service is running and try your request again.
HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Option => removed successfully
=========== EmptyTemp: ==========
FlushDNS => completed
BITS transfer queue => 0 B
DOMStore, IE Recovery, AppCache, Feeds Cache, Thumbcache, IconCache => 4209712 B
Java, Discord, Steam htmlcache, WinHttpAutoProxySvc/winhttp *.cache => 0 B
Windows/system/drivers => 2772471 B
Edge => 0 B
Firefox => 0 B
Opera => 0 B
Temp, IE cache, history, cookies, recent:
Default => 0 B
ProgramData => 0 B
Public => 0 B
systemprofile => 0 B
systemprofile32 => 0 B
LocalService => 0 B
NetworkService => 0 B
flipper26 => 0 B
defaultuser100000 => 0 B
defaultuser100000.LAPTOP-RLPEIM75 => 0 B
Administrator => 1007628 B
RecycleBin => 0 B
EmptyTemp: => 7.6 MB temporary data Removed.
The system needed a reboot.
==== End of Fixlog 15:46:28 ====
Is this black screen in normal mode completely black? Taskbar or anything doesn't show up? Can you see the mouse?
After the latest Fix when I turn on the laptop and try to boot normally it immediately goes to "Safe" Mode, no matter which profile I pick to login. Here is a screenshot:
So there's the taskbar at the bottom as well as the Explorer folder; recycle bin and Microsoft Edge at the top left and all four corners say "Safe Mode". This is a little bit different than yesterday where it was just going into a black screen with the mouse pointer the only thing visible on the screen. The only difference is that I shut it down and left it off overnight instead of trying to login to normal mode repeatedly (which is what I was doing yesterday after the Fix).
The above screenshot is how it opens up when I shut it down by pressing the on/off button on the laptop. When I shut it down using the shutdown option on the bottom left (where it gives you the option to sign out, restart or shutdown, I shutdown), this is how the screen looks when I start it up again - it automatically logs in as Owner, circling dots then goes to this screen (so just the mouse pointer appears on the screen and every so often after awhile, itunes or some other app will appear and say an update is needed):
Please try the following in safe mode and see if you can boot in normal mode. Let me know if you can boot in normal mode.
  • Press Windows key + R, type msconfig and press enter
  • Uncheck load startup items
  • Go to Services tab
  • Check Hide all Microsoft services left below
  • Uncheck everything else
  • Click apply and click ok
  • Try and reboot into normal mode
I'm still just getting the black screen with the mouse pointer when I try to boot into normal mode. Thanks.
Please make sure the option to load startup items and all services except Microsoft services in the msconfig program are unchecked per my earlier instructions, then do the below.
  • Boot your laptop in safe mode
  • Right click the Windows logo on the task bar
  • Select device manager
  • In device manager, expand display adapters
  • Uninstall the NVIDIA device
  • Try and boot in normal mode
This won't prevent you from seeing the screen in normal mode. When no display driver is installed, Windows will default to basic display drivers that are inbuilt. These inbuilt drivers may not be the best drivers, but if something's wrong with the display drivers which I think there may be, this can help troubleshoot that.
Let me know if you can see something more than a black screen.
I've followed the instructions as above but still just have the black screen with the mouse arrow. The "itunes" message popped up as before too and the same with the "NVIDIA Control Panel is not found" as well, so still getting the black screen as before. I am finding that it takes a long time when I boot into "Safe" mode for everything to load so it takes quite awhile before I can get into the device manager.
Could you try the same instructions from my last post but do it for your Intel graphics now.
Please do the following below, and when this is done, please try and uninstall one of the mentioned programs in safe mode and let me know how it goes.
  • DriverFix
  • DriverEasy
Run FRST Fix
Start::
Reg: REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service"
Reg: REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service"
cmd: net start msiserver
End::
Here is the contents of the Fixlog:
Ran by OWNER (22-12-2023 15:16:36) Run:5
Running from E:\
Loaded Profiles: OWNER
fixlist content:
Start::
End::
========= REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\MSIServer" /VE /T REG_SZ /F /D "Service" =========
========= End of Reg: =========
========= REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\MSIServer" /VE /T REG_SZ /F /D "Service" =========
========= net start msiserver =========
The Windows Installer service is starting.
The Windows Installer service was started successfully.
==== End of Fixlog 15:16:39 ====
I'm not sure how I can uninstall a program in Safe mode. I don't see the Control Panel and if I try to search for it in the bottom left window the system just freezes.
Status
