[SOLVED] Problem!!!
Good Afternoon Gary,
Thanks for your latest SFCFix.zip update, which I have applied just now (please see attached SFCFix.txt). Following a restart, the SFC /scannow command has failed again at verification 88% complete:
Microsoft Windows [Version 10.0.19043.1526]
(c) Microsoft Corporation. All rights reserved.
Verification 88% complete.
Windows Resource Protection could not perform the requested operation.
Please find attached a zip of the CBS.log file.
Thanks for your help.
  • Once done, a file will appear on your desktop, called SFCFix.txt
Next ...
  • Restart the computer.
  • Run the command SFC /SCANNOW in an elevated command prompt and report the result.
  • If it fails, attach a zipped C:\Windows\Logs\CBS\CBS.log to your next reply.
Good Morning Gary,
Thank you for the latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt). Following a reboot, the SFC /scannow command ran to verification 100% complete :-).
However, SFC reported finding some corrupt files that it was unable to fix:
Verification 100% complete.
For online repairs, details are included in the CBS log file located at windir\Logs\CBS\CBS.log. For example C:\Windows\Logs\CBS\CBS.log. For offline repairs, details are included in the log file provided by the /OFFLOGFILE flag.
Many thanks for all your help.
Latest log shows a lot of files that need sourcing, so it's likely going to take me a while to get them all together. I'll get back to you ASAP.
Next ...
Hi Gary,
Thanks very much for the latest SFCFix.zip update, which I have applied just now (please see attached SFCFix.txt). Following a restart, the SFC /scannow command returned without any errors or warnings, which is super news :-):
However, when I executed the following DISM commands, they still returned errors (please see attached dism.log in dism.zip file):
C:\WINDOWS\system32>dism /cleanup-image /online /checkhealth
Version: 10.0.19041.844
Image Version: 10.0.19043.1526
No component store corruption detected.
C:\WINDOWS\system32>dism /cleanup-image /online /scanhealth
[=== 6.4% ]
Error: 4448
The WOF driver encountered a corruption in the compressed file's Resource Table.
C:\WINDOWS\system32>dism /cleanup-image /online /restorehealth
[== 4.4% ]
Error: 4448
Are there any other additional steps that I should now perform?
Thanks so much for all your help and support.
Steven
Please can you post your latest ... CBS.log
Next ...
Next ...
  • Run the command Dism /Online /Cleanup-Image /RestoreHealth in an elevated command prompt and report the result.
Next ...
  • If either fails please attach your ... C:\Windows\Logs\CBS\cbs.log ... to your next reply.
Hi Gary,
Thanks for the latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt). Following a reboot, the SFC /scannow ran successfully:
However, the DISM command failed as follows:
[== 4.9% ]
Error: 605
The specified buffer contains ill-formed data.
Please find attached a zip of the latest CBS.log file.
Thanks for your help and support.
Next ...
Next ...
Next ...
Good Evening Gary,
Thanks for your latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt). Following a reboot, the SFC /scannow command completed successfully again:
However, the DISM /restorehealth command failed with the error 4448 at 7.4%:
[==== 7.4% ]
Error: 4448
Thanks for all your help.
Next ...
Next ...
Next ...
Good Evening Gary,
Thanks for the latest SFCFix.zip update, which I have applied (please see attached SFCFix.txt) After a reboot, the SFC /scannow command completed successfully again:
However, the DISM /restorehealth command failed with the error 4448 at 9.4%:
[===== 9.4% ]
Error: 4448
Thanks for all your help and support.
Next ...
Next ...
Next ...
Good Morning Gary,
Thanks for the latest SFCFix.zip, which I have applied (please see attached SFCFix.txt). Following a reboot, the SFC /scannow command reached verification 100% complete.
However, the DISM /restorehealth command again failed with error 4448 at 9.4% complete:
[===== 9.4% ]
Error: 4448
Your topic has been marked as solved, did you do this, because I certainly did not ? I've removed the SOLVED notification, presuming it was placed there in error.
Looking over your latest logs, back ASAP.
Thanks for your reply, Gary. I saw the topic was marked as SOLVED and wondered about this. I did not set it to solved, at least intentionally. It is sometimes easy to accidentally click on a link while scrolling!
Next ...
Next ...
Next ...
