Hi Gary,
After rebooting the computer, I have applied the latest SFCFix.zip (please see attached SFCFix.txt). I then rebooted the computer again. The reboots took a little while with the Windows Update for April
, KB5012599, being successfully applied (please see attached screenshot of Windows update history).
Following the second reboot, the
SFC /scannow command completed successfully. I then ran the
DISM /RestoreHealth command, which also completed successfully this time:
Version: 10.0.19041.844
Image Version: 10.0.19043.1645
[==========================100.0%==========================] The restore operation completed successfully.
So the Windows Update issues on my computer seem to have been successfully resolved. Are there any other actions that I should now perform? I have started taking weekly snapshots of the computer disks to a backup USB drive using Macrium.
Thank you so much to you and your colleague for all the excellent support you have given over the past few weeks in resolving these issues. Thank you for all your patience and the very clear instructions provided throughout.
Kind regards,
Steven
