[SOLVED] SFCFIX unable to find problems
FRST Registry Search
  3. Select the Programs group.
  4. Click the Turn Windows features on or off link. This will bring up the Server Manager or Windows Features dialog.
  5. Right-click on the file FRST.exe and choose Run as administrator.
  6. Copy and paste KB3075220 into the Search box and click the Search Registry button.
Click the Start-button and in the search box, type regedit.
When you see regedit on the list, right-click on it and select Run as administrator.
In the left hand panel of regedit, you will see a list of registry keys. Navigate to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Component Based Servicing\Packages\Package_36_for_KB3075220~31bf3856ad364e35~x86~~6.1.1.0
Right-click on it and select Permissions...
Click Add.
Type Everyone in the text box.
Click OK.
Single click on Everyone and then tick the "Full Control" box under Allow.
Click OK twice.
Let me know if you were successfully able to do this.
  3. Press the Fix button.
Follow the instructions below. If anything is unclear, just ask first.
Click Start typ regedit in the searchbox and press enter.
Allow the program to run.
"Registry-editor" will open. On the leftside browse to the key
Rightclick on it and select Permissions.
A new window opens, click the button Advanced.
A new window opens, select tab Owner.
Put a checkmark at Replace owner on subcontainers and objects
Select Administrators (...) then click Apply and OK.
In the list "Group or user names" select Administrators (...).
Next, put a checkmark to allow "Full Control" and click OK.
Rightclick the registry-key again and click Delete.
Are you able to delete the key ?
Download the attachment and extract it.
Open the extracted folder, double-click the file regfix.reg.
When prompted allow to change the registry settings.
Report the result.
provide the Software Hive
1. Navigate to C:\Windows\System32\Config and locate the SOFTWARE file.
Note: If you receive an error that this file is in-use, try Option#2 below.
3. Right-click on this file on your desktop and select Send To...Compressed (zipped) folder. This will create a file named SOFTWARE.ZIP on your desktop.
4. Upload the zip file (SOFTWARE.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are FileDropper or One Drive or WeTransfer.
5. Note: Send the downloadlink in a private message as the SOFTWARE hive contains sensitive information!
  • This will bring you into the folder where the backup was made. You should see a Users folder and a Windows folder along with a couple other files. Double-click on the Windows folder to open it. Then open the System32 folder and then config folder. You should see around 6 files in here, one of which is named SOFTWARE.
  • Copy the SOFTWARE file to your Desktop. If the SOFTWARE file does not exist, please fetch it instead from C:\Windows\System32\config\SOFTWARE.
  • Now right-click on the SOFTWARE file that is on your desktop and select Send to > Compressed (zipped) folder.
  • Then please upload the zip file (SOFTWARE.zip) to your favourite file sharing website (it will be too big to upload here). Examples of services to upload to are FileDropper or One Drive or WeTransfer.
  • Note: Send the downloadlink in a private message as the SOFTWARE hive contains sensitive information!
Uninstall Advanced SystemCare
Restart the machine.
Step 3:
SFC Scan
  1. Click the Start button and in the search box, type Command Prompt
  3. When command prompt opens, copy and paste the following commands into it, press enter after each.
    Take a screenshot of the commandprompt window and paste it into your next reply.
Perform a new scan with FRST.
FRST Scan:
  1. Right-click to run the tool as administrator.
  2. Note: Ensure that the Addition.txt check box is checked at the bottom of the form within the Optional Scan area.
  3. Press the Scan button.
  4. Please wait for the tool to finish. It will produce two logfiles called FRST.txt and Addition.txt in the same directory the tool is run from (which should be the desktop)
  5. Post the logfiles FRST.txt and Addition.txt as attachment in your next reply.
By the way,this pop up immediately after FRST said that it done scanning.What's happening?The "suspicious behaviour" is FRST LOL
*Don't worry I know you aren't telling me to download virus as FRST isn't a virus.
