[SOLVED] problems related to Internet Explorer dlls
It installed successfully but it did not change anything.
The change may not be noticeable.
Install Update with DISM
  1. Download the update MSU here: http://download.windowsupdate.com/c..._92202202c3dee2f713f67adf6622851b998c6780.msu
    cd C:\temp
    expand windows6.1-kb4555449-x64_92202202c3dee2f713f67adf6622851b998c6780.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4555449-x64.cab
Okay, then I was thinking the same.
Please install the update in message #42 and report the result.
Please provide a downloadlink for ForgeUI.
Provide the Components Hive
4. The file will likely be too large to upload here so please upload to Gofile or WeTransfer and just provide the link here.
  • Then please upload the zip file (COMPONENTS.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Gofile or WeTransfer and then just provide the link in your reply.
It looks like the update mentioned in message #42 wasn't installed completely.
    cd C:\temp
  1. Download the update MSU here: http://download.windowsupdate.com/d..._2798f0d248e08c292076980d2b954e6e1f2c8f99.msu
    cd C:\temp
    expand windows6.1-kb4592510-x64_2798f0d248e08c292076980d2b954e6e1f2c8f99.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4592510-x64.cab
Restart the computer.
If it fails, copy the file C:\Windows\Logs\CBS\cbs.log to your desktop.
FRST Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog.
  6. Copy and paste SearchAll:api-ms-win-downlevel-advapi32-l1-1-0 into the Search box and click the Search Files button.
  7. When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'Search.txt' to your next reply.
I haven't found the source of the missing files yet. They could be part of Windows 7 or SP1.
FRST Search
  6. Copy and paste SearchAll:api-ms-win-core-console-l1-1-0 into the Search box and click the Search Files button.
When available attach the file C:\Windows\IE11_main.log to your next reply.
The following fix will place the missing files to the correct folders.
  3. Press the Fix button.
Step 3:
Does that solve the problem related to ForgeUI ?
If not we may need to add some registry keys as well.
(Thanks again for spending so much time and effort trying to help me.)
SFCFix.txt:
Start time: 2024-08-25 02:25:15.222
Using .zip script file at C:\Users\Gros2\Desktop\SFCFix.zip [0]
Successfully took permissions for file or folder C:\Windows\winsxs
Successfully created directory tree \\?\C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994.
Successfully created directory tree \\?\C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_fef2c6755a84ce37.
Successfully created directory tree \\?\C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081.
Successfully created directory tree \\?\C:\Windows\winsxs\x86_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_862b61bc350b5a4b.
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca.
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_5b1161f912e23f6d.
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7.
Successfully created directory tree \\?\C:\Windows\winsxs\amd64_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_e249fd3fed68cb81.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shell32-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shell32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shlwapi-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shlwapi-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shlwapi-l2-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-shlwapi-l2-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-version-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_cf025cff09637994\api-ms-win-downlevel-version-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_fef2c6755a84ce37\api-ms-win-downlevel-ole32-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_fef2c6755a84ce37\api-ms-win-downlevel-ole32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-advapi32-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-advapi32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-advapi32-l2-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-advapi32-l2-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-normaliz-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_c2b7d547f57dc081\api-ms-win-downlevel-normaliz-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\x86_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_862b61bc350b5a4b\api-ms-win-downlevel-user32-l1-1-0.dll to C:\Windows\winsxs\x86_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_862b61bc350b5a4b\api-ms-win-downlevel-user32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shell32-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shell32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shlwapi-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shlwapi-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shlwapi-l2-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-shlwapi-l2-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-version-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-shell_31bf3856ad364e35_7.1.7601.16492_none_2b20f882c1c0eaca\api-ms-win-downlevel-version-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_5b1161f912e23f6d\api-ms-win-downlevel-ole32-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-com_31bf3856ad364e35_7.1.7601.16492_none_5b1161f912e23f6d\api-ms-win-downlevel-ole32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-advapi32-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-advapi32-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-advapi32-l2-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-advapi32-l2-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-normaliz-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-downlevelapisets-base_31bf3856ad364e35_7.1.7601.16492_none_1ed670cbaddb31b7\api-ms-win-downlevel-normaliz-l1-1-0.dll.
Successfully copied file C:\Users\Gros2\AppData\Local\niemiro\Archive\amd64_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_e249fd3fed68cb81\api-ms-win-downlevel-user32-l1-1-0.dll to C:\Windows\winsxs\amd64_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_e249fd3fed68cb81\api-ms-win-downlevel-user32-l1-1-0.dll.
Successfully restored ownership for C:\Windows\winsxs
Successfully restored permissions on C:\Windows\winsxs
Finish time: 2024-08-25 02:25:20.118
Script hash: Nr5BgFZrySJjgmFhd3wbGhb8dFtE1E2AR2ErrTDD0qM=
2. There are some "Error: access denied" in Fixlog.txt. :\
3. Unfortunately no, the same files are still missing.
The first step looks normal. The second somehow failed causing the problem to persist.
Please do following:
  1. Click on the Start button and in the search box, type CMD
  2. When CMD is listed above, right-click on it and select Run as administrator
  3. When Command Prompt opens, copy and paste the following command into it, then press enter.
    fsutil hardlink create c:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll c:\windows\winsxs\amd64_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_e249fd3fed68cb81\api-ms-win-downlevel-user32-l1-1-0.dll
Provide a screenshot of the Command Prompt window.
