[SOLVED] problems related to Internet Explorer dlls
Start time: 2024-08-25 22:11:17.022
Using .txt script file at C:\Users\Gros2\Desktop\SFCFixScript.txt [0]
CreateHardlink::
Failed to create hardlink from file c:\windows\winsxs\amd64_microsoft-windows-d..evelapisets-windows_31bf3856ad364e35_7.1.7601.16492_none_e249fd3fed68cb81\api-ms-win-downlevel-user32-l1-1-0.dll to c:\windows\system32\api-ms-win-downlevel-user32-l1-1-0.dll with error code ERROR_ACCESS_DENIED.
CreateHardlink:: directive failed to complete successfully.
Finish time: 2024-08-25 22:11:17.078
Script hash: 2s9ze33nUEwJkfwk2yWeYW0JEMZL+jIYVlGLBjv0wvU=
After rebooting I just noticed that something has changed. The good news is that the dlls are not missing anymore, somehow they seem to have been copied despite the reported failure. The bad news is that ForgeUI still can't start because of missing dependencies for c10_cuda.dll. These are not missing files though, I am not sure but I think it's about bad versions of these files resulting in missing functions it can't import from these.
Perform the scan below.
  3. Press the Fix button.
Great. Despite the error the "api-ms-win-downlevel" links are created successful.
FRST Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Windows Features dialog.
  6. Copy and paste SearchAll:c10.dll;c10_cuda.dll into the Search box and click the Search Files button.
  7. When the scan is complete, a message will display that 'Search.txt' is saved in the same folder FRST was started from. Notepad will open this file also. Close Notepad and attach the file 'Search.txt' to your next reply.
What does the hourglass icon mean at the 3 files in the red frame above ?
Install Update with DISM
  1. Download the update MSU here: https://catalog.s.download.windowsu..._8c89a0b8b74adf3630301e9ff4c071ff56644014.msu
    cd C:\temp
    expand windows6.1-kb4493472-x64_8c89a0b8b74adf3630301e9ff4c071ff56644014.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4493472-x64.cab
Ok.
  1. Download the update MSU here: https://catalog.s.download.windowsu..._84e26e414da5d56991c15de19a93824d23b82e89.msu
    cd C:\temp
    expand windows6.1-kb4512506-x64_84e26e414da5d56991c15de19a93824d23b82e89.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4512506-x64.cab
Same, it installed successfully and restarted, but it did not change anything to the missing dependencies.
Ok.
  1. Download the update MSU here: https://catalog.s.download.windowsu..._4dc78a6eeb14e2eac1ede7381f4a93658c8e2cdc.msu
    cd C:\temp
    expand windows6.1-kb4534310-x64_4dc78a6eeb14e2eac1ede7381f4a93658c8e2cdc.msu -f:* C:\temp
    DISM.exe /Online /Add-Package /PackagePath:C:\temp\windows6.1-kb4534310-x64.cab
Like the others, it installed successfully but did not solve the problem.
I'm losing hope.
According to Dependency Walker the function missing from kernel32.dll is "ResolveDelayLoadedAPI" and according to what I read it may only be available on Windows 8 and above.
According to the devs of pytorch the only thing they changed is they started using Visual Studio 2019 instead of 2017, which should not break the compatibility with Windows 7, yet it did.
So I tried "updating" the kernel with VxKex and nt61 but it did not change anything.
Ask them for an older version, build with VS2017 so you can test that.
Fixed at last. It was indeed an incompatibility with Windows 7 and new pytorch. I fixed it adding python.exe to VxKex.
Thank you again for your help. (y)
Great. Thank you for the feedback.
Follow the instructions below to cleanup the tools and logfiles used in this thread.
Rename the file FRST64.exe to uninstall.exe and run it. This will remove all files and folders created by FRST and the tool itself.
Reboot the machine to complete.
You may remove all other tools and log files.
Thread marked as solved.
Take care.
