Problem with wifes notebook ;-)
Step 1 - Run Check Disk (CHKDSK).
  • Click the Start button and in the search box, type Command Prompt
  • When command prompt opens, copy and paste the following command into it, press enter afterwards.
    chkdsk
  • Wait for this to complete.
Step 2 - Download
ListChkdskResult.exe and save it on your desktop.
  • Rightclick ListChkdskResult.exe and select Run as administrator.
  • Notepad will open the file ListChkdskResult.txt on completion. (This logfile ListChkdskResult.txt is also saved on your desktop.)
  • Post the logfile ListChkdskResult.txt as attachment in your next reply.
This looks good, so we can rule out a possible drive problem.
Please run the System File Checker in an elevated command prompt, if it fails attach a new copy of the CBS log.
SFC /Scannow
Upload your COMPONENTS hive.
Please perform the following steps again, but copy SFCFix.exe and SFCFix.zip to your systemdrive C:\ and execute it from there.
Afterwards, reboot the laptop and run the System File Checker again.
Mmm, the CBS log is still reporting the same issues, what was the result of SFC /Scannow?
1 Windows Resource Protection did not find any integrity violations
2 Windows Resource Protection found corrupt files and successfully repaired them
3 Windows Resource Protection found corrupt files but was unable to fix some of them
In the meantime I have installed a VM with the same updates. Here's the next fix to restore the missing registry keys.
Afterwards, reboot the laptop and run the System File Checker again and let me know the result.
Could you please post a new copy of the COMPONENTS hive (see post#26) it seems none of the fixes provided by Philc43 and me seem to work?
Please perform the following steps to look at some folders and files.
Download the
  • Press the Fix button.
Step 1. Start the
Step 2. Run SFCFix with the attached ZIP-file.
Step 3. Run the System File Checker and post the result. If it fails attach a new copy of the CBS log.
SFC /Scannow
