Problem with wifes notebook ;-)
Please try the following command, I wonder if error 126 appears too? If so, please attach the latest DISM log to see if it failed to load drvstore.dll this time.
DISM /online /get-drivers
Here's the new fix: SFCFix.zip - Shared with pCloud
Afterwards, reboot the system and try DISM again and post the result.
Please run the following command in an elevated command prompt and post the result.
regsvr32 C:\windows\system32\dism\dismprov.dll
Please try this command as well, just to see if you get the same error?
%systemroot%\SysWoW64\regsvr32 C:\Windows\SysWOW64\Dism\DismProv.dll
Please try to run DISM again and see what happens now.
There seems to be something badly wrong with the WOW64 file system redirection. Please try the following commands in an elevated command prompt:
CD\
CD C:\Windows\SysWOW64
Mmm. this is really interesting. Try this command again in a regular prompt after: C:\Windows\system32>
The command prompt was not started with administrator privileges, sorry with "regular" I meant not using the SysWOW directory....
Please run DISM again with Process Monitor running, there has to be a clue somewhere why it fails?!
2. Try updating the system just like you have in the past.
3. Stop Process Monitor as soon as it fails. You can simply do this by clicking the square (CTRL +E) on the toolbar as shown below.
5. Zip up the LogFile.PML and upload it to WeTransfer - Send Large Files & Share Photos Online - Up to 2GB Free and provide the link.
done
https://www.swisstransfer.com/d/e0d19713-8f60-4d85-b154-f188ca4bdc51
(i have 2 logs, after dism and after update)
