Problem with wifes notebook ;-)
1. Remove the WUReset Environment Path.
  • Click the Start button and in the search box, type sysdm.cpl
  • When you see sysdm.cpl > Control Panel Item on the list, right-click on it and select Run as administrator.
  • Open the tab Advanced and click on Environment Variables.
  • Select in the System variables section > Path and click on the Edit button.
  • Select the following entry en click on Delete.
    • C:\Program Files\wureset
  • Click on Ok and close the System Properties window.
2. Reboot the system and run the following command and attach set-env.txt to your next post.
set > "%userprofile%\desktop\set-env.txt"
Let's try to run DISM again, but shall fail with error 126 I guess. I wonder if SetupDiag reports: DISM provider failure, error: 0x80070002 or something like this?
Download and run SetupDiag from Microsoft
  • Download
    SetupDiag to your desktop.
  • Right-click on SetupDiag.exe and select Run as administrator.
  • When completed the following files are created: "Logs.zip, SetupDiag.exe.config and SetupDiagResults.log"
  • Attach SetupDiagResults.log and Logs.zip to your next reply.
Error: SetupDiag reports DISM Image Session failure.
Last Phase: Pre-Finalize
Last Operation: Process Drivers for Migration
Message = Failed to get file version: C:\Windows\System32\Dism\dismprov.dll
Function: CDISMManager::IsServiceUpLevelImage
Error: 0x80070002
Great! Please run the following commands and attach "dism-look.txt" to your next post.
icacls C:\Windows\System32\Dism >> "%userprofile%\desktop\dism-look.txt"
icacls C:\Windows\System32\Dism\*.* >> "%userprofile%\desktop\dism-look.txt"
dir /s /a C:\Windows\System32\Dism >> "%userprofile%\desktop\dism-look.txt"
certutil -hashfile C:\Windows\System32\Dism\dismprov.dll SHA256 >> "%userprofile%\desktop\dism-look.txt"
Reboot the laptop, and run the following command in an elevated command prompt.
regsvr32 C:\windows\system32\dism\dismprov.dll
Right-click on the file
FRST64.exe and choose Run as administrator.
  • Copy and paste the following (code) into the Search box and click the Search Files button.
dismprov.dll
  • When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also.
  • Post the logfile Search.txt as attachment in your next reply.
Could you please try the following command as well.
regsvr32 "%systemroot%\system32\dism\dismprov.dll"
Mmm, that's strange?
In post#18 no issues with this command certutil -hashfile "%systemroot%\System32\Dism\dismprov.dll" SHA256
In post#85 this command failed certutil -hashfile C:\Windows\System32\Dism\dismprov.dll SHA256
Run both commands again and post the result of the command prompt..
This is really interessting, try the same for another file.
certutil -hashfile "%systemroot%\System32\Dism\DmiProvider.dll" SHA256
certutil -hashfile C:\Windows\System32\Dism\DmiProvider.dll SHA256
Run
SFCFix again to collect the DISM files to look at..
  • Once done, a file will appear on your desktop, called Collect.zip.
  • Attach this file as attachment to your next reply.
