[SOLVED] SFC and DISM errors
crazy question, i'm seeing access denied in the event viewer for CLSID {69486DD6-C19F-42E8-B508-A53F9F8E67B8} (Offline Files Service Control) and APPID {52551A19-B337-498D-AE75-2283E29902DE} (CscService), found them both in regedit. I wonder if it's related.
No it is not related.
Thanks for the info. Please do the following.
Step#1 - SFCFix Script
Step#2 - SFC Scan
1. Right-click on the Start
Items for your next post
1. SFCFix.txt
2. CBS.txt
I need to gather some more info. Please do the following.
That's odd. Can you browse to the following location and let me know if you see any files in it?
C:\SFCFix\Backups\Registry\HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_10.0.10586.0_none_846e459938ebfdb6
That folder doesn't exist. Here's what is at the path
C:\SFCFix\Backups\C\WINDOWS\
and under there this
C:\SFCFix\Backups\C\WINDOWS\Servicing
C:\SFCFix\Backups\C\WINDOWS\Winsxs
OK, please do the following.
Done, here you go.
SFCFix version 3.0.0.0 by niemiro.Start time: 2016-06-08 15:06:41.150
Microsoft Windows 10 Build 10586 - amd64
Using .txt script file at H:\Users\Dimitris\Desktop\SFCScript.txt [0]
RegistryExport::
Successfully exported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_10.0.10586.0_none_846e459938ebfdb6.
Datablocks:
RegistryExport:: directive completed successfully.
Currently storing 134 datablocks.
Finish time: 2016-06-08 15:06:41.150
Script hash: QN6T3nKX5jRxH2vhF9uzL3t7IJa+MgOjwiDUXMZpoEk=
Hmm, sorry about that, here are the results.
SFCFix version 3.0.0.0 by niemiro.Start time: 2016-06-08 20:31:07.017
Using .txt script file at H:\Users\Dimitris\Desktop\SFCScript.txt [1]
RegistryScript::
Successfully took ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_10.0.10586.0_none_846e459938ebfdb6.
Successfully imported registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_10.0.10586.0_none_846e459938ebfdb6.
Successfully restored ownership and permissions for registry key HKEY_LOCAL_MACHINE\COMPONENTS\DerivedData\Components\amd64_netfx-aspnet_installpersistsql_b03f5f7f11d50a3a_10.0.10586.0_none_846e459938ebfdb6.
Currently storing 135 datablocks.
Finish time: 2016-06-08 20:31:07.080
Script hash: nb3K9AuZS0Fkz1iuDOdzsR14SrXQSOUbaPLH+ndbVsw=
Thanks. Do the following again please.
SFC Scan
Thanks. I need to see your hives.
Retrieve Components/Software Hives
Note: The Software have has confidential and sensitive information in it so please send me a PM with a link to that particular hive so it's not in the public form.
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, two of which are named COMPONENTS and SOFTWARE.
  • Copy these two files to your Desktop. If the COMPONENTS file does not exist, please fetch it instead from C:\Windows\System32\config\COMPONENTS.
  • Now right click on these files on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file(s) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are Dropbox or One Drive or SendSpace and then just provide the link in your reply.
Hi BrianDrab,
It's been sent in a PM. Let me know when you have it so I can delete the zip from dropbox.
thanks,
mrdimi
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Progress!! OK, let's do the following.
Step#2 - SFC Scan
1. SFCFix.txt
2. CBS.txt
Well, got to 100% but also got this error:
Here are the logs
Dropbox - SFCFix:cool:9v2.zip
thanks
mrdimi
