[SOLVED] SFC and DISM errors
2016-06-07 17:33:09, Error                 CSI    00002ffe@2016/6/7:21:33:09.837 (F) base\wcp\componentstore\deltastore.cpp(2472): Error STATUS_INVALID_PARAMETER originated in function ComponentStore::CRawStoreLayout::DecompressFile expression: false
[gle=0x80004005]
DISM /RestoreHealth Scan
  1. Right-click on the Start
Step#1 - SFCFix Script
Step#2 - DISM /RestoreHealth Scan
Items for your next post
1. SFCFix.txt
2. CBS.txt
Thanks. Here's the next set of fixes.
1. SFCFix.txt
2. CBS.txt
Good. Making progress. Here's the next set.
1. SFCFix.txt
2. CBS.txt
Last one hopefully.
1. SFCFix.txt
2. CBS.txt
The following error remains.
2016-06-08 09:49:02, Error                 CSI    00003011@2016/6/8:13:49:02.558 (F) base\wcp\componentstore\deltastore.cpp(2472): Error STATUS_INVALID_PARAMETER originated in function ComponentStore::CRawStoreLayout::DecompressFile expression: false
[gle=0x80004005]
To troubleshoot, I need you to do the following.
2. Open an elevated Command Prompt and run sfc /scannow just like you have in the past.
3. Stop Process Monitor as soon as SFC fails. You can simply do this by clicking the magnifying glass on the toolbar as shown below.
Thank you. Yes, it's large and that's expected. That helped me identify the issue. Please start with the following.
FRST Fix
Go ahead and do sfc /scannow again. I expect an error but hope it will be different. Attach the CBS.log when done.
Thanks.
Hi BrianDrab,
You are correct. Stopped at 57% with this error.
Verification 57% complete.
Dropbox - cbsv1.zip
thanks,
mrdimi
